Hi guys i have been working a bit for this to work on a friends car
Seat Leon ST 5F with halogen headlights (non LED)
(The coding works for me and my car Seat Leon ST FR 5F with LEDlights with som e more lines.)
This code works, kind of, but (USlight=turnsignal=always on, minus when blinking right or left):
Is there anyone whoo can figure this out or even better a coding that actually work on a nos LED car
US-Fahrlicht
(org=xxx) = my information about the default settings before coding.
[ xxx ] = My information about another possible settings.
STG 09, 31347, Adaption,
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0, Abblenlicht links (org=Blinken links Hellphase ) [permanent on=Abblenlicht links or when SPORT mode/Red door light=Ambientelicht 4]
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,Blinken links Hellphase (org=not active)
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 (org=100)
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase (org=Blinken links Dunkelphase)
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize (org=maximize)
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1, Abblenlicht rechts (org=Blinken rechts Hellphase )
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1,Blinken rechts Hellphase (org=not active)
(6)-Leuchte1BLK VRB20-Dimmwert AB 1,100 (org=100)
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts Dunkelphase (org=Blinken rechts Dunkelphase)
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1,minimize (org=maximize)
- Not in DRL mode (Auto/daylight)
- When blinking left it turns off the USlight on the right side, but when blinking right the left USlight stays on as it should.
If i delete the coding for the left side (Leuchte 0 BLK VL B36 xxx) then then it works, (Right turnsignal stays on when blinking left.)
US-Fahrlicht
