Audi a6 avant 2.0 tdi -11 left rear light wont turn off
gnuttisch
Sweden
C?ID=240388
Hi
I have an audi a6 avant 2.0 tdi -11 that the rear light sometimes flashes or stays steady on when the car is turned off. Then it can suddenly disappear after some time without and fault codes and then come back again.
I read that some cars have an faulty brake light switch but I hooked up my VCDS to the car and checked it whit out any errors.
attachment.php
Does someone have any ides?
Regards
Did you try unplugging the BL switch when it happens?
Look for corrosion at light for back feed from water ingress.
Post an auto-scan in code tags please.........
ivagp
C?ID=95551
Did you try replacing the bulb. Swap it
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Both, or just on one side? Sounds like just one side.
If it's just one, that sounds more like the European "parking lights" feature, wherein the light on one side stays on indefinitely if you leave the turn signal stalk set to one side or the other after shutdown. I can't account for it flashing, but you could at least try setting the parking lights on to see if it's enabled on your car and simulates part of what you're seeing.
Jason
gnuttisch
Sweden
C?ID=240388
Thanks for your all replies.
Its is only the left rear light, the one that is mounted to the hatch.
I removed the entire lamp but I couldn't see any signes of corrosion or water.
And It doesnt mather how I have the turn switch when I turn of the car.
Its only the leds on the lamp that are turned on at full power, just like when you where braking.
And the lights are led from the factory and nothing that I have retrofitted. I checked the coding as well, and highlights should be coded.
Wednesday,16,November,2016,21:50:01:41258
VCDS Version: 16.8.3.1 (x64)
VIN: WAUZZZ4F0BN063960   License Plate: JSE379
Mileage: 148980km-92571mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 08 09 15 16 17 18 19 42 46 4F 52 53 55 56 5F 62 69
          6D 72 76
VIN: WAUZZZ4F0BN063960   Mileage: 148980km-92571miles
Address 01: Engine (J623-CAHA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 FG    HW: 03L 906 022 FG
   Component: R4 2,0L EDC   H14 6420
   Revision: 11H14---    Serial number:
   Coding: 010D002C18172918
   Shop #: WSC 02325 785 00200
   ASAM Dataset: EV_ECM20TDI03L906022FG A01007
   ROD: EV_ECM20TDI03L906019L.rod
   VCID: 6FD59106B63C263A55-803A
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 BF
   Component: ESP8 front      H03 0060
   Coding: 0004475
   VCID: 6DE98B0E7430D42A67-8038
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401775033
   Coding: 0000129
   Shop #: WSC 02323 785 00200
   VCID: 2579B32EEC402C6AEF-8070
   Subsystem 1 - Part No: 4F0 910 132 D
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4F0 910 043     HW: 4F1 820 043 AA
   Component: KLIMABETAETIGUNGH20 0170
   Revision: 00000035    Serial number: 00000030610741
   Coding: 0002324
   VCID: 5B8DD5D69A84AA9A89-800E
   Part No SW: 4F0 910 279 AF    HW: 4F0 907 279
   Component: ILM Fahrer      H30 0390
   Coding: 0003122
   Shop #: WSC 02335 785 00200
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H11 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003F9004NSGC
   Coding: 30314236303630303031554A304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3559636E94E05CEA5F-8060
   Serial number: 3574SRB40000D48CF8AU
   Serial number: 3584SRB40000D41CB8FP
   Serial number: 3516HRB40302IFG0VRM-
   Serial number: 3526HRB402O2IFG1141U
   Serial number: 3554NRB40000602F405S
   Serial number: 3564NRB40000602E075V
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026110300350
   Coding: 0002042
   VCID: 2765B926964C3E7ADD-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 901 N    HW: 4F0 920 901 N
   Component: KOMBIINSTR.   H08 0211
   Revision: 00000000    Serial number: FJL40902C
   Coding: 0F7D110502000008010100
   Shop #: WSC 02391 823 56573
   VCID: 2D694B0E74B0142A27-8078
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 AA
   Component: Heizgeraet      H08 0100
   Revision:        B    Serial number: 09018641
   Coding: 0000011
   Shop #: WSC 02145 785 00200
   VCID: 1B0D95D6DA04EA9A49-804E
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L111238290
   Coding: 000B03
   VCID: 39416F5EB0F8B88ABB-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790387721
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0004000210067
   Coding: 011C06204040410001
   VCID: 48A71A9AFB12D10234-801C
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H26 0210
   Revision: 02100026    Serial number: 01073407680000
   Coding: 3345009
   VCID: 32535872AD8E4BD27A-8066
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000767875
   Coding: 0001104
   VCID: 5E8BDCC28996BFB2EE-800A
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0004000215262
   VCID: 47A519A6F60CDE7A3D-8012
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000111
   VCID: 2171A73EF868C04A93-8074
   Part No: 8P0 907 357 M
   Coding: 0000003
   VCID: 44BF0EAA073AF562D8-8010
   Part No SW: 4G0 035 056     HW: 4G0 035 056
   Component: Radio U STD   H52 0051
   Revision: AB001007    Serial number: 469B40B7668445
   Coding: 010003020100000000
   VCID: 5E8BDCC24996BFB2EE-800A
   Part No SW: 4E0 035 646 D    HW: 4E0 035 646
   Component: B-B-ER        H60 0140
   Revision: --------    Serial number: 348B00B7561885
   Coding: 01000001010283ED03000F0DEF6300000200
   VCID: 2579B32E2C402C6AEF-8070
   Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
   Component: DU6 Basic  H42 0084
   Serial number: 9465AP0B0265046
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 M
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001783618
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0004000209317
   Coding: 010804204040220001
   VCID: 46BB14A2F106C772C6-8012
Address 69: Trailer (J345)       Labels: 4F0-907-383.clb
   Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Component: Anhaenger     H08 0080
   Revision: 2B002002    Serial number: 00000123450992
   Coding: 0103030000000000
   VCID: 2C6F460A4FAA1D2230-8078
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 F
   Component: ValeoHeckdeckel H24 0290
   Revision: --H24001    Serial number: E5030000B
   Shop #: WSC 00066 123 73555
   VCID: 6CEF860A4F2ADD2270-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD07.09.07--H24001000A0149ÿ
   Subsystem 4 - Serial number: 0A0149ÿ
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0004000209320
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H03 0500
   Revision: 00H03000    Serial number: 37231103106109
   Coding: 0210016
   VCID: 2961BF1E8058080ACB-807C
End-------------------------(Elapsed Time: 02:27)--------------------------
gnuttisch
Sweden
C?ID=240388
okj so here is some additional information.
I measured at the contact to the light and found that it was steady 12v on pin 1 when the car was off. So i dismounted that pin and hooked it into the light again and now I dont have steady light when the car is off. And when I turn on the car, It will warn me for broken left brake lights.
So then we can exclude the light it self from the problem and look towards to my comfort module. could it be broken? Why does it feed my left brake light with 12v all the time?
Regards
Very good....... I like that you are isolating......now lets trace that hot wire back to where it is picking up that 12 volts or isolate further using WD at module.
A tone generator comes in very handy here...........
Before condemning the module inspect it!
gnuttisch
Sweden
C?ID=240388
I have now checked the wiring schema for my car and the hot wire goes directly to my comfort module, only passing connection T10ab. So it has to be my comfort module that have braked down and cant switch of the brake light voltage.
Now I will open my comfort module to see if their is any chipset that doesnt work as they should.
And it is nice and dry their as well.
iichel
Netherlands, eastern part
C?ID=284912
is there a permament plus somewhere running to the hatch? wires in the rubber grommets could have maybe worn, and lost their insulation. then a permanent plus is rubbing against your wire to the brake wire bulb.
what happens if you connect the plug T10ab completely from the convenience module. does the light go off then? if it stays on, you can have a look at your wiring loom.
gnuttisch
Sweden
C?ID=240388
I will check that when I get home, but I think that it is unlikly cause all wire looms are xtra isolated with isolation tape so that it will reduce noises.
gnuttisch
Sweden
C?ID=240388
Okey,
So I will post an follow up so that it might help others.
At the last time I disconnected the wire at the brake light because I didnt have the time to fix the issue at the moment, result was warning in FIS for broken brake lamp and 4/5 brake lamp where working. But I didnt have one of them turned on 24/7.
But today I had some time over and disconnected the comfort module and put it apart so I could check the board for faults. And I found that the chip who where controlling the lamp was faulty, at the first I where going to replace the chip but as I start soldering I discovered that their where some old solder connecting two pins. Leading to enable the 12v output all the time. So I resolderd the chip and now I have an fully working brake light again.
regards
FOD........Did you take pictures?
If so please post.........:thumbs:
gnuttisch
Sweden
C?ID=240388
Ok, so I have attached an picture of my comfort module and where I found the fault. Its down to the left.
And here you can find the datasheet for the ST chip VND830E http://www.alldatasheet.com/view.jsp?Searchword=VND830E
I also compared my two comfort modules, I got a new one to support electric hatch and the only different I could see was the relay at the top left corner.
It would be interesting to but an relay an attache it and see if my original comfort module would work with electric hatch.
