Results 1 to 8 of 8
Thread: Looking to change workshop code for module
    Feb 2016
    Jamaica
    Greetings,
    I have a 2008 MK5 Golf that I need to change the workshop code for as it is currently filled with "zeroes" I have the WSC configured in the VCDS application itself, but I don't have the option to do any coding in the power steering module itself (so that I can overwrite the WSC). I want to get the steering correctly coded, so that I can in-turn code the brakes as well.
    Friday,18,November,2016,07:26:59:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 16.8.3.1 (x64)
    Dealer/Shop Name: Matthew Taylor
    VIN: WVWZZZ1KZ8W111078   License Plate:
    Mileage: 155270km-96480mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
    VIN: WVWZZZ1KZ8W111078   Mileage: 155270km-96480miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070060
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5EEA5F-8060
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage
                        Mileage: 155258 km
                        Time: 13:37:04
                        Temperature: 40.0∞C
                        Temperature: 40.0∞C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.319 V
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 155259 km
                        Time: 17:15:30
                        RPM: 803 /min
                        Load: 21.2 %
                        Speed: 10.0 km/h
                        Temperature: 71.0∞C
                        Temperature: 31.0∞C
                        Voltage: 13.843 V
    Readiness: 0110 0101
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 04808020    Serial number: 00000907050136
       Shop #: WSC 09537 809 89632
       VCID: 1C192DFCDF37EFA240-8048
       Revision: 00H11001
       Coding: 0004744
       VCID: 73CB2640122900DAB1-8026
                003 - Mechanical Failure
                013 - Check DTC Memory
       Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
       Component: ClimatronicPQ35 120 1111
       Revision: 00120021    Serial number: 00000000000000
       VCID: 79D7146830457A8AFB-802C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 01000007456322
       Coding: E70E8B2F000415004F14000414000000000900005C100100000000000000
       VCID: 71C72C48683532CA43-8024
       Component: Wischer 300807 021  0501
       Coding: 00038805
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 12345
    02499 - Right Low Beam Reflector Motor (V295)
                        Fault Status: 01111100
                        Reset counter: 69
                        Mileage: 155266 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.25 V
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 69
                        Mileage: 155258 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 11.95 V
                010 - Open or Short to Plus
                        Fault Status: 01111010
                        Reset counter: 69
                        Mileage: 155258 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.70 V
                        Reset counter: 69
                        Mileage: 155258 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.75 V
                        Reset counter: 69
                        Mileage: 155258 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.75 V
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86AA97-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    7 Faults Found:
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                007 - Short to Ground - Intermittent - MIL ON
    00589 - Airbag Igniter 1; Passenger Side (N131)
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           036 0070
       Coding: 0012102
       VCID: 01277C885895224AB3-8054
       Part No SW: 1K6 920 974     HW: 1K6 920 974
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G83NA8OV
       Coding: 0004103
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 040907F1000254
       Coding: ED811F060002020001
       VCID: 3041E94CA3BF7BC20C-8064
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 120B
       Coding: 0000564
       Shop #: WSC 00000 785 00200
       VCID: 3851D16C4BCFA38244-806C
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H15000
       VCID: 2F43EA30BE81643A15-807A
    01312 - Powertrain Data Bus
                        Fault Status: 00101110
                        Fault Frequency: 110
                        Reset counter: 107
                        Mileage: 155258 km
                        Time: 07:37:07
                        Voltage: 13.88 V
                            DU
                        Temperature: 42.0∞C
                        RPM: 1498 /min
                        Count: 3
                        Fault Status: 11101000
                        Reset counter: 67
                        Mileage: 155258 km
                        Time: 13:37:09
                        Battery Volts: 12.4 V
                            DD
                        Temperature: 38.0∞C
                        Count: 5
                        Steering Angle: -8.71∞
                            SteerAng Init
       Coding: 9890020851030C7F42CC8F0F70085A2690BC00
       VCID: 032B76804289305AA1-8056
    01134 - Alarm Horn (H12)
                        Reset counter: 67
                        Mileage: 155258 km
                        Time: 13:37:09
       Coding: 0000564
       VCID: 3957D46870C5BA8ABB-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74C9255C172707E2A8-8020
    01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
    01533 - Terminal 56 (High Beams)
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio PM6       018 0035
       Revision: 00018000    Serial number: VWZ5Z7G2174742
       Coding: 0040400
       VCID: 2A75FB2485630112C2-807E
    End-------------------------(Elapsed Time: 01:08)--------------------------
    Control Module Part Number: 1K0 959 701 M    HW: 1K0 959 701 M
      Component and/or Version: Tuer-SG         006 120B
               Software Coding: 0000564
                Work Shop Code: WSC 00000 785 00200
    Address 44,1K0 909 144 H,channel 3,adapted from,1,to,0,
    Address 46,1K0 959 433 BT,recoded (Long Coding),from,9890020851030C7F42CC8F0F70085A2690BC00,to,9890020851030C3F42CC0F0FF0085A26D09C40,(12345/123/12345),
    Control Module Part Number: 1K0 909 144 H
      Component and/or Version: EPS_ZFLS Kl. 69     2901
               Software Coding:
    Advanced Identification
         Identification: ZF0-103
         Revision: 00H15000
         Date: 29.05.09
         Test stand number: 4080
         Manufacturer number: 0070
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 00000 000 00000
    Software
         Z0000
    Misc.
    Car Info
         Chassis Number: WVWZZZ1KZ8W111078
         Engine code: ABE
    VCDS Info:
    Try changing one of the documented Adaptation channels.
    Feb 2016
    Jamaica
    I tried. It accepted the adaptation, but the workshop value was still the same. Is there a way for me to do some SVM to get the values to change?
    Login the module in security access.
    Try typing 83q...
    Why do you need to do this?
  5. Likes NitrousOxide liked this post
    Feb 2016
    Jamaica
    M
    My car has had ABS and power steering error messages from day1 when I got the VCDS cable and started messing around without first SAVING the initial autoscan.
    I was under the impression that modules no longer accept coding / adaptations once the WSC is "00000". I was just trying to eliminate my errors one by one.
    Quote Originally Posted by NitrousOxide View Post
    SOME module will not accept coding changes unless the WSC (and potentially the Importer and Equipment number) are changed from their factory defaults, which are often (but not always) zeros. But this behavior is by no means universal. It sounds to me like this particular module simply does not care.
  8. Likes NitrousOxide liked this post
    Feb 2016
    Jamaica
    Speaking about factory defaults, is there anywhere online that has default or suggested coding for modules in a particular chassis?
    I'm sure that I've coded the ABS module in accordance with the tips provided in the popup balloon, but I'm still getting these errors even among related modules
  10. #8
    Search similar auto-scan's online ..........that's why we request people post them.............
