Results 1 to 5 of 5
Thread: audi a6 tdi -11 cant reset service reminder
    Mar 2015
    Sweden
    Hi
    Using VCDS and following this guide, http://www.ross-tech.com/vcds/tour/sri-reset.php I cant manage to reset the service reminder. VCDS resets all data and according to VCDS their should not be any service reminder active. It is set to 0 insted of 1.
    And in the car the mmi shows that I have 1500/365 days to the next service.
    But also that Service due is 2 days ago, also in the headup display, when I start or shut down the car, it says Service Due.
    How do I get rid of it?
    Im running the latest build of VCDS from your webpage.
    Regards
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    You can post here complete Auto Scan along with Control Module Map, address 17, so that we can see what happens there.
    Mar 2015
    Sweden
    Like this?
    Regards
    Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
       Part No SW: 4F0 920 901 N    HW: 4F0 920 901 N
       Component: KOMBIINSTR.   H08 0211
       Revision: 00000000    Serial number: FJL40902C
       Coding: 0F7D110502000008010100
       Shop #: WSC 02391 823 56573
       VCID: 2D694B0E74B0142A27-8078
    ;SW:4F0-920-901-N   HW:4F0-920-901-N ---  Instruments
    ;Component:KOMBIINSTR.   H08 0211, Coding:0F7D110502000008010100
    ;Thursday,17,November,2016,13:36:40:41258
    ;VCDS Version: Release 16.8.3 (x64)  Data version: 20161010 DS267.0
    ;VCID: 2D694B0E74B0142A27-8078
    1,0,,
    1,1,,,
    ;0.0 km/h,,
    1,2,,,
    ;0 /min,,
    1,3,,,
    ;Oil Pr. 2 <min,,
    1,4,,,
    ;13:38,,
    2,0,,
    2,1,,,
    ;149030 km,,
    2,2,,,
    ;30.1 l,,
    2,3,,,
    ;12.22 V,,
    2,4,,,
    ;2016:10:17,,
    3,0,,
    3,1,,,
    ;42.0C,,
    3,2,,,
    ;00:00,,
    3,3,,,
    3,4,,,
    4,0,,
    4,1,,,
    ;7.5C,,
    4,2,,,
    ;4.5C,,
    4,3,,,
    4,4,,,
    5,0,,
    5,1,,,
    ;0.0,,
    5,2,,,
    ;0.0,,
    5,3,,,
    ;150,,
    5,4,,,
    ;365,,
    6,0,,
    6,1,,,
    ;1915 ml,,
    6,2,,,
    ;-1905 ml,,
    6,3,,,
    ;16 ml,,
    6,4,,,
    ;Closed,,
    7,0,,
    7,1,,,
    ;408,,
    7,2,,,
    7,3,,,
    7,4,,,
    8,0,,
    8,1,,,
    ;33.0,,
    8,2,,,
    ;408,,
    8,3,,,
    8,4,,,
    27,0,,
    27,1,,,
    ;  000000,,
    27,2,,,
    ;0,,
    27,3,,,
    27,4,,,
    28,0,,
    28,1,,,
    ;16,,
    28,2,,,
    ;0,,
    28,3,,,
    ;    0000,,
    28,4,,,
    ;00000000 00000000,,
    29,0,,
    29,1,,,
    ;0,,
    29,2,,,
    ;06:45,,
    29,3,,,
    ;2016:11:17,,
    29,4,,,
    ;30,,
    90,0,,
    90,1,,,
    ;32,,
    90,2,,,
    ;6.0 %,,
    90,3,,,
    ;46.0 %,,
    90,4,,,
    ;9.0 %,,
    91,0,,
    91,1,,,
    ;9.0 %,,
    91,2,,,
    ;10.0 %,,
    91,3,,,
    ;9.0 %,,
    91,4,,,
    ;8.0 %,,
    92,0,,
    92,1,,,
    ;19.0 %,,
    92,2,,,
    ;0.0 %,,
    92,3,,,
    ;0.0 %,,
    92,4,,,
    ;69.0 %,,
    93,0,,
    93,1,,,
    ;24.0 %,,
    93,2,,,
    ;89.0 %,,
    93,3,,,
    ;17.0 %,,
    93,4,,,
    ;0.0 %,,
    100,0,,
    100,1,,,
    ;330,,
    100,2,,,
    ;0,,
    100,3,,,
    ;330,,
    100,4,,,
    ;399,,
    101,0,,
    101,1,,,
    ;312,,
    101,2,,,
    ;9,,
    101,3,,,
    ;0,,
    101,4,,,
    ;0,,
    102,0,,
    102,1,,,
    ;00000000,,
    102,2,,,
    102,3,,,
    ;6,,
    102,4,,,
    ;16,,
    120,0,,
    120,1,,,
    ;BrkFl.levl 0,,
    120,2,,,
    ;WashFluid 1,,
    120,3,,,
    ;Cool.level 0,,
    120,4,,,
    ;Oil Level 1,,
    121,0,,
    121,1,,,
    ;BrakePad 1,,
    121,2,,,
    121,3,,,
    121,4,,,
    122,0,,
    122,1,,,
    ;00000000,,
    122,2,,,
    ;00000000,,
    122,3,,,
    122,4,,,
    124,0,,
    124,1,,,
    124,2,,,
    124,3,,,
    124,4,,,
    125,0,,
    125,1,,,
    ;Engine 1,,
    125,2,,,
    ;Transm. 1,,
    125,3,,,
    ;ABS 1,,
    125,4,,,
    ;Airbag 1,,
    202,0,,
    202,1,,,
    ;2013,,
    202,2,,,
    ;2065,,
    202,3,,,
    202,4,,,
    203,0,,
    203,1,,,
    ;46,,
    203,2,,,
    ;56,,
    203,3,,,
    ;55,,
    203,4,,,
    ;490,,
    220,0,,
    220,1,,,
    ;2293,,
    220,2,,,
    ;6146,,
    220,3,,,
    220,4,,,
    221,0,,
    221,1,,,
    221,2,,,
    221,3,,,
    ;0 ml,,
    221,4,,,
    ;8,,
    222,0,,
    222,1,,,
    ;15,,
    222,2,,,
    ;30,,
    222,3,,,
    ;24,,
    222,4,,,
    ;24,,
    223,0,,
    223,1,,,
    ;41,,
    223,2,,,
    ;100,,
    223,3,,,
    ;6155,,
    223,4,,,
    ;7500,,
    224,0,,
    224,1,,,
    224,2,,,
    ;0,,
    224,3,,,
    224,4,,,
    241,0,,
    241,1,,,
    ;255,,
    241,2,,,
    ;255,,
    241,3,,,
    ;255,,
    241,4,,,
    ;255,,
    242,0,,
    242,1,,,
    ;88,,
    242,2,,,
    ;106,,
    242,3,,,
    ;700,,
    242,4,,,
    ;700,,
    243,0,,
    243,1,,,
    ;651,,
    243,2,,,
    ;604,,
    243,3,,,
    ;613,,
    243,4,,,
    ;613,,
    244,0,,
    244,1,,,
    ;655,,
    244,2,,,
    ;655,,
    244,3,,,
    ;677,,
    244,4,,,
    ;700,,
    245,0,,
    245,1,,,
    ;68,,
    245,2,,,
    ;78,,
    245,3,,,
    ;700,,
    245,4,,,
    ;700,,
    246,0,,
    246,1,,,
    ;408,,
    246,2,,,
    ;0,,
    246,3,,,
    ;0,,
    246,4,,,
    ;0,,
    247,0,,
    247,1,,,
    ;408,,
    247,2,,,
    ;0,,
    247,3,,,
    ;0,,
    247,4,,,
    ;0,,
    248,0,,
    248,1,,,
    ;306,,
    248,2,,,
    ;885,,
    248,3,,,
    ;0,,
    248,4,,,
    ;0,,
    249,0,,
    249,1,,,
    ;306,,
    249,2,,,
    ;0,,
    249,3,,,
    ;0,,
    249,4,,,
    ;0,,
    250,0,,
    250,1,,,
    250,2,,,
    ;00000000 00000100,,
    250,3,,,
    250,4,,,
    252,0,,
    252,1,,,
    ;1632,,
    252,2,,,
    252,3,,,
    252,4,,,
    253,0,,
    253,1,,,
    253,2,,,
    ;00011100 00000100,,
    253,3,,,
    253,4,,,
    ;00000000 00101000,,
    Aug 2014
    Now permanent in Maryland, USA.
    There is a function on VCDS called SRI..click on that and life will be easy..very simple way of doing the reset.Did you try that?
    Mar 2015
    Sweden
    Okej,
    So I have found what I where doing wrong.
    I had to set "Fixed oil service reset (rest of the world)" and "Time based service reset (rest of the world / great britain)"
    Then All warnings gone away.
    Thanks anyway!!
  6. Likes Boki Ar, Uwe, RyMar liked this post
