Audi A7 2016 66 Reg Hidden Menu
   #21
satpat2
C?ID=255340
Any progress Dana ?, have I given you the info ?
   #22
andyhud
C?ID=32695
Green Menu on MIB2 is activated by enabled Developing Mode in Adaption Channel in 5F then holding the Engineering mode Keys down for at least 20 seconds. I think its NAV up and MEDIA down. hold them simultaneously for 20 seconds.
However, Green Menu doesnt offer much like the old green menu now in MIB2. Activating new options in the MIB2 is driven primarily from coding and adaption channel changes now.
HTH
Andy
   #23
rlarsen
Copenhagen, Denmark
C?ID=78998
HTH
Andy
Hidden menu (Green menu) is NAV/MAP (or CAR) + RADIO
Engineering Menu is NAV/Map (or CAR) + MEDIA
http://forums.ross-tech.com/showthr...7-Developer-Mode&p=91232&viewfull=1#post91232
satpat2
C?ID=255340
Hey Folks
Great work, I can now confirm back and the bottom left of the silver keys gets you into the hidden green menu, it's changed dramatically, so can't see anywhere to do mods but we are progressing, thank you folks
   #25
satpat2
C?ID=255340
Anymore info on the window closure issue ?
   #26
Dana
Western PA, USA
Hey Dana
here is the Measuring Blocks log for 42 and 52, carried out the output test and window going down and up on 42 and 52 as well as folding door mirrors
MVB 002 in the logs are correct
Mileage:    Repair Order: Log 42
                Address 42: Door Elect, Driver  (4G8 959 793 H)
10:13:59 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.00 V  Voltage
10:13:59 Group 002
  Not Oper.
  Not Oper.
  Not Oper.
  Not Oper.
10:13:59 Group 003
  0.0 %  Load
  11.0°C  Temperature
      1101  Bin. Bits
  Still
Mileage:    Repair Order: 52
                Address 52: Door Elect, Pass.  (4G8 959 792 J)
10:23:02 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.16 V  Voltage
10:23:02 Group 002
  Not Oper.
  Not Installed
  Not Installed
  Not Installed
10:23:02 Group 003
  0.0 %  Load
  10.0°C  Temperature
      1101  Bin. Bits
  Still
... but I was looking to see if all of the switch positions (Auto Open/Auto Close/Manual Open/Manual Close/Not Oper.) were shown when the switches are operated. The only switch position that really maters is Auto - but making sure all positions are recognized isn't a bad idea. At this point it does confirm the correct group number based on the Not Oper. data.
Also, did you try with the factory condition 46: Central Conv. coding in post # 16?
satpat2
C?ID=255340
I haven't tried this yet but it has never worked from factory, should I take it back in and get them to have a look as it's still in warranty ?
   #28
andyhud
C?ID=32695
Hey Folks
You'll find to enable "new" menu options in the MIB2, that is driven from enabling adaption channels in 5F along with the correct Terminal (in most cases its Terminal 15)
If you scroll through them to see ones that are enabled from factory you can duplicate for ones that arent.
Cheers
Andy
   #29
satpat2
C?ID=255340
Cheers
Andy
10:13:59 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.00 V  Voltage
10:13:59 Group 002
  Not Oper.
  Not Oper.
  Not Oper.
  Not Oper.
10:13:59 Group 003
  0.0 %  Load
  11.0°C  Temperature
      1101  Bin. Bits
  Still
10:23:02 Group 001
  00000000  Bin. Bits
  00000000  Bin. Bits
      0101  Bin. Bits
  12.16 V  Voltage
10:23:02 Group 002
  Not Oper.
  Not Installed
  Not Installed
  Not Installed
10:23:02 Group 003
  0.0 %  Load
  10.0°C  Temperature
      1101  Bin. Bits
  Still
Tried your recommendations but still not working, I have left window regulator active on, still no change
   #30
satpat2
C?ID=255340
Hey Guys, I have enabled audi smartphone and its brilliant, works great, wondering why this was never enabled ?
   #31
satpat2
C?ID=255340
Hey guys, I have fixed the error in 46 option but i'm stuck on this error, can you please help
Address 5F: Information Electr. Labels: User\4G1-035-021.clb
Control Module Part Number: 4G1 035 021 F HW: 4G1 035 021 D
Component and/or Version: MU-H-LND-EU 052 0670
Software Coding: 017503010000000013111102000A00332F000CE7F1700100DF
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115 (AU57)
VCID: 1D318F3E0CF36CA9E2-8048
7181 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 183
Mileage: 6976 km
Date: 2017.04.01
Time: 07:19:08
Voltage terminal 30: 14.2 V
BAP-BAP_Function_ID: 02
vpanaiotov
Pirate
Walking the Plank
Sofia, Bulgaria
Could you please explain how to activate the Smartphone Interface? I enabled MirrorLink, Apple, Google options and activated the apple_devices and other_devices options. However, I still have no Audi Smartphone Interface in the menu. I assume there are many more steps to be taken, but could we start from there?
