Wednesday,16,November,2016,08:48:25:48394
VCDS Version: 16.8.3.1 HEX-NET CB: 0.4323.4
VIN: WVWUK63B12P302399 License Plate:
Mileage: 194910km-121111mi Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWUK63B12P302399 Mileage: 194910km-121111miles
Address 01: Engine Labels: 07D-906-018-BDP.lbl
Part No: 07D 906 018 E
Component: B5S-4.0L-AG-LEVG 5088
Coding: 00173
Shop #: WSC 02402
VCID: 281C37DDCA4E1102D4-5184
WVWUK63B12P302399 VWZ7Z0A4567095
17700 - Map Controlled Engine Cooling Thermostat (F265)
P1292 - 35-10 - Open Circuit - Intermittent
16839 - EVAP System
P0455 - 35-00 - Large Leak Detected
18613 - Performance Malfunction in Cooling System
P2181 - 35-00 -
16455 - Sensor for Ambient Air Temperature (G17)
P0071 - 35-00 - Implausible Signal
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 T
Component: AG5 01V 4.0lWR8 USA 2222
Coding: 01102
Shop #: WSC 02402
VCID: 373EE4A117F08EFA4D-5184
17125 - Torque Converter Clutch
P0741 - 35-00 - Stuck OFF / No Power being transferred
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AA
Component: ABS/ESP allrad 2329
Coding: 05397
Shop #: WSC 02415
VCID: 608C6FFDE2FEA942DC-5184
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B7 907 044
Component: CLIMATRONIC B5W8 0005
Coding: 27210
Shop #: WSC 00028
VCID: 648463EDF6E6B56238-51A8
6 Faults Found:
00792 - A/C Pressure Switch (F129)
35-00 - -
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-00 - Faulty
01271 - Positioning Motor for Temperature Flap (V68)
37-00 - Faulty
01272 - Positioning Motor for Central Flap (V70)
37-10 - Faulty - Intermittent
37-00 - Faulty
79-00 - Please Check Fault Codes
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 0C AIRBAG VW61 04 0001
Coding: 12355
Shop #: WSC 00402
VCID: 240423EDB666F562F8-5160
00532 - Supply Voltage B+
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0003
Coding: 00118
Shop #: WSC 02402
VCID: 2F2EDCC1EFA0463A15-5216
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B7 920 946 E
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 23236
Shop #: WSC 02667
VCID: 2F2EDCC1EFA0463A15-5160
29-00 - Short to Ground
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00028
VCID: 70AC1FBD321E19C24C-5160
Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl
Part No: 3B1 959 760 E
Component: Sitzverstellung 0301
VCID: 2F2EDCC1BFA0463A15-5160
01008 - Note; Emergency OFF Switch is Active!
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 09 Komfortgerát HLO 0003
Coding: 00258
VCID: 373EE4A117F08EFA4D-4B3C
Subsystem 1 - Part No: 1C0959801
Component: 09 Tõrsteuer.FS KLO 0002
Subsystem 2 - Part No: 1C0959802A
Component: 09 Tõrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811
Component: 09 Tõrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812
Component: 09 Tõrsteuer.HR KLO 0004
00912 - Window Regulator Switch; Front Left (E40)
27-00 - Implausible Signal
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00008
Shop #: WSC 00028
VCID: 0444436D16A6156298-4BBA
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
30-00 - Open or Short to Plus
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 C
Component: Radio NP2 0011
Coding: 05035
Shop #: WSC 00028
VCID: 200C2FFDA27EE9429C-5160
Address 58: Aux Fuel Tank Labels: 3B7-906-268.lbl
Part No: 3B7 906 268
Component: Kraftst. Zusatztank 0004
VCID: 6B9608D11B38FA1A79-5160
End----------(Elapsed Time: 05:15, VBatt start/end: 12.3V/11.9V)-----------
