Hi
I have a problem amarok at my workshop that has been everywhere to be fixed and still has problems.
It is low on power, low on bottom end toque hard to start in the morning and has a very deep loud induction noise at idle.
Intermittently throwing code
4794 - Mass Air Flow Sensor (G70)
P0101 00 [101] - Implausible Signal
When I put an oscilloscope on the air mass meter and compare it to another amarok the frequency is fluctuating a lot more than the test car.
When I have a look at the EGR position it says it is open 50% and compared to the test amarok it is only at 30% at the same running time, coolant temp and same RPM.
When I do a EGR adaption I can hear the valve open and close and it make the induction noise stop, but when it is finished it its loud again.
its like the exhaust is coming back through the intake and I can see it on oscilloscope through air mass meter.
if I do the EGR adaption on the test amarok it makes the same induction noise as the problem car until it is finished.
what I want to know is why the ECU is turning on the EGR so much at idle.
Things that have been done to this vehicle before it has come to my workshop.
2 New Sets of turbos fitted by VW Dealer- Yes 4 turbos.
2 New Airflow air mass meters - Fitted by 2 different mechanics
New set of injectors
New EGR motor and pipes.
Air filter
Full service
EGR blank of plate just for testing- made car drive better until engine light came on. Then plate was removed.
DPF was removed to check for soot accumulation it was fine.
All sensors and solenoids removed from test amarok and put in this vehicle.
When I do a basic setting air mass plausibility calculated test its stops at the end and says test aborted safety REASONS
when I do basic setting oxygen sensor test it is aborts - timeout
all other basic settings and adaptions pass.
if I do the tests on the test amarok it passes all the tests.
I don't what to just throw an ECU at it as every sensor and actuator is working just not the way they are meant to.
This car has already had $20000 AUD spent on it.
Any help would be very appreciated
Dean
Air filter
Full service
Dean
Tuesday,08,November,2016,13:26:58:13589
VCDS Version: 16.8.3.1 (x64)
Dealer/Shop Name: Newcastle Auto Electrics
Workshop Code: 333 66669 066662
VIN: WV1ZZZ2HZB806XXXX License Plate: XXXXXX
Mileage: 120120km-74639mi Repair Order:
Chassis Type: 2H (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 56 69
VIN: WV1ZZZ2HZB806XXXX Mileage: 120120km-74639miles
Address 01: Engine (J623-CDCA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2.0l BTD H40 9978
Revision: 26H40--- Serial number: 00000000000000
Coding: 01194012232600080000
Shop #: WSC 30417 002 1048576
ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
ROD: EV_ECM20BTD_VN81.rod
VCID: 6FED80D5B6A8193A55-803A
P0101 00 [237] - Implausible Signal
Mileage: 119968 km
Date: 2016.10.29
Time: 11:57:06
Engine speed: 2153.00 /min
Vehicle speed: 96 km/h
Coolant temperature: 88 °C
Intake air temperature: 47 °C
Voltage terminal 30: 13.980 V
Air mass: actual value (mg/stroke): 457.6 mg/stroke
Standardized airflow ratio: filtered: 1.2427
EGR solenoid valve: actual value: 99.61 %
Throttle valve adapter: actual value: 99.78 %
Charge air pressure specified value: 1085 hPa
Charge air pressure: actual value: 1207.8 hPa
Mean injection quantity: 0.00 mg/stroke
Readiness: 0010 0000
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 G HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0106
Revision: 00H44001
Coding: C07324B6919A039A24A489A4AF5910
Shop #: WSC 07456 790 49164
VCID: 34674FB9970E7AE268-8060
Fault Status: 00100011
Reset counter: 192
Mileage: 118801 km
Date: 2016.10.19
Time: 17:14:47
Count: 16384
Count: 1
Count: 51
Count: 768
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 192
Mileage: 118801 km
Date: 2016.10.19
Time: 17:14:47
Count: 16384
Count: 1
Count: 35
Count: 768
00789 - Backup Switch (F41)
Reset counter: 133
Mileage: 118910 km
Date: 2016.10.21
Time: 15:59:06
Count: 19008
Count: 4097
Count: 202
Count: 254
Address 08: Auto HVAC (J255) Labels: 7E5-907-040.clb
Part No SW: 2H0 907 040 D HW: 2H0 907 040 D
Component: ClimatronicT5 H11 0304
Coding: 0000000002
Shop #: WSC 07456 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimatronicT5.rod
VCID: 224BB9E135FAE4528A-8076
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 H HW: 6R7 937 087 H
Component: PQ25 BCM H12 0022
Revision: -1------ Serial number: 1002480801
Coding: 3C0002380C41040080300800240A04C40080412E600000003000
Shop #: WSC 07462 790 50316
VCID: 49990E4DE08C170A2B-801C
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3321
Coding: 110000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3321
Coding: 110000
Subsystem 3 - Part No: 1K8 951 605 B
Component: LIN BACKUP HORN H11 H11 9005
Subsystem 4 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 5 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00H H06 0013
Revision: -------- Serial number: 003HN002KRHN
Coding: 000000000000000000000000000000003048
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 33654CA59A007DDA71-8066
Serial number: 3495RRB405R0CIU2H0L7
Serial number: 3505RRB4053058P0BO6/
Serial number: 3555YRB40510891I4OJB
Serial number: 3565YRB40510891IAGE5
Part No SW: 2H0 920 863 A HW: 2H0 920 863 A
Component: KOMBI H05 0304
Coding: 150A00
ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
VCID: 275DA8F55ED8017ADD-8072
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R7 937 087 H
Component: GW-K-CAN TP20 0022
Revision: -1------
Coding: 742300
VCID: 70EF83A9A39606C24C-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IYC30301HYTB
Coding: 0000013
VCID: 2F6D40D5BE28593A15-807A
Component: IMMO H05 0304
VCID: 6ADB91C18D4AFC1202-803E
Address 32: Differential Locks (J647) Labels: 2H0-927-771.clb
Part No SW: 2H0 927 771 HW: 2H0 927 771
Component: Quersperre H04 0014
Revision: 11001001 Serial number: 4DG 11.12.10 00
Coding: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01005
ROD: EV_QuersUDSAAMVN817.rod
VCID: 6BD594C582B0E51A79-803E
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3551655
Coding: 0000040002
VCID: 62CBF9E17D7AA452CA-8036
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 5
Mileage: 119331 km
Date: 2016.10.23
Time: 14:00:09
Reset counter: 5
Mileage: 119331 km
Date: 2016.10.23
Time: 14:00:09
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000159454716
Coding: 0100000100000000
VCID: 306F43A9631646C20C-8064
End-------------------------(Elapsed Time: 02:00)--------------------------
