Results 1 to 10 of 10
Thread: Disable lights monitoring
    Apr 2015
    Romania
    Question Disable lights monitoring
    Car in question is a 2011 Octavia 2 RS FL.
    I have replaced the standard indicator bulbs with LEDs and as expected I'm getting errors on all 4 as well as the so-called "hyper-blinking" of the dash indicator arrows along with the fast ticking (on the outside, blinkers work normally).
    I would really like to have the monitoring disabled on all bulbs if possible, because I'm planning to replace them all with LEDs.
    Is this possible only with VCDS alone, because I've tried and I don't have the option to disable monitoring, seeing as I have an all-in-one BCM (or so I'm told)
    Thank you so much for any suggestions!
    Please post an Auto-Scan so we can see what BCM you have, and what other modules are fitted to your Octavia 2.
  3. Likes Uwe, Boki Ar liked this post
    Apr 2015
    Romania
    Here is the auto-scan, thanks again:
    Thursday,10,November,2016,22:44:50:23304
    VCDS Version: 16.8.1.3 (x64)
    Data version: 20160902 DS256
    Workshop Code: 123 54563 006500
    VIN: TMBEH61Z8B2079021   License Plate: STH
    Mileage: 92850km-57694mi   Repair Order:
    Chassis Type: 1Z (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 47 52 55 56
              62 72 77
    VIN: TMBEH61Z8B2079021   Mileage: 92850km-57694miles
    Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 RE    HW: 03L 906 022 GA
       Component: R4 2,0L EDC G000AG  5752
       Revision: 13H13---    Serial number:
       Coding: 0000078
       Shop #: WSC 73430 790 00999
       VCID: 79F3CED730825A8AE9-802C
       Part No SW: 02E 300 054 H    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2601
       Revision: 05351112    Serial number: 00001010301040
       VCID: 1B3FF45FDAFEC89A5B-804E
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Revision: 00H31001
       Coding: 143B601C09290003280B06E6901A0042350800
       Shop #: WSC 73430 790 00083
       VCID: 76E9C5EBC19C35F284-8022
       Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
       Component: Climatronic   H16 0402
       Revision: 00005001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SK12.rod
       VCID: 76E9C5EBC99C35F284-8022
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 40000ABAE85BF1C040080080510091E4477800AE737D8560808C40040040
       Shop #: WSC 54563 123 06500
       VCID: 38750BD38B08838256-806C
       Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 14111  26  0601
       Coding: 00D7B7
       Component: RLS 231110 05  54  0403
       Coding: 0750ED
       Subsystem 3 - Part No: 1Z0 951 171 A
       Component: Innenraumuebe  009 5103
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
                        Fault Status: 01101100
                        Reset counter: 13
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:36:45
                            Term 15 On
                        Voltage: 11.90 V
                            Term 50 Off
                        Reset counter: 13
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:36:45
                            Term 15 On
                        Voltage: 11.90 V
                            Term 50 Off
    01501 - Bulb for Blinkers; Rear Left (M6)
                        Reset counter: 13
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:36:45
                            Term 15 On
                        Voltage: 11.90 V
                            Term 50 Off
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Reset counter: 13
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:36:45
                            Term 15 On
                        Voltage: 11.90 V
                            Term 50 Off
                        Fault Status: 00100111
                        Reset counter: 53
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:40:11
                            Term 15 On
                        Voltage: 14.10 V
                            Term 50 Off
                        Reset counter: 53
                        Mileage: 92854 km
                        Date: 2011.04.03
                        Time: 22:40:11
                            Term 15 On
                        Voltage: 14.10 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
       Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0005
       Revision: --H06---    Serial number: 28291030900180
       Coding: 108102
       Shop #: WSC 13765 790 00083
       ASAM Dataset: EV_EPHVA18SKxxx0000 001001
       ROD: EV_EPHVA18SKxxx0000.rod
       VCID: 438F6C3FCACED05AF3-8016
       Component: Q6 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC22N0B0
       Coding: 0020790
       VCID: 3D7B1AC7642AA6AA85-8068
       Subsystem 1 - Serial number: 6332MSME5922471EF
       Subsystem 2 - Serial number: 6342MSME5946093AI
       Subsystem 3 - Serial number: 6351HSME2501111EZ
       Subsystem 4 - Serial number: 6361HSME2501051D
       Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101124300782
       Coding: 189A140000
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWSXS.rod
       VCID: 7EF9DDCBE1AC7DB2DC-802A
       Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO  H07 0012
       Coding: 830000
       Part No SW: 1Z0 920 843 N    HW: 1Z0 920 843 N
       Coding: 110D01
       ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 211110F1002251
       Coding: 351302
       VCID: 306533F363785BC21E-8064
       VCID: 6AD1E19B8D24E11210-803E
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
       Component: SG EXT.PLAYER H13 0111
       Revision: A1001003    Serial number: 7668900875
       VCID: 2757D8AF56B61C7ACF-8072
       Part No SW: 3T0 035 680 G    HW: 3T0 035 680 A
       Component: RNS-MID       H42 5238
       Revision: AB001001    Serial number: SKZ6Z7K4331152
       Coding: 00060002000000A10000
       VCID: 346D3FE3976067E27A-8060
       Subsystem 1 - Part No: 3T0 051 859 AM
       Component: EU East V13  8350
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Coding: 0004350
       VCID: 76E9C5EB019C35F284-8022
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       VCID: 316336F7A87252CA11-8064
       Part No SW: 3T0 035 456     HW: 3T0 035 456
       Component: KonzernAmp10K H06 0342
       Revision: --------    Serial number: BP218209152882
       ASAM Dataset: EV_AudioVerst10KanalBNO2 A01003
       ROD: EV_AudioVerst10KanalBNO2.rod
       VCID: 6ED9ED8BB1CC0D324C-803A
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Coding: 0004342
       VCID: 48957B133BE8F30226-801C
    00121 - Outside Warning Light/Door exit Light Passenger Side
       Coding: 1507354
       VCID: 346D3FE3576067E27A-8060
       Coding: 00000023
       Coding: 00000023
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012563
       VCID: 326139FBAD7469D268-8066
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 336F3CFF526E60DA63-8066
    Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
       Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
       Component: Telefon       009 0511
       Revision: --------    Serial number: 35909603070689
       Coding: 020100000100010000000000
       ASAM Dataset: EV_UHVPremi A01005
       ROD: EV_UHVPremi_VW32.rod
       VCID: 2953DE9748A22A0AD9-807C
    End-------------------------(Elapsed Time: 03:21)--------------------------
  5. Likes Boki Ar liked this post
    Stoke on Trent, England
    This is a common problem when fitting LED bulbs. You normally have to fit a resistor in the circuit so the bulb out warning doesn't show. You can Google this problem.
    New User Keith
    There's a suggestion on post #7 of this thread http://www.briskoda.net/forums/topic...ash-mot-issue/ on briskoda.net that the ability to code out LED bulb errors wasn't added to the Octavia 2 until 2012MY.
    If that's true then as you say you have a 2011 model you'll have to add resistors in parallel with the LED bulbs to get rid of the errors.
  8. Likes Uwe liked this post
  9. #6
    Mar 2015
    Australia
    I've got LEDs in my 2011 Octavia vRS and they don't throw any faults.
    Its a matter of finding some that are 'canbus friendly' unless you add the resistors inline in the circuit.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  10. Likes PetrolDave liked this post
  11. #7
    Apr 2015
    Romania
    I am aware of the resistor "solution" I've done that to a few cars before, but I was hoping to avoid that. Since nobody knows how to disable this GD monitoring, I guess that's where I'm heading.
    Thanks for the suggestion to try out different LEDs, I would do that if I could afford to spend 50$/pair on LEDs to find one that works. Maybe you can point me to some that you know works for sure.
  12. #8
    Mar 2015
    Australia
    I just used these ones, in yellow for indicators:
    https://www.aliexpress.com/item/Ford...608.0.0.QOadPi
    They have been in the car now for about 2.5 years.
    I don't think the red ones work as well for brake lights as I've had some of them fail. But indicators are going strong.
  13. #9
    Oct 2014
    I coded out the bulb warnings (indicators, tails, reverse, sidelights, fogs) on a MY12 Octavia using information from skodapilot.
    If you have access to the right tools it might be possible, although I think your BCM might be too old to support LED lighting.
    - 1K0 937 087 K (HW:103 SW:0615) didn't support LED lighting on a Skoda Superb (I tried this for someone)
    - 1K0 937 087 P (HW:104 SW:0615) apparently did support LED lighting on a Skoda Superb (report from another person so unverified)
    - 1K0 937 087 Q/R (HW:110 SW:651) both support LED lighting (my car)
    I did try flashing the K rev to a P rev and it made no difference. As you have a J rev with HW:103 I think you may need to use resistors I'm afraid.
  14. #10
    Dec 2019
    Lancs, UK
    For anyone visiting this thread looking for an answer regarding retrofitting LEDs, here's what you need to know if you have a car equipped with the BCMPQ35 module (as with the original post).
    The BCM...
    If you're wanting to fit retrofit LED bulbs rather than the dedicated clusters available from the likes of Hella it doesn't matter if you have an LED-ready BCM revision or not.
    ANY BCM will work with LED bulbs (ignoring bulb-monitoring issues for a moment).
    LED-ready BCMs are for those cars where factory LED options are available (later Golf 6, Scirocco etc.).
    An LED-ready BCMPQ35 is not designed to support LED bulbs fitted in traditional filament bulb housings.
    Bulb Monitoring
    For clarity, bulb monitoring and diagnostics are performed by the BCM. This is not a function of CAN which is a networking communication standard using a bus topology. "CANBUS friendly" is utterly meaningless marketing blurb while "error-free" accurately describes a bulb design. More on this in a moment.
    There are three ways of dealing with existing bulb diagnostics when retrofitting LED bulbs.
    The software route involves coding the BCM so diagnostics are either disabled or adjusted to take into account LED operating characteristics. This involves software other than VCDS. Those wanting a "clean" solution without physical modifications will want to try this.
    The hardware route involves the addition of a high-wattage wire wound resistor in parallel with every retrofitted LED. This could become a wiring mess if the intention is to replace every bulb, and these resistors get HOT. I routinely solder with a 25W iron, a resistor correctly specced for a 21W bulb ideally needs to rated for double this in continuous applications and the nearest common value is 50W. Every bulb you fit will require a wire wound resistor and these will require careful placement to avoid melting nearby plastic components. This is a good solution for those with some DIY and soldering experience but without access to potentially expensive diagnostic software. Referring back to CAN bus, some resistors are sold as "CANBUS cancellers" and "CANBUS decoders". Again, this is meaningless marketing rubbish, they don't "cancel" CAN bus or "decode" it in any way, they merely provide a load to the lighting circuit similar to that of a filament bulb.
    Finally, the mindware route involves ignoring the bulb warning and accompanying MFD error messages. This requires no software or DIY skills.
    A full LED retrofit without errors or resistors is possible with the BCMPQ35 purely through coding, I know because I've done it. One interesting thing about this module and LED retrofits is many people still think resistors are required to maintain a correct flash rate. This was true with old designs of flasher circuit that relied on the bulb resistance for the correct flash rate, but it's not true with this module. Without coding or resistors you will see hyper-flashing on the dashboard but the lights will be operating externally at the correct rate. This seems to be a deliberately engineered feature to remind you there is an issue with the indicators because with bulb diagnostics disabled there is no hyper-flashing internally either.
    One other thing I found in my experiments was at one point my BCM would appear to accept coding changes (DRL Dimming Factor was one) but the change wouldn't take while the BCM was showing error codes. The coding was reporting correctly (LED fogs running at 10%) but there was no output and changing this value didn't make a difference. Returning bulbs to standard and clearing DTCs resolved this issue, and since disabling bulb diagnostics there have been no further quirks of fitting LEDs as replacements to the factory originals.
  15. Likes PetrolDave liked this post
