Dear all,
1.8T ARY Engine with stage 1 map.
Experiencing a feeling of loss of power. Have full VCDS and no fault codes logged at all. Lambda (add) 0.4% and (multi) -3.1%.
Oil changed 2,000 miles ago.
New plugs (BKRE7 gap 0.30)
2.0L Coil Packs
New fuel filter
Use RON 99 or 98 fuel.
New N75
New thermostat
New CTS
Replacement Bosch MAF.
Experiencing a loss of overall power and juddering when accelerating. Better when cold, but still not great. Have completed a pressure test and no obvious leaks. Any advice would be appreciated. Have scanned all the forums for months and no one solution or symptom fits my issue.
Attached is a picture of the VCDS that I pulled recently. Knock as high as 20v on cyl 2 6000rpm.
Thank in advance
https://www.flickr.com/photos/93860156@N04/30209406134/in/dateposted-public/
2.0L Coil Packs
New fuel filter
New N75
New thermostat
New CTS
Thank in advance
8N0 906 018 AQ 1.8L R4/5VT 0002
Group A: '003 Group B: '026 Group C: '032
Engine Speed Intake Air Mass Throttle Drive Ignition Voltage Cyl. 1 Voltage Cyl. 2 Voltage Cyl. 3 Voltage Cyl. 4 Lambda (add.) Lambda (mult.) Bin. Bits
TIME Angle Sensor 1 Timing Angle TIME Knock Sensor Knock Sensor Knock Sensor Knock Sensor TIME Self-Adaptation Self-Adaptation
Marker STAMP /min g/s % °BTDC STAMP V V V V STAMP % %
0.6 2560 16.33 9.4 25.5 0.01 2.925 3.861 2.925 1.872 0.3 0.4 -3.1
1.5 2640 27.31 14.9 26.3 0.9 3.159 3.744 2.808 1.755 1.2 0.4 -3.1
2.41 2800 37.92 18.4 25.5 1.8 3.627 4.446 3.51 2.106 2.11 0.4 -3.1
3.31 2960 20.75 11.4 29.3 2.71 3.978 5.733 3.51 2.691 3.01 0.4 -3.1
4.22 2960 7.61 4.3 30 3.62 3.861 5.733 3.51 2.106 3.92 0.4 -3.1
5.12 2880 7.28 4.3 0.8 4.52 3.861 5.616 3.393 1.989 4.82 0.4 -3.1
6.03 2760 7.67 4.3 0.8 5.43 3.978 5.265 2.925 1.989 5.73 0.4 -3.1
6.94 2680 7.08 3.9 0 6.33 4.68 4.446 3.861 2.106 6.63 0.4 -3.1
30.47 1680 7.17 3.9 19.5 29.87 2.106 1.872 1.755 0.936 30.17 0.4 -3.1
31.37 1720 11.11 6.7 19.5 30.77 2.106 2.106 1.404 1.17 31.07 0.4 -3.1
32.28 1840 24.47 16.1 18.8 31.67 2.106 1.872 1.755 1.17 31.98 0.4 -3.1
33.18 2080 30.19 17.6 18 32.58 2.106 2.691 1.872 1.755 32.88 0.4 -3.1
34.09 2280 31 16.1 20.3 33.49 2.808 3.042 1.638 2.106 33.79 0.4 -3.1
34.99 2480 31.67 15.7 23.3 34.39 2.925 3.627 1.755 2.808 34.69 0.4 -3.1
35.9 2640 33.33 16.5 24 35.3 3.51 4.446 1.872 2.691 35.6 0.4 -3.9
36.8 2800 34.5 16.9 16.5 36.2 3.861 4.446 2.223 2.808 36.5 0.4 -3.1
37.71 2960 33.92 16.5 27 37.11 4.212 5.616 2.808 2.457 37.41 0.4 -3.1
38.61 3080 27.75 14.5 30 38.01 5.265 6.669 2.34 2.808 38.31 0.4 -3.1
39.52 3120 29.89 15.3 30 38.92 5.148 6.786 2.34 2.691 39.22 0.4 -3.1
40.42 3200 33.92 16.9 29.3 39.82 5.616 7.488 2.106 2.34 40.12 0.4 -3.1
41.33 3320 34.67 16.5 29.3 40.73 4.914 9.009 2.34 3.042 41.03 0.4 -3.1
42.23 3440 27.56 14.1 30.8 41.63 3.861 8.424 2.457 3.861 41.93 0.4 -3.1
43.14 3520 28.94 14.9 31.5 42.54 5.148 5.265 2.925 3.978 42.84 0.4 -3.1
44.05 3640 35.06 16.9 31.5 43.44 5.265 6.669 3.276 4.212 43.74 0.4 -3.1
44.96 3720 40.58 18.4 30.8 44.35 6.786 5.382 3.861 4.68 44.65 0.4 -3.1
45.86 3800 42.11 18.8 24 45.25 6.552 6.318 3.861 4.797 45.56 0.4 -3.1
46.77 3920 47.42 20 23.3 46.17 5.85 5.733 3.978 5.148 46.47 0.4 -3.1
47.68 4040 48.89 20.4 23.3 47.07 6.552 6.084 4.68 5.85 47.36 0.4 -3.1
48.58 4120 49.81 20.4 25.5 47.97 5.85 6.669 4.914 4.914 48.28 0.4 -3.1
49.48 4240 50.08 20.4 23.3 48.88 6.318 6.318 6.786 5.382 49.18 0.4 -3.1
50.39 4360 50.08 20.4 30.8 49.79 6.201 7.488 9.36 5.382 50.09 0.4 -3.1
51.3 4440 56.19 22 30.8 50.69 5.85 7.488 8.424 5.85 50.99 0.4 -3.1
52.2 4560 67.64 25.5 21.8 51.6 6.786 9.945 7.137 6.786 51.9 0.4 -3.1
53.11 4720 65.03 24.7 26.3 52.49 7.137 7.488 8.073 6.786 52.8 0.4 -3.1
54.01 4840 65.22 24.7 31.5 53.41 7.02 9.36 7.488 7.488 53.71 0.4 -3.1
54.92 5000 66.14 25.1 21.8 54.31 7.488 9.945 7.137 9.945 54.62 0.4 -3.1
55.82 5120 67.86 25.1 31.5 55.22 7.722 9.009 6.786 10.881 55.52 0.4 -3.1
56.73 5240 79.22 27.8 31.5 56.12 5.85 14.274 9.009 9.945 56.43 0.4 -3.1
57.63 5400 101.5 40 17.3 57.03 8.658 12.402 14.625 12.753 57.33 0.4 -3.1
58.53 5360 12.25 7.1 9 57.93 11.817 18.018 9.945 9.594 58.23 0.4 -3.1
59.43 5160 12.94 7.8 6.8 58.83 10.53 10.881 7.722 5.85 59.13 0.4 -3.1
60.34 4800 12.28 7.5 4.5 59.73 13.338 11.817 7.488 5.382 60.04 0.4 -3.1
61.24 4360 11.14 6.7 3 60.64 14.04 6.786 9.945 4.797 60.94 0.4 -3.1
62.15 4000 10.19 5.9 3 61.54 8.073 11.466 10.296 4.212 61.85 0.4 -3.1
63.05 3680 9.5 5.5 2.3 62.45 6.786 11.466 5.85 4.446 62.75 0.4 -3.1
63.96 3560 8.83 5.1 2.3 63.36 7.722 8.658 5.85 3.978 63.66 0.4 -3.1
