'17 GLI - DRL Dimming with Blinker...
Veedubya79
Lil' Rhody... USA
C?ID=262499
Hi all,
I coded my car to turn off the "wink" feature when using turn signals, but would like to take it a step further and dim the LED DRL while the turn signal is on. I have searched and searched, and all the coding I find is for MK7 cars.
Does anyone know if this is possible?
Thanks in advance!
DV52
C?ID=194404
Hi all,
Thanks in advance!
Veedubya79: Hello and thank-you for your question! As you probably already know the GLI (Jetta - I assume) is based on the now ubiquitous MQB platform. In this sense, it shares many of the attributes for the mk7 Golf and it is on this understanding that I reply to your question (incidentally, it would be immensely useful if you could post-up a copy of an auto-scan from your car - to confirm my assumption)
So - here's the thing: If your Jetta shares the same DNA as the mk7 (as I suspect that it does), then likely you implemented the "DRL wink" by adding the Blinken links/rechts aktiv (beide Phasen) command to the Leuchte channels for the left/right DRLs. Likely also, you accompanied these changes, by also altering the "dimmwert" setting for same leuchte "alpa-pair" to a value of zero. If this is the case, then the answer to your question is to simply raise this setting to a higher number for both of the Leuchte-sets on the left/right DRL!
Veedubya79
Lil' Rhody... USA
C?ID=262499
Hi Don,
Thanks for the response. I'll post a current scan later tonight. When I coded the car to turn off the "wink", all I did was check off a box in LC. I didn't go into Adaptation. To me, it seems the 2017 GLI (and most likely all new Jetta's?) is an MK6 with MK7 DNA sprinkled everywhere electronically.
PetrolDave
Westbury, UK
C?ID=1423
A full Auto-Scan will confirm whether this is a good assumption.
Dana
Western PA, USA
Please do post the complete scan but I searched our files and Joe sent a scan from that car when it was brand new (which we highly appreciate).
Sprinkle version confirmed:
> Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
> Part No SW: 5K0 937 087 AJ HW: 5K0 937 087 AJ
> Component: BCM PQ35 H+ 122 0184
> Revision: BL122001
> Coding: EF200ABFFC2F06D401880081250081C40678000845A08DB2E4802000A040
> Shop #: WSC 00066 000 00000
> VCID: 7DF1A461E4C631AAC3-8028
> Subsystem 1 - Part No: 5K7 955 559 C
> Component: RLS 040616 04 42 0106
> Coding: 0228DD
Since this is a Mk6 you are limited to the Coding Functions. Adaptation is boring - but nice and simple :) in that module type.
DV52
C?ID=194404
Dana: I agree : Adaptation on a mk6 takes all the fun out of the experience!!!
don
Veedubya79
Lil' Rhody... USA
C?ID=262499
Hi all,
Sorry for the delay, but here's my scan from tonight...
Saturday,05,November,2016,19:13:08:14175
VCDS Version: 16.8.3.1 (x64)
VIN: 3VW5T7AJ6HMxxxxxx   License Plate:
Mileage: 4250km-2640mi   Repair Order: 11-05-16
Chassis Type: AJ (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 5F
          62 72 75
VIN: 3VW5T7AJ6HMxxxxxx   Mileage: 4250km-2640miles
Address 01: Engine (J623-CPPA)       Labels: None
   Part No SW: 06K 906 071 BL    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 3686
   Revision: --H13---
   Coding: 00190012242400171000
   Shop #: WSC 00066 790 00191
   ASAM Dataset: EV_ECM20TFS02006K906071BL 001005
   ROD: N/A
   VCID: 76E3BB4DC9F062F296-8022
No ASAM data for: "EV_ECM20TFS02006K906071BL" (VW36)
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B600C49230000851306EC922100412118F02A
   VCID: 75E1BC41DCF669EA9F-8020
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0405881547
   Coding: 032C0C
   Shop #: WSC 00066 000 00293
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 39797071B86ECD8ABB-806C
   Part No SW: 1K8 907 044 CN    HW: 1K8 907 044 CN
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 0050019003
   Shop #: WSC 00066 790 00320
   VCID: 7DF1A461ECC631AAD7-8028
   Revision: BL122001
   Shop #: WSC 00066 123 12345
   VCID: 7DF1A461E4C631AAD7-8028
   Coding: 0228DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331615311452
   Coding: 0071155001
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   ROD: EV_EPHVA18VW364GP00.rod
   VCID: 36637B4D897022F256-8062
Address 15: Airbags (J234)       Labels: 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM06ZW9
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63C5F2196A62E75AC1-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000005DCUM%
   Coding: 30314C
   Subsystem 2 - Part No SW: -----------    HW: 480 001 305 16
   Serial number: 357000000009A1557A1K
   Subsystem 3 - Part No SW: -----------    HW: 480 001 305 16
   Serial number: 3580000000088809DA1U
   Subsystem 4 - Part No SW: -----------    HW: 480 022 305 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001A720E18B405D%
   Subsystem 5 - Part No SW: -----------    HW: 480 022 405 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B9210BB05B5D4
   Subsystem 6 - Part No SW: -----------    HW: 480 022 405 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001B520E18B4635+
   Subsystem 7 - Part No SW: -----------    HW: 480 022 405 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001B520E18B47686
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160531300819
   Coding: 0002440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F0D5E69E6CA23BAC5-802A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160000988080076224
   Coding: B0FFFF
   Part No SW: 5C6 920 986 C    HW: 5C6 920 986 C
   Component: KOMBI         H02 1104
   Coding: 221E030000
   Shop #: WSC 00066 790 00289
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 336542599A0237DA71-8066
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 26061603010038
   Coding: 351032
   VCID: 7BF5AA79FAD23F9AE9-802E
   Component: IMMO          H02 1104
   Coding: 000007
   VCID: 6ADB9F3D8D48B61202-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000092095006
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 31694851601E05CA03-8064
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0405304365
   Coding: 02011102
   Shop #: WSC 01383 790 50316
   ROD: EV_HREntryHella.rod
   VCID: 3C776965B75CF8A2A0-8068
   Lane Change Assistant 2:
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010533120
   Coding: 0404BD
   Shop #: WSC 00066 790 00084
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 1D3184E10C8691AAB7-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745160627133458
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   VCID: 39797071706ECD8ABB-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0095257
   VCID: 285FA53553C44402D4-807C
   Component: EZE_2         H56 1682
   Coding: 01030100
   VCID: 6FED8E29BEAA533A55-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST000Z8O8300000
   Coding: 180000
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010554852
   Coding: 0404BC
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 1E3383ED01808AB2AE-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744160628115146
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H30 0357
   Serial number: VWZAZ2S0222824
   Coding: 02630102AA00000051220003001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2447B1052FECA062F8-8070
   Subsystem 1 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
Address 75: Telematics (J949)       Labels: 12E-035-284.clb
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140551
   Coding: 02630102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 1427E1C5FF4CD0E208-8040
End-------------------------(Elapsed Time: 03:09)--------------------------
