Results 21 to 30 of 38
Thread: New VCDS Hex-Net User
  1. #21
    Did the HEX-NET have an internet connection at that time? If not, have you done a [Check for Updates] since they while it did?
    I was able to download and update to the latest version.
  2. #22
    Quote Originally Posted by brknhalo View Post
    I just replaced the pads and rotors for both front and back. The front pads had the sensors on them as expected. I am hoping there is a way to clear that fault.
    Well, there doesn't seem to be a fault code to clear. Historically, the front wear is just a simple circuit, that turns on a dumb light in the cluster, without ever setting fault code. If the light stays on, there's a problem with the circuit.
    That looks to have been before you did the scan, and hence before your HEX-NET knew what data it needed for that particular car.
    I have to bring it into the dealer to fix the rearview mirror that is hopefully covered under warranty. I am curious to see what they will say about the warnings and what they did to fix them. I am thinking that the two-wire sensor on one of the front pads-set may have gotten pinched when it was being installed.
    I will supply an update with whatever I can find out. I will ask about the other brake warning as well.
  5. #25
    I also received a notice while doing the scan:
    "ASAM Data missing for some modules in scan. You will be prompted to download the missing data after the scan"
    I have not been prompted.
    Does anyone have anything on this?
  6. #26
    I did. I asked you if your HEX-NET has had the opportunity to talk to the server since you did the Auto-Scan, and I don't see a clear answer to that.
    I am not clear on what you are asking. I checked again for an update after the scan and verified I was up to date.
    Was there another answer you were looking for?
  8. #28
    Yes. If you've successfully checked for updates after doing a scan, it SHOULD have downloaded any files it detected as needing during the scan. Now the question is, whether it really did or not. We'll have to see what we can see from this end.
    OK, that isn't working quite the way it should -- stand by....
    OK, that's broken and needs to be fixed. Now the work-around: Connect to the car again and talk to some module that's missing ASAM data by accessing the module directly, rather than just doing an Auto-Scan. Assuming you have internet access, it should then prompt you.
  11. Likes jakematic liked this post
