Results 1 to 10 of 14
Thread: Electronic Park Brake issue
    Dec 2015
    Australia
    Hi All,
    About 1 year ago, I attempted to change all 4 discs and 4 brake pads on my 2005 Audi A6 C6 3.0L.
    I've changed these before on other vehicles, but this was the first time with an EPB.
    I used VCDS to retract the rear caliper. What I didn't know, was I after retracting, I had to manually push in the piston...
    I just assumed by retracting the piston via VCDS it would go in by itself. So with that wrong assumption, I then proceeded to de-tract and retract it again via VCDS.
    Before I knew what was going on, the piston fell out! I managed to work it out, fitted the piston back on. I cleared all the air bubbles by sucking the brake fluid out and pouring more into the main chamber.
    I proceed to the other rear brake pad and completed that one with ease, as this time I knew to manually retract the piston after performing the retract function on VCDS.
    Tested the car and brakes are fine.
    After the job was completed, I got error codes for the EPB.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 D HW: 4F0 614 517
    Component: ESP8 front H03 0010
    Coding: 0021338
    Shop #: WSC 02327 785 00200
    VCID: 25410182EC37981638-8070
    Reset counter: 170
    Mileage: 121003 km
    Date: 2015.11.07
    Time: 17:11:53
    Hex Value: 0x0240
    Hex Value: 0x4086
    Hex Value: 0x122A
    Hex Value: 0x00A8
    Hex Value: 0x00FF
    So ever since then I've been having issues with the right EPB. Sometimes it will engage and sometimes it won't.
    So there would be times where, the right park brake will not release at all, which means I can't drive, it was intermitent when releasing.
    So what I did was, when it did release, I pulled out the Fuse located in the boot for that right EPB. So for the past year, I've only been using my left EPB which is working fine, however I've had the parking brake error on my dash.
    I've been real busy over the last year and now have some time to fix this, hence this post.
    Can you please help me on where to start? Do I need to replace the control module? I believe the control module is situated under the tools in the boot? I looked it up and its very pricey. Please let me know what to troubleshoot to get this right EPB working again.
    Thanks in advanced and appreciate your time.
    David
    Oct 2014
    Arandjelovac, Serbia
    Post complete Auto-Scan, please.
    HQ
    I don't know what VW/Audi say today, but use to, when a piston popped out, you replaced the caliper. As I tell repair shops:
    You do not have a good enuff of a lawyer to reuse that caliper.
    And as Boki Ar says.... Auto-Scan please.
    ... and I'm watching some fool do odd yoga in front of me here at the airport....
    Jef
  4. Likes Boki Ar, Uwe liked this post
    Oct 2014
    Cool
    Hi Jef
    Whether to join him?
    HQ
    I'm sitting in a plane, I can't do a thing to help out now. I'm sure a full Auto-Scan will soon be posted.
    Jef
  7. Likes Uwe liked this post
    Oct 2014
    Cool
    Apology for yet another poor formulated messages and off topic... I thought you going to join a man who practices yoga...
  9. Likes Uwe liked this post
  10. #7
    Dec 2015
    Australia
    Hi Guys,
    Please see scan below.
    Log-NXN53J-WAUZZZ4F35N069899-121380km-75422mi.txt
    Saturday,05,December,2015,10:58:35:54942
    VCDS Version: 15.7.2.0 (x64)
    Data version: 20151124
    VIN: WAUZZZ4F35N069899   License Plate: NXN53J
    Mileage: 121380km-75422mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
                56 57 61 62 72 76 77
    VIN: WAUZZZ4F35N069899   Mileage: 121380km-75422miles
    37-Navigation -- Status: Sporadic communication error 1000
    77-Telephone -- Status: Malfunction 1010
    Address 01: Engine        Labels: 06C-909-559-ASN.lbl
         Part No SW: 4F0 910 559 A    HW: 4F0 907 559
         Component: 3.0L V6/5V      G01 0030
         Revision: --------    Serial number:
         Coding: 0004582
         Shop #: WSC 21530 822 65259
         VCID: 285F08B69B25857E03-807C
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
         Part No SW: 4F1 910 155     HW: 01J 927 156 HT
         Component: V30 01J 3.0l 5V RdW 0040
         Revision: 00000011    Serial number: 00000001244314
         Shop #: WSC 00010 822 74775
         VCID: 60CF5096B3953D3E0B-8034
         Coding: 0021338
                          Reset counter: 170
                          Mileage: 121003 km
                          Date: 2015.11.07
                          Time: 17:11:53
                          Hex Value: 0x0240
                          Hex Value: 0x4086
                          Hex Value: 0x122A
                          Hex Value: 0x00A8
                          Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
         Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
         Component: FBSAUDIC6 ELVSG H01 0030
         Revision: 31050601    Serial number: 10601200609898
         Coding: 0000019
         VCID: 24471C86E70D611E2F-8070
         Subsystem 1 - Part No: 4F0 910 131 A
         Component: FBSAUDIC6 EZS   H43 0070
         Subsystem 2 - Part No: 4F0 910 220
         Component: FBSAUDIC6 IDG   H36 0040
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
         Part No SW: 4F0 910 729 R    HW: 4E0 035 729 A
         Component: Interfacebox    H43 0500
         Revision: 00000000    Serial number: 351JR047505834
         Shop #: WSC 02335 785 00200
         VCID: 387FD8F64B8515FE93-806C
         Component: Bedienteil MMIC6H03 0050
         Subsystem 2 - Serial number: 00000000412696
         Subsystem 3 - Serial number: 0110.05.060000000100010350ÿ
         Subsystem 4 - Serial number: 010350ÿ
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
         Part No SW: 4F0 910 043     HW: 4F2 820 043 B
         Component: KLIMABETAETIGUNGH11 0110
         Revision: 00000023    Serial number: 00000000077556
         Coding: 0001094
         VCID: 5BB5677A9AF31EE65E-800E
         Part No SW: 4F0 910 279 A    HW: 4F0 907 279 A
         Component: ILM Fahrer      H14 0080
         Coding: 0100101
         VCID: 275D0B8A963B8A060A-8072
         Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
         Component: Wischer AudiC6  H04 0150
         Coding: 00062736
         Shop #: WSC 02335
         Coding: 00141886
         Shop #: WSC 02335
         Part No SW: 4E0 910 111 D    HW: 4E0 035 111 A
         Component: CD-Changer      H44 0340
         Revision: 00000000    Serial number: AUZ5ZBD6030044
         VCID: 1A3B227ED54927EE85-804E
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
         Part No SW: 4F0 910 655 D    HW: 4F0 959 655 B
         Component: 39 AIRBAG AUDI8RH29 0250
         Revision: 05H29000    Serial number: 0037LD04HMAB
         Coding: 0013113
         Shop #: WSC 21520 822 15502
         Subsystem 1 - Serial number: 6332CSME07211866Z
         Subsystem 2 - Serial number: 6342CSME07161D741
         Subsystem 3 - Serial number: 6351HSME04504D0A3
         Subsystem 4 - Serial number: 6361HSME04510615X
         Subsystem 5 - Serial number: 6371VSME044C4674O
         Subsystem 6 - Serial number: 6381VSME043F5713M
         Component: Lenksäulenmodul H07 0230
         Revision: 00H07000    Serial number: 90026042960138
         Coding: 0112141
         VCID: 66C3468E51B1530EF1-8032
         Part No SW: 4F0 910 900 A    HW: 4F0 920 900 M
         Component: KOMBIINSTR. M73 H09 0630
         Revision: 00300000    Serial number: 4LZ78CVA4
         Coding: 0256763
         Shop #: WSC 21540 822 100545
         VCID: 1E332E6EC9614BCE79-804A
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
         Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
         Component: Gateway         H09 0030
         Revision: 09          Serial number: 0800804A19039B
         Coding: ECFE53CC1B3504
         Shop #: WSC 02325 785 00200
                          Reset counter: 135
                          Mileage: 120843 km
                          Date: 2015.10.24
                          Time: 08:36:21
                          Reset counter: 135
                          Mileage: 120843 km
                          Date: 2015.10.24
                          Time: 08:36:21
         Coding: 0091138
         VCID: 61C95592B89F343604-8034
         Part No SW: 4E0 910 887 C    HW: 4E0 919 887 C
         Component: MNS ECE         H43 0100
         Revision: 00000000    Serial number: 353JU047586610
         VCID: 2D51F9A2B4C7A056F0-8078
         Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
         Component: TSG FA          H10 0020
         Revision: 00000000    Serial number: 9h0
         Coding: 0000666
         VCID: 29590DB2802FBC761C-807C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
         Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
         Component: Komfortgeraet   H14 0090
         Revision: 00900014    Serial number: 01001431480000
         Coding: 0262541
         Shop #: WSC 21520 822 04345
         VCID: 2C57F4A68FDDA95EE7-8078
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
         Part No SW: 4F0 910 223 B    HW: 4F0 035 223
         Component: Amp.-ASK        H09 0270
         Revision: 16S00001    Serial number: 00110040037328
         Coding: 0000007
         VCID: 1D312962C46750D660-8048
         Component: ILM Beifahrer   H09 0050
         Revision:             Serial number: 00000000044023
         Coding: 0001014
         Shop #: WSC 02323 785 00200
         VCID: 5EB36E6E89E10BCE39-800A
         Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
         Component: TSG BF          H10 0020
         Revision: 00000000    Serial number:  b0
         Coding: 0000666
         Part No SW: 4F0 910 801     HW: 4F0 907 801
         Component: EPB  C63C0030   H03 0030
         Revision: C63C0030
         Coding: 0004031
         Shop #: WSC 02334 785 00200
         VCID: 5DB1696284E710D620-8008
    02433 - Supply Voltage for Right Parking Brake Motor (V283)
                          Fault Status: 00111011
                          Reset counter: 170
                          Mileage: 121384 km
                          Date: 2015.12.05
                          Time: 10:28:04
                          Voltage: 13.56 V
                          Count: 103
         Part No SW: 4E0 910 541 C    HW: 4F0 035 541
         Component: TUNER EU/US/RDW H41 0290
         Revision: 00000000    Serial number: 352KR047575015
         VCID: 204F1096F3157D3E4B-8074
    Address 57: TV Tuner        Labels: 4E0-910-146.clb
         Part No SW: 4E0 910 146 E    HW: 4E0 919 146 A
         Component: TV analog TUNER H13 0270
         Revision: 00000028    Serial number: 00000000008054
         Coding: 0000007
         VCID: 23451F9AE203662656-8076
         Component: ENERGIEMANAGER  H11 0490
         Revision: 00000000    Serial number: 00000000079522
         Subsystem 1 - Part No: 4F0 915 105 B
         Component: von VA0  410610A1R2
         Coding: 344630393135313035422056413034313036313041315232
         Shop #: WSC 31250 000 1048576
         Part No SW: 4F0 910 795 A    HW: 4F0 959 795 A
         Component: TSG HL          H09 0010
         VCID: 2A5BF2BE8529B76E15-807E
         Part No SW: 4F0 910 795 A    HW: 4F0 959 794 A
         Component: TSG HR          H09 0010
         Part No SW: 4F0 910 283     HW: 4F0 919 283
         Component: Parkhilfe 4-Kan H09 0030
         Revision: --.--.--    Serial number: 11720430301511
         Coding: 0001006
         Part No SW: 4E0 910 336 C    HW: 4E0 862 335
         Component: Handyvorb2      H10 0120
         Revision: 00000000    Serial number: 00000007530046
         Coding: 0010920
         Shop #: WSC 21520 822 65259
         VCID: 224B1A9EFD196F2E5D-8076
    00532 - Supply Voltage B+
                          Reset counter: 169
                          Mileage: 121370 km
                          Date: 2015.12.04
                          Time: 21:15:21
    (Elapsed Time:02:30)--------------------------
  11. Likes Boki Ar liked this post
  12. #8
    HQ
    Quote Originally Posted by chukc6 View Post
    See if the fault code clears out. If not, hook up a good battery charger to the vehicle. Set and then release the parking brakes. Go into the EPM module, Basic Settings group 010 and see if both left and right side motors operate. Wait about 30 seconds after you hear the EPB motors stop operating before you exit out of Basic Settings.
    I've helped a lot of customers where the code may not clear out at first, but after a few rounds of setting/releasing EPB and 53-04-010, things start to work and the codes clear out.
    This still won't help a popped out piston issue. And IMHO, most cases of these type of fault codes happen in the first place due to a voltage issue in the first place.... not having a battery charger hooked up.
    Jef
  13. Likes Uwe liked this post
  14. #9
    Dec 2015
    Australia
    Thanks Jef I will try this tomorrow night after work.
    I did have a battery charger hooked up, but to be honest I'm not 100% confident that it was working properly.
    I do now have a proper CTEK 7.0 charger, so I'll use that.
    Will update tomorrow night, thanks again.
    David.
  15. #10
    Dec 2015
    Australia
    /bumping thread
    Hi All,
    Been busy with "life", finally replaced the entire rear right brake caliper. Put the fuse back in, the EPB seems to open and close fine on both sides however I still get the blinking (P) park light when engaged. Below is my latest scan, do I need to replace the right Control Module? And if so, can someone refer me to instructions. Thanks in advanced!
    Saturday,04,November,2017,13:33:45:54942
    VCDS Version: 17.8.0.1 (x64)
    Mileage: 132730km-82474mi   Repair Order:
    VIN: WAUZZZ4F35N069899   Mileage: 132730km-82474miles
       Coding: 0004582
       VCID: 285F08B69B258506E2-807C
       VCID: 60CF5096B3953D46EA-8034
       Coding: 0021338
       VCID: 25410182EC37986ED9-8070
                        Reset counter: 240
                        Mileage: 132732 km
                        Date: 2017.11.04
                        Time: 13:28:57
                        Hex Value: 0x0280
                        Hex Value: 0x40A2
                        Hex Value: 0x0000
                        Hex Value: 0x00AB
                        Hex Value: 0x00FF
       Coding: 0000019
       VCID: 24471C86E70D6166CE-8070
       VCID: 387FD8F64B85158672-806C
       Coding: 0001094
       VCID: 5BB5677A9AF31E9EBF-800E
       Coding: 0100101
       VCID: 275D0B8A963B8A7EEB-8072
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       VCID: 1A3B227ED549279664-804E
       Coding: 0013113
       Coding: 0112141
       VCID: 66C3468E51B1537610-8032
       Coding: 0256763
       VCID: 1E332E6EC9614BB698-804A
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Coding: 0091138
       VCID: 61C95592B89F344EE5-8034
       VCID: 2D51F9A2B4C7A02E11-8078
       Coding: 0000666
       VCID: 29590DB2802FBC0EFD-807C
       Coding: 0262541
       VCID: 2C57F4A68FDDA92606-8078
    02729 - Wire for Sunroof Enable Signal
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 240
                        Mileage: 132732 km
                        Date: 2017.11.04
                        Time: 13:15:42
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 240
                        Mileage: 132732 km
                        Date: 2017.11.04
                        Time: 13:15:42
       Coding: 0000007
       VCID: 1D312962C46750AE81-8048
       Coding: 0001014
       VCID: 5EB36E6E89E10BB6D8-800A
       Coding: 0000666
       Revision: C63C0030
       Coding: 0004031
       VCID: 5DB1696284E710AEC1-8008
    02435 - Supply Voltage for Control Module for Right Channel
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Reset counter: 158
                        Mileage: 121912 km
                        Date: 2016.01.03
                        Time: 12:37:11
                        Voltage: 9.73 V
                        Count: 113
       VCID: 204F1096F3157D46AA-8074
       Coding: 0000007
       VCID: 23451F9AE203665EB7-8076
       Subsystem 1 - Part No: 3D0 915 105 H
       Component: von VA0  590116G0Q9
       Coding: 334430393135313035482056413035393031313647305139
       VCID: 2A5BF2BE8529B716F4-807E
       Coding: 0001006
       Coding: 0010920
       VCID: 224B1A9EFD196F56BC-8076
    End-------------------------(Elapsed Time: 02:33)--------------------------
