Results 1 to 2 of 2
Thread: Headlights high beams don't go on when car is running (passing lights)
    Oct 2016
    I have an 2008 r32, every time I go for inspection they mechanic always asked to turn on the inside lights...he thought they are the fogs, but no switch... I have a '04 Touareg so I know they go on just for flashing..( I did change them to go on as a high beam...) but in my R32 they don't go on for a second wen the car is running... they only time they go on is wen the car is park and key on zero position.....
    I did try changing the UK instrument from xx02 to xx04 code and then [center electronics] to long code hex 17....and did not work or change anything.... any help would be appreciated tnx (sorry for my English)
    Tuesday,25,October,2016,13:13:26:29363
    VCDS Version: 16.8.2.3
    Data version: 20160926 DS261.0
    VIN: WVWKC71K38W185548   License Plate: FROSTED
    Mileage: 75000km-46602mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 65
    VIN: WVWKC71K38W185548   Mileage: 75000km-46602miles
    01-Engine -- Status: Sporadic communication error 1000
    02-Auto Trans -- Status: Malfunction 1010
    22-AWD -- Status: Malfunction 1010
    Address 01: Engine        Labels: 022-906-032-BDB.lbl
       Part No SW: 022 906 032 KR    HW: 022 906 032 GP
       Component: R32-DQ-80.8     G  |5N
       Revision: 1QH02---    Serial number: VWX7Z0GN3NJ88I
       Coding: 0000178
       Shop #: WSC 12848 922 394950
       VCID: 65C19170AC13756A27-8030
    Address 02: Auto Trans (UM)       Labels: 02E-927-770.clb
       Part No SW: 02E 300 011 CC    HW: 02E 927 770 AD
       Component: United 515m     082 1405
       Revision: 05108020    Serial number: 00001005030068
       Shop #: WSC 04940 001 00001
       VCID: 52AB5AACCD9DF2D252-8006
    18258 - Powertrain Data Bus
                P1850 - 000 - Missing Message from ECU - Intermittent
                        Fault Frequency: 255
                        Reset counter: 27
                        Mileage: 73719 km
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
       Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
       Component: ESP 4MOTION MK60    0102
       Revision: 00H13001
       Coding: 0021128
       Shop #: WSC 01279 785 00200
       VCID: 72EBFA2C6DDD92D2B2-8026
       Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
       Component: ClimatronicPQ35 130 1212
       Revision: 00130022    Serial number: 00000000000000
       VCID: 78FFC8040BA1F8828C-802C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 00000007781521
       Coding: F68F8F214004150047140000001400000008730B5C000100000000000000
       Shop #: WSC 03087 444 84487
       VCID: 71E9F52068DBA9CA4B-8024
       Component: Wischer 201107 021  0501
       Coding: 00038805
       Shop #: WSC 03087
       Subsystem 2 - Component: Fehler Lin-Slave 02
    02071 - Local Databus
                        Reset counter: 143
                        Mileage: 65973 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.20 V
    00532 - Supply Voltage B+
                        Reset counter: 148
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 5.00 V
                        Reset counter: 173
                        Mileage: 71133 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.00 V
                        Reset counter: 143
                        Mileage: 65973 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.20 V
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0191368
       VCID: 2E532E5CB965F63216-807A
                        Reset counter: 148
                        Time: 06:44:41
                        Voltage: 6.70 V
                        Reset counter: 148
                        Time: 06:44:41
                        Voltage: 5.80 V
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 43182 km
                        Time: 00:11:54
    01304 - Radio
                        Reset counter: 143
                        Mileage: 75005 km
                        Time: 13:04:36
       Component: 6T AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0A067D
       Coding: 0013908
       Shop #: WSC 01269 785 00200
       VCID: 6CD7E4544FF9442278-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME2B616F57O
       Subsystem 3 - Serial number: 6342MSME2A33426AC
       Subsystem 4 - Serial number: 6352QSME3F730963N
       Subsystem 5 - Serial number: 6362QSME43181B41B
       Subsystem 6 - Serial number: 63727SME1211115AP
       Subsystem 7 - Serial number: 63827SME1211731BV
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           036 0070
       Coding: 0012122
       VCID: 0109A5E0587BB94ABB-8054
       Part No SW: 1K6 920 974 D    HW: 1K6 920 974 D
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0GN3NJ88I
       Coding: 0007203
       Shop #: WSC 01287 785 00200
       VCID: 356101305C33C5EA57-8060
                        Reset counter: 148
                        Reset counter: 148
                        Reset counter: 173
                        Mileage: 71133 km
                        Time: 12:10:06
                        Reset counter: 173
                        Mileage: 71133 km
                        Time: 12:19:41
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K07B070273
       Coding: ED831F071003020000
       VCID: 306F3024A351E0C204-8064
    01304 - Radio
                        Reset counter: 59
                        Mileage: 65973 km
                        Time: 15:17:48
                        Reset counter: 162
                        Mileage: 71133 km
                        Time: 11:56:43
                        Reset counter: 173
                        Mileage: 71133 km
                        Time: 12:10:07
                        Reset counter: 173
                        Mileage: 71133 km
                        Time: 12:19:42
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 UM
       Component: Haldex 4Motion      0154
       VCID: 0C1784D46F39E422D8-8058
       Component: IMMO            VDD 1216
    01176 - Key
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 387F08044B2138824C-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.141 H08 1901
       Shop #: WSC 00000 028 00001
                        Mileage: 73710 km
                        Temperature: 73.0C
                        Voltage: 12.50 V
                        Voltage: 12.30 V
       Coding: 139006885103281B0904058FB0080A04889C00
       VCID: 0407ACF44769AC6290-8050
                        Reset counter: 148
    Address 47: Sound System        Labels: 3C0-035-456.lbl
       Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
       Component: 08K Audioverst.     0006
       Revision: 00004000    Serial number: 00000008130038
       VCID: 2B5527488A77831A31-807E
       Coding: 0001076
       VCID: 39790D00702B218AB3-806C
       Part No: 1T0 907 357
       Coding: 0000004
       VCID: 74E7FC3417C99CE2A0-8020
    Address 56: Radio
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Fault Status: 00111000
                        Reset counter: 148
                        Mileage: 69703 km
    End-------------------------(Elapsed Time: 02:19)--------------------------
    Feb 2015
    With the parking brake on and engine running the inner FTP will come on when pulling back stalk, they will also come on with parking brake off and engine off. They will not come on if your HIDs are on. This is in original NAR setup.
  3. Likes Uwe liked this post
