Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: '14 Touareg: 3 blinks or 5?
    Stoke on Trent, England
    Quote Originally Posted by flygteye View Post
    I had a 2013 Tiguan and this is how I did it.....
    Central Electronics > Adaptation > “comfort turn signals (cycles)”
    Enter the number of blinks you want (3-5) and save them.
    The strange thing I've noticed with VCDS if you type numbers into the textboxes the Save button doesn't get enabled you have to use the up/down arrow buttons to select the new value then the Save button is enabled.
    New User Keith
  2. #12
    When performing Adaptations on a non-UDS module, if you type values in, you have to click [Test] before [Save] is enabled.
    Jun 2014
    Sorry it took so long, but I just emailed the .PLA and .PLB files in. Plus an AutoScan.
    Does anyone know what's the next step in the process?
  4. #14
    Aug 2014
    hallo Makva,
    with VCDS you can change the blinks from 3 to 5, if you done this than start the car and go to the MFA menu, look for the light and comfort and scroll down till you see "Factory Settings" click it after this your turn signals will work 5 times instead of 3 times.
  5. #15
    United States
    Quote Originally Posted by antwerpautoshop View Post
    hallo Makva,
    I don't think the Touareg clusters support that type of Golf based reset but even if it does, it wouldn't apply if an Adaptation channel does not exist for the number of flashes in this BCM.
  6. #16
    United States
    Per the maps that Mark sent:
    ;SW:4H0-907-063-CD   HW:4H0-907-063-D ---  Cent. Elect.
    ;Component:BCM1 2.0      H12 0130, Coding:26001012953C5D010020180300005D0C431C660882010261000000020000
    ;Friday,01,August,2014,18:18:40:40687
    ;VCDS Version: Release 12.12.2 (x64)  Data version: 20140212
    ;VCID: 6CD7DC058F15187E57F-8039
    A01,0,
    ;100
    A01,1,
    A01,2,
    A01,3,
    A01,4,
    ;02 N/A
    A03,0,
    ;9
    A03,1,
    A03,2,
    A03,3,
    ;0.0 %
    A03,4,
    ;0.0 %
    ;04 N/A
    ;05 N/A
    ;06 N/A
    ;07 N/A
    A08,0,
    ;450
    A08,1,
    ;N/A
    A08,2,
    ;N/A
    A08,3,
    ;N/A
    A08,4,
    ;N/A
    A09,0,
    ;500
    A09,1,
    ;N/A
    A09,2,
    ;N/A
    A09,3,
    ;N/A
    A09,4,
    ;N/A
    A10,0,
    ;450
    A10,1,
    ;N/A
    A10,2,
    ;N/A
    A10,3,
    ;N/A
    A10,4,
    ;N/A
    A11,0,
    ;500
    A11,1,
    ;N/A
    A11,2,
    ;N/A
    A11,3,
    ;N/A
    A11,4,
    ;N/A
    A12,0,
    ;120
    A12,1,
    ;N/A
    A12,2,
    ;N/A
    A12,3,
    ;N/A
    A12,4,
    ;N/A
    A13,0,
    ;60
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    A14,0,
    ;15
    A14,1,
    ;N/A
    A14,2,
    ;N/A
    A14,3,
    ;N/A
    A14,4,
    ;N/A
    A15,0,
    ;0
    A15,1,
    ;N/A
    A15,2,
    ;N/A
    A15,3,
    ;N/A
    A15,4,
    ;N/A
    A16,0,
    ;3
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    A17,0,
    ;3
    A17,1,
    ;N/A
    A17,2,
    ;N/A
    A17,3,
    ;N/A
    A17,4,
    ;N/A
    A18,0,
    ;255
    A18,1,
    ;N/A
    A18,2,
    ;N/A
    A18,3,
    ;N/A
    A18,4,
    ;N/A
    A19,0,
    ;17
    A19,1,
    ;N/A
    A19,2,
    ;N/A
    A19,3,
    ;N/A
    A19,4,
    ;N/A
    A20,0,
    ;0
    A20,1,
    ;N/A
    A20,2,
    ;N/A
    A20,3,
    ;N/A
    A20,4,
    ;N/A
    A21,0,
    ;1
    A21,1,
    ;N/A
    A21,2,
    ;N/A
    A21,3,
    ;N/A
    A21,4,
    ;N/A
    A22,0,
    ;1
    A22,1,
    ;N/A
    A22,2,
    ;N/A
    A22,3,
    ;N/A
    A22,4,
    ;N/A
    A23,0,
    ;1
    A23,1,
    ;N/A
    A23,2,
    ;N/A
    A23,3,
    ;N/A
    A23,4,
    ;N/A
    A24,0,
    ;1
    A24,1,
    ;N/A
    A24,2,
    ;N/A
    A24,3,
    ;N/A
    A24,4,
    ;N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    ;30 N/A
    A31,0,
    ;100
    A31,1,
    ;N/A
    A31,2,
    ;N/A
    A31,3,
    ;N/A
    A31,4,
    ;N/A
    A32,0,
    ;1000
    A32,1,
    ;N/A
    A32,2,
    ;N/A
    A32,3,
    ;N/A
    A32,4,
    ;N/A
    A33,0,
    ;4000
    A33,1,
    ;N/A
    A33,2,
    ;N/A
    A33,3,
    ;N/A
    A33,4,
    ;N/A
    A34,0,
    ;4
    A34,1,
    ;N/A
    A34,2,
    ;N/A
    A34,3,
    ;N/A
    A34,4,
    ;N/A
    A35,0,
    ;0
    A35,1,
    ;N/A
    A35,2,
    ;N/A
    A35,3,
    ;N/A
    A35,4,
    ;N/A
    ;36 N/A
    A37,0,
    ;3
    A37,1,
    ;N/A
    A37,2,
    ;N/A
    A37,3,
    ;N/A
    A37,4,
    ;N/A
    ;38 N/A
    ;39 N/A
    ;40 N/A
    A41,0,
    ;1
    A41,1,
    ;N/A
    A41,2,
    ;N/A
    A41,3,
    ;N/A
    A41,4,
    ;N/A
    A42,0,
    ;1
    A42,1,
    ;N/A
    A42,2,
    ;N/A
    A42,3,
    ;N/A
    A42,4,
    ;N/A
    A43,0,
    ;20
    A43,1,
    ;N/A
    A43,2,
    ;N/A
    A43,3,
    ;N/A
    A43,4,
    ;N/A
    A44,0,
    ;1
    A44,1,
    ;N/A
    A44,2,
    ;N/A
    A44,3,
    ;N/A
    A44,4,
    ;N/A
    A45,0,
    ;0
    A45,1,
    ;N/A
    A45,2,
    ;N/A
    A45,3,
    ;N/A
    A45,4,
    ;N/A
    A46,0,
    ;1
    A46,1,
    ;N/A
    A46,2,
    ;N/A
    A46,3,
    ;N/A
    A46,4,
    ;N/A
    A47,0,
    ;1
    A47,1,
    ;N/A
    A47,2,
    ;N/A
    A47,3,
    ;N/A
    A47,4,
    ;N/A
    A48,0,
    ;120
    A48,1,
    ;N/A
    A48,2,
    ;N/A
    A48,3,
    ;N/A
    A48,4,
    ;N/A
    A49,0,
    ;120
    A49,1,
    ;N/A
    A49,2,
    ;N/A
    A49,3,
    ;N/A
    A49,4,
    ;N/A
    A50,0,
    ;120
    A50,1,
    ;N/A
    A50,2,
    ;N/A
    A50,3,
    ;N/A
    A50,4,
    ;N/A
    A51,0,
    ;120
    A51,1,
    ;N/A
    A51,2,
    ;N/A
    A51,3,
    ;N/A
    A51,4,
    ;N/A
    A52,0,
    ;50
    A52,1,
    ;N/A
    A52,2,
    ;N/A
    A52,3,
    ;N/A
    A52,4,
    ;N/A
    A53,0,
    ;0
    A53,1,
    ;N/A
    A53,2,
    ;N/A
    A53,3,
    ;N/A
    A53,4,
    ;N/A
    ;54 N/A
    A55,0,
    ;1
    A55,1,
    ;N/A
    A55,2,
    ;N/A
    A55,3,
    ;N/A
    A55,4,
    ;N/A
    A56,0,
    ;1
    A56,1,
    ;N/A
    A56,2,
    ;N/A
    A56,3,
    ;N/A
    A56,4,
    ;N/A
    A57,0,
    ;0
    A57,1,
    ;N/A
    A57,2,
    ;N/A
    A57,3,
    ;N/A
    A57,4,
    ;N/A
    A58,0,
    ;1
    A58,1,
    ;N/A
    A58,2,
    ;N/A
    A58,3,
    ;N/A
    A58,4,
    ;N/A
    A59,0,
    ;10
    A59,1,
    ;N/A
    A59,2,
    ;N/A
    A59,3,
    ;N/A
    A59,4,
    ;N/A
    A60,0,
    ;1
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    ;61 N/A
    ;62 N/A
    ;63 N/A
    ;64 N/A
    ;65 N/A
    ;66 N/A
    ;67 N/A
    ;68 N/A
    ;69 N/A
    ;70 N/A
    A71,0,
    ;14742
    A71,1,
    ;N/A
    A71,2,
    ;N/A
    A71,3,
    ;N/A
    A71,4,
    ;N/A
    A72,0,
    ;1911
    A72,1,
    ;N/A
    A72,2,
    ;N/A
    A72,3,
    ;N/A
    A72,4,
    ;N/A
    A73,0,
    ;1911
    A73,1,
    ;N/A
    A73,2,
    ;N/A
    A73,3,
    ;N/A
    A73,4,
    ;N/A
    A74,0,
    ;819
    A74,1,
    ;N/A
    A74,2,
    ;N/A
    A74,3,
    ;N/A
    A74,4,
    ;N/A
    A75,0,
    ;1911
    A75,1,
    ;N/A
    A75,2,
    ;N/A
    A75,3,
    ;N/A
    A75,4,
    ;N/A
    A76,0,
    ;14742
    A76,1,
    ;N/A
    A76,2,
    ;N/A
    A76,3,
    ;N/A
    A76,4,
    ;N/A
    A77,0,
    ;10300
    A77,1,
    ;N/A
    A77,2,
    ;N/A
    A77,3,
    ;N/A
    A77,4,
    ;N/A
    A78,0,
    ;0
    A78,1,
    ;N/A
    A78,2,
    ;N/A
    A78,3,
    ;N/A
    A78,4,
    ;N/A
    A79,0,
    ;4728
    A79,1,
    ;N/A
    A79,2,
    ;N/A
    A79,3,
    ;N/A
    A79,4,
    ;N/A
    A80,0,
    ;5752
    A80,1,
    ;N/A
    A80,2,
    ;N/A
    A80,3,
    ;N/A
    A80,4,
    ;N/A
    A81,0,
    ;7680
    A81,1,
    ;N/A
    A81,2,
    ;N/A
    A81,3,
    ;N/A
    A81,4,
    ;N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    ;95 N/A
    ;96 N/A
    ;97 N/A
    ;98 N/A
    ;99 N/A
    A100,0,
    ;26
    A100,1,
    ;N/A
    A100,2,
    ;N/A
    A100,3,
    ;N/A
    A100,4,
    ;N/A
    A101,0,
    ;28
    A101,1,
    ;N/A
    A101,2,
    ;N/A
    A101,3,
    ;N/A
    A101,4,
    ;N/A
    A102,0,
    ;55
    A102,1,
    ;N/A
    A102,2,
    ;N/A
    A102,3,
    ;N/A
    A102,4,
    ;N/A
    A103,0,
    ;57
    A103,1,
    ;N/A
    A103,2,
    ;N/A
    A103,3,
    ;N/A
    A103,4,
    ;N/A
    A104,0,
    ;46
    A104,1,
    ;N/A
    A104,2,
    ;N/A
    A104,3,
    ;N/A
    A104,4,
    ;N/A
    A105,0,
    ;48
    A105,1,
    ;N/A
    A105,2,
    ;N/A
    A105,3,
    ;N/A
    A105,4,
    ;N/A
    A106,0,
    ;69
    A106,1,
    ;N/A
    A106,2,
    ;N/A
    A106,3,
    ;N/A
    A106,4,
    ;N/A
    A107,0,
    ;71
    A107,1,
    ;N/A
    A107,2,
    ;N/A
    A107,3,
    ;N/A
    A107,4,
    ;N/A
    A108,0,
    ;66
    A108,1,
    ;N/A
    A108,2,
    ;N/A
    A108,3,
    ;N/A
    A108,4,
    ;N/A
    A109,0,
    ;68
    A109,1,
    ;N/A
    A109,2,
    ;N/A
    A109,3,
    ;N/A
    A109,4,
    ;N/A
    A110,0,
    ;93
    A110,1,
    ;N/A
    A110,2,
    ;N/A
    A110,3,
    ;N/A
    A110,4,
    ;N/A
    A111,0,
    ;95
    A111,1,
    ;N/A
    A111,2,
    ;N/A
    A111,3,
    ;N/A
    A111,4,
    ;N/A
    ;112 N/A
    ;113 N/A
    ;114 N/A
    ;115 N/A
    ;116 N/A
    ;117 N/A
    ;118 N/A
    ;119 N/A
    ;120 N/A
    A121,0,
    ;10
    A121,1,
    ;N/A
    A121,2,
    ;N/A
    A121,3,
    ;N/A
    A121,4,
    ;N/A
    A122,0,
    ;13
    A122,1,
    ;N/A
    A122,2,
    ;N/A
    A122,3,
    ;N/A
    A122,4,
    ;N/A
    A123,0,
    ;6
    A123,1,
    ;N/A
    A123,2,
    ;N/A
    A123,3,
    ;N/A
    A123,4,
    ;N/A
    A124,0,
    ;20
    A124,1,
    ;N/A
    A124,2,
    ;N/A
    A124,3,
    ;N/A
    A124,4,
    ;N/A
    A125,0,
    ;0
    A125,1,
    ;N/A
    A125,2,
    ;N/A
    A125,3,
    ;N/A
    A125,4,
    ;N/A
    A126,0,
    ;100
    A126,1,
    ;N/A
    A126,2,
    ;N/A
    A126,3,
    ;N/A
    A126,4,
    ;N/A
    ;127 N/A
    A128,0,
    ;0
    A128,1,
    ;N/A
    A128,2,
    ;N/A
    A128,3,
    ;N/A
    A128,4,
    ;N/A
    ;129 N/A
    ;130 N/A
    A131,0,
    ;0
    A131,1,
    ;N/A
    A131,2,
    ;N/A
    A131,3,
    ;N/A
    A131,4,
    ;N/A
    A132,0,
    ;0
    A132,1,
    ;N/A
    A132,2,
    ;N/A
    A132,3,
    ;N/A
    A132,4,
    ;N/A
    A133,0,
    ;0
    A133,1,
    ;N/A
    A133,2,
    ;N/A
    A133,3,
    ;N/A
    A133,4,
    ;N/A
    A134,0,
    ;0
    A134,1,
    ;N/A
    A134,2,
    ;N/A
    A134,3,
    ;N/A
    A134,4,
    ;N/A
    A135,0,
    ;0
    A135,1,
    ;N/A
    A135,2,
    ;N/A
    A135,3,
    ;N/A
    A135,4,
    ;N/A
    A136,0,
    ;0
    A136,1,
    ;N/A
    A136,2,
    ;N/A
    A136,3,
    ;N/A
    A136,4,
    ;N/A
    A137,0,
    ;0
    A137,1,
    ;N/A
    A137,2,
    ;N/A
    A137,3,
    ;N/A
    A137,4,
    ;N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    ;150 N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    ;179 N/A
    ;180 N/A
    ;181 N/A
    ;182 N/A
    ;183 N/A
    ;184 N/A
    ;185 N/A
    ;186 N/A
    ;187 N/A
    ;188 N/A
    ;189 N/A
    ;190 N/A
    ;191 N/A
    ;192 N/A
    ;193 N/A
    ;194 N/A
    ;195 N/A
    ;196 N/A
    ;197 N/A
    ;198 N/A
    ;199 N/A
    ;200 N/A
    ;201 N/A
    ;202 N/A
    ;203 N/A
    ;204 N/A
    ;205 N/A
    ;206 N/A
    ;207 N/A
    ;208 N/A
    ;209 N/A
    ;210 N/A
    ;211 N/A
    ;212 N/A
    ;213 N/A
    ;214 N/A
    ;215 N/A
    ;216 N/A
    ;217 N/A
    ;218 N/A
    ;219 N/A
    ;220 N/A
    ;221 N/A
    ;222 N/A
    ;223 N/A
    ;224 N/A
    ;225 N/A
    ;226 N/A
    ;227 N/A
    ;228 N/A
    ;229 N/A
    ;230 N/A
    ;231 N/A
    ;232 N/A
    ;233 N/A
    ;234 N/A
    ;235 N/A
    ;236 N/A
    ;237 N/A
    ;238 N/A
    ;239 N/A
    ;240 N/A
    ;241 N/A
    ;242 N/A
    ;243 N/A
    ;244 N/A
    ;245 N/A
    ;246 N/A
    ;247 N/A
    ;248 N/A
    ;249 N/A
    A250,0,
    A250,1,
    ;ERROR:
    A250,2,
    ;Security
    A250,3,
    ;access
    A250,4,
    ;required
    ;251 N/A
    ;252 N/A
    ;253 N/A
    A254,0,
    A254,1,
    ;ERROR:
    A254,2,
    ;Security
    A254,3,
    ;access
    A254,4,
    ;required
    A255,0,
    A255,1,
    ;ERROR:
    A255,2,
    ;Security
    A255,3,
    ;access
    A255,4,
    ;required
    Adaptation channels: 016, 017 and 037 contain a stored value of ;3 in #09 / BCM1. Since that control module controls the front exterior lighting and it is not the backdoor to the KESSY/Immobilizer system like #46 / BCM2 I would consider experimenting with those fairly safe - providing you do so one at a time and revert back to the original value if the number of comfort turn signals is not altered.
    ;SW:4H0-907-064-DK   HW:4H0-907-064-DK ---  Central Conv.
    ;Component:BCM2 2.0      H35 0510, Coding:0186163A68B9509580A00620210000000000000000000000000000000000
    ;Friday,01,August,2014,18:23:56:40687
    ;VCID: 75E1F961DC5FD9B6B81-8020
    A01,0,
    ;57315
    A01,1,
    ;N/A
    A01,2,
    ;N/A
    A01,3,
    ;N/A
    A01,4,
    ;N/A
    A02,0,
    ;36963
    A02,1,
    ;N/A
    A02,2,
    ;N/A
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;36963
    A03,1,
    ;N/A
    A03,2,
    ;N/A
    A03,3,
    ;N/A
    A03,4,
    ;N/A
    A04,0,
    ;36963
    A04,1,
    ;N/A
    A04,2,
    ;N/A
    A04,3,
    ;N/A
    A04,4,
    ;N/A
    A05,0,
    ;0
    A05,1,
    ;N/A
    A05,2,
    ;N/A
    A05,3,
    ;N/A
    A05,4,
    ;N/A
    A06,0,
    ;0
    A06,1,
    ;N/A
    A06,2,
    ;N/A
    A06,3,
    ;N/A
    A06,4,
    ;N/A
    A07,0,
    ;0
    A07,1,
    ;N/A
    A07,2,
    ;N/A
    A07,3,
    ;N/A
    A07,4,
    ;N/A
    A08,0,
    ;0
    A08,1,
    ;N/A
    A08,2,
    ;N/A
    A08,3,
    ;N/A
    A08,4,
    ;N/A
    A09,0,
    ;36963
    A09,1,
    ;N/A
    A09,2,
    ;N/A
    A09,3,
    ;N/A
    A09,4,
    ;N/A
    A10,0,
    ;0
    A10,1,
    ;N/A
    A10,2,
    ;N/A
    A10,3,
    ;N/A
    A10,4,
    ;N/A
    ;11 N/A
    ;12 N/A
    A13,0,
    ;87
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    ;14 N/A
    ;15 N/A
    A16,0,
    ;5
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    ;17 N/A
    ;18 N/A
    ;19 N/A
    ;20 N/A
    ;21 N/A
    ;22 N/A
    ;23 N/A
    ;24 N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    A30,0,
    A30,1,
    ;ERROR:
    A30,2,
    ;Security
    A30,3,
    ;access
    A30,4,
    ;required
    ;31 N/A
    ;32 N/A
    ;33 N/A
    ;34 N/A
    ;35 N/A
    ;36 N/A
    ;37 N/A
    ;38 N/A
    ;39 N/A
    ;40 N/A
    ;41 N/A
    ;42 N/A
    ;43 N/A
    ;44 N/A
    ;45 N/A
    ;46 N/A
    ;47 N/A
    ;48 N/A
    ;49 N/A
    ;50 N/A
    ;51 N/A
    ;52 N/A
    ;53 N/A
    ;54 N/A
    ;55 N/A
    ;56 N/A
    ;57 N/A
    ;58 N/A
    ;59 N/A
    A60,0,
    ;0
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    A61,0,
    ;12287
    A61,1,
    ;N/A
    A61,2,
    ;N/A
    A61,3,
    ;N/A
    A61,4,
    ;N/A
    A62,0,
    ;65535
    A62,1,
    ;N/A
    A62,2,
    ;N/A
    A62,3,
    ;N/A
    A62,4,
    ;N/A
    A63,0,
    ;184
    A63,1,
    ;N/A
    A63,2,
    ;N/A
    A63,3,
    ;N/A
    A63,4,
    ;N/A
    A64,0,
    ;40
    A64,1,
    ;N/A
    A64,2,
    ;N/A
    A64,3,
    ;N/A
    A64,4,
    ;N/A
    A65,0,
    ;63
    A65,1,
    ;N/A
    A65,2,
    ;N/A
    A65,3,
    ;N/A
    A65,4,
    ;N/A
    A66,0,
    ;21
    A66,1,
    ;N/A
    A66,2,
    ;N/A
    A66,3,
    ;N/A
    A66,4,
    ;N/A
    A67,0,
    ;6425
    A67,1,
    ;N/A
    A67,2,
    ;N/A
    A67,3,
    ;N/A
    A67,4,
    ;N/A
    A68,0,
    A68,1,
    ;ERROR:
    A68,2,
    ;Security
    A68,3,
    ;access
    A68,4,
    ;required
    A69,0,
    ;0
    A69,1,
    ;N/A
    A69,2,
    ;N/A
    A69,3,
    ;N/A
    A69,4,
    ;N/A
    ;70 N/A
    ;71 N/A
    ;72 N/A
    ;73 N/A
    ;74 N/A
    ;75 N/A
    ;76 N/A
    ;77 N/A
    ;78 N/A
    ;79 N/A
    ;80 N/A
    ;81 N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    A95,0,
    ;3
    A95,1,
    ;N/A
    A95,2,
    ;N/A
    A95,3,
    ;N/A
    A95,4,
    ;N/A
    A96,0,
    ;30
    A96,1,
    ;N/A
    A96,2,
    ;N/A
    A96,3,
    ;N/A
    A96,4,
    ;N/A
    A97,0,
    ;50
    A97,1,
    ;N/A
    A97,2,
    ;N/A
    A97,3,
    ;N/A
    A97,4,
    ;N/A
    A98,0,
    ;1
    A98,1,
    ;N/A
    A98,2,
    ;N/A
    A98,3,
    ;N/A
    A98,4,
    ;N/A
    ;99 N/A
    ;100 N/A
    ;101 N/A
    A102,0,
    ;18477
    A102,1,
    ;N/A
    A102,2,
    ;N/A
    A102,3,
    ;N/A
    A102,4,
    ;N/A
    A103,0,
    ;0
    A103,1,
    ;N/A
    A103,2,
    ;N/A
    A103,3,
    ;N/A
    A103,4,
    ;N/A
    A104,0,
    ;190
    A104,1,
    ;N/A
    A104,2,
    ;N/A
    A104,3,
    ;N/A
    A104,4,
    ;N/A
    A105,0,
    ;22
    A105,1,
    ;N/A
    A105,2,
    ;N/A
    A105,3,
    ;N/A
    A105,4,
    ;N/A
    ;106 N/A
    ;107 N/A
    ;108 N/A
    ;109 N/A
    ;110 N/A
    ;111 N/A
    ;112 N/A
    ;113 N/A
    ;114 N/A
    ;115 N/A
    ;116 N/A
    ;117 N/A
    ;118 N/A
    ;119 N/A
    ;120 N/A
    ;121 N/A
    ;122 N/A
    ;123 N/A
    ;124 N/A
    ;125 N/A
    ;126 N/A
    ;127 N/A
    ;128 N/A
    ;129 N/A
    ;130 N/A
    ;131 N/A
    ;132 N/A
    ;133 N/A
    ;134 N/A
    ;135 N/A
    ;136 N/A
    ;137 N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    A150,0,
    ;0
    A150,1,
    ;N/A
    A150,2,
    ;N/A
    A150,3,
    ;N/A
    A150,4,
    ;N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    A179,0,
    A179,1,
    ;ERROR:
    A179,2,
    ;Security
    A179,3,
    ;access
    A179,4,
    ;required
    A180,0,
    A180,1,
    ;ERROR:
    A180,2,
    ;Security
    A180,3,
    ;access
    A180,4,
    ;required
    A181,0,
    A181,1,
    ;ERROR:
    A181,2,
    ;Security
    A181,3,
    ;access
    A181,4,
    ;required
    A182,0,
    A182,1,
    ;ERROR:
    A182,2,
    ;Security
    A182,3,
    ;access
    A182,4,
    ;required
    A183,0,
    A183,1,
    ;ERROR:
    A183,2,
    ;Security
    A183,3,
    ;access
    A183,4,
    ;required
    A184,0,
    A184,1,
    ;ERROR:
    A184,2,
    ;Security
    A184,3,
    ;access
    A184,4,
    ;required
    A185,0,
    A185,1,
    ;ERROR:
    A185,2,
    ;Security
    A185,3,
    ;access
    A185,4,
    ;required
    A186,0,
    A186,1,
    ;ERROR:
    A186,2,
    ;Security
    A186,3,
    ;access
    A186,4,
    ;required
    A187,0,
    A187,1,
    ;ERROR:
    A187,2,
    ;Security
    A187,3,
    ;access
    A187,4,
    ;required
    A188,0,
    A188,1,
    ;ERROR:
    A188,2,
    ;Security
    A188,3,
    ;access
    A188,4,
    ;required
    A189,0,
    A189,1,
    ;ERROR:
    A189,2,
    ;Security
    A189,3,
    ;access
    A189,4,
    ;required
    A190,0,
    A190,1,
    ;ERROR:
    A190,2,
    ;Security
    A190,3,
    ;access
    A190,4,
    ;required
    A191,0,
    A191,1,
    ;ERROR:
    A191,2,
    ;Security
    A191,3,
    ;access
    A191,4,
    ;required
    A192,0,
    A192,1,
    ;ERROR:
    A192,2,
    ;Security
    A192,3,
    ;access
    A192,4,
    ;required
    A193,0,
    A193,1,
    ;ERROR:
    A193,2,
    ;Security
    A193,3,
    ;access
    A193,4,
    ;required
    A194,0,
    ;7
    A194,1,
    ;N/A
    A194,2,
    ;N/A
    A194,3,
    ;N/A
    A194,4,
    ;N/A
    A195,0,
    A195,1,
    ;ERROR:
    A195,2,
    ;Security
    A195,3,
    ;access
    A195,4,
    ;required
    A196,0,
    A196,1,
    ;ERROR:
    A196,2,
    ;Security
    A196,3,
    ;access
    A196,4,
    ;required
    A197,0,
    A197,1,
    ;ERROR:
    A197,2,
    ;Security
    A197,3,
    ;access
    A197,4,
    ;required
    A198,0,
    A198,1,
    ;ERROR:
    A198,2,
    ;Security
    A198,3,
    ;access
    A198,4,
    ;required
    A199,0,
    A199,1,
    ;ERROR:
    A199,2,
    ;Security
    A199,3,
    ;access
    A199,4,
    ;required
    A200,0,
    A200,1,
    ;ERROR:
    A200,2,
    ;Security
    A200,3,
    ;access
    A200,4,
    ;required
    A201,0,
    A201,1,
    ;ERROR:
    A201,2,
    ;Security
    A201,3,
    ;access
    A201,4,
    ;required
    A202,0,
    A202,1,
    ;ERROR:
    A202,2,
    ;Security
    A202,3,
    ;access
    A202,4,
    ;required
    A203,0,
    A203,1,
    ;ERROR:
    A203,2,
    ;Security
    A203,3,
    ;access
    A203,4,
    ;required
    A204,0,
    A204,1,
    ;ERROR:
    A204,2,
    ;Security
    A204,3,
    ;access
    A204,4,
    ;required
    A205,0,
    A205,1,
    ;ERROR:
    A205,2,
    ;Security
    A205,3,
    ;access
    A205,4,
    ;required
    A206,0,
    A206,1,
    ;ERROR:
    A206,2,
    ;Security
    A206,3,
    ;access
    A206,4,
    ;required
    A207,0,
    A207,1,
    ;ERROR:
    A207,2,
    ;Security
    A207,3,
    ;access
    A207,4,
    ;required
    A208,0,
    A208,1,
    ;ERROR:
    A208,2,
    ;Security
    A208,3,
    ;access
    A208,4,
    ;required
    A209,0,
    A209,1,
    ;ERROR:
    A209,2,
    ;Security
    A209,3,
    ;access
    A209,4,
    ;required
    A210,0,
    A210,1,
    ;ERROR:
    A210,2,
    ;Security
    A210,3,
    ;access
    A210,4,
    ;required
    A211,0,
    A211,1,
    ;ERROR:
    A211,2,
    ;Security
    A211,3,
    ;access
    A211,4,
    ;required
    A212,0,
    A212,1,
    ;ERROR:
    A212,2,
    ;Security
    A212,3,
    ;access
    A212,4,
    ;required
    A213,0,
    A213,1,
    ;ERROR:
    A213,2,
    ;Security
    A213,3,
    ;access
    A213,4,
    ;required
    A214,0,
    A214,1,
    ;ERROR:
    A214,2,
    ;Security
    A214,3,
    ;access
    A214,4,
    ;required
    A215,0,
    A215,1,
    ;ERROR:
    A215,2,
    ;Security
    A215,3,
    ;access
    A215,4,
    ;required
    A216,0,
    A216,1,
    ;ERROR:
    A216,2,
    ;Security
    A216,3,
    ;access
    A216,4,
    ;required
    A217,0,
    A217,1,
    ;ERROR:
    A217,2,
    ;Security
    A217,3,
    ;access
    A217,4,
    ;required
    A218,0,
    A218,1,
    ;ERROR:
    A218,2,
    ;Security
    A218,3,
    ;access
    A218,4,
    ;required
    A219,0,
    A219,1,
    ;ERROR:
    A219,2,
    ;Security
    A219,3,
    ;access
    A219,4,
    ;required
    A220,0,
    A220,1,
    ;ERROR:
    A220,2,
    ;Security
    A220,3,
    ;access
    A220,4,
    ;required
    A221,0,
    A221,1,
    ;ERROR:
    A221,2,
    ;Security
    A221,3,
    ;access
    A221,4,
    ;required
    A222,0,
    A222,1,
    ;ERROR:
    A222,2,
    ;Security
    A222,3,
    ;access
    A222,4,
    ;required
    A223,0,
    A223,1,
    ;ERROR:
    A223,2,
    ;Security
    A223,3,
    ;access
    A223,4,
    ;required
    A224,0,
    A224,1,
    ;ERROR:
    A224,2,
    ;Security
    A224,3,
    ;access
    A224,4,
    ;required
    A225,0,
    A225,1,
    ;ERROR:
    A225,2,
    ;Security
    A225,3,
    ;access
    A225,4,
    ;required
    A226,0,
    A226,1,
    ;ERROR:
    A226,2,
    ;Security
    A226,3,
    ;access
    A226,4,
    ;required
    A227,0,
    A227,1,
    ;ERROR:
    A227,2,
    ;Security
    A227,3,
    ;access
    A227,4,
    ;required
    A228,0,
    A228,1,
    ;ERROR:
    A228,2,
    ;Security
    A228,3,
    ;access
    A228,4,
    ;required
    A229,0,
    A229,1,
    ;ERROR:
    A229,2,
    ;Security
    A229,3,
    ;access
    A229,4,
    ;required
    A230,0,
    A230,1,
    ;ERROR:
    A230,2,
    ;Security
    A230,3,
    ;access
    A230,4,
    ;required
    A231,0,
    A231,1,
    ;ERROR:
    A231,2,
    ;Security
    A231,3,
    ;access
    A231,4,
    ;required
    A232,0,
    A232,1,
    ;ERROR:
    A232,2,
    ;Security
    A232,3,
    ;access
    A232,4,
    ;required
    A233,0,
    A233,1,
    ;ERROR:
    A233,2,
    ;Security
    A233,3,
    ;access
    A233,4,
    ;required
    A234,0,
    A234,1,
    ;ERROR:
    A234,2,
    ;Security
    A234,3,
    ;access
    A234,4,
    ;required
    A235,0,
    A235,1,
    ;ERROR:
    A235,2,
    ;Security
    A235,3,
    ;access
    A235,4,
    ;required
    A236,0,
    A236,1,
    ;ERROR:
    A236,2,
    ;Security
    A236,3,
    ;access
    A236,4,
    ;required
    A237,0,
    A237,1,
    ;ERROR:
    A237,2,
    ;Security
    A237,3,
    ;access
    A237,4,
    ;required
    A238,0,
    A238,1,
    ;ERROR:
    A238,2,
    ;Security
    A238,3,
    ;access
    A238,4,
    ;required
    A239,0,
    A239,1,
    ;ERROR:
    A239,2,
    ;Security
    A239,3,
    ;access
    A239,4,
    ;required
    A240,0,
    A240,1,
    ;ERROR:
    A240,2,
    ;Security
    A240,3,
    ;access
    A240,4,
    ;required
    A241,0,
    A241,1,
    ;ERROR:
    A241,2,
    ;Security
    A241,3,
    ;access
    A241,4,
    ;required
    A242,0,
    A242,1,
    ;ERROR:
    A242,2,
    ;Security
    A242,3,
    ;access
    A242,4,
    ;required
    A243,0,
    A243,1,
    ;ERROR:
    A243,2,
    ;Security
    A243,3,
    ;access
    A243,4,
    ;required
    A244,0,
    A244,1,
    ;ERROR:
    A244,2,
    ;Security
    A244,3,
    ;access
    A244,4,
    ;required
    A245,0,
    A245,1,
    ;ERROR:
    A245,2,
    ;Security
    A245,3,
    ;access
    A245,4,
    ;required
    A246,0,
    A246,1,
    ;ERROR:
    A246,2,
    ;Security
    A246,3,
    ;access
    A246,4,
    ;required
    A247,0,
    A247,1,
    ;ERROR:
    A247,2,
    ;Security
    A247,3,
    ;access
    A247,4,
    ;required
    ;248 N/A
    ;249 N/A
    ;250 N/A
    ;251 N/A
    ;252 N/A
    ;253 N/A
    ;254 N/A
    ;255 N/A
    BCM2 on the other hand has a stored value of ;3 in Adaptation channel 095. #46 / BCM2 supports the ability to completely enable and/or disable Highway/Comfort Turn Signals per each ignition key personalization Adaptation function so those may be worth tinkering with but please be aware - this is 100% experimental!
    You may want to search around in some of the Audi forums to see if anyone with a 2008+ B8 or better Audi had has any success before tinkering with this brand new T'reg.
  7. Likes Uwe, jakematic liked this post
  8. #17
    May 2014
    CO, USA
    Interestingly, in my '14 S6, the similar BCM1 only has of those channels 016 and 037 defaulting to 3:
    ;SW:4H0-907-063-CG   HW:4H0-907-063 ---  Cent. Elect.
    ;Component:BCM1 2.0      H12 0130, Coding:09072091073C9FE2A90008C4A0003800CF9CD208A20802218001085C7B00
    ;Monday,04,August,2014,21:11:36:20148
    ;VCDS Version: Beta 14.7.2 (x64)  Data version: 20140714
    ;VCID: EFAE93133ED33842EA-80BA
    A01,0,
    ;100
    A01,1,
    ;26.0 %
    A01,2,
    ;26.0 %
    A01,3,
    ;0.0 %
    A01,4,
    ;0.0 %
    A02,0,
    ;100
    A02,1,
    ;100.0 %
    A02,2,
    ;100.0 %
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;26
    A03,1,
    ;26.0 %
    A03,2,
    ;26.0 %
    A03,3,
    ;0.0 %
    A03,4,
    ;0.0 %
    ;04 N/A
    ;05 N/A
    ;06 N/A
    ;07 N/A
    ;08 N/A
    ;09 N/A
    ;10 N/A
    ;11 N/A
    A12,0,
    ;120
    A12,1,
    ;N/A
    A12,2,
    ;N/A
    A12,3,
    ;N/A
    A12,4,
    ;N/A
    A13,0,
    ;60
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    A14,0,
    ;15
    A14,1,
    ;N/A
    A14,2,
    ;N/A
    A14,3,
    ;N/A
    A14,4,
    ;N/A
    A15,0,
    ;0
    A15,1,
    ;N/A
    A15,2,
    ;N/A
    A15,3,
    ;N/A
    A15,4,
    ;N/A
    A16,0,
    ;3
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    A17,0,
    ;15
    A17,1,
    ;N/A
    A17,2,
    ;N/A
    A17,3,
    ;N/A
    A17,4,
    ;N/A
    A18,0,
    ;255
    A18,1,
    ;N/A
    A18,2,
    ;N/A
    A18,3,
    ;N/A
    A18,4,
    ;N/A
    A19,0,
    ;1
    A19,1,
    ;N/A
    A19,2,
    ;N/A
    A19,3,
    ;N/A
    A19,4,
    ;N/A
    A20,0,
    ;1
    A20,1,
    ;N/A
    A20,2,
    ;N/A
    A20,3,
    ;N/A
    A20,4,
    ;N/A
    A21,0,
    ;1
    A21,1,
    ;N/A
    A21,2,
    ;N/A
    A21,3,
    ;N/A
    A21,4,
    ;N/A
    A22,0,
    ;1
    A22,1,
    ;N/A
    A22,2,
    ;N/A
    A22,3,
    ;N/A
    A22,4,
    ;N/A
    A23,0,
    ;1
    A23,1,
    ;N/A
    A23,2,
    ;N/A
    A23,3,
    ;N/A
    A23,4,
    ;N/A
    A24,0,
    ;1
    A24,1,
    ;N/A
    A24,2,
    ;N/A
    A24,3,
    ;N/A
    A24,4,
    ;N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    ;30 N/A
    A31,0,
    ;100
    A31,1,
    ;N/A
    A31,2,
    ;N/A
    A31,3,
    ;N/A
    A31,4,
    ;N/A
    A32,0,
    ;1000
    A32,1,
    ;N/A
    A32,2,
    ;N/A
    A32,3,
    ;N/A
    A32,4,
    ;N/A
    A33,0,
    ;4000
    A33,1,
    ;N/A
    A33,2,
    ;N/A
    A33,3,
    ;N/A
    A33,4,
    ;N/A
    A34,0,
    ;52
    A34,1,
    ;N/A
    A34,2,
    ;N/A
    A34,3,
    ;N/A
    A34,4,
    ;N/A
    ;35 N/A
    ;36 N/A
    A37,0,
    ;3
    A37,1,
    ;N/A
    A37,2,
    ;N/A
    A37,3,
    ;N/A
    A37,4,
    ;N/A
    ;38 N/A
    ;39 N/A
    A40,0,
    ;117
    A40,1,
    ;31.0C
    A40,2,
    ;OFF
    A40,3,
    ;N/A
    A40,4,
    ;N/A
    A41,0,
    ;1
    A41,1,
    ;N/A
    A41,2,
    ;N/A
    A41,3,
    ;N/A
    A41,4,
    ;N/A
    A42,0,
    ;1
    A42,1,
    ;N/A
    A42,2,
    ;N/A
    A42,3,
    ;N/A
    A42,4,
    ;N/A
    A43,0,
    ;20
    A43,1,
    ;N/A
    A43,2,
    ;N/A
    A43,3,
    ;N/A
    A43,4,
    ;N/A
    A44,0,
    ;1
    A44,1,
    ;N/A
    A44,2,
    ;N/A
    A44,3,
    ;N/A
    A44,4,
    ;N/A
    A45,0,
    ;0
    A45,1,
    ;N/A
    A45,2,
    ;N/A
    A45,3,
    ;N/A
    A45,4,
    ;N/A
    A46,0,
    ;1
    A46,1,
    ;N/A
    A46,2,
    ;N/A
    A46,3,
    ;N/A
    A46,4,
    ;N/A
    A47,0,
    ;1
    A47,1,
    ;N/A
    A47,2,
    ;N/A
    A47,3,
    ;N/A
    A47,4,
    ;N/A
    A48,0,
    ;10
    A48,1,
    ;N/A
    A48,2,
    ;N/A
    A48,3,
    ;N/A
    A48,4,
    ;N/A
    A49,0,
    ;10
    A49,1,
    ;N/A
    A49,2,
    ;N/A
    A49,3,
    ;N/A
    A49,4,
    ;N/A
    A50,0,
    ;120
    A50,1,
    ;N/A
    A50,2,
    ;N/A
    A50,3,
    ;N/A
    A50,4,
    ;N/A
    A51,0,
    ;120
    A51,1,
    ;N/A
    A51,2,
    ;N/A
    A51,3,
    ;N/A
    A51,4,
    ;N/A
    A52,0,
    ;120
    A52,1,
    ;N/A
    A52,2,
    ;N/A
    A52,3,
    ;N/A
    A52,4,
    ;N/A
    A53,0,
    ;0
    A53,1,
    ;N/A
    A53,2,
    ;N/A
    A53,3,
    ;N/A
    A53,4,
    ;N/A
    ;54 N/A
    A55,0,
    ;1
    A55,1,
    ;N/A
    A55,2,
    ;N/A
    A55,3,
    ;N/A
    A55,4,
    ;N/A
    A56,0,
    ;1
    A56,1,
    ;N/A
    A56,2,
    ;N/A
    A56,3,
    ;N/A
    A56,4,
    ;N/A
    A57,0,
    ;1
    A57,1,
    ;N/A
    A57,2,
    ;N/A
    A57,3,
    ;N/A
    A57,4,
    ;N/A
    A58,0,
    ;1
    A58,1,
    ;N/A
    A58,2,
    ;N/A
    A58,3,
    ;N/A
    A58,4,
    ;N/A
    A59,0,
    ;60
    A59,1,
    ;N/A
    A59,2,
    ;N/A
    A59,3,
    ;N/A
    A59,4,
    ;N/A
    A60,0,
    ;1
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    ;61 N/A
    ;62 N/A
    A63,0,
    ;0
    A63,1,
    ;N/A
    A63,2,
    ;N/A
    A63,3,
    ;N/A
    A63,4,
    ;N/A
    A64,0,
    ;218
    A64,1,
    ;N/A
    A64,2,
    ;N/A
    A64,3,
    ;N/A
    A64,4,
    ;N/A
    A65,0,
    ;0
    A65,1,
    ;N/A
    A65,2,
    ;N/A
    A65,3,
    ;N/A
    A65,4,
    ;N/A
    A66,0,
    ;15
    A66,1,
    ;N/A
    A66,2,
    ;N/A
    A66,3,
    ;N/A
    A66,4,
    ;N/A
    A67,0,
    ;2
    A67,1,
    ;N/A
    A67,2,
    ;N/A
    A67,3,
    ;N/A
    A67,4,
    ;N/A
    A68,0,
    ;2
    A68,1,
    ;N/A
    A68,2,
    ;N/A
    A68,3,
    ;N/A
    A68,4,
    ;N/A
    A69,0,
    ;600
    A69,1,
    ;N/A
    A69,2,
    ;N/A
    A69,3,
    ;N/A
    A69,4,
    ;N/A
    A70,0,
    ;14
    A70,1,
    ;N/A
    A70,2,
    ;N/A
    A70,3,
    ;N/A
    A70,4,
    ;N/A
    A71,0,
    ;14805
    A71,1,
    ;N/A
    A71,2,
    ;N/A
    A71,3,
    ;N/A
    A71,4,
    ;N/A
    A72,0,
    ;2366
    A72,1,
    ;N/A
    A72,2,
    ;N/A
    A72,3,
    ;N/A
    A72,4,
    ;N/A
    A73,0,
    ;1974
    A73,1,
    ;N/A
    A73,2,
    ;N/A
    A73,3,
    ;N/A
    A73,4,
    ;N/A
    A74,0,
    ;1610
    A74,1,
    ;N/A
    A74,2,
    ;N/A
    A74,3,
    ;N/A
    A74,4,
    ;N/A
    A75,0,
    ;1974
    A75,1,
    ;N/A
    A75,2,
    ;N/A
    A75,3,
    ;N/A
    A75,4,
    ;N/A
    A76,0,
    ;11739
    A76,1,
    ;N/A
    A76,2,
    ;N/A
    A76,3,
    ;N/A
    A76,4,
    ;N/A
    A77,0,
    ;10814
    A77,1,
    ;N/A
    A77,2,
    ;N/A
    A77,3,
    ;N/A
    A77,4,
    ;N/A
    A78,0,
    ;0
    A78,1,
    ;N/A
    A78,2,
    ;N/A
    A78,3,
    ;N/A
    A78,4,
    ;N/A
    A79,0,
    ;3604
    A79,1,
    ;N/A
    A79,2,
    ;N/A
    A79,3,
    ;N/A
    A79,4,
    ;N/A
    A80,0,
    ;5160
    A80,1,
    ;N/A
    A80,2,
    ;N/A
    A80,3,
    ;N/A
    A80,4,
    ;N/A
    A81,0,
    ;7168
    A81,1,
    ;N/A
    A81,2,
    ;N/A
    A81,3,
    ;N/A
    A81,4,
    ;N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    A90,0,
    ;25
    A90,1,
    ;N/A
    A90,2,
    ;N/A
    A90,3,
    ;N/A
    A90,4,
    ;N/A
    ;91 N/A
    A92,0,
    ;4369
    A92,1,
    ;N/A
    A92,2,
    ;N/A
    A92,3,
    ;N/A
    A92,4,
    ;N/A
    A93,0,
    ;24929
    A93,1,
    ;N/A
    A93,2,
    ;N/A
    A93,3,
    ;N/A
    A93,4,
    ;N/A
    A94,0,
    ;25680
    A94,1,
    ;N/A
    A94,2,
    ;N/A
    A94,3,
    ;N/A
    A94,4,
    ;N/A
    A95,0,
    ;127
    A95,1,
    ;N/A
    A95,2,
    ;N/A
    A95,3,
    ;N/A
    A95,4,
    ;N/A
    A96,0,
    ;12870
    A96,1,
    ;N/A
    A96,2,
    ;N/A
    A96,3,
    ;N/A
    A96,4,
    ;N/A
    A97,0,
    ;57575
    A97,1,
    ;N/A
    A97,2,
    ;N/A
    A97,3,
    ;N/A
    A97,4,
    ;N/A
    A98,0,
    ;768
    A98,1,
    ;N/A
    A98,2,
    ;N/A
    A98,3,
    ;N/A
    A98,4,
    ;N/A
    A99,0,
    ;2063
    A99,1,
    ;N/A
    A99,2,
    ;N/A
    A99,3,
    ;N/A
    A99,4,
    ;N/A
    ;100 N/A
    ;101 N/A
    ;102 N/A
    ;103 N/A
    ;104 N/A
    ;105 N/A
    ;106 N/A
    ;107 N/A
    ;108 N/A
    ;109 N/A
    ;110 N/A
    ;111 N/A
    ;112 N/A
    ;113 N/A
    A114,0,
    ;0
    A114,1,
    ;N/A
    A114,2,
    ;N/A
    A114,3,
    ;N/A
    A114,4,
    ;N/A
    A115,0,
    ;110
    A115,1,
    ;N/A
    A115,2,
    ;N/A
    A115,3,
    ;N/A
    A115,4,
    ;N/A
    A116,0,
    ;140
    A116,1,
    ;N/A
    A116,2,
    ;N/A
    A116,3,
    ;N/A
    A116,4,
    ;N/A
    A117,0,
    ;100
    A117,1,
    ;N/A
    A117,2,
    ;N/A
    A117,3,
    ;N/A
    A117,4,
    ;N/A
    A118,0,
    ;20
    A118,1,
    ;N/A
    A118,2,
    ;N/A
    A118,3,
    ;N/A
    A118,4,
    ;N/A
    A119,0,
    ;1
    A119,1,
    ;N/A
    A119,2,
    ;N/A
    A119,3,
    ;N/A
    A119,4,
    ;N/A
    A120,0,
    ;0
    A120,1,
    ;N/A
    A120,2,
    ;N/A
    A120,3,
    ;N/A
    A120,4,
    ;N/A
    A121,0,
    ;10
    A121,1,
    ;N/A
    A121,2,
    ;N/A
    A121,3,
    ;N/A
    A121,4,
    ;N/A
    A122,0,
    ;0
    A122,1,
    ;N/A
    A122,2,
    ;N/A
    A122,3,
    ;N/A
    A122,4,
    ;N/A
    A123,0,
    ;10
    A123,1,
    ;N/A
    A123,2,
    ;N/A
    A123,3,
    ;N/A
    A123,4,
    ;N/A
    A124,0,
    ;20
    A124,1,
    ;N/A
    A124,2,
    ;N/A
    A124,3,
    ;N/A
    A124,4,
    ;N/A
    A125,0,
    ;0
    A125,1,
    ;N/A
    A125,2,
    ;N/A
    A125,3,
    ;N/A
    A125,4,
    ;N/A
    A126,0,
    ;200
    A126,1,
    ;N/A
    A126,2,
    ;N/A
    A126,3,
    ;N/A
    A126,4,
    ;N/A
    ;127 N/A
    A128,0,
    ;30
    A128,1,
    ;N/A
    A128,2,
    ;N/A
    A128,3,
    ;N/A
    A128,4,
    ;N/A
    ;129 N/A
    ;130 N/A
    A131,0,
    ;50
    A131,1,
    ;N/A
    A131,2,
    ;N/A
    A131,3,
    ;N/A
    A131,4,
    ;N/A
    A132,0,
    ;60
    A132,1,
    ;N/A
    A132,2,
    ;N/A
    A132,3,
    ;N/A
    A132,4,
    ;N/A
    A133,0,
    ;3
    A133,1,
    ;N/A
    A133,2,
    ;N/A
    A133,3,
    ;N/A
    A133,4,
    ;N/A
    A134,0,
    ;200
    A134,1,
    ;N/A
    A134,2,
    ;N/A
    A134,3,
    ;N/A
    A134,4,
    ;N/A
    A135,0,
    ;200
    A135,1,
    ;N/A
    A135,2,
    ;N/A
    A135,3,
    ;N/A
    A135,4,
    ;N/A
    A136,0,
    ;200
    A136,1,
    ;N/A
    A136,2,
    ;N/A
    A136,3,
    ;N/A
    A136,4,
    ;N/A
    A137,0,
    ;200
    A137,1,
    ;N/A
    A137,2,
    ;N/A
    A137,3,
    ;N/A
    A137,4,
    ;N/A
    ;138 N/A
    ;139 N/A
    ;140 N/A
    ;141 N/A
    ;142 N/A
    ;143 N/A
    ;144 N/A
    ;145 N/A
    ;146 N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    ;150 N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    ;179 N/A
    ;180 N/A
    ;181 N/A
    ;182 N/A
    ;183 N/A
    ;184 N/A
    ;185 N/A
    ;186 N/A
    ;187 N/A
    ;188 N/A
    ;189 N/A
    ;190 N/A
    ;191 N/A
    ;192 N/A
    ;193 N/A
    ;194 N/A
    ;195 N/A
    ;196 N/A
    ;197 N/A
    ;198 N/A
    ;199 N/A
    ;200 N/A
    ;201 N/A
    ;202 N/A
    ;203 N/A
    ;204 N/A
    ;205 N/A
    ;206 N/A
    ;207 N/A
    ;208 N/A
    ;209 N/A
    ;210 N/A
    ;211 N/A
    ;212 N/A
    ;213 N/A
    ;214 N/A
    ;215 N/A
    ;216 N/A
    ;217 N/A
    ;218 N/A
    ;219 N/A
    ;220 N/A
    ;221 N/A
    ;222 N/A
    ;223 N/A
    ;224 N/A
    ;225 N/A
    ;226 N/A
    ;227 N/A
    ;228 N/A
    ;229 N/A
    ;230 N/A
    ;231 N/A
    ;232 N/A
    ;233 N/A
    ;234 N/A
    ;235 N/A
    ;236 N/A
    ;237 N/A
    ;238 N/A
    ;239 N/A
    ;240 N/A
    ;241 N/A
    ;242 N/A
    ;243 N/A
    ;244 N/A
    ;245 N/A
    ;246 N/A
    ;247 N/A
    ;248 N/A
    ;249 N/A
    A250,0,
    A250,1,
    ;ERROR:
    A250,2,
    ;Security
    A250,3,
    ;access
    A250,4,
    ;required
    ;251 N/A
    ;252 N/A
    ;253 N/A
    A254,0,
    A254,1,
    ;ERROR:
    A254,2,
    ;Security
    A254,3,
    ;access
    A254,4,
    ;required
    A255,0,
    A255,1,
    ;ERROR:
    A255,2,
    ;Security
    A255,3,
    ;access
    A255,4,
    ;required
    016 only tests for 0..3, and 5 seems like the common max in other cars, either way it won't take 5
    037 is listed as "Ambient Light Threshold Coming/Leaving Home" in the 14.7.2 label file set so I doubt that's it.
    My similar revision BCM2 *also* has 3 in 095:
    ;SW:4H0-907-064-ER   HW:4H0-907-064-ER ---  Central Conv.
    ;Component:BCM2 2.0      H36 0521, Coding:0106063A00FA418580B0088002070E000000000000000000000000000000
    ;Monday,25,August,2014,21:25:09:20148
    ;VCID: FDB2B95B64BF5AD268-80A8
    A01,0,
    ;53344
    A01,1,
    ;N/A
    A01,2,
    ;N/A
    A01,3,
    ;N/A
    A01,4,
    ;N/A
    A02,0,
    ;57312
    A02,1,
    ;N/A
    A02,2,
    ;N/A
    A02,3,
    ;N/A
    A02,4,
    ;N/A
    A03,0,
    ;36961
    A03,1,
    ;N/A
    A03,2,
    ;N/A
    A03,3,
    ;N/A
    A03,4,
    ;N/A
    A04,0,
    ;36961
    A04,1,
    ;N/A
    A04,2,
    ;N/A
    A04,3,
    ;N/A
    A04,4,
    ;N/A
    A05,0,
    ;0
    A05,1,
    ;N/A
    A05,2,
    ;N/A
    A05,3,
    ;N/A
    A05,4,
    ;N/A
    A06,0,
    ;0
    A06,1,
    ;N/A
    A06,2,
    ;N/A
    A06,3,
    ;N/A
    A06,4,
    ;N/A
    A07,0,
    ;0
    A07,1,
    ;N/A
    A07,2,
    ;N/A
    A07,3,
    ;N/A
    A07,4,
    ;N/A
    A08,0,
    ;0
    A08,1,
    ;N/A
    A08,2,
    ;N/A
    A08,3,
    ;N/A
    A08,4,
    ;N/A
    A09,0,
    ;36961
    A09,1,
    ;N/A
    A09,2,
    ;N/A
    A09,3,
    ;N/A
    A09,4,
    ;N/A
    A10,0,
    ;0
    A10,1,
    ;N/A
    A10,2,
    ;N/A
    A10,3,
    ;N/A
    A10,4,
    ;N/A
    ;11 N/A
    ;12 N/A
    A13,0,
    ;87
    A13,1,
    ;N/A
    A13,2,
    ;N/A
    A13,3,
    ;N/A
    A13,4,
    ;N/A
    ;14 N/A
    ;15 N/A
    A16,0,
    ;5
    A16,1,
    ;N/A
    A16,2,
    ;N/A
    A16,3,
    ;N/A
    A16,4,
    ;N/A
    ;17 N/A
    ;18 N/A
    ;19 N/A
    ;20 N/A
    ;21 N/A
    ;22 N/A
    ;23 N/A
    ;24 N/A
    ;25 N/A
    ;26 N/A
    ;27 N/A
    ;28 N/A
    ;29 N/A
    A30,0,
    A30,1,
    ;ERROR:
    A30,2,
    ;Security
    A30,3,
    ;access
    A30,4,
    ;required
    ;31 N/A
    ;32 N/A
    ;33 N/A
    ;34 N/A
    ;35 N/A
    ;36 N/A
    ;37 N/A
    ;38 N/A
    ;39 N/A
    ;40 N/A
    ;41 N/A
    ;42 N/A
    ;43 N/A
    ;44 N/A
    ;45 N/A
    ;46 N/A
    ;47 N/A
    ;48 N/A
    ;49 N/A
    ;50 N/A
    ;51 N/A
    ;52 N/A
    ;53 N/A
    ;54 N/A
    ;55 N/A
    ;56 N/A
    ;57 N/A
    ;58 N/A
    ;59 N/A
    A60,0,
    ;15
    A60,1,
    ;N/A
    A60,2,
    ;N/A
    A60,3,
    ;N/A
    A60,4,
    ;N/A
    A61,0,
    ;12287
    A61,1,
    ;N/A
    A61,2,
    ;N/A
    A61,3,
    ;N/A
    A61,4,
    ;N/A
    A62,0,
    ;65535
    A62,1,
    ;N/A
    A62,2,
    ;N/A
    A62,3,
    ;N/A
    A62,4,
    ;N/A
    A63,0,
    ;168
    A63,1,
    ;N/A
    A63,2,
    ;N/A
    A63,3,
    ;N/A
    A63,4,
    ;N/A
    A64,0,
    ;40
    A64,1,
    ;N/A
    A64,2,
    ;N/A
    A64,3,
    ;N/A
    A64,4,
    ;N/A
    A65,0,
    ;63
    A65,1,
    ;N/A
    A65,2,
    ;N/A
    A65,3,
    ;N/A
    A65,4,
    ;N/A
    A66,0,
    ;21
    A66,1,
    ;N/A
    A66,2,
    ;N/A
    A66,3,
    ;N/A
    A66,4,
    ;N/A
    A67,0,
    ;6425
    A67,1,
    ;N/A
    A67,2,
    ;N/A
    A67,3,
    ;N/A
    A67,4,
    ;N/A
    A68,0,
    A68,1,
    ;ERROR:
    A68,2,
    ;Security
    A68,3,
    ;access
    A68,4,
    ;required
    A69,0,
    ;0
    A69,1,
    ;N/A
    A69,2,
    ;N/A
    A69,3,
    ;N/A
    A69,4,
    ;N/A
    A70,0,
    ;0
    A70,1,
    ;N/A
    A70,2,
    ;N/A
    A70,3,
    ;N/A
    A70,4,
    ;N/A
    ;71 N/A
    A72,0,
    ;25600
    A72,1,
    ;N/A
    A72,2,
    ;N/A
    A72,3,
    ;N/A
    A72,4,
    ;N/A
    A73,0,
    ;25700
    A73,1,
    ;N/A
    A73,2,
    ;N/A
    A73,3,
    ;N/A
    A73,4,
    ;N/A
    A74,0,
    ;25700
    A74,1,
    ;N/A
    A74,2,
    ;N/A
    A74,3,
    ;N/A
    A74,4,
    ;N/A
    A75,0,
    ;12830
    A75,1,
    ;N/A
    A75,2,
    ;N/A
    A75,3,
    ;N/A
    A75,4,
    ;N/A
    A76,0,
    ;0
    A76,1,
    ;N/A
    A76,2,
    ;N/A
    A76,3,
    ;N/A
    A76,4,
    ;N/A
    A77,0,
    ;50
    A77,1,
    ;N/A
    A77,2,
    ;N/A
    A77,3,
    ;N/A
    A77,4,
    ;N/A
    ;78 N/A
    ;79 N/A
    ;80 N/A
    ;81 N/A
    ;82 N/A
    ;83 N/A
    ;84 N/A
    ;85 N/A
    ;86 N/A
    ;87 N/A
    ;88 N/A
    ;89 N/A
    ;90 N/A
    ;91 N/A
    ;92 N/A
    ;93 N/A
    ;94 N/A
    A95,0,
    ;3
    A95,1,
    ;N/A
    A95,2,
    ;N/A
    A95,3,
    ;N/A
    A95,4,
    ;N/A
    A96,0,
    ;30
    A96,1,
    ;N/A
    A96,2,
    ;N/A
    A96,3,
    ;N/A
    A96,4,
    ;N/A
    A97,0,
    ;50
    A97,1,
    ;N/A
    A97,2,
    ;N/A
    A97,3,
    ;N/A
    A97,4,
    ;N/A
    A98,0,
    ;1
    A98,1,
    ;N/A
    A98,2,
    ;N/A
    A98,3,
    ;N/A
    A98,4,
    ;N/A
    ;99 N/A
    ;100 N/A
    ;101 N/A
    A102,0,
    A102,1,
    ;ERROR:
    A102,2,
    ;Security
    A102,3,
    ;access
    A102,4,
    ;required
    A103,0,
    ;0
    A103,1,
    ;N/A
    A103,2,
    ;N/A
    A103,3,
    ;N/A
    A103,4,
    ;N/A
    A104,0,
    ;190
    A104,1,
    ;N/A
    A104,2,
    ;N/A
    A104,3,
    ;N/A
    A104,4,
    ;N/A
    A105,0,
    ;22
    A105,1,
    ;N/A
    A105,2,
    ;N/A
    A105,3,
    ;N/A
    A105,4,
    ;N/A
    ;106 N/A
    ;107 N/A
    ;108 N/A
    ;109 N/A
    A110,0,
    ;16
    A110,1,
    ;N/A
    A110,2,
    ;N/A
    A110,3,
    ;N/A
    A110,4,
    ;N/A
    A111,0,
    ;16
    A111,1,
    ;N/A
    A111,2,
    ;N/A
    A111,3,
    ;N/A
    A111,4,
    ;N/A
    A112,0,
    ;16
    A112,1,
    ;N/A
    A112,2,
    ;N/A
    A112,3,
    ;N/A
    A112,4,
    ;N/A
    A113,0,
    ;16
    A113,1,
    ;N/A
    A113,2,
    ;N/A
    A113,3,
    ;N/A
    A113,4,
    ;N/A
    A114,0,
    ;16
    A114,1,
    ;N/A
    A114,2,
    ;N/A
    A114,3,
    ;N/A
    A114,4,
    ;N/A
    A115,0,
    ;16
    A115,1,
    ;N/A
    A115,2,
    ;N/A
    A115,3,
    ;N/A
    A115,4,
    ;N/A
    A116,0,
    ;16
    A116,1,
    ;N/A
    A116,2,
    ;N/A
    A116,3,
    ;N/A
    A116,4,
    ;N/A
    A117,0,
    ;16
    A117,1,
    ;N/A
    A117,2,
    ;N/A
    A117,3,
    ;N/A
    A117,4,
    ;N/A
    A118,0,
    ;16
    A118,1,
    ;N/A
    A118,2,
    ;N/A
    A118,3,
    ;N/A
    A118,4,
    ;N/A
    A119,0,
    ;16
    A119,1,
    ;N/A
    A119,2,
    ;N/A
    A119,3,
    ;N/A
    A119,4,
    ;N/A
    A120,0,
    ;0
    A120,1,
    ;N/A
    A120,2,
    ;N/A
    A120,3,
    ;N/A
    A120,4,
    ;N/A
    A121,0,
    ;64
    A121,1,
    ;N/A
    A121,2,
    ;N/A
    A121,3,
    ;N/A
    A121,4,
    ;N/A
    A122,0,
    ;2
    A122,1,
    ;N/A
    A122,2,
    ;N/A
    A122,3,
    ;N/A
    A122,4,
    ;N/A
    A123,0,
    ;31
    A123,1,
    ;N/A
    A123,2,
    ;N/A
    A123,3,
    ;N/A
    A123,4,
    ;N/A
    A124,0,
    ;0
    A124,1,
    ;N/A
    A124,2,
    ;N/A
    A124,3,
    ;N/A
    A124,4,
    ;N/A
    A125,0,
    ;224
    A125,1,
    ;N/A
    A125,2,
    ;N/A
    A125,3,
    ;N/A
    A125,4,
    ;N/A
    A126,0,
    ;66
    A126,1,
    ;N/A
    A126,2,
    ;N/A
    A126,3,
    ;N/A
    A126,4,
    ;N/A
    A127,0,
    ;31
    A127,1,
    ;N/A
    A127,2,
    ;N/A
    A127,3,
    ;N/A
    A127,4,
    ;N/A
    A128,0,
    ;45
    A128,1,
    ;N/A
    A128,2,
    ;N/A
    A128,3,
    ;N/A
    A128,4,
    ;N/A
    A129,0,
    ;0
    A129,1,
    ;N/A
    A129,2,
    ;N/A
    A129,3,
    ;N/A
    A129,4,
    ;N/A
    A130,0,
    ;17
    A130,1,
    ;N/A
    A130,2,
    ;N/A
    A130,3,
    ;N/A
    A130,4,
    ;N/A
    A131,0,
    ;192
    A131,1,
    ;N/A
    A131,2,
    ;N/A
    A131,3,
    ;N/A
    A131,4,
    ;N/A
    A132,0,
    ;0
    A132,1,
    ;N/A
    A132,2,
    ;N/A
    A132,3,
    ;N/A
    A132,4,
    ;N/A
    A133,0,
    ;48
    A133,1,
    ;N/A
    A133,2,
    ;N/A
    A133,3,
    ;N/A
    A133,4,
    ;N/A
    A134,0,
    ;10
    A134,1,
    ;N/A
    A134,2,
    ;N/A
    A134,3,
    ;N/A
    A134,4,
    ;N/A
    A135,0,
    ;9
    A135,1,
    ;N/A
    A135,2,
    ;N/A
    A135,3,
    ;N/A
    A135,4,
    ;N/A
    A136,0,
    ;255
    A136,1,
    ;N/A
    A136,2,
    ;N/A
    A136,3,
    ;N/A
    A136,4,
    ;N/A
    A137,0,
    ;255
    A137,1,
    ;N/A
    A137,2,
    ;N/A
    A137,3,
    ;N/A
    A137,4,
    ;N/A
    A138,0,
    ;65535
    A138,1,
    ;N/A
    A138,2,
    ;N/A
    A138,3,
    ;N/A
    A138,4,
    ;N/A
    A139,0,
    ;224
    A139,1,
    ;N/A
    A139,2,
    ;N/A
    A139,3,
    ;N/A
    A139,4,
    ;N/A
    A140,0,
    ;6
    A140,1,
    ;N/A
    A140,2,
    ;N/A
    A140,3,
    ;N/A
    A140,4,
    ;N/A
    A141,0,
    ;25
    A141,1,
    ;N/A
    A141,2,
    ;N/A
    A141,3,
    ;N/A
    A141,4,
    ;N/A
    A142,0,
    ;255
    A142,1,
    ;N/A
    A142,2,
    ;N/A
    A142,3,
    ;N/A
    A142,4,
    ;N/A
    A143,0,
    ;5
    A143,1,
    ;N/A
    A143,2,
    ;N/A
    A143,3,
    ;N/A
    A143,4,
    ;N/A
    A144,0,
    ;60
    A144,1,
    ;N/A
    A144,2,
    ;N/A
    A144,3,
    ;N/A
    A144,4,
    ;N/A
    A145,0,
    ;5
    A145,1,
    ;N/A
    A145,2,
    ;N/A
    A145,3,
    ;N/A
    A145,4,
    ;N/A
    A146,0,
    ;5
    A146,1,
    ;N/A
    A146,2,
    ;N/A
    A146,3,
    ;N/A
    A146,4,
    ;N/A
    ;147 N/A
    ;148 N/A
    ;149 N/A
    A150,0,
    ;0
    A150,1,
    ;N/A
    A150,2,
    ;N/A
    A150,3,
    ;N/A
    A150,4,
    ;N/A
    ;151 N/A
    ;152 N/A
    ;153 N/A
    ;154 N/A
    ;155 N/A
    ;156 N/A
    ;157 N/A
    ;158 N/A
    ;159 N/A
    ;160 N/A
    ;161 N/A
    ;162 N/A
    ;163 N/A
    ;164 N/A
    ;165 N/A
    ;166 N/A
    ;167 N/A
    ;168 N/A
    ;169 N/A
    ;170 N/A
    ;171 N/A
    ;172 N/A
    ;173 N/A
    ;174 N/A
    ;175 N/A
    ;176 N/A
    ;177 N/A
    ;178 N/A
    A179,0,
    A179,1,
    ;ERROR:
    A179,2,
    ;Security
    A179,3,
    ;access
    A179,4,
    ;required
    A180,0,
    A180,1,
    ;ERROR:
    A180,2,
    ;Security
    A180,3,
    ;access
    A180,4,
    ;required
    A181,0,
    A181,1,
    ;ERROR:
    A181,2,
    ;Security
    A181,3,
    ;access
    A181,4,
    ;required
    A182,0,
    A182,1,
    ;ERROR:
    A182,2,
    ;Security
    A182,3,
    ;access
    A182,4,
    ;required
    A183,0,
    A183,1,
    ;ERROR:
    A183,2,
    ;Security
    A183,3,
    ;access
    A183,4,
    ;required
    A184,0,
    A184,1,
    ;ERROR:
    A184,2,
    ;Security
    A184,3,
    ;access
    A184,4,
    ;required
    A185,0,
    A185,1,
    ;ERROR:
    A185,2,
    ;Security
    A185,3,
    ;access
    A185,4,
    ;required
    A186,0,
    A186,1,
    ;ERROR:
    A186,2,
    ;Security
    A186,3,
    ;access
    A186,4,
    ;required
    A187,0,
    A187,1,
    ;ERROR:
    A187,2,
    ;Security
    A187,3,
    ;access
    A187,4,
    ;required
    A188,0,
    A188,1,
    ;ERROR:
    A188,2,
    ;Security
    A188,3,
    ;access
    A188,4,
    ;required
    A189,0,
    A189,1,
    ;ERROR:
    A189,2,
    ;Security
    A189,3,
    ;access
    A189,4,
    ;required
    A190,0,
    A190,1,
    ;ERROR:
    A190,2,
    ;Security
    A190,3,
    ;access
    A190,4,
    ;required
    A191,0,
    A191,1,
    ;ERROR:
    A191,2,
    ;Security
    A191,3,
    ;access
    A191,4,
    ;required
    A192,0,
    A192,1,
    ;ERROR:
    A192,2,
    ;Security
    A192,3,
    ;access
    A192,4,
    ;required
    A193,0,
    A193,1,
    ;ERROR:
    A193,2,
    ;Security
    A193,3,
    ;access
    A193,4,
    ;required
    A194,0,
    ;7
    A194,1,
    ;N/A
    A194,2,
    ;N/A
    A194,3,
    ;N/A
    A194,4,
    ;N/A
    A195,0,
    A195,1,
    ;ERROR:
    A195,2,
    ;Security
    A195,3,
    ;access
    A195,4,
    ;required
    A196,0,
    A196,1,
    ;ERROR:
    A196,2,
    ;Security
    A196,3,
    ;access
    A196,4,
    ;required
    A197,0,
    A197,1,
    ;ERROR:
    A197,2,
    ;Security
    A197,3,
    ;access
    A197,4,
    ;required
    A198,0,
    A198,1,
    ;ERROR:
    A198,2,
    ;Security
    A198,3,
    ;access
    A198,4,
    ;required
    A199,0,
    A199,1,
    ;ERROR:
    A199,2,
    ;Security
    A199,3,
    ;access
    A199,4,
    ;required
    A200,0,
    A200,1,
    ;ERROR:
    A200,2,
    ;Security
    A200,3,
    ;access
    A200,4,
    ;required
    A201,0,
    A201,1,
    ;ERROR:
    A201,2,
    ;Security
    A201,3,
    ;access
    A201,4,
    ;required
    A202,0,
    A202,1,
    ;ERROR:
    A202,2,
    ;Security
    A202,3,
    ;access
    A202,4,
    ;required
    A203,0,
    A203,1,
    ;ERROR:
    A203,2,
    ;Security
    A203,3,
    ;access
    A203,4,
    ;required
    A204,0,
    A204,1,
    ;ERROR:
    A204,2,
    ;Security
    A204,3,
    ;access
    A204,4,
    ;required
    A205,0,
    A205,1,
    ;ERROR:
    A205,2,
    ;Security
    A205,3,
    ;access
    A205,4,
    ;required
    A206,0,
    A206,1,
    ;ERROR:
    A206,2,
    ;Security
    A206,3,
    ;access
    A206,4,
    ;required
    A207,0,
    A207,1,
    ;ERROR:
    A207,2,
    ;Security
    A207,3,
    ;access
    A207,4,
    ;required
    A208,0,
    A208,1,
    ;ERROR:
    A208,2,
    ;Security
    A208,3,
    ;access
    A208,4,
    ;required
    A209,0,
    A209,1,
    ;ERROR:
    A209,2,
    ;Security
    A209,3,
    ;access
    A209,4,
    ;required
    A210,0,
    A210,1,
    ;ERROR:
    A210,2,
    ;Security
    A210,3,
    ;access
    A210,4,
    ;required
    A211,0,
    A211,1,
    ;ERROR:
    A211,2,
    ;Security
    A211,3,
    ;access
    A211,4,
    ;required
    A212,0,
    A212,1,
    ;ERROR:
    A212,2,
    ;Security
    A212,3,
    ;access
    A212,4,
    ;required
    A213,0,
    A213,1,
    ;ERROR:
    A213,2,
    ;Security
    A213,3,
    ;access
    A213,4,
    ;required
    A214,0,
    A214,1,
    ;ERROR:
    A214,2,
    ;Security
    A214,3,
    ;access
    A214,4,
    ;required
    A215,0,
    A215,1,
    ;ERROR:
    A215,2,
    ;Security
    A215,3,
    ;access
    A215,4,
    ;required
    A216,0,
    A216,1,
    ;ERROR:
    A216,2,
    ;Security
    A216,3,
    ;access
    A216,4,
    ;required
    A217,0,
    A217,1,
    ;ERROR:
    A217,2,
    ;Security
    A217,3,
    ;access
    A217,4,
    ;required
    A218,0,
    A218,1,
    ;ERROR:
    A218,2,
    ;Security
    A218,3,
    ;access
    A218,4,
    ;required
    A219,0,
    A219,1,
    ;ERROR:
    A219,2,
    ;Security
    A219,3,
    ;access
    A219,4,
    ;required
    A220,0,
    A220,1,
    ;ERROR:
    A220,2,
    ;Security
    A220,3,
    ;access
    A220,4,
    ;required
    A221,0,
    A221,1,
    ;ERROR:
    A221,2,
    ;Security
    A221,3,
    ;access
    A221,4,
    ;required
    A222,0,
    A222,1,
    ;ERROR:
    A222,2,
    ;Security
    A222,3,
    ;access
    A222,4,
    ;required
    A223,0,
    A223,1,
    ;ERROR:
    A223,2,
    ;Security
    A223,3,
    ;access
    A223,4,
    ;required
    A224,0,
    A224,1,
    ;ERROR:
    A224,2,
    ;Security
    A224,3,
    ;access
    A224,4,
    ;required
    A225,0,
    A225,1,
    ;ERROR:
    A225,2,
    ;Security
    A225,3,
    ;access
    A225,4,
    ;required
    A226,0,
    A226,1,
    ;ERROR:
    A226,2,
    ;Security
    A226,3,
    ;access
    A226,4,
    ;required
    A227,0,
    A227,1,
    ;ERROR:
    A227,2,
    ;Security
    A227,3,
    ;access
    A227,4,
    ;required
    A228,0,
    A228,1,
    ;ERROR:
    A228,2,
    ;Security
    A228,3,
    ;access
    A228,4,
    ;required
    A229,0,
    A229,1,
    ;ERROR:
    A229,2,
    ;Security
    A229,3,
    ;access
    A229,4,
    ;required
    A230,0,
    A230,1,
    ;ERROR:
    A230,2,
    ;Security
    A230,3,
    ;access
    A230,4,
    ;required
    A231,0,
    A231,1,
    ;ERROR:
    A231,2,
    ;Security
    A231,3,
    ;access
    A231,4,
    ;required
    A232,0,
    A232,1,
    ;ERROR:
    A232,2,
    ;Security
    A232,3,
    ;access
    A232,4,
    ;required
    A233,0,
    A233,1,
    ;ERROR:
    A233,2,
    ;Security
    A233,3,
    ;access
    A233,4,
    ;required
    A234,0,
    A234,1,
    ;ERROR:
    A234,2,
    ;Security
    A234,3,
    ;access
    A234,4,
    ;required
    A235,0,
    A235,1,
    ;ERROR:
    A235,2,
    ;Security
    A235,3,
    ;access
    A235,4,
    ;required
    A236,0,
    A236,1,
    ;ERROR:
    A236,2,
    ;Security
    A236,3,
    ;access
    A236,4,
    ;required
    A237,0,
    A237,1,
    ;ERROR:
    A237,2,
    ;Security
    A237,3,
    ;access
    A237,4,
    ;required
    A238,0,
    A238,1,
    ;ERROR:
    A238,2,
    ;Security
    A238,3,
    ;access
    A238,4,
    ;required
    A239,0,
    A239,1,
    ;ERROR:
    A239,2,
    ;Security
    A239,3,
    ;access
    A239,4,
    ;required
    A240,0,
    A240,1,
    ;ERROR:
    A240,2,
    ;Security
    A240,3,
    ;access
    A240,4,
    ;required
    A241,0,
    A241,1,
    ;ERROR:
    A241,2,
    ;Security
    A241,3,
    ;access
    A241,4,
    ;required
    A242,0,
    A242,1,
    ;ERROR:
    A242,2,
    ;Security
    A242,3,
    ;access
    A242,4,
    ;required
    A243,0,
    A243,1,
    ;ERROR:
    A243,2,
    ;Security
    A243,3,
    ;access
    A243,4,
    ;required
    A244,0,
    A244,1,
    ;ERROR:
    A244,2,
    ;Security
    A244,3,
    ;access
    A244,4,
    ;required
    A245,0,
    A245,1,
    ;ERROR:
    A245,2,
    ;Security
    A245,3,
    ;access
    A245,4,
    ;required
    A246,0,
    A246,1,
    ;ERROR:
    A246,2,
    ;Security
    A246,3,
    ;access
    A246,4,
    ;required
    A247,0,
    A247,1,
    ;ERROR:
    A247,2,
    ;Security
    A247,3,
    ;access
    A247,4,
    ;required
    ;248 N/A
    ;249 N/A
    ;250 N/A
    ;251 N/A
    ;252 N/A
    ;253 N/A
    ;254 N/A
    ;255 N/A
    That tests for 0..20 so doesn't seem likely either
    Any thoughts?
    Richard
  9. #18
    Aug 2018
    This thread hasn't been touch since 2014. Figured I'd bump it.
    Has anyone figured out how to change the comfort blinks on a 2011 Touareg 7P?
    Also it's been mentioned that a factory reset of lighting options to factory settings. Since I updated my RNS850 firmware K0711 I no longer see this option. I definitely remember seeing it prior to updating.
    Thanks in advance for any help/ideas.
