2005 Audi A3 2.0 TDI No Electric Windows inop
Auto Elite
C?ID=230843
Hi Guys ,
I have a few issues with an Audi A3 , the 1st one I need to sort out is the windows.
I thought I'd look for advice before I start heading in the wrong direction.
The windows all work if you operate via vagcom apart from the rear drivers side (I think it's that one)
I've pasted the scan I ran after I'd cleared dtc's.
I also have a new convenience unit which is located drivers side boot if that helps, i plugged it in but no change but not sure if it needs coding ?
I have the car in the workshop so I can get any details that may help
Many Thanks
Anthony
Auto Elite
Tuesday,25,October,2016,16:59:54:62149
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8P25A161516   License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P25A161516   Mileage: 234160km-145500miles
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FF    HW: 028 101 147 7
   Component: R4 2,0L EDC G000SG  6337
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   Shop #: WSC 00000 028 00001
   VCID: 6CD7EA774F79325EB2-8038
18048 - Internal Control Module
            P1640 - 000 - EEPROM Error - MIL ON
                    Torque: 74.0 Nm
                    Bin. Bits: 10111000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
18107 - Powertrain Data Bus
            P1699 - 000 - Missing Message from Steering Wheel Electronics
                    Torque: 74.0 Nm
                    Voltage: 12.01 V
                    Bin. Bits: 00001100
                    Bin. Bits: 00000000
                    (no units): 1.0
Readiness: 1 1 0 1 1
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023174
   Shop #: WSC 06314 000 00000
   VCID: 3A7B1C2F75AD5CEE70-806E
00810 - Sensor 1/2 for Brake Pressure
   Part No SW: 8P0 820 043 H    HW: 8P0 820 043 H
   Component: KlimavollautomatH14 0180
   Revision: 179531      Serial number: 8P0820043H
   VCID: 31693B03A8DB9FB6C1-8064
                    Reset counter: 184
                    Mileage: 234165 km
                    Date: 2016.06.11
                    Time: 20:27:11
                    Reset counter: 184
                    Mileage: 234165 km
                    Date: 2016.06.11
                    Time: 20:31:43
00532 - Supply Voltage B+
                    Reset counter: 184
                    Mileage: 234165 km
                    Voltage: 8.50 V
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 C    HW: 8P0 907 279 C
   Component: Bordnetz-SG     H37 0301
   Revision: 00H37000    Serial number: 00000001779326
   Coding: 01884F02B214100000160000160000000000FE075C
   Shop #: WSC 06314 000 08192
   VCID: 3D71173364836BD655-8068
   Subsystem 1 - Part No: 8P2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 C    HW: 8P0 959 655 C
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 00362002UGP+
   Coding: 0034622
   VCID: 428B64CF1D7D142E28-8016
   Subsystem 1 - Serial number: 6332DRB4014BCC2D
   Subsystem 2 - Serial number: 6342DRB4014BC7A1U
   Subsystem 3 - Serial number: 63528RB4005E85AE-
   Subsystem 4 - Serial number: 63628RB40059E48DY
   Subsystem 5 - Serial number: 63729RB4006003877
   Subsystem 6 - Serial number: 63829RB40061B21BG
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                    Fault Status: 11101010
                    Mileage: 234166 km
                    Date: 2016.07.18
                    Time: 00:11:08
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                    Mileage: 234166 km
                    Date: 2016.07.18
                    Time: 00:11:08
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000012
   VCID: 35610F135CB3B3969D-8060
   Part No SW: 8P0 920 981 A    HW: 8P0 920 981 A
   Component: KOMBIINSTR. VDO H73 0300
   Revision: D06         Serial number: 2243ED06008520
   Coding: 0004443
   Shop #: WSC 00441 210 91426
   VCID: 3663081F41B5B88E94-8062
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500105407895E
   Coding: 3D3F0B42072103
   VCID: 285FD6679B01DE7E16-807C
                    Reset counter: 184
                    Mileage: 234166 km
                    Date: 2016.07.18
                    Time: 00:35:55
Address 25: Immobilizer
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 E
   Component: Tuersteuerger.  H10 0030
   Coding: 0000048
00939 - Mirror Adjust Motor; Drivers Side (V149)
   Part No: 1K2 909 144 K
   VCID: 3467321757C9AA9EAA-8060
02546 - Steering Limit Stop
                    Mileage: 4160 km
                    Temperature: 12.0°C
                    Voltage: 12.00 V
                    Voltage: 11.80 V
   Part No: 8P0 959 433 C
   Component:    KSG          H04 0050
   Coding: 198000187F088505489FC63000
   Shop #: WSC 31414 210 01865
   VCID: 3C771A377F9962DE62-8068
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Component: Innenraumueberw.H03 0020
01134 - Alarm Horn (H12)
   Part No SW: 8P4 035 382     HW: 8P4 035 382
   Component: AB2 SUBWOOFERBOXH03 0180
   Revision: 00002       Serial number: 10000001241577
   VCID: 71E9FB03685BDFB681-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 E
   Component: Tuersteuerger.  H10 0040
   Coding: 0000048
   Shop #: WSC 06314 210 01865
   VCID: 3E73103F698570CE4C-806A
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186 C    HW: 8P0 035 186 C
   Component: concert II EU   H51 0100
   Revision:      01S    Serial number: AUZ2Z3E2260337
   Coding: 0001001
   Shop #: WSC 06435 000 00000
   VCID: 326B340FADDDA4AEB8-8066
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 B
   Component: Tuer-SG         010 0030
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 B
   Coding: 0000144
   VCID: 3F8D6D3B6E8F79C647-806A
   Revision: 00800000    Serial number:
   VCID: 2D512773B4E3FB56E5-8078
End-------------------------(Elapsed Time: 01:46)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Have You had central convenience module connected when You cleared all dtc's and rescanned? Have You a good charged battery or charger connected?
A lot of communications related errors...
P.S. Be sure to uncheck "use CAN command" next to "Clear All DTC" button. With this option checked not all old DTC's are cleared.
smokey08
C?ID=120732
Looks like the immobiliser has been bypassed. No comms with address 25 and checksum fault in the ecu.
Im pretty sure that turning off the immo makes windows and the aircon stop working. FOD
Smokey........Turning immobilizer off no but communication loss yes...............
Auto Elite
C?ID=230843
Hi MartinsX...
Yes it was connected and a new battery, I'll try uncheck CAN command next today and post up results
Auto Elite
C?ID=230843
Thanks for your reply Jack@European_Parts and smokey08 , starting to make some progress after this car has been parked up for a few weeks
I'm going to do another scan later and post up results
Any ideas how the immobiliser could have been bypassed , if its in the main ecu I can get that checked
And is the "No comms with address 25 and checksum fault in the ecu " the main issue
thanks
Tell us what VCDS says here.
0x01-10-091 Report back the value in adaption.
Dana
Western PA, USA
I realize this thread is older and the Immo problem shouldn't be ignored but 19 is coded for RHD when the coding strings for the doors are too small to include it:
Coding: 0000048
+0000512 = Right Hand Steering
Coding: 0000048
The same applies to the rear door coding. Speaking of rear doors, +0000128 = 5-Door Chassis isn't included in the front configuration either. I would try something closer to 0000752/0000753 in the fronts for now.
46 is coded for right drive and 4 doors so I don't see any obvious conflicts there.
