Hi Guy
New member and need a little help with the above topic
Procedure
Stage 1 - Engine basis settings - 04
The Adaptation off diff pressure sensor particulate filter - press GO to activate the basic setting
Stage 2 - Then select Resetting of learned values of diff pressure sensor particulate filter - press GO to active basis settings
Then Stop
However the stage two on my VCDS shows the following in the drop down mode
Reset learned values . quantity meter. unit and press. control .valve ----- IS this the correct precedure for stage 2 ???????
Thanks Mark
Procedure
Then Stop
Thanks Mark
