Results 1 to 10 of 17
Thread: TBA
    Verified VCDS-Lite User
    Aug 2016
    TBA
    Was gettng fault code:
    00516 closed throttle (idle) position switch f60 2700 implausible signal
    Ive removed the throttle body on a 1.4 16v ahw, cleaned it and refitted. Used a pole to hold accelerator down, pulled the cable back just to the point were throttle body butterfly was open.
    Heres a vid off the vcds process, am now getting basic setting not complete error, the engine refuses to idle and cuts out
    Please post an Auto-Scan.
    If this is a cable-throttle engine, the cable needs to have a bit of slack in it when the throttle is closed.
    Aug 2016
    its cable throttle
    VCDS-Lite Version: Release 1.2
    Sunday, 16 October 2016, 16:41:05:3906
    Chassis Type: 17 - VW Golf Citi
    Scan: 01,09,15,17,25,56
    Address 01: Engine       Labels: 036-906-014-AHW.LBL
       Controller: 036 906 014 AN
       Component:  MARELLI 4CV       2893
       Coding: 00031
       Shop #: WSC 00028
       VCID: 5CCB1831DF33
    01087 -  Basic Setting Not Performed
                35-00 -   -
    Readiness: N/A
    Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
       Controller: 6Q0 909 605 A
       Component: Y2 AIRBAG VW5       0003
       Coding: 22834
       Shop #: WSC 00028
       VCID: 351DAD951C59
    00532 -  Supply Voltage B+
                07-10 -  Signal too Low - Intermittent
    Address 17: Instruments       Labels: 1J0-920-xx0-17.LBL
       Controller: 1J0 920 901
       Component: A4-KOMBIINSTR. VDO V12
       Coding: 01441
       Shop #: WSC 00001
       VCID: E0B3ACC1735B
       IMMO-IDENTNR: VWZ7Z0X1452133
    Address 25: Immobilizer       Labels: None
       Controller: Bit teA dre sst
       Component: e 17 eingeben
       VCID: CEEF627919CF
    No Faults Found
      or a communication error ocurred
    End   --------------------------------------------------------------------------------------------------
    Aug 2016
    after engines been started
    Sunday, 16 October 2016, 16:51:59:3906
       Coding: 00031
       Shop #: WSC 00028
       VCID: 5CCB1831DF33
    00282 -  Throttle Position Actuator (V60)
                26-00 -  Output Open
                35-00 -   -
    Readiness: N/A
       Coding: 22834
       Shop #: WSC 00028
       VCID: 351DAD951C59
       Coding: 01441
       Shop #: WSC 00001
       VCID: E0B3ACC1735B
       VCID: CEEF627919CF
    No Faults Found
    edit: cable has slack
    the for cleaning the tb is the engine was hunting and cutting out
    the original fault code was 00516 closed throttle (idle) position switch f60 2700 implausible signal
    I would suggest that whatever is causing this needs to be fixed:
                26-00 -  Output Open
    Sep 2016
    Riga, Latvia
    Completely agree. Bad wiring, bad throttle motor, bad output driver IC inside ECU in the worst case.
  8. Likes Uwe liked this post
    Aug 2016
    narrowed it down to the throttle body, it shows as throttle open on vcds even with cable disconnected. bridging pins 3 and 7 on the throttle body plug changed it to idle
  10. Likes jyoung8607, Jack@European_Parts liked this post
  11. #8
    Sep 2016
    Riga, Latvia
    The best way is to replace TB with new one. Or used one, if You want to save some money. Is Your TB clean inside? No soot or something like it not allowing full range movement of throttle?
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #9
    Aug 2016
    Already cleaned the Tb mate, hence the TBA. Going to go for a known working used one and see how it goes. Thanks for the help
  14. #10
    Aug 2016
    Thursday, 20 October 2016, 13:20:02:3906
       Coding: 00031
       Shop #: WSC 00028
       VCID: 5CCB1831DF33
                35-00 -   -
    Readiness: N/A
       Coding: 22834
       Shop #: WSC 00028
       VCID: 351DAD951C59
       Coding: 01441
       Shop #: WSC 00001
       VCID: E0B3ACC1735B
       VCID: CEEF627919CF
    No Faults Found
    00282 - Throttle Position Actuator(V60)
    26-00 - Output Open
    isnt returning now, it will if engine is started
    edit: to avoid any mix up, the above means the code only returned after the engine has been started.
    It goes straight to error when i first put 098 into basic settings, i then switch to measuring blocks using the tab at the bottom left and it shows the same results, i then switch back to basic settings, sometimes for a split second its shows ADP OK then quickly changes to error.
  15. Likes Jack@European_Parts liked this post
