Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: TBA
    You are not supposed to do the ADP with the engine running!
    I liked your post because it's funny.......
  2. Likes MartinsX liked this post
  3. #12
    Sep 2016
    Riga, Latvia
    It is another TB showing the same fault code?
  4. #13
    Verified VCDS-Lite User
    Aug 2016
    i didnt.... sorry jack, it means the code only returns after the engine has been started
  5. #14
    Aug 2016
    it started off with
    00516 closed throttle (idle) position switch f60 2700 implausible signal
    00532 supply voltage b+ 07-10 signal to low intermittent
    after the throttle body clean
    00282 - Throttle Position Actuator (V60)
    26-00 - Output Open
    but it was reading as part throttle with the cable disconnected, and changed to idle once pins 3 and 7 were briged
    throttle body from breakers was fitted, it now shows as idle in vcds but still shows error in adaptation idle/error field
    and this code if the engine has been started, after codes have been cleared
    00282 - Throttle Position Actuator(V60)
    26-00 - Output Open
  6. #15
    If all fuse ok ..........
    Time for a TV, harness damage, or ECU.
  7. Likes MartinsX liked this post
  8. #16
    Aug 2016
    had some help, looking for a second opinion. Would you guys agree that the following results from measuring blocks point towards a faulty replacement throttle body?
     005 zone 4 tv cal. xx000000 = 00000100
  9. #17
    Aug 2016
    got there in the end, turned out to be a fault with the wiring/plug at the throttle body
  10. Likes Uwe liked this post
