hello.
How to enable rear door warning lights? I have only front ones (version Style). I connected wires and lights but they do not work.
Saturday,15,October,2016,19:27:16:28586
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 16.8.3.1 (x64)
Data version: 20161010 DS267.0
VIN: TMBAB9NPXH70xxxxx License Plate:
Mileage: 5379km-3342mi Repair Order:
Chassis Type: NP (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 52 55 5F 6C
6D A5
VIN: TMBAB9NPXH70xxxxx Mileage: 5379km-3342miles
Address 01: Engine (J623-CZEA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 BT HW: 04E 907 309 AB
Component: R4 1.4l TFS H23 9042
Revision: R6H23---
Coding: 02250072236401087000
Shop #: WSC 33361 790 00063
ASAM Dataset: EV_ECM14TFS01104E906027BT 001010
ROD: EV_ECM14TFS01104E906027BT.rod
VCID: 77FC6863CEA2EEFA8D-8023
CAN Converter 01:
Part No SW: 0CW 300 049 Q HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0902
Revision: 00005006 Serial number: CU501606097202
ROD: EV_TCMDQ200021.rod
VCID: 4B94E493E2AABA1A19-801F
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61706000001292
Coding: 1D076A9C34211371477A060241C949B8562CC8E2608292753821F078C20902
ROD: EV_Brake1UDSContiMK100IPB_035_SK37.rod
VCID: 7BF47453F28ACA9AE9-802F
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0407354144
Coding: 032C0C0F03
VCID: 3C76B74FB7040DA2A0-8069
Address 08: Auto HVAC (E87) Labels: 3V0-907-044.clb
Part No SW: 3V0 907 044 BP HW: 3V0 907 044 BP
Component: AC Automat H34 4003
Revision: 20K06000 Serial number: 00000B00143242
Coding: 1101000400041001100500010010100A
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X_SK48.rod
VCID: 03040CB38A7AB25AA1-8057
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001616301303
ROD: EV_BCMBOSCH_017.rod
VCID: 7F0C8043E692D6BAC5-802B
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 160525 032 0121
Serial number: 00000001605240301404
Coding: 165DDD
Component: RLHS 042 0105
Serial number: S7Y16M06D17H15M42S30
Coding: 0088DF
Serial number: 000000000ZY161300Z4G
Serial number: 00000000000066197808
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616163
Coding: 0271161851
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000_009.rod
VCID: 0D102A8BDC3EF42AC7-8059
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 320067C355FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34669F6F9F54C5E268-8061
Part No SW: 5Q0 959 655 AE HW: 5Q0 959 655 AE
Component: AirbagVW21 005 0130
Serial number: 003NSR1UW38Q
Coding: 98FCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X_SK48.rod
Subsystem 1 - Part No SW: ----------- HW: 480 001 006 16
Serial number: 357000000006C748CA1W
Subsystem 2 - Part No SW: ----------- HW: 480 001 006 16
Serial number: 358000000006E32DDB1-
Subsystem 3 - Part No SW: ----------- HW: 480 401 406 16
Serial number: 3510002A921160C2512J
Subsystem 4 - Part No SW: ----------- HW: 480 401 406 16
Serial number: 3520002B720FC4C3F04B
Subsystem 5 - Part No SW: ----------- HW: 480 401 106 16
Serial number: 3550002C320FC4C5C107
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EF HW: 5Q0 953 569 A
Revision: FF035035 Serial number: 20160611400356
Coding: 6410
ROD: EV_SMLSVALEOMQB.rod
VCID: 78FE6B5FC3BCE18284-802D
Part No SW: 3V0 920 750 A HW: 3V0 920 750 A
Component: KOMBI 304 8311
Coding: 07A5011A6F84000801886B031001000000000000
Shop #: WSC 73430 031 00063
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 3168967B6046F0CA03-8065
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 15061610802673
Coding: 030100047F085700EB00025A1C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00114
ROD: EV_GatewConti_013.rod
VCID: 7CF6774FF784CDA2E0-8029
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B1805060616
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 3112320304
Component: ELV-MQBB H05 0032
Serial number: 16000119509003
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E8567BA0C6B0CA43-8025
Address 36: Seat Mem. Drvr (J810) Labels: None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PFF15201
Coding: 0010000000000500018280808080000000008181000000D400
Shop #: WSC 33361 790 00030
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide_VW37.rod
Component: TSG FS 010 0031
Serial number: 0000204280463
Coding: 001D0820DE00040000001100
VCID: 479CD8A3FEC25E7A3D-8013
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000010394288
Coding: 110200
Address 44: Steering Assist (J500) Labels: 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000855098
Coding: 01010011005001
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_SK37.rod
VCID: 3D70BA4BAC1E04AA97-8069
Component: TSG BFS 010 0031
Serial number: 0000204940247
Coding: 001D0220DE00040000001100
VCID: 4682D5A7F9C84772C6-8013
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000010443269
Coding: 090200
Component: AFS-ECU H07 0090
Coding: 06DA00003F010000
VCID: 408EC3BFDBEC6942FC-8015
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-HGH2.clb
Part No SW: 3V0 035 021 C HW: 3V0 035 021
Component: MU-H-LND-EU H50 0702
Serial number: A674E0G7505194
Coding: 03840101FF00000051111201008808332F0101C4012001009E
ROD: EV_MUHig4CGen2HBAS_SK37.rod
VCID: 275C78235E82BE7ADD-8073
Subsystem 1 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H47 1031
Serial number: SKZ8Z9SLU000NP
Subsystem 2 - Part No SW: V03 959 801 JM HW: -----------
Component: ECE 2017 --- 0157
Component: Gracenote2--- --- 1013
Address 6C: Back-up Cam. (J772) Labels: None
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 04840101A600201F000040
ROD: EV_CamSysRVRVCPANAMQBAB_VW37.rod
Address 6D: Trunk Elect. (J605) Labels: 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30613477100000
Coding: 1008
VCID: 3F8CC043A61216BA85-806B
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H04 0220
Serial number: 25051611K14111
Coding: 020408010000040100262344C050A10090000E100020
ROD: EV_MFKBoschMQBB.rod
VCID: 3A7AB157BD303392B2-806F
End-------------------------(Elapsed Time: 05:14)--------------------------
