Passat tail lights on with DRL
PMB2015
C?ID=83916
Anyone know how to enable the tail lights on my 2016 Passat NMS to be on as rear DRL's? Like Scandinavian mode? I had this on my MK7 GTI.
Thank you 😊
DV52
C?ID=194404
^^^^^^ Hi. Just a suggestion, but it is normally useful when asking this type of question to post-up an autoscan. That way folks here can see what type of equipment is in your car - this usually facilitates a response (sometimes)
golfi_vend
Tartu, Estonia
C?ID=195131
Maybe some byte18 config is with _S(scandinavian), but one working way is direct edit of memory of BCM. - Other tools, not VCDS.
Although, Pseudoproblem in my Point of View.
DV52
C?ID=194404
^^^^ golf-_vend: I was hoping to see in the autoscan that the 2016 Passat NMS had received some MQB control modules in the facelifted model. I have read somewhere that these vehicles are fitted with MIB units, but I'm not sure if their BCM is also MQB -ish. Byte18 issues always look real scary to me, but if the answer is Leuchte adaptation channels, it gets easier IMO
Dana
Western PA, USA
Hi guys,
The NAR NMS models with MQBish 5F units (in addition to ACC and similar fun/new stuff) still use Mk6 chassis PQ35 BCMs and regular old MK60EC1 ABS. I believe the answer is in Byte 18 for that reason - BUT please post the scan before tinkering. I don't know the stock value for that Byte and Yanping's 2016 NMS is hidden under zeros.
If you post the scan we can confirm this is the same module setup and hopefully someone can chime in on the latest factory values. If not, I can ping Andy because we knew the stock value in his (previous) 2012 NMS... but I can't remember it.
PMB2015
C?ID=83916
Here is a auto scan of my car.
I had this feature on my MK7 GTI and loved having it.
Tuesday,13,September,2016,20:20:31:20418
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: 1VWCT7A39GC066140   License Plate: 2016 PASSAT
Mileage: 2170km-1348mi   Repair Order:
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
          4F 52 5F 61 62 72 75 A5
VIN: 1VWCT7A39GC066140   Mileage: 2170km-1348miles
Address 01: Engine (J623-CPRA)       Labels: 06K-907-425-V2.clb
   Part No SW: 06K 906 071 AG    HW: 06K 907 425 C
   Component: R4 1.8l TFS   H13 2359
   Revision: --H13---
   Coding: 001A0092244400179000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM18TFS02006K906071AG 001004
   ROD: EV_ECM18TFS02006K906071AG.rod
   VCID: 70C11F7AABECD1C258-8024
Address 02: Auto Trans (J217)       Labels: 09G-927-749.clb
   Part No SW: 09G 927 749 AN    HW: 09G 927 749 AN
   Component: AISIN AG6 G3  129 2969
   Coding: 000348
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031.rod
   VCID: 052F5EAE846EE46A9B-8050
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: C54BC0F549280000A30C03E89219004100F1F01A
   VCID: 75CF2E6EDC8EF4EA8B-8020
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 F    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1202
   Revision: 00093000    Serial number: 0403117220
   Coding: 130C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: 3851E75A831C498250-806C
   Slave 1:
   Serial number: 93800481
   Part No SW: 561 907 044 AM    HW: 561 907 044 AM
   Component: Climatronic   H07 0910
   Revision: 00001K04
   Coding: 0050019012
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 62E5653275007352DE-8036
   Part No SW: 5K0 937 087 AL    HW: 5K0 937 087 AL
   Component: BCM PQ35 H++  122 0184
   Revision: BN122001
   Coding: EF200EBAEC2B28D409880609340081C802F1000847A00DB0E4806200BC70
   VCID: 7F23CC46EEB2BEBAD1-802A
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 210516 03  37  0059
   Coding: 0038DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0479
   Revision: --------    Serial number: 39491607700686
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 3957E25EB816508AAF-806C
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 7N0 907 572 B    HW: 7N0 907 572
   Component: ACC Bosch PQx H03 0120
   Serial number: 07041677092069
   Coding: 01001002FE0739
   ASAM Dataset: EV_ACCBEGVW361 001005
   ROD: EV_ACCBEGVW361.rod
   VCID: 354FEE6E940EB4EA4B-8060
6 Faults Found:
0110 - Transport Mode Active
          U1105 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 41
                    Mileage: 8 km
                    Date: 2016.06.13
                    Time: 06:19:06
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1130 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 66
                    Mileage: 1548 km
                    Date: 2016.09.09
                    Time: 16:05:28
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 12.5 V
1132 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 66
                    Mileage: 1511 km
                    Date: 2016.09.09
                    Time: 15:24:59
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 13.8 V
                    Vehicle speed: 27.81 m/s
                    Acceleration: -0.10 m/s²
1131 - Sensor for Automatic Distance Control
                    Fault Priority: 9
                    Reset counter: 66
                    Mileage: 1548 km
                    Date: 2016.09.09
                    Time: 16:05:28
1542 - Sensor for Automatic Distance Control
                    Reset counter: 66
                    Mileage: 1548 km
                    Date: 2016.09.09
                    Time: 15:59:38
                    Control Module temperature: 39 °C
                    Vehicle speed: 6.58 m/s
                    Acceleration: -2.44 m/s²
1545 - Sensor for Automatic Distance Control
                    Reset counter: 66
                    Mileage: 1548 km
                    Date: 2016.09.09
                    Time: 15:59:38
Address 15: Airbags (J234)       Labels: 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    001 0207
   Serial number: 003RXM05BYEK
   Coding: 8CCCCC00000000005000001A020800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63EB60366A1A7A5AD5-8036
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH0000000000050R9OP
   Coding: 30324A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 404 16
   Serial number: 3570000000084A682A1L
   Subsystem 3 - Part No SW: -----------    HW: 480 000 404 16
   Serial number: 35800000000F378CA91
   Subsystem 4 - Part No SW: -----------    HW: 480 020 804 16
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001A72080C23E5B+
   Subsystem 5 - Part No SW: -----------    HW: 480 021 104 16
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001A72080C2316FY
   Subsystem 6 - Part No SW: -----------    HW: 480 020 404 16
   Component: FrontSensor_D  000 0189
   Serial number: 3550001A11F21403C2CY
   Subsystem 7 - Part No SW: -----------    HW: 480 020 404 16
   Component: FrontSensor_P  000 0189
   Serial number: 3560001A11F21406427P
   Part No SW: 1K5 953 521 CS    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20160420200143
   Coding: 2002C40008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 00214FBA9B4CC142A8-8054
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B
   Serial number: 0681609592501098AF2B
   Coding: 2C0000
   Part No SW: 561 920 981     HW: 561 920 981
   Component: KOMBI         H04 1008
   Coding: 231C010000
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 599742DE5856B08A8F-800C
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 15051603010664
   Coding: 461010
   VCID: 76CD2962C188FFF282-8022
   Component: IMMO          H04 1008
   Coding: 000007
   VCID: 6AF50D128D302B1216-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 16000071399003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3147DA7E606698CA17-8064
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0183
   Revision: AA000000    Serial number: 00000163575219
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 226525323D8033529E-8076
Address 3C: Lane Change (J1086)       Labels: None
   Component: HRE_Master    H12 0071
   Serial number: 0401589503
   Coding: 02011102
   ROD: EV_HREntryHella.rod
   VCID: 3C59FB4AB72465A2B4-8068
   Lane Change Assistant 2:
   Part No SW: 561 959 701 C    HW: 3C0 959 793 J
   Component: TUER-SG FT    002 0637
   Revision: 12100010    Serial number: 0010510424
   Coding: 3415FD
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1E1D11C201F817B2BA-804A
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 C    HW: 561 959 811 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  022 1472
   Serial number: 14102746160527110209
67584 - Warning Light for Front Door
          B11F5 01 [008] - Electrical Failure
                    Reset counter: 71
                    Mileage: 1922 km
                    Date: 2016.09.10
                    Time: 16:56:00
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 313    3501
   Revision: 00H22000
   VCID: 3957E25E7016508AAF-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0090254
   VCID: 2871371A53BCD902C0-807C
   Component: EZE_2         H56 1673
   Coding: 01030108
   VCID: 6FC31C06BED2CE3A41-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011606001587
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 C    HW: 561 919 204 C
   Component: Analoguhr  002 0002
   Part No SW: 561 959 702 C    HW: 3C0 959 792 J
   Component: TUER-SG BT    002 0637
   Revision: 14100010    Serial number: 0010496789
   Coding: 3415FC
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1F632CC606F21EBAB1-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 C    HW: 561 959 812 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  022 1472
   Serial number: 14102747160527085105
                    Reset counter: 71
                    Mileage: 2049 km
                    Date: 2016.09.11
                    Time: 21:19:21
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0247
   Serial number: VWZAZ2S0208167
   Coding: 02140102AA0000005122000300180A001F0300D400200105CE
   ROD: EV_MUStd4CTSAT_VW26.rod
   Subsystem 1 - Part No SW: 3G0 919 866 R    HW: -----------
   Component: NAR 2016  --- 0321
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Component: Batt.regelung H56 1673
   Coding: E1200859
   VCID: 71C71A7EA8E6D8CA57-8024
Address 75: Telematics (J949)       Labels: 12E-035-284.clb
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0158
   Serial number: 000003554140549
   Coding: 02140102C24232107F1606000000
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow.rod
   VCID: 140973EAFF344DE21C-8040
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0023
   Serial number: 30101511K10599
   Coding: 000401010001020100201346C080400090000E200020
   ROD: EV_MFKBoschMQBB.rod
   VCID: 3753E4668E0246FA59-8062
End-------------------------(Elapsed Time: 03:22)--------------------------
Dana
Western PA, USA
Byte 18 is covered (masked) by 00s as we suspected. We believe the factory NMS Byte 18 coding is still HEX A0 so you can use that as a back-up plan (to restore it to a factory condition) if modifications to that Byte result in undesirable lighting.
Just make sure to apply coding changes one at a time while monitoring battery voltage. If the battery voltage goes low connect a charger or start the engine for a bit and start a new session. After a single coding modification to Byte 18, check all exterior lights, check/clear faults, recheck lighting functions and fault codes, repeat. Due to the sensitivity of that Byte I would not toss a bunch of coding attempts at it without the entire song and dance.
PMB2015
C?ID=83916
Hello, if I was to change byte 18 what would you change it to? I've never changed byte 18 before.
Thanks in advance,
Paul
Bobdhd
Canada
C?ID=277963
Was there any more information about the choice of codes to use ?
PMB2015
C?ID=83916
Not to my knowledge
Mihnea Florin
C?ID=326226
Hello guys, I am looking for the same thing to code my car tail lights to run as DRL if somebody know how and advice me.
I have found a lot of videos on youtube with cars having tail lights as DRL, but nothing about how to code it with VCDS step by step.
Sorry for asking same question but I am thinking that coding can be different from one car to another one.
Thank you!
VW Passat B7 2012
Monday,05,August,2019,17:26:08:14860
Dealer/Shop Name:
Workshop Code: 000 00000 000001
VIN: WVWZZZ3CZCE105450   License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
          62 65 72
VIN: WVWZZZ3CZCE105450   Mileage: 263300km-163607miles
   Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H25 2291
   Revision: 41H25---    Serial number: 00000000000000
   Coding: 00190012042501080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PR 003002
   ROD: EV_ECM20TDI01103L906018PR.rod
   VCID: 094F607EC9BAE28F9D7-805C
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V4A0 0023
   Revision: --H07---    Serial number: 00000004994546
   Coding: 0002992
   Shop #: WSC 05311 000 00000
   VCID: 71BF289ECDAABA4F357-8024
   Part No SW: 3AA 907 044 B    HW: 3AA 907 044 B
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0014004803
   VCID: 2F3BEEE6179EECBF633-807A
   Part No SW: 3AA 937 087 G    HW: 3AA 937 087 G
   Component: BCM PQ47 H    421 0464
   Revision: BB421001
   Coding: 000000000000000000180080140081E403714E88406C81606480C7200041
   Shop #: WSC 05311 123 12345
   VCID: 3E25C3A2C0741537F85-806A
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 02111  26  0612
   Coding: 00BF95
   Component: RLS 161111 05  54  0403
   Coding: 0630ED
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631131800710
   Coding: 108001
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 7CA109AA9668C727961-8028
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0PP4FS5$
   Coding: 0012338
   VCID: 4CC1996A8AC8B7A7661-8018
   Subsystem 1 - Serial number: 6332MTS661053011
   Subsystem 2 - Serial number: 6342MTS646682991
   Subsystem 3 - Serial number: 6351HTS6MT1G0AKJ
   Subsystem 4 - Serial number: 6361HTS68TLH1AKJ
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20111031201071
   Coding: 018A250000
   VCID: 72BD2792C42C8157CCD-8026
   Coding: E20000
   Part No SW: 3AA 920 970 E    HW: 3AA 920 970 E
   Coding: 160F00
   Shop #: WSC 05314 115 12345
   VCID: 3537DC8EF5C2D66F29F-8060
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 231011F6000130
   Coding: 461007
   Shop #: WSC 05314 000 00000
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   VCID: 76B51B82A4C49D77E05-8022
   Revision: A1001003    Serial number: 7661294997
   Coding: 020000
   VCID: 290F00FE29FA828FBD7-807C
   Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
   Component: RNS315-EU   H35 0263
   Serial number: VWZAZ2L3868259
   Coding: 040004010400100000011002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 270B06C63F6EB4FFAB3-8072
   Component: EUR_W_V9  0069
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0003845943
   Coding: 0202B7
   Shop #: WSC 05311 115 12345
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002573558
   Coding: 000290
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 195    3301
   Revision: 00H22000
   VCID: 3537DC8EF942D66F29F-8060
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002864E763402941D7C08DFCE105C01
   Component: EZE_2         H41 1623
   Coding: 00000008
   VCID: 6FBB2EE6D79EACBF233-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0003846829
   Coding: 0202B6
   VCID: 3635DB82E8C4DD77205-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002577191
   Coding: 000290
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000416988
   Coding: 0022167
   Component: Batt.regelung H41 1623
   Coding: 030F185A
   VCID: 71BF289EC1AABA4F357-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900982409
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000076419
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.4V)-----------
