Hi. If anyone knows what this fault means and how to fix it I would be gratefull. The fault shows recently and didnt have this problem before.
Thanks Dom.
Thanks Dom.
Sunday,09,October,2016,13:29:52:54646
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
VIN: WAUZZZ4G8CN028450 License Plate: X17DLK
Mileage: 140318km-87189mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ4G8CN028450 Mileage: 140318km-87189miles
Address 01: Engine (J623-CGLC) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 LA HW: 03L 906 018 JL
Component: R4 2.0l TDI H23 9977
Revision: 45H23---
Coding: 0A194012242401080000
Shop #: WSC 60052 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018LA 003011
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 74ED9FCADF6E59E2A0-8020
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Coding: 06A087016005E1809B00
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 346D5FCA9FEE19E260-8060
Part No SW: 4H0 907 064 BN HW: 4H0 907 064 BN
Component: BCM2 2.0 H31 0330
Coding: 03B83006000000000000
VCID: 76E9A5C2C1124BF29E-8022
Component: J764 ELV MLB H39 0046
Serial number: 2311000133275002
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 G HW: 4G0 820 043 G
Component: KLIMA 2 ZONEN H10 0056
Serial number: 14071100040583
Coding: 34210008A0
ASAM Dataset: EV_AirCondiBasisUDS 002033
VCID: 234FAC962A008E5A89-8076
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0100
Revision: 19012002 Serial number: 00000001131484
Coding: 2600201141349F600481008000001D0C4F9D830827090101000004602100
VCID: 6CDD87AA8F5E812278-8038
Component: WWS57X 110610 H35 0051
Serial number: 110627051423
Coding: 004DF7
Component: RLS H04 0003
Serial number: 11542280
Coding: 035159
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 09 07 2011 00000279
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 5308C8B5000000000001
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901119400911
Coding: 080206
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3B7F74F6B2B0D69AA1-806E
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0037H1N
Coding: 30323436313230303235554A305234473053
VCID: 366965C289920BF25E-8062
Serial number: 3575HRB405H0ISD458V-
Serial number: 3585HRB405R0JR9QCPKZ
Serial number: 3515JRB405V0JNPM49JH
Serial number: 3525JRB405V0JNPMCPR7
Serial number: 3554VRB404R0JL5ID86$
Serial number: 3564VRB404T0JL5I7P04
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110713000748
Coding: 000014
VCID: 306553DA63F625C204-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 950 G HW: 4G8 920 950 G
Component: MDieGb H33 0120
Revision: 25450103 Serial number: 658150711592019
Coding: 33A509000B012600010400
ASAM Dataset: EV_RBC7KMID 004040
ROD: EV_RBC7KMID.rod
VCID: 336F5CD69AE01EDA79-8066
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000197667
Coding: 00CD074400
ROD: EV_GatewUDS_AU57.rod
VCID: 326159D265FA17D272-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650898042
Voltage stabilizer:
0019 - Terminal 15
U1405 00 [009] - Implausible signal
Reset counter: 3
Mileage: 140309 km
Date: 2016.10.08
Time: 20:18:09
Voltage terminal 30: 12.0 V
Voltage terminal 15: 0.0 V
Control Module temperature: 28 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: OFF
Datenfeld: 0
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA3200BPA20
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6BDF84B68250861A71-803E
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16205001620002080002
VCID: 42810912DD5AA752E2-8016
Address 44: Steering Assist (J500) Labels: None
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0007111705
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009_AU57.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0153921877
Coding: 015F162220B904C083200804000100000000000000000000000000000000
Component: DWA-Sensor H01 0010
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4183061ED85CBC4AFB-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000105598
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A5141B24D2A5F12CA-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Serial number: 110713-0004-024
Coding: 112196101000A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2C5D47AA47DE412238-8078
Part No SW: 4G0 035 193 C HW: 4G0 035 193 C
Component: RMC Cnct Nav H51 0717
Coding: 0101000101415B47002B060301010000000000
VCID: 234FAC9622008E5A89-8076
Subsystem 1 - Part No: 8X0 919 884 J
Component: P32-50-15.03 0001
Subsystem 2 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464FW0B0044783
Subsystem 3 - Part No SW: 4G2 919 710 HW: 4G2 919 710
Component: E380 BDT C7 H08 0203
Serial number: 90349KG800034
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 448D0F0AC74EA962D0-8010
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 03:45)--------------------------
