Results 11 to 20 of 40
Thread: MkVII Golf - XDS Adaptation
    Could you make an Adaptation Control Module Map of [ABS - 03] and post here.
    NEtech:Hi and thank you for responding.
    Here is the Adaptation report for address 03 from the Control Module Map. I think this is what you suggeted (please advise if I got it wrong).
    ;SW:5Q0-907-379-AC   HW:5Q0-907-379-D ---  ABS Brakes
    ;Component:ESC           H75 0437, Coding:01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
    ;EV_Brake1UDSContiMK100IPB,008020,EV_Brake1UDSContiMK100IPB_VW37.rod
    ;Saturday,05,July,2014,23:33:05:03521
    ;VCDS Version: Beta 14.7.0  Data version: 20140601
    ;VCID: 7DF1154CECFCAFD204-8028
    ABS in lower speed range,activated
    Activating and deactivating all development messages,0
    AUTO HOLD functional status,Last setting
    AUTO HOLD functionality,not activated
    AUTO HOLD increase threshold; full tensioning force,10 %
    AUTO HOLD increase threshold; reduced tensioning force,0 %
    AUTO HOLD slippage recognition,activated
    Automatic application during engine stalling,activated
    Brake booster,4
    Brake disk drying,Weak
    Brake pedal evaluation,activated
    Brake prefill,activated
    Brake system vacuum pump,5
    Braking torque boost for distance regulation,3
    Counter steer support,Strong
    Driver door status,activated
    Dynamic starting assist,Early
    (1)-Electromechanical parking brake-Automatic application,not activated
    (2)-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated
    Electromechanical parking brake; delay level,6
    Electronic Stability Program,not activated
    Engine drag torque control,activated
    Hill-start assistant,normal
    Hydraulic brake assistant,normal
    Hydraulic brake booster,8
    (1)-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7
    (2)-Monitoring of functional lights-Indicator light in AUTO HOLD button,0
    Offroad,0
    Overboost in brake system,activated
    Roller test bench mode,Manual activation; possible
    Roller test bench mode; functional,not activated
    Running manufacturer number,activated
    Seat belt buckle scan,activated
    Starting vibration reduction,Strong
    Straight ahead brake stabilization,activated
    Thresholds for brake performance,activated
    Tire pressure monitoring display,2
    Tire pressure monitoring display; tire selection,1
    Vehicle and trailer stabilization,not activated
    XCP calibration protocol,not activated
    Developer_Function_1,0
  2. #12
    Quote Originally Posted by andyvee View Post
    Melbourne might be a bit far for a couple of beers LOL
    Andyvee: Narrh.... it's not far at all. Just remember to make a right-hand turn at Dover - from there it's all down hill!
  3. #13
    From what i can see, it is only available in Adaptation from model year 2014.
  4. #14
    Netech: Again, many thanks for taking an interest in my problem.
    That's a real interesting observation, given that I have in my hands as I type this post a VW brochure (publication: VAG7MY13 - printed April 2013) that clearly states on page 34 (Specification table) "Extended Electronic Differential Lock (XDL) - Standard on models 90TSI, 90TSI Comfortline, 103TSI Highline & 110TSI Highline"!
    If I could press you for two further questions please- when you say that "it is only available in Adaptation from model year 2014", is this a RT software restriction, or is it a VW restriction? And, because I enjoy learning stuff, is it OK for you to explain how you made your observation from the Control Module Map report that I provided - I'll understand if this is proprietary information?
  5. #15
    I just tested with another login on a 2013 model, the adaption is showed (so it is not a RT software restriction), but not possible to change, just like yours.
    I think you certainly have XDS (PR-1Y3), but on 2013 model it is not possible to change how it works, that is first from 2014.
    So in my opinion, buy a new car or ABS unit, if that could be installed, if you REALLY want to change it.
  6. Likes Uwe, DV52 liked this post
  7. #16
    Netech: Again, my appreciation for your efforts in trying to solve my problem. Whilst I would have liked to change the XDS setting, I'm certainly not going to spend money on the task. Tak endnu en gang - I think!
  8. #17
    NEtech's observation is very sensible because there is no mention of a channel called "Expanded Electronic Differential Lock" in the Adaptation control map for my car. But this absence raises another question in my mind. Can someone (anyone really) explain how the RT software can access an Adaptation channel for the control module in my car (giving me the screen shot in my first post) when the actual adaptation channel doesn't exist in the Controller map for my car? The answer is probably very simple-what am I missing?
  9. #18
    Verified VCDS User ConD's Avatar
    Jul 2014
    Oulu, Finland
    A friend of mine has been digging this XDS thing with his 2014 Seat Leon 5F to get his XDS setting changed. It is basically almost same car as the Golf so i think this post belongs here too.
    Car is 2014 model, and i personally tried to code XDS when my friend bought it from dealer nearby. However ABS control module refused to accept because of missing login code. Now he found the "right" code for this particular car. Code supported by this car was 20103
    However. Another problem was found after the code was found. Most recent versions of VCDS does not support XDS adaptation any more! We have tried to found adaptation with VCDS versions 12.12.0, 12.12.2 and Beta 14.7.2. Only version that worked was 12.12.0! In newer data versions there is no adaptation!
    Below is full scans and adaptation map scans from my friend's Leon, so please be patient with the length of the post.
    12.12.0:
    VCDS Version: Release 12.12.0
    Data version: 20130910
    Monday,28,July,2014,20:00:06:25647
    Chassis Type: 5F (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
    VIN: VSSZZZ5FZER059421
    Address 01: Engine (J623-CJSA)       Labels: None
       Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
       Component: 1.8l R4 TFSI  H09 0003
       Revision: --H09---
       Coding: 0B2500322424010B0000
       Shop #: WSC 00049 770 00129
       ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
       ROD: EV_ECM18TFS0218V0906264B_SE37.rod
       VCID: 3B7F3E5CB2018FC6811-806E
       Part No SW: 0CW 300 046 C    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5110
       Revision: 00043014    Serial number: CU501311066119
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021.rod
       VCID: 3A713B58BD3BB6CE9A7-806F
       Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
       Component: EMB8 EHCB     H31 0356
       Revision: 00000000    Serial number: 62993000000F5C
       Coding: 20EE6A9234252975007B060241C42904562C9400608294F400410070C003
       Shop #: WSC 00049 770 00106
       ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
       VCID: 4B9F6E9CE2A13F46311-801E
       Part No SW: 5F0 907 044 E    HW: 5F0 907 044 E
       Component: Climatronic   H03 0705
       Revision: 00001K07
       Coding: 00000004200100011105000000101000
       ROD: EV_ACClimaBHBVW37X_SE37.rod
       VCID: 2855F1105397345EFC3-807D
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
       Component: BCM MQBAB H   H16 0124
       Serial number: 00011330801215
       Coding: 08001B46C24102FB4BE44000401C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 7BFFFE5CF2814FC6C11-802E
       Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119
       Component: WWS370 131009  041 0574
       Serial number:         131010200028
       Coding: 0BC5FD
       Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547
       Component: RLFS  024 0042
       Serial number: Y13M11D05H22M35S25S6
       Coding: 00885D
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231331203265
       Coding: 0031051011
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       ROD: EV_EPHVA18AU3700000_SE37.rod
    Address 15: Airbags (J234)       Labels: Redir Fail!
       Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
       Component: Airbag VW20   011 0189
       Revision: --------    Serial number: 003P3PLJ0VLJ
       Coding: 98FCC000000000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X_SE37.rod
       VCID: 7EF9F748E1935AEEE6F-802B
       Subsystem 1 - Part No SW: -----------    HW: 454 000 211 13
       Serial number: 3576U000000330202E0W
       Subsystem 2 - Part No SW: -----------    HW: 454 002 810 13
       Serial number: 3586U000000AEA4CED00
       Subsystem 3 - Part No SW: -----------    HW: 454 800 811 13
       Serial number: 3516R87810C02000000.
       Subsystem 4 - Part No SW: -----------    HW: 454 800 811 13
       Serial number: 3526R66890C020000000
       Subsystem 5 - Part No SW: -----------    HW: 454 802 110 13
       Serial number: 3556V72F703020000000
       Part No SW: 5Q0 953 507 DK    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 31101308490266
       Coding: 2C00
       ROD: EV_SMLSKLOMQB.rod
       VCID: 820103B8156BBE0E027-80D7
       Part No SW: 5F0 920 871     HW: 5F0 920 871
       Component: KOMBI         303 2210
       Coding: 07A401086980000800086A02000000
       VCID: E6C93F281903622E8EF-80B3
       Revision: --------    Serial number: 0001251776
       Coding: 030100F42B085A00EF0006E81C0F00010001000000000000000000000000
       ROD: EV_GatewLear_AU37.rod
       VCID: 3F874A4CA61993E6AD9-806A
       Generator:
       Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
       Component: E221__MFL-PR6  H03 0120
       Serial number: 000000000A0757200913
       Coding: 012000
       Serial number: 0020190603
       Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
       Component: TSG FS        009 0014
       Serial number: 0000082564367
       Coding: 00100320D000040000001000
       VCID: 448D45A0CFFFF03EF0B-8011
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000001037569
       Coding: 310000
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
       Component: EPS_MQB_ZFLS  127 1021
       Coding: 91
       ROD: EV_SteerAssisMQB.rod
       VCID: 3D7B3044AC1581F6BF5-8068
       Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0014
       Serial number: 0000081889859
       VCID: 438F46BCCAF1F706C91-8016
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000001023425
       Coding: 290000
    Address 55: Xenon Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 049A000009000000
       VCID: F5EB686454A599B6375-80A0
       Part No SW: 5F0 035 846 A    HW: 5F0 035 846 A
       Component: MU-S-N-ER     040 0425
       Serial number: E1F01411131182
       Coding: 04730001FF0A000021110001000800002F0101040100010046
       ASAM Dataset: EV_MUStd6C3PASE 002029
       ROD: EV_MUStd6C3PASE_SE37.rod
       VCID: 2649FF285983222ECEF-8073
       Media Player Position 1:
       Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
       Component: ABTmin_Std_Nv  H51 0022
       Serial number: SEZ8Z9NL400ETQ
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5F0 919 866 F    HW: -----------
       Component:  ECE 2014  --- 0036
    Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0051
       Serial number: 00000141884
       Coding: 0100010001000004000500000000000100
       ROD: EV_MFKBoschAU370.rod
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 5F0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0002
       Serial number: 131004200237
       VCID: 2B5F0E1C42611F46111-807E
    	SW:5Q0-907-379-R   HW:5Q0-907-379-F ---  ABS Brakes
    	Component:EMB8 EHCB     H31 0356, Coding:20EE6A9234252975007B060241C42904562C9400608294F400410070C003
    	EV_Brake1UDSContiMK100ESP,033001,EV_Brake1UDSContiMK100ESP_SE37.rod
    	Monday,28,July,2014,20:01:20:25647
    	VCDS Version: Release 12.12.0  Data version: 20130910
    Brake Boost,4
    Offroad,0
    Roller test bench mode,Manual activation	 possible
    Roller test bench mode	 functional,not activated
    Tire pressure monitoring display	 tire selection,2
    Extended_electronic_differential_lock,Strong
    Uphill_Assist_Gradient_Threshold,3 %
    And now the 12.12.2:
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Monday,28,July,2014,19:43:35:25647
    Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
       Revision: --H09---
       VCID: 3B7F3E5CB2018FC68E5-806E
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 3A713B58BD3BB6CE953-806F
       VCID: 4B9F6E9CE2A13F463E5-801E
       Revision: 00001K07
       VCID: 2855F1105397345EF37-807D
       ROD: EV_BCMBOSCH_SE37.rod
       VCID: 7BFFFE5CF2814FC6CE5-802E
       Coding: 0BC5FD
       Coding: 00885D
       Coding: 0031051011
       ROD: EV_EPHVA18AU3700000_AU37.rod
       VCID: 7EF9F748E1935AEEE9B-802B
       Coding: 2C00
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 820103B8156BBE0E0D3-80D7
       ROD: EV_DashBoardVDDMQBAB_SE37.rod
       VCID: E6C93F281903622E81B-80B3
       ROD: EV_GatewLear_SE37.rod
       VCID: 3F874A4CA61993E6A2D-806A
       Coding: 012000
       ROD: EV_DCUDriveSideEWMAXKLO.rod
       VCID: 448D45A0CFFFF03EFFF-8011
       Coding: 310000
       Coding: 91
       VCID: 3D7B3044AC1581F6B01-8068
       ROD: EV_DCUPasseSideEWMAXKLO.rod
       VCID: 438F46BCCAF1F706C65-8016
       Coding: 290000
       VCID: F5EB686454A599B6381-80A0
       ROD: EV_MUStd6C3PASE.rod
       VCID: 2649FF285983222EC1B-8073
       ROD: EV_MFKBoschAU370_AU37.rod
       VCID: 2B5F0E1C42611F461E5-807E
    	Monday,28,July,2014,19:49:40:25647
    	VCDS Version: Release 12.12.2  Data version: 20140212
    Brake booster,4
    Hill-start assistant	 increase threshold,3 %
    No display,Medium
    Offroad,0
    Notice! No XDS any more!
    Beta 14.7.2:
    VCDS Version: Beta 14.7.2
    Data version: 20140714
    Wednesday,30,July,2014,21:31:37:25647
    VIN: VSSZZZ5FZER059421   Mileage: 11701km-7270miles
       Revision: --H09---
       VCID: 3B7F3E5CB2018FE296-806E
       VCID: 3A713B58BD3BB6EA8D-806F
       VCID: 4B9F6E9CE2A13F6226-801E
       Revision: 00001K07
       VCID: 2855F1105397347AEB-807D
       VCID: 7BFFFE5CF2814FE2D6-802E
       Coding: 0BC5FD
       Coding: 00885D
       Coding: 0031051011
       VCID: 7EF9F748E1935ACAF1-802B
       Coding: 2C00
       VCID: 020183B8956B3E2A95-8057
       VCID: 66C9BF289903E20A19-8033
       VCID: 3F874A4CA61993C2BA-806A
       Coding: 012000
       VCID: 448D45A0CFFFF01AE7-8011
       Coding: 310000
       Coding: 91
       VCID: 3D7B3044AC1581D2A8-8068
       VCID: 438F46BCCAF1F722DE-8016
       Coding: 290000
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       VCID: 75EBE864D4A51992A0-8020
       VCID: 2649FF285983220AD9-8073
       VCID: 2B5F0E1C42611F6206-807E
    End-------------------------(Elapsed Time: 04:08)--------------------------
    	Wednesday,30,July,2014,21:33:32:25647
    	VCDS Version: Beta 14.7.2  Data version: 20140714
    Brake booster,4
    No display,Medium
    Offroad,0
    So... the XDS is there and with "Strong" setting. It can be felt easily when cornering. 12.12.2 and 14.7.2 Beta just does not know anything about it.
    So please, can you take a look what can be done to have this setting available in coming VCDS versions. Thank you, and greetings from Finland!
  10. Likes cerumen liked this post
  11. #19
    Quote Originally Posted by Con
    Con: your post adds yet another vital piece to this intruding jig-saw puzzle! Many thanks for sharing your incisive observations. As the part numbers for both vehicles appears to be identical, I was keen to replicate your hypothesis- so I tried ver 12.12.2 on my Golf mk7. Access Code was accepted,, the results on my golf were exactly the same - no access (boo-hoo). Also, there was no change in the Adaptation maps bwteen ver 14.7.2 and ver 12.2.2 on my car for address 03.
    I'd like to try ver 12.12.0, but I removed the file copy from my laptop (yes, I know that I shouldn't have done this, but the ver 12.12.2 looked so shiny and new!)
    Question for the good folk at RT: how does a verified VCDS user get hold of an obsolete version of the RT software?
  12. #20
    Check your PMs.
