MkVII Golf - XDS Adaptation
DV52
C?ID=194404
Hello VCDS gurus!
I come seeking advice from those with knowledge about the settings for the Expanded electronic differential lock on a mkVII Golf. Specifically, I'm trying to alter the XDS setting on my car. I have understood from various forums that it is possible to change the setting from “Standard”, “Not activated”, “Weak”, “Medium”, or “Strong” via the adaptation channel for the ABS module.
The process that I have attempted to use is as follows :
1, Select [03] ABS
2. Select 10 Adaptation
3. From the pull down menu, select “Expanded electronic differential lock”
4. In the New value box select : “Standard”, “Not activated”, “Weak”, “Medium”, “Strong”
(These instructions have been taken from " http://golf7vcds.moonfruit.com/driver-convenience/4581555424"
My problem is that that I can't get to step 4 above because of the error message on the following pic:
I had thought that there was perhaps a security code for the ABS module, but there is no mention of this in any of the forums that discuss this tweak.
Has anyone else experienced this problem and if so how has it been resolved?
Thanks in advance for your replies
Oh... here's the autoscan report from my car
Wednesday,25,June,2014,12:25:31:03521
VCDS Version: 14.6.1.0
Data version: 20140601
VIN:    License Plate:
Mileage: 9713km   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN:    Mileage: 9713km-6035miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 7615
   Revision: WAH08---
   Coding: 01250032242405082000
   Shop #: WSC 20604 001 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016G 002010
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 26431A2059EACC0A4B-8073
Readiness: 0000 0001
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4510
   Revision: 00043014    Serial number: CU501212296246
   Shop #: WSC 00028 028 00025
   ROD: EV_TCMDQ200021_AU37.rod
   VCID: 76E30A60C9CAFC8A3B-8023
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
   VCID: 7DF1154CECFCAFD27A-8028
   Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
   Revision: 00001K06
   Coding: 00120004200100011005000012101800
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 3561CD6C944CB792F2-8060
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011234701612
   Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 4385A3B4CA9819224C-8016
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    121120  042 0551
   Serial number:         121206042218
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M01D03H20M05S37S1
   Coding: 06A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231233000504
   Coding: 0031151011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3A7BDE50BD5258EA1F-806F
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R01UHNZ
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00061
   VCID: 408FACB8DB8E023A51-8015
   Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 357670000007612C7C0W
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 358670000006332C7C0V
   Crash sensor for side airbag; rear driver side:
   Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
   Serial number: 3516502AF0CD5EC471C+
   Crash sensor for side airbag; rear passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
   Serial number: 3526502B30CD5EC2136J
   Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
   Serial number: 3556502B30CD5EC4008M
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Component: Lenª007 0070
   Revision: --------    Serial number: 08011304220489
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 79F9015CF8D493F256-802C
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         235 0555
   Coding: 27A401082380000801087A00040000
   VCID: 65C15D2C646C071282-8030
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000188941
   Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_AU37.rod
   VCID: 3365F3749A38A9A2DC-8066
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H13 0035
   Serial number: 02120005290300060291
   Coding: 280000
   Serial number: 3451678601
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Serial number: 0000046453458
   Coding: 003A02208001020000001000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 020B66B09502D02A07-8057
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000000502227
   Coding: 0D0000
   Coding: 01
   ROD: EV_SteerAssisMQB.rod
   VCID: 3D71D54CAC7C6FD23A-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Serial number: 0000048027940
   Coding: 003A00208E01020000801000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 010969BC9004CB321E-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000000502825
   Coding: 050000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846
   Component: MU-S-N-ER     039 0421
   Serial number: V1F00501130081
   Coding: 02730008FF00000011510001000900001F0100960100010247
   Shop #: WSC 43847 000 1048576
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 275D17245EE0D50270-8072
   Media Player Position 1:
   Component: ABT_Std_Nav  H44 0022
   Serial number: VWZ8Z9M3400KZM
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 A    HW: -----------
   Component:  ROW 2013  --- 0022
End-------------------------(Elapsed Time: 03:14)--------------------------
DV52
C?ID=194404
You either haven't got XDS or need a login code
Andyvee: Hi and thanks for the reponse.
Unless the folk that wrote the VW brochure for my model car are telling an untruth (which is entirely possible), I'm certain that I've got XDS on my car! Seriously, it says in the specification table of the brochure that XDS is "standard" on the Australian 103TSI model.
Which brings me to your "login code" suggestion, which I guess is a question for the (clever, good-looking, wise and good humoured) guys/gals at RT- does flattery help?. Is anyone at Ross Tech aware of a "login code" for the ABS module on MQB platform vehicles and if so, can it be shared with cable users?
Dana
Western PA, USA
The only SA code I'm aware of is 40168 but I will mention that the NAR Mk7 (which just made it here) has a conventional parking brake and I believe the Octavia does as well (you know, the click click style handle) so these controllers may vary. For instance the local cars we scanned so far use:
Brake1UDSContiMK100ESP
.. and yours has:
I do not have any XDS comments or contributions but if WVWZZZAUZDP034070 is the real VIN and PL24 decrypted it properly the PR code is:
Differential lock 1Y3 Differential lock (XDS)
dynamic traction control
.. so I agree with the VW brochure but I don't know why it wouldn't be activated.
DV52
C?ID=194404
.. and yours has:
Dana.
Once again, thanks for your response. I'm thanking the staff at RT so often, I fear that I'm starting to sound disingenuous - but I'm not!
I'll pose my question to one of the Australian forums and see if mine is a unique problem, or if it more prevalent on mk7 Golf's that are sold down here.
andyvee
Rossendale, Lancashire, UK
C?ID=159389
I have asked the question on another forum for you, let you know if I get a response
DV52
C?ID=194404
andyvee:Thanks for your interest. Next time that you are down this way, I owe you a beer (or two)!
PS: I tried Dana's magic number (40168) -I know that she wasn't suggesting that it was an answer, but I thought that it was worth a try. The controller accepted the security code. Thought to myself "wow-this is looking real good". But alas my expectations were dashed yet again- ain't fate a cruel mistress? Still got the same error message when I tried to access the XDS channel.
andyvee
C?ID=159389
I was just about to post the following:
Try 40168 or 20103
andyvee
C?ID=159389
Melbourne might be a bit far for a couple of beers LOL
NEtech
C?ID=56995
DV52
C?ID=194404
Could you make an Adaptation Control Module Map of [ABS - 03] and post here.
NEtech:Hi and thank you for responding.
Here is the Adaptation report for address 03 from the Control Module Map. I think this is what you suggeted (please advise if I got it wrong).
;SW:5Q0-907-379-AC   HW:5Q0-907-379-D ---  ABS Brakes
;Component:ESC           H75 0437, Coding:01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
;EV_Brake1UDSContiMK100IPB,008020,EV_Brake1UDSContiMK100IPB_VW37.rod
;Saturday,05,July,2014,23:33:05:03521
;VCDS Version: Beta 14.7.0  Data version: 20140601
;VCID: 7DF1154CECFCAFD204-8028
ABS in lower speed range,activated
Activating and deactivating all development messages,0
AUTO HOLD functional status,Last setting
AUTO HOLD functionality,not activated
AUTO HOLD increase threshold; full tensioning force,10 %
AUTO HOLD increase threshold; reduced tensioning force,0 %
AUTO HOLD slippage recognition,activated
Automatic application during engine stalling,activated
Brake booster,4
Brake disk drying,Weak
Brake pedal evaluation,activated
Brake prefill,activated
Brake system vacuum pump,5
Braking torque boost for distance regulation,3
Counter steer support,Strong
Driver door status,activated
Dynamic starting assist,Early
(1)-Electromechanical parking brake-Automatic application,not activated
(2)-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated
Electromechanical parking brake; delay level,6
Electronic Stability Program,not activated
Engine drag torque control,activated
Hill-start assistant,normal
Hydraulic brake assistant,normal
Hydraulic brake booster,8
(1)-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7
(2)-Monitoring of functional lights-Indicator light in AUTO HOLD button,0
Offroad,0
Overboost in brake system,activated
Roller test bench mode,Manual activation; possible
Roller test bench mode; functional,not activated
Running manufacturer number,activated
Seat belt buckle scan,activated
Starting vibration reduction,Strong
Straight ahead brake stabilization,activated
Thresholds for brake performance,activated
Tire pressure monitoring display,2
Tire pressure monitoring display; tire selection,1
Vehicle and trailer stabilization,not activated
XCP calibration protocol,not activated
Developer_Function_1,0
DV52
C?ID=194404
Andyvee: Narrh.... it's not far at all. Just remember to make a right-hand turn at Dover - from there it's all down hill!
NEtech
C?ID=56995
From what i can see, it is only available in Adaptation from model year 2014.
DV52
C?ID=194404
Netech: Again, many thanks for taking an interest in my problem.
That's a real interesting observation, given that I have in my hands as I type this post a VW brochure (publication: VAG7MY13 - printed April 2013) that clearly states on page 34 (Specification table) "Extended Electronic Differential Lock (XDL) - Standard on models 90TSI, 90TSI Comfortline, 103TSI Highline & 110TSI Highline"!
If I could press you for two further questions please- when you say that "it is only available in Adaptation from model year 2014", is this a RT software restriction, or is it a VW restriction? And, because I enjoy learning stuff, is it OK for you to explain how you made your observation from the Control Module Map report that I provided - I'll understand if this is proprietary information?
NEtech
C?ID=56995
I just tested with another login on a 2013 model, the adaption is showed (so it is not a RT software restriction), but not possible to change, just like yours.
I think you certainly have XDS (PR-1Y3), but on 2013 model it is not possible to change how it works, that is first from 2014.
So in my opinion, buy a new car ;) or ABS unit, if that could be installed, if you REALLY want to change it.
DV52
C?ID=194404
Netech: Again, my appreciation for your efforts in trying to solve my problem. Whilst I would have liked to change the XDS setting, I'm certainly not going to spend money on the task. Tak endnu en gang - I think!
DV52
C?ID=194404
NEtech's observation is very sensible because there is no mention of a channel called "Expanded Electronic Differential Lock" in the Adaptation control map for my car. But this absence raises another question in my mind. Can someone (anyone really) explain how the RT software can access an Adaptation channel for the control module in my car (giving me the screen shot in my first post) when the actual adaptation channel doesn't exist in the Controller map for my car? The answer is probably very simple-what am I missing?
ConD
Oulu, Finland
C?ID=82663
A friend of mine has been digging this XDS thing with his 2014 Seat Leon 5F to get his XDS setting changed. It is basically almost same car as the Golf so i think this post belongs here too. :)
Car is 2014 model, and i personally tried to code XDS when my friend bought it from dealer nearby. However ABS control module refused to accept because of missing login code. Now he found the "right" code for this particular car. Code supported by this car was 20103
However. Another problem was found after the code was found. Most recent versions of VCDS does not support XDS adaptation any more! We have tried to found adaptation with VCDS versions 12.12.0, 12.12.2 and Beta 14.7.2. Only version that worked was 12.12.0! In newer data versions there is no adaptation!
Below is full scans and adaptation map scans from my friend's Leon, so please be patient with the length of the post. :)
12.12.0:
VCDS Version: Release 12.12.0
Data version: 20130910
Monday,28,July,2014,20:00:06:25647
Chassis Type: 5F (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A5 A9
VIN: VSSZZZ5FZER059421
Address 01: Engine (J623-CJSA)       Labels: None
   Part No SW: 8V0 906 264 B    HW: 06K 907 425 A
   Component: 1.8l R4 TFSI  H09 0003
   Revision: --H09---
   Coding: 0B2500322424010B0000
   Shop #: WSC 00049 770 00129
   ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
   ROD: EV_ECM18TFS0218V0906264B_SE37.rod
   VCID: 3B7F3E5CB2018FC6811-806E
   Part No SW: 0CW 300 046 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5110
   Revision: 00043014    Serial number: CU501311066119
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 3A713B58BD3BB6CE9A7-806F
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 62993000000F5C
   Coding: 20EE6A9234252975007B060241C42904562C9400608294F400410070C003
   Shop #: WSC 00049 770 00106
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
   VCID: 4B9F6E9CE2A13F46311-801E
   Part No SW: 5F0 907 044 E    HW: 5F0 907 044 E
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00000004200100011105000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2855F1105397345EFC3-807D
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011330801215
   Coding: 08001B46C24102FB4BE44000401C07281000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 012001
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7BFFFE5CF2814FC6C11-802E
   Subsystem 1 - Part No SW: 5F1 955 119     HW: 5F1 955 119
   Component: WWS370 131009  041 0574
   Serial number:         131010200028
   Coding: 0BC5FD
   Serial number: Y13M11D05H22M35S25S6
   Coding: 00885D
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231331203265
   Coding: 0031051011
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_SE37.rod
Address 15: Airbags (J234)       Labels: Redir Fail!
   Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
   Component: Airbag VW20   011 0189
   Revision: --------    Serial number: 003P3PLJ0VLJ
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X_SE37.rod
   VCID: 7EF9F748E1935AEEE6F-802B
   Subsystem 1 - Part No SW: -----------    HW: 454 000 211 13
   Serial number: 3576U000000330202E0W
   Subsystem 2 - Part No SW: -----------    HW: 454 002 810 13
   Serial number: 3586U000000AEA4CED00
   Subsystem 3 - Part No SW: -----------    HW: 454 800 811 13
   Serial number: 3516R87810C02000000.
   Subsystem 4 - Part No SW: -----------    HW: 454 800 811 13
   Serial number: 3526R66890C020000000
   Subsystem 5 - Part No SW: -----------    HW: 454 802 110 13
   Serial number: 3556V72F703020000000
   Part No SW: 5Q0 953 507 DK    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 31101308490266
   Coding: 2C00
   ROD: EV_SMLSKLOMQB.rod
   VCID: 820103B8156BBE0E027-80D7
   Part No SW: 5F0 920 871     HW: 5F0 920 871
   Component: KOMBI         303 2210
   Coding: 07A401086980000800086A02000000
   VCID: E6C93F281903622E8EF-80B3
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001251776
   Coding: 030100F42B085A00EF0006E81C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   VCID: 3F874A4CA61993E6AD9-806A
   Generator:
   Subsystem 2 - Part No SW: 5F0 959 537 A    HW: 5F0 959 537 A
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0757200913
   Coding: 012000
   Serial number: 0020190603
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000082564367
   Coding: 00100320D000040000001000
   VCID: 448D45A0CFFFF03EF0B-8011
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001037569
   Coding: 310000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 91
   VCID: 3D7B3044AC1581F6BF5-8068
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000081889859
   VCID: 438F46BCCAF1F706C91-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001023425
   Coding: 290000
Address 55: Xenon Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 049A000009000000
   VCID: F5EB686454A599B6375-80A0
   Part No SW: 5F0 035 846 A    HW: 5F0 035 846 A
   Component: MU-S-N-ER     040 0425
   Serial number: E1F01411131182
   Coding: 04730001FF0A000021110001000800002F0101040100010046
   ASAM Dataset: EV_MUStd6C3PASE 002029
   ROD: EV_MUStd6C3PASE_SE37.rod
   VCID: 2649FF285983222ECEF-8073
   Subsystem 1 - Part No SW: 5F0 919 603 A    HW: 5F0 919 603 A
   Component: ABTmin_Std_Nv  H51 0022
   Serial number: SEZ8Z9NL400ETQ
   Subsystem 2 - Part No SW: 5F0 919 866 F    HW: -----------
   Component:  ECE 2014  --- 0036
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000141884
   Coding: 0100010001000004000500000000000100
   ROD: EV_MFKBoschAU370.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 5F0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0002
   Serial number: 131004200237
   VCID: 2B5F0E1C42611F46111-807E
	SW:5Q0-907-379-R   HW:5Q0-907-379-F ---  ABS Brakes
	Component:EMB8 EHCB     H31 0356, Coding:20EE6A9234252975007B060241C42904562C9400608294F400410070C003
	EV_Brake1UDSContiMK100ESP,033001,EV_Brake1UDSContiMK100ESP_SE37.rod
	Monday,28,July,2014,20:01:20:25647
	VCDS Version: Release 12.12.0  Data version: 20130910
Brake Boost,4
Offroad,0
Roller test bench mode,Manual activation	 possible
Roller test bench mode	 functional,not activated
Tire pressure monitoring display	 tire selection,2
Extended_electronic_differential_lock,Strong
Uphill_Assist_Gradient_Threshold,3 %
And now the 12.12.2:
VCDS Version: Release 12.12.2
Data version: 20140212
Monday,28,July,2014,19:43:35:25647
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Revision: --H09---
   VCID: 3B7F3E5CB2018FC68E5-806E
   VCID: 3A713B58BD3BB6CE953-806F
   VCID: 4B9F6E9CE2A13F463E5-801E
   Revision: 00001K07
   VCID: 2855F1105397345EF37-807D
   Air quality sensor:
   VCID: 7BFFFE5CF2814FC6CE5-802E
   Coding: 0BC5FD
   Coding: 00885D
   Coding: 0031051011
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 7EF9F748E1935AEEE9B-802B
   Coding: 2C00
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 820103B8156BBE0E0D3-80D7
   ROD: EV_DashBoardVDDMQBAB_SE37.rod
   VCID: E6C93F281903622E81B-80B3
   ROD: EV_GatewLear_SE37.rod
   VCID: 3F874A4CA61993E6A2D-806A
   Coding: 012000
   VCID: 448D45A0CFFFF03EFFF-8011
   Coding: 310000
   Coding: 91
   VCID: 3D7B3044AC1581F6B01-8068
   VCID: 438F46BCCAF1F706C65-8016
   Coding: 290000
   VCID: F5EB686454A599B6381-80A0
   ROD: EV_MUStd6C3PASE.rod
   VCID: 2649FF285983222EC1B-8073
   ROD: EV_MFKBoschAU370_AU37.rod
   VCID: 2B5F0E1C42611F461E5-807E
	Monday,28,July,2014,19:49:40:25647
	VCDS Version: Release 12.12.2  Data version: 20140212
Brake booster,4
Hill-start assistant	 increase threshold,3 %
No display,Medium
Offroad,0
Notice! No XDS any more!
Beta 14.7.2:
VCDS Version: Beta 14.7.2
Data version: 20140714
Wednesday,30,July,2014,21:31:37:25647
VIN: VSSZZZ5FZER059421   Mileage: 11701km-7270miles
   Revision: --H09---
   VCID: 3B7F3E5CB2018FE296-806E
   VCID: 3A713B58BD3BB6EA8D-806F
   VCID: 4B9F6E9CE2A13F6226-801E
   Revision: 00001K07
   VCID: 2855F1105397347AEB-807D
   Air quality sensor:
   VCID: 7BFFFE5CF2814FE2D6-802E
   Coding: 0BC5FD
   Coding: 00885D
   Coding: 0031051011
   VCID: 7EF9F748E1935ACAF1-802B
   Coding: 2C00
   VCID: 020183B8956B3E2A95-8057
   VCID: 66C9BF289903E20A19-8033
   VCID: 3F874A4CA61993C2BA-806A
   Coding: 012000
   VCID: 448D45A0CFFFF01AE7-8011
   Coding: 310000
   Coding: 91
   VCID: 3D7B3044AC1581D2A8-8068
   VCID: 438F46BCCAF1F722DE-8016
   Coding: 290000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   VCID: 75EBE864D4A51992A0-8020
   VCID: 2649FF285983220AD9-8073
   VCID: 2B5F0E1C42611F6206-807E
End-------------------------(Elapsed Time: 04:08)--------------------------
	Wednesday,30,July,2014,21:33:32:25647
	VCDS Version: Beta 14.7.2  Data version: 20140714
Brake booster,4
No display,Medium
Offroad,0
So... the XDS is there and with "Strong" setting. It can be felt easily when cornering. 12.12.2 and 14.7.2 Beta just does not know anything about it.
So please, can you take a look what can be done to have this setting available in coming VCDS versions. Thank you, and greetings from Finland!
DV52
C?ID=194404
Con: your post adds yet another vital piece to this intruding jig-saw puzzle! Many thanks for sharing your incisive observations. As the part numbers for both vehicles appears to be identical, I was keen to replicate your hypothesis- so I tried ver 12.12.2 on my Golf mk7. Access Code was accepted,, the results on my golf were exactly the same - no access (boo-hoo). Also, there was no change in the Adaptation maps bwteen ver 14.7.2 and ver 12.2.2 on my car for address 03.
I'd like to try ver 12.12.0, but I removed the file copy from my laptop (yes, I know that I shouldn't have done this, but the ver 12.12.2 looked so shiny and new!)
Question for the good folk at RT: how does a verified VCDS user get hold of an obsolete version of the RT software?
Check your PMs.
