Page 1 of 3 123 LastLast
Results 1 to 10 of 40
Thread: MkVII Golf - XDS Adaptation
Hybrid View
    May 2014
    Hello VCDS gurus!
    I come seeking advice from those with knowledge about the settings for the Expanded electronic differential lock on a mkVII Golf. Specifically, I'm trying to alter the XDS setting on my car. I have understood from various forums that it is possible to change the setting from “Standard”, “Not activated”, “Weak”, “Medium”, or “Strong” via the adaptation channel for the ABS module.
    The process that I have attempted to use is as follows :
    1, Select [03] ABS
    2. Select 10 Adaptation
    3. From the pull down menu, select “Expanded electronic differential lock”
    4. In the New value box select : “Standard”, “Not activated”, “Weak”, “Medium”, “Strong”
    (These instructions have been taken from " http://golf7vcds.moonfruit.com/driver-convenience/4581555424"
    My problem is that that I can't get to step 4 above because of the error message on the following pic:
    I had thought that there was perhaps a security code for the ABS module, but there is no mention of this in any of the forums that discuss this tweak.
    Has anyone else experienced this problem and if so how has it been resolved?
    Thanks in advance for your replies
    Oh... here's the autoscan report from my car
    Wednesday,25,June,2014,12:25:31:03521
    VCDS Version: 14.6.1.0
    Data version: 20140601
    VIN:    License Plate:
    Mileage: 9713km   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN:    Mileage: 9713km-6035miles
    Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 G    HW: 04E 907 309 A
       Component: 1,4l R4 TSI   H08 7615
       Revision: WAH08---
       Coding: 01250032242405082000
       Shop #: WSC 20604 001 1048576
       ASAM Dataset: EV_ECM14TFS01104E906016G 002010
       ROD: EV_ECM14TFS01104E906016G.rod
       VCID: 26431A2059EACC0A4B-8073
    Readiness: 0000 0001
       Part No SW: 0CW 300 045     HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 4510
       Revision: 00043014    Serial number: CU501212296246
       Shop #: WSC 00028 028 00025
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 76E30A60C9CAFC8A3B-8023
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
       VCID: 7DF1154CECFCAFD27A-8028
       Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
       Revision: 00001K06
       Coding: 00120004200100011005000012101800
       ROD: EV_ACClimaBHBVW37X_SE37.rod
       VCID: 3561CD6C944CB792F2-8060
       Air quality sensor:
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011234701612
       Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
       ROD: EV_BCMBOSCH_SE37.rod
       VCID: 4385A3B4CA9819224C-8016
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
       Component: WWS    121120  042 0551
       Serial number:         121206042218
       Coding: 0E4DD5
       Component: RLFS  024 0042
       Serial number: Y13M01D03H20M05S37S1
       Coding: 06A8DD
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231233000504
       Coding: 0031151011
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       ROD: EV_EPHVA18AU3700000_VW37.rod
       VCID: 3A7BDE50BD5258EA1F-806F
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Serial number: 003F5R01UHNZ
       Coding: 98CCC000000000005C00000000C800000065
       Shop #: WSC 00028 028 00061
       VCID: 408FACB8DB8E023A51-8015
       Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
       Serial number: 357670000007612C7C0W
       Crash sensor for side airbag; passenger side:
       Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
       Serial number: 358670000006332C7C0V
       Crash sensor for side airbag; rear driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
       Serial number: 3516502AF0CD5EC471C+
       Crash sensor for side airbag; rear passenger side:
       Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
       Serial number: 3526502B30CD5EC2136J
       Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
       Serial number: 3556502B30CD5EC4008M
       Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
       Component: Lenª007 0070
       Revision: --------    Serial number: 08011304220489
       Coding: 0500
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 79F9015CF8D493F256-802C
       Part No SW: 5G0 920 860     HW: 5G0 920 860
       Component: KOMBI         235 0555
       Coding: 27A401082380000801087A00040000
       VCID: 65C15D2C646C071282-8030
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    121 1109
       Revision: --------    Serial number: 0000188941
       Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_AU37.rod
       VCID: 3365F3749A38A9A2DC-8066
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
       Component: E221__MFL-DC1  H13 0035
       Serial number: 02120005290300060291
       Coding: 280000
       Serial number: 3451678601
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Serial number: 0000046453458
       Coding: 003A02208001020000001000
       ROD: EV_DCUDriveSideEWMAXKLO.rod
       VCID: 020B66B09502D02A07-8057
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Serial number: 00000000000000502227
       Coding: 0D0000
       Coding: 01
       ROD: EV_SteerAssisMQB.rod
       VCID: 3D71D54CAC7C6FD23A-8068
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Serial number: 0000048027940
       Coding: 003A00208E01020000801000
       ROD: EV_DCUPasseSideEWMAXKLO.rod
       VCID: 010969BC9004CB321E-8054
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Serial number: 00000000000000502825
       Coding: 050000
       Part No SW: 5G0 035 846 A    HW: 5G0 035 846
       Component: MU-S-N-ER     039 0421
       Serial number: V1F00501130081
       Coding: 02730008FF00000011510001000900001F0100960100010247
       Shop #: WSC 43847 000 1048576
       ROD: EV_MUStd4CPASE_SE37.rod
       VCID: 275D17245EE0D50270-8072
       Media Player Position 1:
       Component: ABT_Std_Nav  H44 0022
       Serial number: VWZ8Z9M3400KZM
       Engine Control Module 2:
       Subsystem 2 - Part No SW: 5G0 919 866 A    HW: -----------
       Component:  ROW 2013  --- 0022
    End-------------------------(Elapsed Time: 03:14)--------------------------
    Verified VCDS User andyvee's Avatar
    May 2014
    Rossendale, Lancashire, UK
    You either haven't got XDS or need a login code
    May 2014
    Quote Originally Posted by andyvee View Post
    Andyvee: Hi and thanks for the reponse.
    Unless the folk that wrote the VW brochure for my model car are telling an untruth (which is entirely possible), I'm certain that I've got XDS on my car! Seriously, it says in the specification table of the brochure that XDS is "standard" on the Australian 103TSI model.
    Which brings me to your "login code" suggestion, which I guess is a question for the (clever, good-looking, wise and good humoured) guys/gals at RT- does flattery help?. Is anyone at Ross Tech aware of a "login code" for the ABS module on MQB platform vehicles and if so, can it be shared with cable users?
    United States
    The only SA code I'm aware of is 40168 but I will mention that the NAR Mk7 (which just made it here) has a conventional parking brake and I believe the Octavia does as well (you know, the click click style handle) so these controllers may vary. For instance the local cars we scanned so far use:
    Brake1UDSContiMK100ESP
    .. and yours has:
    I do not have any XDS comments or contributions but if WVWZZZAUZDP034070 is the real VIN and PL24 decrypted it properly the PR code is:
    Differential lock 1Y3 Differential lock (XDS)
    dynamic traction control
    .. so I agree with the VW brochure but I don't know why it wouldn't be activated.
    May 2014
    .. and yours has:
    Dana.
    Once again, thanks for your response. I'm thanking the staff at RT so often, I fear that I'm starting to sound disingenuous - but I'm not!
    I'll pose my question to one of the Australian forums and see if mine is a unique problem, or if it more prevalent on mk7 Golf's that are sold down here.
  6. #6
    May 2014
    I have asked the question on another forum for you, let you know if I get a response
  7. #7
    May 2014
    andyvee:Thanks for your interest. Next time that you are down this way, I owe you a beer (or two)!
    PS: I tried Dana's magic number (40168) -I know that she wasn't suggesting that it was an answer, but I thought that it was worth a try. The controller accepted the security code. Thought to myself "wow-this is looking real good". But alas my expectations were dashed yet again- ain't fate a cruel mistress? Still got the same error message when I tried to access the XDS channel.
  8. #8
    May 2014
    Melbourne might be a bit far for a couple of beers LOL
  9. #9
    May 2014
    Andyvee: Narrh.... it's not far at all. Just remember to make a right-hand turn at Dover - from there it's all down hill!
  10. #10
    May 2014
    I was just about to post the following:
    Try 40168 or 20103
