Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: MK5 GTI Intermittent Faults/Misfires
    Verified VCDS User GTIF's Avatar
    Jun 2016
    San Diego USA
    ED: Continuation of this thread
    I just got this 07 GTI running after a slipped timing belt. (See: "07 GTI Won't Start, Turns over and fires a couple times" for list of sensors replaced and other work) I cleared codes and I've taken it out for about a 15 mile drive. Getting these intermittent faults and random misfires on multiple cylinders. Could it be a loose ground or signal wire? Not sure where to go here. Thanks.
    Saturday,08,October,2016,09:38:45:50930
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WVWFV71K37W16XXXX   License Plate: GTIF
    Mileage: 333180km-207028mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    VIN: WVWFV71K37W166153   Mileage: 333180km-207028miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
       Revision: 5BH15---    Serial number: VWZ7Z0G8013765
       Coding: 0403010A1C070160
       Shop #: WSC 01279 067 57207
       VCID: 2B7BF8198AC3C21A25-807E
    8 Faults Found:
                   P0300 - 008 -  - Intermittent
                        Mileage: 333160 km
                        Time: 20:45:20
                        RPM: 1207 /min
                        Load: 52.5 %
                        Temperature: 15.00C
                        Temperature: 15.00C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.097 V
    000771 - Cylinder 3
                   P0303 - 008 - Misfire Detected - Intermittent
                        Mileage: 333160 km
                        Time: 20:45:55
                        RPM: 2077 /min
                        Load: 51.0 %
                        Speed: 27.0 km/h
                        Temperature: 24.00C
                        Temperature: 15.00C
                        Voltage: 14.097 V
    000770 - Cylinder 2
                   P0302 - 008 - Misfire Detected - Intermittent
                        Mileage: 333160 km
                        Time: 20:45:55
                        RPM: 2077 /min
                        Load: 51.0 %
                        Speed: 27.0 km/h
                        Temperature: 24.00C
                        Temperature: 15.00C
                        Voltage: 14.097 V
    004243 - Bank 1; Fuel Measuring System 2
                   P1093 - 008 - Malfunction - Intermittent
                        Mileage: 333160 km
                        Time: 20:46:10
                        RPM: 1325 /min
                        Load: 12.9 %
                        Speed: 56.0 km/h
                        Temperature: 29.00C
                        Temperature: 15.00C
                        Voltage: 14.351 V
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
                   P0016 - 002 - Incorrect Correlation - MIL ON
                        Fault Status: 11100010
                        Mileage: 333161 km
                        Time: 20:47:11
                        RPM: 2887 /min
                        Load: 50.6 %
                        Speed: 56.0 km/h
                        Temperature: 45.00C
                        Temperature: 17.00C
                        Voltage: 14.224 V
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 001 - Malfunction - Intermittent
                        Fault Status: 00100001
                        Mileage: 333162 km
                        Time: 20:49:45
                        RPM: 808 /min
                        Load: 16.1 %
                        Speed: 3.0 km/h
                        Temperature: 70.00C
                        Temperature: 20.00C
                        Voltage: 14.097 V
    008825 - Leak in Air Intake System
                   P2279 - 002 -
                        Fault Status: 01100010
                        Mileage: 333162 km
                        Time: 20:50:05
                        RPM: 748 /min
                        Load: 16.1 %
                        Temperature: 72.00C
                        Temperature: 20.00C
                        Voltage: 13.843 V
    008196 - Intake Manifold Flap; Bank 1
                   P2004 - 008 - Stuck Open - MIL ON
                        Fault Status: 11101000
                        Mileage: 333170 km
                        Time: 21:02:29
                        Temperature: 81.00C
                        Temperature: 32.00C
                        Voltage: 12.954 V
    Readiness: 0000 0001
       Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
       Component: GSG DSG         070 1306
       Revision: 04607000    Serial number: 00000612040951
       Shop #: WSC 01279 785 00200
       VCID: 2265153DFD09035296-8076
    18243 - Pressure Control Valve 5 (N233)
                P1835 - 000 - Short to Plus - Intermittent
                        Fault Frequency: 255
                        Reset counter: 8
                        Mileage: 333169 km
       Revision: 00H11001
       Coding: 0021122
       VCID: 73CB20791273DADAAD-8026
       Part No: 1K0 820 047 GS
       Component: Climatic PQ35   120 0606
       VCID: 7BDB08593A23929AF5-802E
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000006559540
       Coding: 178D8F214004150047140000001400000028770B5C0001
       Shop #: WSC 22580 444 57677
       VCID: 6CF93B054F4D05226C-8038
       Component: Wischer 201206 020  0501
       Coding: 00038805
       Shop #: WSC 22580
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7F0024301
       VCID: 2E7DF10DB9D1B73202-807A
                        Reset counter: 253
                        Mileage: 333157 km
                        Time: 04:18:46
    02788 - Internal Communications Error
                        Fault Frequency: 46
                        Reset counter: 1
                        Mileage: 333170 km
                        Time: 21:18:34
                        Bin. Bits: 00000000
                        Bin. Bits: 00000001
       Component: 5L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D07R6RE
       Coding: 0013644
       Shop #: WSC 01269 785 00200
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME151A07522
       Subsystem 3 - Serial number: 6342MSME156A6B6EV
       Subsystem 4 - Serial number: 6352QSME1C76133DN
       Subsystem 5 - Serial number: 6362QSME1E183E4D-
       Subsystem 6 - Serial number: 63727SME0B640C2E9
       Subsystem 7 - Serial number: 63827SME0B771B200
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
    00591 - Seat Belt Switch; Driver (E24)
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           636 0070
       Coding: 0012122
       VCID: 77D31469060BB6FA91-8022
       Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWZ7Z0G8013765
       Coding: 0007207
       Shop #: WSC 22580 444 53700
       VCID: 3147EA71A8EFA8CA1F-8064
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 070107F1001226
       Coding: 7F8F03600F000000
       VCID: 2F43EC09BEDBBE3A09-807A
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T1QSF03
       VCID: 7DDF064124379CAACB-8028
       Component: IMMO            VDD 1610
       Component: Tuer-SG         005 0983
       Coding: 0001077
       VCID: 3851D7554B95798258-806C
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 3449E36557FD9DE274-8060
       Component:    KSG PQ35 RDK 052 0218
       Coding: 139006885103281B0904058FB0080A04889C00
       Shop #: WSC 22580 444 999999
       VCID: 042973A547DDED6284-8050
       Coding: 0001076
       VCID: 3957D251709F608AA7-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74C92365177DDDE2B4-8020
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio PM6       017 0023
       Revision: 00017000    Serial number: VWZ5Z7F2121101
       Coding: 0040401
       VCID: 24691325E71D0D62E4-8070
       Component:    RDK              0440
       Coding: 0100101
    End-------------------------(Elapsed Time: 01:11)--------------------------
    Good Thing It's Fast! '07 GTI Fahrenheit
    Sep 2016
    Riga, Latvia
    If You are sure that all timing is done correct, You have got damaged at least one camshaft after timing belt issues.
    I disagree......Not with open circuits..........
    Jun 2016
    San Diego USA
    Cleared codes again and got one fault almost right away. CMP and ESS incorrect correlation. Given the rattling diesel sound in the top end I chose to order a cam chain and tensioner and wait till they get here. Back on it next weekend.
  5. Likes themadscientist liked this post
    Jun 2016
    San Diego USA
    The top nylon slider on the tensioner was broken in two. No other obvious damage. Cams look good. I can't get the adjuster bolt out though. Using an impact gun with 120 psi at the gauge and 50 ft of hose. I'm holding it on there for 20-30 seconds at a time with no sign of movement. And, yes, it's in reverse. I don't have an acetylene torch, but would heat be appropriate on this if I did? What else can I do to get it loose? It must have Loctite on the threads, all the cover bolts did.
    That sir is the sign of a broken keyway on the adjuster barrel.
    Here is a trick how to get it loose.
    Heat head of bolt cherry red with an acetylene torch or MAP gas torch you can buy cheap in Home Depot or Lowes etc.
    Than while still hot immediately put the impact hammer on it and it will back out easy.
    Do not reuse this bolt because it's a stretch bolt anyway.
    NostraJackAss Has Spoken!
  8. Likes Jetta ,97 liked this post
    Jun 2016
    San Diego USA
    I have a propane torch, slightly less hot than MAPP, but should do the same trick. I tried spraying with Aero Kroil and let it sit for a couple hours, then put the air up to 150psi and still no joy. I'll try heat. I hope it does come out easy then, because I sure don't want to have to drill it out.
  10. #8
    Yeah penetrant isn't going to help with this due to shear TQ on the stretch bolt.
    Kroil is an excellent fluid though........pretty much anything from Kano is the stuff to use.
    This is also a sign of a lubrication issue in the sump...........
    When and if you see it is sheared .......A solution?
    "I tig weld the cam to the barrel adjuster, and further hard weld it so it can never do this again"!
  11. #9
    Jun 2016
    San Diego USA
    I tried a propane torch, slightly less hot than MAPP, thinking it would do the same trick. That was pitifully inadequate.
    I had an acetylene torch in the garage and got it in there. 5 minutes of heat and no luck, then another 5 minutes of more concentrated heat with the torch up a little and BOOM! out it came.
    Thanks Jack. Need I say, you da man! (but don't let it go to your head) I already had the replacement bolt before I started.
    EDIT: I didn't see your reply till I posted this. If you weld the barrel adjuster to the cam, that would make it difficult, if not impossible, to change the tensioner and chain, no?
  12. Likes Uwe liked this post
  13. #10
    Nope........... because the barrel tensioner can be disassembled, and or you can install the cams in the head directly....... using the bearing caps to achieve the same thing as the weld point blocks and lose the bolt access which weakens the thing anyway, due to being inadequate TQ to begin with.
    Pictures of what you have there?
