I have a US speed MK6 Jetta and a 2012 Beetle that I am going to be taking to Canada, so I wanted to switch the instrument cluster to display the mileage as kilometers instead of miles. After poking around in module 17 (Instruments) I couldn't find any way to change the display, although I did see that the mileage is stored in KMS already.
Anyone have any idea's on how to make my car display the current mileage as KMS? Here's the Beetle dump.
Wednesday,14,May,2014,10:54:34:43690 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.5.0.0 (x64)
Data version: 20140501
VIN: 3VWD07AJ0EM2XXXXX License Plate: GR1Z Mileage: 80km-49mi Repair Order:
Chassis Type: AJ (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 75 77
VIN: 3VWD07AJ0EM2XXXXX Mileage: 80km-49miles
03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CPKA)
Part No SW: 06K 906 070 D
Component: Simos12.2 H09 6864
Revision: --H09--- Serial number: 00000000000000 Coding: 001A0012242400160000
Shop #: WSC 00066 000 00184
ASAM Dataset: EV_ECM18TFS02006K906070D 001010 ROD: EV_ECM18TFS02006K906070D.rod
VCID: 2B55C05B42AF9A6322-807E
No fault code found. Readiness: 0000 0100
Address 02: Auto Trans (J217) PartNoSW:09G927749A Component: AISIN AG6 G3 101 Coding: 000348
Shop #: WSC 00066 000 00184 ASAM Dataset: EV_TCMAQ250031 ROD: EV_TCMAQ250031_SK37.rod VCID: 377DEC2B8EE72E8356-8062
Labels: None HW:09G927749A 2659
001004
Labels: None HW: 06K 907 425
------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: A14B400C492400FC850D02EB92220041A71000
VCID: 7DF13E03E45BC4D3CC-8028
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BA HW: 5C0 820 047 BA
Component: J301 Klimaanlage 0204
Revision: 2001012S Serial number: 00000001771043
VCID: 60CF6777B3E9093BC7-8035
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
PartNoSW:5C0937087J HW:5C0937087A
Component: BCM25 JLB H3 H34 0411
Revision: B2034001 Serial number: 08018258130020
Coding: 7B994B1808230F0000382000240884C500C2502E60000000300050002000
Shop #: WSC 07807 444 122406
VCID: 3467DB279791C59B73-8061
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels:
6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels:
6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD010ZJ
Coding: 00004138
ROD: EV_AirbaVW10SMEVW360.rod VCID: 74E71B27DF11859BB3-8021
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046 Serial number: 6940000Y130000XGR90D
Coding: 303036
Serial number: 3572MSME1167547CZZZ-
Component: S.Sens.Beif.V H02 ---- Serial number: 3582MSME1C20617BZZZY
Component: S.Sens.Fahr.H H02 ---- Serial number: 3516KSME0B773E27ZZZ/
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ---- Serial number: 3526KSME4E2F4027ZZZ
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME10162F27ZZZS
Crash sensor for front airbag; passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME52132F27ZZZW
PartNoSW:5C6920953B HW:5C6920953B
Component: KOMBI H04 0809
Coding: 270A01
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 2C57C34747A19D5B2B-8079
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H34 0411
Revision: B2034001
Coding: 102200
VCID: 70EF1737A309B9BB57-8025
Component: IMMO H04 0809
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: 6ADB055F8DD5436B19-803F
End ---------------------------------------------------------------------
