VW Caddy 2011 1.6tdi CR NO ROD File found when reading engine module
silky16v
C?ID=273755
Hi had a suspected injector fault with my 2011 VW Caddy Van 1.6tdi CR today
so manage to limp it home and went to read the codes and when i went in to the engine module i got the below error
so i did a full read of the auto scan here are the results
i've not had any previous issues reading the engine module I've re-installed VCDS and also tried another windows laptop and get the same error code
anyone any ideas of the error as i need to find out which injector is misbehaving
Tuesday,04,October,2016,18:31:48:62485
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
VIN: WV1ZZZ2KZBX266022   License Plate: PN11ZNO
Mileage: 170770km-106111mi   Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 77
VIN: WV1ZZZ2KZBX266022   Mileage: 170770km-106111miles
37-Navigation -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0011
Address 01: Engine (J623-CAYD)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 DB    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8684
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014032500080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM16TDI02103L906023DB 003004
   ROD: N/A
   VCID: 69D9CFAE888DF70A03-803C
No ASAM data for: "EV_ECM16TDI02103L906023DB" (VW36 *)
9840 - ROD - Unknown Error Code
          - 00 [032]
                    Mileage: 170665 km
                    Date: 2016.10.04
                    Time: 15:43:09
9772 - ROD - Unknown Error Code
          - 00 [044]
                    Mileage: 170664 km
                    Date: 2016.10.04
                    Time: 15:42:52
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 433C400D09280300C20B02E6901BC081300000
   Shop #: WSC 35110 377 00160
   VCID: 75E193DEDC3523EA97-8020
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 7N0 907 426 R    HW: 7N0 907 426 R
   Component: AC Manuell    H17 0202
   Revision: 00012001
   Coding: 0000000002
   Shop #: WSC 35110 790 50316
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 43853D06CA61CD5AE9-8016
9477141 - Position Sensor for Air Distribution Flap Motor
          B109C 15 [008] - Open or Short to Plus
                    Reset counter: 74
                    Mileage: 170129 km
                    Date: 2016.10.02
                    Time: 13:21:10
          B10AB F0 [009] - Too Low
                    Reset counter: 6
                    Mileage: 169414 km
                    Date: 2016.09.17
                    Time: 12:48:02
   Part No SW: 2K5 937 085     HW: 2K5 937 085
   Component: BCM PQ35 B+   011 1044
   Revision: BB011001
   Coding: 401A583A8025182A08800082900000640301728852028060648000000040
   VCID: 72EBA8C2AD5B34D2B2-8026
   Subsystem 1 - Part No: 1T2 955 119 A
   Component: Wischer 07011  26  0512
   Coding: 009795
                    Fault Status: 00101010
                    Fault Frequency: 17
                    Reset counter: 80
                    Mileage: 169426 km
                    Date: 2016.09.18
                    Time: 13:19:15
                        Term 15 On
                    Voltage: 11.55 V
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL003L8PC
   Coding: 000000000000000000000000000000003055
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356153DE94B563EA57-8060
   Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number: WHRPIyhsHHH€T
   Coding: 0082160000
   ROD: EV_SMLSNGKUDS_VW36.rod
   VCID: 78FF9AEAC3275E828C-802C
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0478596
   Coding: 820000
267264 - Control Module Incorrectly Coded
          U1014 00 [008] - -
                    Reset counter: 68
                    Mileage: 169931 km
                    Date: 2016.09.28
                    Time: 18:29:18
530190 - Local Databus
          U1030 00 [008] - Electrical Malfunction
                    Reset counter: 56
                    Mileage: 169651 km
                    Date: 2016.09.22
                    Time: 13:02:37
   Part No SW: 5K0 920 970 L    HW: 5K0 920 970 L
   Component: KOMBI         H04 0206
   Coding: 470800
   VCID: 377D59D68EB991FA45-8062
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 220111F1003309
   Coding: 357401
   VCID: 306F62CA63D746C204-8064
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:03
            000 -  -
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:25:59
   Component: IMMO          H04 0206
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0158
   Coding: 0000052
   Shop #: WSC 01324 785 00200
   VCID: 74E7AEDA174F3AE2A0-8020
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 34676EDA57CF7AE260-8060
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: 75E193DE1C3523EA97-8020
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
   Component: Radio RCD510  041 0166
   Revision: 00000001    Serial number: VWZ1Z3L0732897
   Coding: 0100040004
   VCID: 2643849251131872EE-8072
8 Faults Found:
                    Fault Status: 01101011
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:09
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:09
00874 - Treble Speaker Front Left (R20)
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:07
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:07
00876 - Treble Speaker Rear Left (R14)
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:07
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:07
00856 - Radio Antenna
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:17
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:26:17
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661635139
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 2643849259131872EE-8072
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 89
                    Mileage: 161959 km
                    Date: 2016.06.13
                    Time: 19:25:57
End-------------------------(Elapsed Time: 03:29)--------------------------
Address 01: DTCs cleared
Address 08: DTCs cleared
Andy
Sector 7G
HC424490
I just sent you an email (to the same address you used for the forum and for registering with Ross-Tech for tech support) with a potential fix. Please let us know the results.
In the meantime, the faults should mean:
9840 Injector: Cylinder 4 (N33): Circuit Malfunction
9772 Internal Control Module: Processor Fault
That second one is scary.
ref: E?ID=318308
silky16v
C?ID=273755
ref: E?ID=318308
Thanks very much will check it out tomorrow, I hope scary is related to injector fault
John Stratton
C?ID=165387
I have this same issue on my vw Caddy 1.6 TDI . Could you please post how to resolve please or send to my email jdstratton@btinternet.com
Many Thanks
sazimam
Czech Republic
C?ID=217645
Hi Andy,
I have exactly the same issue here in another Caddy 1.6.
Could you please help me too ?
Thanks
Edit - the injector NO4 has a short in it - 0 OHM. So I am sure it just died. Strange is that we all talk about the same one - number 4 ....
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 CT HW: 03L 907 425 C
Component and/or Version: 1,6l R4 CR td H43 8682
Software Coding: 00114014030400080000
Work Shop Code: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023CT 003004 (VN35)
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: 7AFD89D3FD7B1D91A7-802E
9840 - Injector: Cylinder 4 (N33)
P0204 00 [175] - Circuit Malfunction
Mileage: 52408 km
Date: 2066.14.31
Time: 08:31:44
Engine speed: 878.50 /min
Normed load value: 32.5 %
Vehicle speed: 9 km/h
Coolant temperature: 87 °C
Intake air temperature: 14 °C
Voltage terminal 30: 14.231 V
Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
Injector valve 3: capacity-CAPA_INJ_MAIN[2]: 32.1019 µF
Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]: 1462.3 µAs
Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]: 3.526 mJ
Supply voltage of analog output 1-VCC_1: 5.00 V
Supply voltage of analog output 2-VCC_2: 5.02 V
Injection valve 3: voltage-V_INJ_MAIN[2]: 4.82 V
9772 - Internal Control Module
P0606 00 [044] - Processor Fault
Mileage: 52408 km
Date: 2066.14.31
Time: 08:31:38
Engine speed: 2266.25 /min
Normed load value: 82.7 %
Vehicle speed: 34 km/h
Voltage terminal 30: 14.456 V
Accelerator monitoring level-PV_AV_MON: 99.609375 %
Injection release status-LF_INJ_AD_ACT: 0
ASR-torque request-LV_TCS_INC_40: 00000000
Cruise control torque request-LV_TQ_CRU_ACT_40: 00000000
Transmission control module torque request-LV_ETCU_INC_40: 00000000
RPM monitoring level-N_32_MON: 2240 /min
Engine torque-TQI_SP: 199.00 Nm
sazimam
Czech Republic
C?ID=217645
It was just an injector in my case. 10000 km yet with no problem. Just to let all know. Cheers.
