Results 1 to 6 of 6
Thread: VW Caddy 2011 1.6tdi CR NO ROD File found when reading engine module
    Apr 2016
    Hi had a suspected injector fault with my 2011 VW Caddy Van 1.6tdi CR today
    so manage to limp it home and went to read the codes and when i went in to the engine module i got the below error
    so i did a full read of the auto scan here are the results
    i've not had any previous issues reading the engine module I've re-installed VCDS and also tried another windows laptop and get the same error code
    anyone any ideas of the error as i need to find out which injector is misbehaving
    Tuesday,04,October,2016,18:31:48:62485
    VCDS Version: 16.8.2.3
    Data version: 20160926 DS261.0
    VIN: WV1ZZZ2KZBX266022   License Plate: PN11ZNO
    Mileage: 170770km-106111mi   Repair Order:
    Chassis Type: 2K (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 77
    VIN: WV1ZZZ2KZBX266022   Mileage: 170770km-106111miles
    77-Telephone -- Status: Not registered 0011
    Address 01: Engine (J623-CAYD)       Labels: 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 DB    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 8684
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114014032500080000
       ASAM Dataset: EV_ECM16TDI02103L906023DB 003004
       ROD: N/A
       VCID: 69D9CFAE888DF70A03-803C
    No ASAM data for: "EV_ECM16TDI02103L906023DB" (VW36 *)
    9840 - ROD - Unknown Error Code
              - 00 [032]
                        Mileage: 170665 km
                        Date: 2016.10.04
                        Time: 15:43:09
    9772 - ROD - Unknown Error Code
              - 00 [044]
                        Mileage: 170664 km
                        Date: 2016.10.04
                        Time: 15:42:52
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 433C400D09280300C20B02E6901BC081300000
       Shop #: WSC 35110 377 00160
       VCID: 75E193DEDC3523EA97-8020
       Part No SW: 7N0 907 426 R    HW: 7N0 907 426 R
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000000002
       Shop #: WSC 35110 790 50316
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 43853D06CA61CD5AE9-8016
    9477141 - Position Sensor for Air Distribution Flap Motor
              B109C 15 [008] - Open or Short to Plus
                        Reset counter: 74
                        Mileage: 170129 km
                        Date: 2016.10.02
                        Time: 13:21:10
              B10AB F0 [009] - Too Low
                        Reset counter: 6
                        Mileage: 169414 km
                        Date: 2016.09.17
                        Time: 12:48:02
       Part No SW: 2K5 937 085     HW: 2K5 937 085
       Component: BCM PQ35 B+   011 1044
       Revision: BB011001
       Coding: 401A583A8025182A08800082900000640301728852028060648000000040
       VCID: 72EBA8C2AD5B34D2B2-8026
       Subsystem 1 - Part No: 1T2 955 119 A
       Component: Wischer 07011  26  0512
       Coding: 009795
                        Fault Status: 00101010
                        Fault Frequency: 17
                        Reset counter: 80
                        Mileage: 169426 km
                        Date: 2016.09.18
                        Time: 13:19:15
                        Voltage: 11.55 V
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag00U H06 0013
       Revision: --------    Serial number: 003HL003L8PC
       Coding: 000000000000000000000000000000003055
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 356153DE94B563EA57-8060
       Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number: WHRPIyhsHHH€T
       Coding: 0082160000
       ROD: EV_SMLSNGKUDS_VW36.rod
       VCID: 78FF9AEAC3275E828C-802C
       Serial number: 0478596
       Coding: 820000
    267264 - Control Module Incorrectly Coded
              U1014 00 [008] - -
                        Reset counter: 68
                        Mileage: 169931 km
                        Date: 2016.09.28
                        Time: 18:29:18
    530190 - Local Databus
              U1030 00 [008] - Electrical Malfunction
                        Reset counter: 56
                        Mileage: 169651 km
                        Date: 2016.09.22
                        Time: 13:02:37
       Part No SW: 5K0 920 970 L    HW: 5K0 920 970 L
       Component: KOMBI         H04 0206
       Coding: 470800
       VCID: 377D59D68EB991FA45-8062
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 220111F1003309
       Coding: 357401
       VCID: 306F62CA63D746C204-8064
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:03
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:25:59
       Component: IMMO          H04 0206
    Address 37: Navigation
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1T0 959 701
       Component: Tuersteuergeraet 09 0158
       Coding: 0000052
       Shop #: WSC 01324 785 00200
       VCID: 74E7AEDA174F3AE2A0-8020
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 140    3201
       Revision: 00H20000
       VCID: 34676EDA57CF7AE260-8060
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1T0 959 702
       Coding: 0000116
       VCID: 75E193DE1C3523EA97-8020
    00121 - Outside Warning Light/Door exit Light Passenger Side
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
       Component: Radio RCD510  041 0166
       Revision: 00000001    Serial number: VWZ1Z3L0732897
       Coding: 0100040004
       VCID: 2643849251131872EE-8072
    8 Faults Found:
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:09
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:09
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:07
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:07
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:07
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:07
    00856 - Radio Antenna
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:17
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:26:17
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
       Component: TELEFON       H12 2902
       Revision: 1B001001    Serial number: 00007661635139
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 2643849259131872EE-8072
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
                        Reset counter: 89
                        Mileage: 161959 km
                        Date: 2016.06.13
                        Time: 19:25:57
    End-------------------------(Elapsed Time: 03:29)--------------------------
    Address 01: DTCs cleared
    Address 08: DTCs cleared
    Administrator Andy's Avatar
    Sector 7G
    I just sent you an email (to the same address you used for the forum and for registering with Ross-Tech for tech support) with a potential fix. Please let us know the results.
    In the meantime, the faults should mean:
    9840 Injector: Cylinder 4 (N33): Circuit Malfunction
    9772 Internal Control Module: Processor Fault
    That second one is scary.
    ref: E?ID=318308
    Apr 2016
    Quote Originally Posted by Andy View Post
    ref: E?ID=318308
    Thanks very much will check it out tomorrow, I hope scary is related to injector fault
    Sep 2016
    I have this same issue on my vw Caddy 1.6 TDI . Could you please post how to resolve please or send to my email jdstratton@btinternet.com
    Many Thanks
    Nov 2015
    Czech Republic
    Hi Andy,
    I have exactly the same issue here in another Caddy 1.6.
    Could you please help me too ?
    Edit - the injector NO4 has a short in it - 0 OHM. So I am sure it just died. Strange is that we all talk about the same one - number 4 ....
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 CT HW: 03L 907 425 C
    Component and/or Version: 1,6l R4 CR td H43 8682
    Software Coding: 00114014030400080000
    Work Shop Code: WSC 35110 790 50316
    ASAM Dataset: EV_ECM16TDI02103L906023CT 003004 (VN35)
    ROD: EV_ECM16TDI02103L906023DB.rod
    VCID: 7AFD89D3FD7B1D91A7-802E
    9840 - Injector: Cylinder 4 (N33)
    P0204 00 [175] - Circuit Malfunction
    Mileage: 52408 km
    Date: 2066.14.31
    Time: 08:31:44
    Engine speed: 878.50 /min
    Normed load value: 32.5 %
    Vehicle speed: 9 km/h
    Coolant temperature: 87 C
    Intake air temperature: 14 C
    Voltage terminal 30: 14.231 V
    Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
    Injector valve 3: capacity-CAPA_INJ_MAIN[2]: 32.1019 F
    Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]: 1462.3 As
    Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]: 3.526 mJ
    Supply voltage of analog output 1-VCC_1: 5.00 V
    Supply voltage of analog output 2-VCC_2: 5.02 V
    Injection valve 3: voltage-V_INJ_MAIN[2]: 4.82 V
    9772 - Internal Control Module
    P0606 00 [044] - Processor Fault
    Mileage: 52408 km
    Date: 2066.14.31
    Time: 08:31:38
    Engine speed: 2266.25 /min
    Normed load value: 82.7 %
    Vehicle speed: 34 km/h
    Voltage terminal 30: 14.456 V
    Accelerator monitoring level-PV_AV_MON: 99.609375 %
    Injection release status-LF_INJ_AD_ACT: 0
    ASR-torque request-LV_TCS_INC_40: 00000000
    Cruise control torque request-LV_TQ_CRU_ACT_40: 00000000
    Transmission control module torque request-LV_ETCU_INC_40: 00000000
    RPM monitoring level-N_32_MON: 2240 /min
    Engine torque-TQI_SP: 199.00 Nm
    Nov 2015
    Czech Republic
    It was just an injector in my case. 10000 km yet with no problem. Just to let all know. Cheers.
  7. Likes Uwe liked this post
