Results 1 to 7 of 7
Thread: Door Electric (Address 42) Code 00928 and 00105
    Florida
    2006.5 Jetta Tdi 1.9 BRM (83K miles)
    How do you determine if these faults are caused by the wire harness or door lock module? I unplugged the wire harness and cleaned the plug with electronics cleaner cleared the codes and it worked for the day than the codes and problems came back.
    Any help would be great.
    Address 42: Door Elect, Driver Labels:1K0-959-701-MIN3.lbl
    Part No. SW: 1K0-959-701-P HW: 1K0959793L
    Component: J386 TUER-SG FT 1127
    Revision: 12007001 Serial Number: 00000538468922
    Coding: 0001205
    VCID: 3B39A4EF2984B0A2084180-806E
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
    NC USA
    Please post a complete Auto-Scan - there may be things in it that do not seem applicable but in fact very much are.
    Well... looking at the 00928 is does say to check wiring.
    Based on your initial temporary fix I'd check the harness per the wiring diagram, and check your voltage and grounds specificallty (one of those 'other' things we might see in the Auto-Scan)
    Do the lock mechanisms work smoothly mechanically ?
    Florida
    Thanks for your reply Jakematic. Here is a complete scan below. Yes, the lock mechanism works smoothly but I originally had a problem with the locking system intermittently not locking the drivers door. Once I turned off the the automatic locking in the convenience group (The one that automatically locks the doors over 7 miles per hour) I was able to lock my drivers door via remote with no problems. Now I see that the drivers door and hood no longer shows open or closed on the dash display. I did peel back the boot on the harness near the door plug and did not see any broken wires, but I was not able to peel it back far enough to see the wires closer to the door. I am wanting to purchase the harness or module and fix the problem.
    Sunday,22,June,2014,20:09:22:32568
    VCDS Version: 14.6.1.0 (x64)
    Data version: 20140601
    VIN: 3VWCT71K46M848141   License Plate: ERIC1
    Mileage: 133660km-83052mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 56 62 65
              72 7D
    VIN: 3VWCT71K46M848141   Mileage: 133660km-83052miles
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H05---    Serial number: VWZ7Z0F4596756
       Coding: 0050078
       VCID: E484E9B22724071A15-80B1
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000607080501
       VCID: D1EA3066489682B24E-8084
       Revision: 00H11001
       Coding: 0021122
       VCID: F3A69AEE92CA90A29C-80A6
       Part No: 1K0 820 047 FQ
       Component: Climatic PQ35   120 0606
       VCID: F8BCADC28BACF3FAA9-80AD
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Revision: 00H46000    Serial number: 00000000460007
       Coding: 14018E234004150007140000001400000028770B5C0000
       VCID: B73E6EFEC6323C8260-80E2
       Component: Wischer 031006 020  0501
       Coding: 00038805
       Shop #: WSC 00066
                        Fault Status: 00101100
                        Reset counter: 150
                        Mileage: 133611 km
                        Voltage: 14.10 V
       Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
       Component: SDAR SIRIUS     H03 0060
       Revision: 00000000    Serial number: AUZ4Z7F1042387
       VCID: AA18478A0580916AEF-80FF
                        Reset counter: 108
                        Mileage: 133611 km
                        Time: 17:01:39
       Revision: 05034000    Serial number: 003B6D05X7KC
       Coding: 0013889
       VCID: EC948192CFF44F5A5D-80B9
    No Faults Found
       Part No SW: 1K0 953 549 AS    HW: 1K0 953 549 AS
       Component: J0527           035 0070
       Coding: 0012021
       VCID: 8346CA2EC26AA0228C-80D6
       Part No SW: 1K0 920 973 D    HW: 1K0 920 973 D
       Component: KOMBIINSTRUMENT 3HL 1610
       Revision: V0003000    Serial number: VWZ7Z0F4596756
       Coding: 0023203
       Shop #: WSC 05226 444 84503
       VCID: AE104B9A3968FD4A33-80FB
       Coding: 0023203
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 31001068150219
       Coding: 3FBF0B620F001002
       VCID: AC1441920F748F5A1D-80F9
       Component: Kompass         005 0004
       Revision: 000    Serial number: 1293324T2R9D04
       Coding: 0000003
       Shop #: WSC 05054 444 82868
       VCID: B93A68C6F0262AF296-80EC
       Component: IMMO            3HL 1610
       Revision: 12007001    Serial number: 00000538468922
       Coding: 0001205
       VCID: BB3672CEFA1A18E284-80EE
                        Fault Status: 01100101
                        Reset counter: 110
                        Fault Status: 00111000
                        Reset counter: 149
                        Fault Frequency: 29
                        Reset counter: 145
                        Mileage: 131865 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: B42459F2D744D79A45-80E1
       Part No: 1K0 959 433 CD
       Component:    KSG PQ35 RDK 051 0215
       Revision: 00051000    Serial number: 00000000000000
       Coding: 13900F880186281B0904058FB0880F0488DC00
       VCID: F4A499F297C4979A85-80A1
    No Faults Found
    Address 47: Sound System        Labels: 3C0-035-456.lbl
       Part No: 1K6 035 456 A
       Component: 08K Audioverst.     0005
       Revision: 00003000    Serial number: 00000000012956
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1127
       Revision: 12007001    Serial number: 00000018968922
       Coding: 0001204
       VCID: BC3471D2FF141FDA8D-80E9
       Part No SW: 1K0 035 180 G    HW: 1K0 035 180 G
       Component: Radio DE2       145 0176
       Revision: 00145000    Serial number: VWZ4Z7F2129894
       Coding: 0010011
       VCID: A404A9B267A4471AD5-80F1
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1115
       Revision: 12005001    Serial number: 00000000410086
       Coding: 0001168
       VCID: BE307BDAE9080DCAA3-80EB
       Part No SW: 1K0 959 433 CD    HW: 1K0 959 433 CD
       Component:    RDK              0420
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1115
       Revision: 12005001    Serial number: 00000000401112
       Coding: 0001168
       VCID: BFCE06DEEE0204C2A8-80EA
       Revision: 00800000    Serial number:
       VCID: AD124C96346E86520A-80F8
    End-------------------------(Elapsed Time: 02:43)--------------------------
    Last edited by Uwe; 06-25-2014 at 07:34 PM. Reason: Wrapped CODE tags around Auto-Scan
    Could be harness needed in drivers door......... as Jake states, or lock module due to bad micro switch or faulty latch......... worn to nub.
    There was a TSB for this and even service actions for this problem if within warranty.
    The skin pulls from the outside and the repair manual is recommended.
    Ref the length of the screws for locations......... they are different lengths......!
    It is no surprise being these parts are made of straw and human feces.
    At that mile value........ I would just buy a latch and door harness.
    NC USA
    Quote Originally Posted by oceanrunner View Post
    Thank you. Voltage looks reasonable in the 09 freeze frame data.
    I recall a fellow on AudiWorld who went round and round for months refusing to give us a complete scan.
    Once he did it was a serious facepalm moment for all of us... lots of data in there.
    Hrmmm, see below...
    Yep.
    Hours and days of troubleshooting only to do that in the long run...
  6. Likes Jack@European_Parts, Dana liked this post
    Florida
    This is an accurate observation!
    Thank you both for the reply's. I have ordered the new wire harness and door lock actuator mechanism. I have noted the screw locations and lengths - this is a good point.
  8. Likes jakematic, Jack@European_Parts liked this post
    Florida
    I have replaced both and all is well. After opening up the door I was glad I ordered both as I would not like to reopen the door again. Not fun!
    Thanks again.
  10. Likes Uwe, Jack@European_Parts liked this post
