Results 11 to 20 of 26
Thread: Help please 2.0TDI CR Cambelt
    Oct 2014
    Arandjelovac, Serbia
    It is possible to do this with the help of an oscilloscope, but it is necessary to have "known good" signal pattern.
    For example, Alfa 147:
    Perhaps it is suitable for your check with tools?
  2. Likes Sacha35, RyMar liked this post
  3. #12
    Timing can be charted in VCDS advance measuring values.
    This is done by watching the G40 and G28 value displayed, for timing correlation to move into proper spec just like a PD.
    You never lock the pump in CR engines, because it doesn't matter the position and is not timed.
  4. Likes Sacha35, Boki Ar liked this post
  5. #13
    Sep 2016
    Riga, Latvia
    I agree and disagree at the same time, Jack.
    In general pump timing is not important for CR, however a lot of engines have requirement from manufacturer to set timing for pump, too. Guess why
  6. Likes Boki Ar liked this post
  7. #14
    We are not talking about other manufactures and this thread pertains to the VW CR engines which don't.
    I'd say RTFB..........why guess?
    If you have something to say to help the forum understand something, why be cryptic?.....just do it!
    Some pumps are timed due to balance for motion resonance, and the stroke of the PSI to reach a peak point of pump efficiency.
  8. #15
    Sep 2016
    Riga, Latvia
    Exactly! And a lot of VAG CR TDI engines have timing marks on pump sprocket, too
  9. #16
    Next time just say it, don't spray it.......
  10. #17
    Sep 2016
    Hi Guys thank you so much for the information and reply's, sorry its taken me so long in getting back to you but been away all last week and only got home late last night.
    Anyway tried to do what Jack@European_Parts said only to find that the Camshaft Position Sensor (G40) is not listed/showing in the measuring blocks, I know the car has the Camshaft Position Sensor but from what I can see there is no way of testing with VCDS.
    Many Thanks once again and hopefully someone can explain what I am doing wrong or advise on further testing.
  11. #18
    Perhaps you could JPPSG and post an auto-scan...........
  12. Likes Sacha35 liked this post
  13. #19
    Sep 2016
    Thanks Jack
    Please find full scan of the car this morning.
    You will see fault code on Address 46, this is because LED rear lights installed.
    Tuesday,18,October,2016,10:32:30:47835
    VCDS Version: 16.8.3.1 (x64)
    VIN: WAUZZZ8K68A048757   License Plate:
    Mileage: 109690km-68158mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53 55
              56 62 72 77
    VIN: WAUZZZ8K68A048757   Mileage: 109690km-68158miles
    Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 B    HW: 03L 906 022 B
       Component: R4 2,0L EDC   H01 3210
       Revision: --H01---
       Coding: 0104002C18072118
       Shop #: WSC 99999 123 12345
       ASAM Dataset: EV_ECM20TDI03L906022B A01014
       ROD: EV_ECM20TDI03L906022B.rod
       VCID: 244CFA4D2F612462F8-8070
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 P    HW: 8K0 907 379 P
       Component: ESP8 front    H04 0180
       Coding: 160500
       Shop #: WSC 06325 123 12345
       VCID: 468840C5F11D3672C6-8012
       Part No SW: 8K0 907 064 BC    HW: 8K0 907 064 C
       Component: BCM2 1.1      H70 0252
       Coding: 031100
       Shop #: WSC 06325 000 00000
       VCID: 72E0CC15AD15FAD2BA-8026
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0508000018062009
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000005823009
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 T    HW: 4E0 035 729
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 329DM087564020
       Shop #: WSC 00000 000 08192
       VCID: 4A9074F52505D21222-801E
       Subsystem 1 - Part No: 8T0 919 609
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000077250
       Subsystem 3 - Serial number: 0124.04.080000000100010114’
       Subsystem 4 - Serial number: 010114’
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0140
       Revision: D0000000    Serial number: 0130.04.080590
       Coding: 34040000
       VCID: 42805CD5DD350A52EA-8016
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H21 0253
       Revision: 04021001    Serial number: 00000000133453
       Coding: 2600D2994114BF000501000000001D0D4F99030800010141000000
       VCID: 2F6605617EA7973A15-807A
       Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 250408  H05 0060
       Serial number: SWFBIE 0001159
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10116665
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000000405080593
       Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
       Component: MP3-Changer     H42 0390
       Revision: 00042001    Serial number: AUZ5ZBH8379535
       VCID: 2B5E11718ABFEB1A39-807E
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0080
       Revision: 11001001    Serial number: 12501104002886
       Coding: 100003
       Shop #: WSC 06335 123 12345
       VCID: 78F4FE3DCB69908284-802C
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Component: AirbagVW-AU10 H26 0410
       Serial number: 0038JD155YDF
       Coding: 30363434363030303030554A3052384B3053
       VCID: 3C7C222DB7D17CA2A0-8068
       Serial number: 6334MSME3A234031%
       Serial number: 6344MSME336034362
       Serial number: 6352QSME6713277BL
       Serial number: 6362QSME630C4857N
       Serial number: 63732SME62491607Y
       Serial number: 63832SME67171039Y
       Component: Lenks.Modul   H12 0013
       Revision: --------    Serial number: 90315HE6000JN
       Coding: 000016
       VCID: 3D7A2F29A4CB75AA97-8068
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
       Component: KOMBIINSTR.   H15 0221
       Revision: 00100000    Serial number: 7BY72R258
       Coding: 2F34080002003600010400
       VCID: 31620319689381CA03-8064
       Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0092
       Revision: EB302042    Serial number: 4200E08425835D
       Coding: 000003
       VCID: 49924BF9E003D90A2B-801C
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H03 0150
       Serial number: 1800264B140108
    Address 1E: Media Player 2 (R199)       Labels: 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B5E11714ABFEB1A39-807E
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H51 1060
       Revision: 00000000    Serial number: 333EZ087564847
       Shop #: WSC 00976 210 89512
       VCID: 3B7E21317ADF7B9AA9-806E
       Part No SW: 8K0 959 793 B    HW: 8K0 959 793
       Component: TSG FA        H10 0170
       Revision:             Serial number: 0000007127739
       Coding: 011F02201C01410001
       VCID: 3F865521AEC767BA85-806A
       Revision: 00002001    Serial number: 0111326377
       Coding: 011F0662003904400220010000000000
       Shop #: WSC 00546 210 84725
    03389 - Data Set Implausible
                        Reset counter: 36
                        Mileage: 109666 km
                        Date: 2016.10.16
                        Time: 15:56:39
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 T    HW: 8T0 035 223 F
       Component: DSP Prem      H14 0400
       Revision: 00H14003    Serial number: 34814000992200
       Coding: 020101
       Shop #: WSC 12336 024 394758
       Part No SW: 8K0 959 792 B    HW: 8K0 959 792
       Component: TSG BF        H10 0170
       Revision:             Serial number: 0000007118379
       Coding: 011C02201C01410001
       VCID: 3E782825A9CD6EB28E-806A
       Part No SW: 8K0 907 801 D    HW: 8K0 907 801 D
       Component: EPB Audi B8   H04 0050
       Revision: 00000003    Serial number: 00000000115881
       VCID: 3064061D639988C20C-8064
       Part No: 8K0 907 357 B
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 346C0A0D5781B4E268-8060
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 336EY087557256
       VCID: 31620319A89381CA03-8064
       Part No SW: 8K0 959 795     HW: 8K0 959 795
       Component: TSG HL        H06 0170
       Revision:             Serial number: 0000007131093
       Coding: 010C02200001210001
       VCID: 7F061521EE47A7BAC5-802A
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Part No SW: 8K0 959 794     HW: 8K0 959 795
       Component: TSG HR        H06 0170
       Revision:             Serial number: 0000007125393
       Coding: 010C02204001210001
       VCID: 7EF8E825E94DAEB2CE-802A
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H18 1130
       Revision: 00000000    Serial number: 00000005146826
       Coding: 0010920
       VCID: 2C5C126D8FB1EC2230-8078
    End-------------------------(Elapsed Time: 03:51)--------------------------
    Also did Injection amount deviation and Fuel consumption test which if I am right in thinking it Is showing a am a little to advanced on the cam timing but your put me right.
    Tuesday,18,October,2016,10:55:27:47835
                    Address 01: Engine  (03L 906 022 B)
    10:55:09
      IDE00021   Engine speed 833 /min
      IDE00025   Coolant temperature 81 °C
      IDE00351   Main injection: start of activation -4.00 °
      IDE00352   Main injection: duration of activation 522.4 µs
      IDE00357   Fuel temperature 29.8 °C
      IDE00365   Injection amount deviation cylinder 1 -0.51 mg/stroke
      IDE00366   Injection amount deviation cylinder 2 0.14 mg/stroke
      IDE00367   Injection amount deviation cylinder 3 0.19 mg/stroke
      IDE00368   Injection amount deviation cylinder 4 0.19 mg/stroke
      IDE00371   Fuel consumption 0.72 l/h
      IDE00472   Mean injection quantity 6.14 mg/stroke
      ENG107474   Lambda probe oxygen concentration 695.2 mV
    Thanks again for all your help if there are any other tests I can do please let me know.
  14. #20
    Sep 2016
    Bump
    Any advice Jack@European_Parts ?
