Hi guys
I have a problem with a Golf mk6 2.0tdi abs unit. Car was crashed, airbags deployed, Car was parked in yard for a while without driver side dors (RHD car), rain water damaged instruments and can module. I have replaced can module, fixed instruments (they working just no immo comunication) and turned off immo in ecu. I lost long coding for abs unit. Is it posible to calculate coding from autoscan?
Thanks in advance
Regards
Andrew
Thursday,29,September,2016,17:47:35:29218
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: WVWZZZ1KZCP009596 License Plate: 11LD1320
Mileage: 177130km-110063mi Repair Order: 123
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 56 61 77
VIN: WVWZZZ1KZCP009596 Mileage: 177130km-110063miles
25-Immobilizer -- Status: Not registered 0001
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 GC HW: 03L 907 309 N
Component: R4 2,0L EDC H24 7111
Revision: 47H24--- Serial number: 00000000000000
Coding: 00190012042501080000
Shop #: WSC 00028 028 00070
ASAM Dataset: EV_ECM20TDI01103L906018GC 003004
ROD: EV_ECM20TDI01103L906018GA.rod
VCID: 71E9BE6EA0DB38CA5F-8024
4638 - Engine Oil Temp. Sensor (G8)
P0196 00 [039] - Implausible Signal
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:50
Coolant temperature: 16 °C
Intake air temperature: 15 °C
Voltage terminal 30: 11.960 V
Fuel consumption: 0.00 l/h
Engine oil temperature: 79.3 °C
Oil warning threshold: 22.388 mm
Control Module temperature: 15.5 °C
Oil fill level: 0.000 mm
Outside air temperature: 14.5 °C
Fuel temperature: 14.4 °C
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
ACC target acceleration: 0.000 m/s˛
ACC control module received status-Bit 0: 00000110
Status of ACC/CCS acceleration interface-Bit 0: 00000000
Acceleration: 0.000 m/s˛
Engine status: COENG_READY
Cruise Control System (CCS): status-Bit 0: 00101000
5523 - Engine Start Blocked by Immobilizer
P1570 00 [167] - -
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
Immobilizer snapshot A-Sia Error Snap A: 14 80 09
Immobilizer snapshot B-Sia Error Snap B: 02 00 00
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Shop #: WSC 00028 028 00001
VCID: 7BF59C46FA97429AF5-802E
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:45
Count: 7
Count: 2
Count: 4096
Count: 195
Count: 42496
Count: 256
Fault Status: 01100101
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:45
Count: 2
Count: 2
Count: 4096
Count: 279
Count: 42496
Count: 256
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:45
Count: 7
Count: 2
Count: 4096
Count: 295
Count: 42496
Count: 256
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:45
Count: 2
Count: 2
Count: 4096
Count: 270
Count: 42496
Count: 256
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004003
Shop #: WSC 00028 028 00023
VCID: 7F0D6856E68F5EBAD9-802A
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 48180A3A8825F100400800C0340000E44B510288436D8160648087200041
VCID: 31697E6E685B78CA1F-8064
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 25051 26 0512
Coding: 009795
Component: RLS 170611 05 54 0403
Coding: 0230AD
Component: LIN BACKUP HO H11 9005
00927 - Terminal 30 (Right)
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
Voltage: 11.95 V
Term 50 On
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA5SY0%
Coding: 00003954
Shop #: WSC 00028 028 00056
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 31697E6E605B78CA1F-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME4C0C564DZZZ6
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2D4A3260ZZZY
Serial number: 3512QSME74210C45ZZZQ
Serial number: 3522QSME76120C12ZZZN
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KFF000IT
Coding: 1082140000
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 72EBB162A5DD03D2A6-8026
Component: E221__MFL-TK6 H06 0022
Serial number: 30000000000000323716
Coding: E30000
Part No SW: 5K0 920 972 A HW: 5K0 920 972 A
Component: KOMBI H03 0607
Coding: 470B00
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 2E5365127165673202-807A
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
Mileage: 177132 km
Date: 2016.06.04
Time: 13:57:51
13639427 - Please Check Fault Codes in Engine Control Module
U101F 00 [009] - -
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 170311F2001083
Coding: 350001
Shop #: WSC 05314 123 12345
VCID: 3467777A97494DE274-8060
01304 - Radio
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:50
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:46
03272 - Control Module for Audio Interface
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:50
Address 25: Immobilizer
Address 2E: Media Player 3
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2104
Coding: 0131636
VCID: 377D4076463FA6FA51-8062
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
VCID: 3467777A57494DE274-8060
Fault Status: 11100101
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
Battery Volts: 12.0 V
DD
Temperature: 20.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 00000008
VCID: 6FEDB816BEEF2E3A49-803A
02174 - Analog/Digital clock
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:49
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 J HW: 5K0 959 702 J
Coding: 0131892
VCID: 3A7B5942752DBB92AE-806E
Address 56: Radio
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1614
Coding: 030B185A
VCID: 71E9BE6EA8DB38CA5F-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900652045
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660213375
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA.rod
VCID: 3467777A9F494DE274-8060
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
0022 - Radio
U1066 00 [009] - No Communication
Reset counter: 144
Mileage: 177133 km
Date: 2016.09.29
Time: 00:16:44
End-------------------------(Elapsed Time: 02:52)--------------------------
Regards
Andrew
