Results 1 to 5 of 5
Thread: VW Transporter 5 GP DPF Exhaust Gas Temp Sensor Fault
    Apr 2016
    Hi I have a 2010 2.0l Transporter 5 GP. Engine code CAAC. Flashing coil light on, scanned using VCDS and comes up with codes 4911 & 5257 - Exhaust Gas Temperature Sensor; B1 S3 - P242A 00 [036] - Malfunction. I cleared faults and ran for a while then came back. First scan shows sensor 3 (pre DPF) as 1000∞C, (which I think is open circuit). I cleared the codes, started the engine and did a live measure of values, Exhaust gas temperature sensor 3 was showing a value of 113.4 ∞C.
    Does it look like sensor 3 is faulty / on its way out? Posted below are the scan and some live data for DPF / EGT sensors etc.
    Thanks in advance for any advice / help. Also appreciate any info on how to interpret the state of the DPF soot / ash levels.
    Scan:
    Wednesday,28,September,2016,20:54:28:30670
    VCDS Version: 16.8.1.3
    Data version: 20160902 DS256
    VIN: WV1ZZZ7HZAH243635   License Plate: WN10EAC
    Mileage: 101090km-62814mi   Repair Order: 28-09-16(2)
    Chassis Type: 7H (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
    VIN: WV1ZZZ7HZAH243635   Mileage: 101090km-62814miles
    Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
       Component: R4 2,0L EDC   X32 9970
       Revision: 26X32---    Serial number: 00000000000000
       Coding: 01194012233400080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
       ROD: EV_ECM20TDI01103L906022CH.rod
       VCID: 6DD19296BCE6302A75-8038
    4911 - Exhaust Gas Temperature Sensor; B1 S3
                        Mileage: 101075 km
                        Date: 2016.09.28
                        Time: 20:02:40
                        Engine speed: 1541.00 /min
                        Normed load value: 57.6 %
                        Vehicle speed: 34 km/h
                        Coolant temperature: 53 ∞C
                        Intake air temperature: 28 ∞C
                        Voltage terminal 30: 14.380 V
                        Exhaust gas temperature sensor 1: 280.1 ∞C
                        Exhaust gas temperature sensor 2: -0.0 ∞C
                        Exhaust gas temperature sensor 3: 1000.0 ∞C
                        Exhaust gas temperature sensor 4: 250.1 ∞C
                        Shut-off timer: last engine shut-off time: 47563 s
                        Mileage: 101075 km
                        Date: 2016.09.28
                        Time: 20:02:36
                        Engine speed: 1594.00 /min
                        Normed load value: 76.9 %
                        Vehicle speed: 35 km/h
                        Coolant temperature: 52 ∞C
                        Voltage terminal 30: 14.400 V
                        Exhaust gas temperature sensor 1: 314.0 ∞C
                        Exhaust gas temperature sensor 4: 252.8 ∞C
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0103
       Revision: 00H43001
       Coding: 508724AD89A80A9824A89174A96310
       Shop #: WSC 02736 790 49152
       VCID: 346747F2974CA1E27A-8060
    Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
       Part No SW: 7E5 907 047 T    HW: 7E5 907 047 T
       Component: Climatic-T5   H10 0101
       Revision: 00004001
       Coding: 0000000002
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ClimaticT5 A01002
       ROD: EV_ClimaT5Basis.rod
       VCID: 408F1B22DBF40D42EE-8014
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 31
                        Mileage: 101073 km
                        Date: 2016.09.28
                        Time: 19:59:07
    Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
       Part No SW: 7H0 937 087 H    HW: 7H0 937 087
       Component: BCM T5GP H+4  H47 0254
       Revision: BO047001    Serial number: 0429 272120758
       Coding: B8A030382E212033002808102C2B8CD40080430F60000000320000000000
       Shop #: WSC 02736 790 12345
       VCID: 397976C6B02E5C8AA9-806C
       Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-801.CLB
       Component: J386__TSG_FT  003 3310
       Coding: 050000
       Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-802.CLB
       Component: J387__TSG_BT  003 3310
       Coding: 040000
       Subsystem 3 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP  H4ˇ 0021
       Serial number: 10000000000000083963
       Coding: E20000
       Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
       Component: VW10Airbag00Y H05 0011
       Revision: --------    Serial number: 003E500160H3
       Coding: 000000000000000000000000000000003059
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 346747F29F4CA1E27A-8060
       Part No SW: 7E0 920 960 A    HW: 7E0 920 960 A
       Component: KOMBI         H16 0111
       Coding: 460800
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
       ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
       VCID: 275DA0BE5E9ADA7ACF-8072
    Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H47 0254
       Revision: BO047001
       Coding: 042300
       VCID: 70EF8BE2A3D4DDC25E-8024
       Component: IMMO          H16 0111
    Address 56: Radio
    Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
       Component: Anhaenger     H07 0100
       Revision: 3A001001    Serial number: 00000132260014
       Coding: 0100000100000000
       VCID: 306F4BE263549DC21E-8064
    End-------------------------(Elapsed Time: 03:25)--------------------------
    Live data after fault codes were cleared:
                    Address 01: Engine  (03L 906 022 CH)
    20:58:13
      IDE00427   Particle filter: difference pressure 5 hPa
      IDE00428   Particle filter: offset for differential press. 1 hPa
      IDE00432   Particle filter: time since last regeneration 11332 s
      IDE00433   Particle filter: oil ash volume 0.08 l
      IDE00434   Particle filter: soot mass calculated 6.58 g
      IDE00435   Particle filter: soot mass measured 1.87 g
      IDE00436   Particle filter: kilometers since last regeneration 97598 m
      IDE01361   Exhaust gas recirculation (EGR) cooler pump: specified value 95.00 %
      IDE01373   EGR valve: offset closed 0.65 %
      IDE01374   EGR valve: offset open -0.65 %
      IDE01405-ENG104207   Status of starter activation-Bit 0 2
      IDE01406-ENG104207   Service regeneration: status-Bit 0 0
      IDE01407   Particle filter: fuel consumption since last regeneration 8.50 l
      IDE01408   Charge limit for field regeneration 23.13 g
      IDE01409   Charge limit for service regeneration 40.00 g
      IDE02229   Exhaust gas temperature sensor 1 158.4 ∞C
      IDE02233   Exhaust gas temperature sensor 2 -0.0 ∞C
      IDE02234   Exhaust gas temperature sensor 3 113.4 ∞C
      IDE02236   Exhaust gas temperature sensor 4 100.1 ∞C
      IDE03270   Exhaust gas temperature sensor 1: unconditioned voltage 796.6 mV
      IDE03271   Exhaust gas temperature sensor 2: unconditioned voltage 0.0 mV
      IDE03273   Exhaust gas temperature sensor 3: unconditioned voltage 732.2 mV
      IDE03275   Exhaust gas temperature sensor 4: unconditioned voltage 712.8 mV
      IDE03353   Particle filter differential press. sensor: uncond. voltage 1042.0 mV
      IDE03383   Exhaust mass flow of EGR 0.0 kg/h
      IDE04652   Exhaust gas jet volume in particle filter 59.4 m≥/h
      IDE04653   Simulated particle filter surface temperature 117.1 ∞C
    Sep 2016
    From what I've experienced on the CR TDI engines, that is a bad temp sensor.
  3. Likes Uwe liked this post
    Are EGT's missassigned in diagnostic stack?
    Block values appear different from DTC's.
    Make sure you pull electrical connectors and for each sensor to be sure of locations.
  5. Likes Uwe liked this post
  6. #4
    Apr 2016
    Not sure which is sensor #2 as i have read that the location / block is not used on this van and it shows as -0.0 ∞C on the scan.
    However, looking at another van with the same problem on sensor #3, there is a reading for sensor #2 so a bit confused ... scan below:
    Part No S 03L 906 022 CH H 03L 907 309 K
    Mileage: 101075 km
    Date: 2016.09.28
    Time: 20:02:40
    Mileage: 101075 km
    Date: 2016.09.28
    Time: 20:02:36
    scan of other van:
    Address 01: Engine (J623-CAAA) Labels: 03L-906-022-CAA.clb
    Part No S 03L 906 022 CB H 03L 907 309 K
    Component: R4 2,0L EDC H41 9116
    Revision: 26H41--- Serial number: 00000000000000
    Coding: 01114010230400080000
    Shop #: WSC 00005 210 100502
    ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
    ROD: EV_ECM20TDI01103L906022CB.rod
    VCID: 67DDE0BE9E1A1A7A01-8032
    P242A 00 [175] - Malfunction
    Mileage: 160957 km
    Date: 2016.07.30
    Time: 11:19:57
    Engine speed: 2446.00 /min
    Normed load value: 73.7 %
    Vehicle speed: 104 km/h
    Coolant temperature: 93 �C
    Intake air temperature: 38 �C
    Exhaust gas temperature sensor 1: 602.5 �C
    Exhaust gas temperature sensor 2: 473.1 �C
    Exhaust gas temperature sensor 3: 1000.0 �C
    Exhaust gas temperature sensor 4: 337.4 �C
    Shut-off timer: last engine shut-off time: 376 s
    13811 - Exhaust Gas Temperature Sensor; B1 S3
    P242B 00 [237] - Range/Performance
    Mileage: 161557 km
    Time: 00:00:00
    Coolant temperature: 14 �C
    Intake air temperature: 15 �C
    Voltage terminal 30: 12.480 V
    Exhaust gas temperature sensor 1: 15.8 �C
    Exhaust gas temperature sensor 2: 18.0 �C
    Exhaust gas temperature sensor 4: 16.1 �C
    Shut-off timer: last engine shut-off time: 51825 s
    5568 - Sensor for Ambient Air Temperature (G17)
    P0073 00 [032] - Signal too High
    Mileage: 160929 km
    Date: 2016.06.15
    Time: 11:24:47
    Coolant temperature: 15 �C
    Intake air temperature: 17 �C
    Voltage terminal 30: 11.680 V
    Unlearning counter according OBD: 20
    Exhaust gas temperature sensor 1: 17.1 �C
    Exhaust gas temperature sensor 3: 20.0 �C
    Exhaust gas temperature sensor 4: 18.0 �C
    Shut-off timer: last engine shut-off time: 39962 s
    8623 - Sensor for Ambient Air Temperature (G17)
    P0071 00 [032] - Implausible Signal
    Mileage: 160929 km
    Date: 2016.06.15
    Time: 11:24:45
    Voltage terminal 30: 11.360 V
    Exhaust gas temperature sensor 1: 17.0 �C
    Shut-off timer: last engine shut-off time: 39961 s
    Mileage: 160957 km
    Date: 2016.07.30
    Time: 11:19:52
    Engine speed: 2487.00 /min
    Normed load value: 52.5 %
    Vehicle speed: 105 km/h
    Intake air temperature: 39 �C
    Exhaust gas temperature sensor 1: 812.4 �C
    Exhaust gas temperature sensor 2: 562.0 �C
    Exhaust gas temperature sensor 4: 328.5 �C
    Readiness: 1 2 0 0 0
    Sep 2016
    Ireland
    different engine codes in them vans. In tdi pd engines lambda sensor is counted as egt sensor... i mean 1st egt sitting in turbo, 2nd is a lambda, 3rd in top of dpf (below lambda) and 4th in the bottom of dpf. Not all lambdas checking temperature, thats why you have 0 degrees in mvb on sensor number 2.
    Mileage: 101075 km
    Date: 2016.09.28
    Time: 20:02:36
    You need to replace sensor number 3, shows 1000 degrees when fault come on.
  8. Likes langyyyy liked this post
