Tuesday,27,September,2016,17:11:23:55621VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WA1LFAFP8CA012511 License Plate: AUDI
Mileage: 108950km-67698mi Repair Order:
Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
62 6C 6D 72
VIN: WA1LFAFP8CA012511 Mileage: 108950km-67698miles
Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0002
Revision: E1H20---
Coding: 0121010A290F0160
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
ROD: EV_ECM20TFS0118R0907115P.rod
VCID: 41897AF6D0508F4AE1-8014
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 T HW: 0BK 927 156 R
Component: 0BK 20TFSIUSA H08 1003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
ROD: EV_TCMAL551211_AU48.rod
VCID: 4E9351CA110E60326C-801A
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 121D18
VCID: 45816EE6CC78A36ADD-8010
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H05 0435
Coding: 0D0500
Shop #: WSC 06335 000 00000
VCID: 0305B0FE82CC5D5AB3-8056
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000131297011
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01200620110317
Coding: 64112000
VCID: 000FBFF293DA4642AE-8054
00711 - Left Footwell Flap Positioning Motor (V108)
001 - Upper Limit Exceeded
Fault Status: 01100001
Reset counter: 226
Mileage: 106680 km
Date: 2016.08.20
Time: 10:33:33
Voltage: 13.30 V
Temperature: 23.0°C
Temperature: 26.0°C
Count: 15811
Count: 23077
Bin. Bits: 01000000
Bin. Bits: 00000001
Time: 33.00 s
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001114096
Coding: 26001091073C8F010000080300001D0D0F1C460802010161000000
VCID: 3C770B02BFB2E2A2B2-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110615 H11 0050
Serial number: 90243014110614191542
Coding: 01DD13
Component: RLS H04 0003
Serial number: 11512826
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001506110275
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0081
Revision: 11001001 Serial number: 12501117500229
Coding: 300105
Shop #: WSC 42399 444 13805
VCID: 78FFD712CB0A0E8296-802C
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H44 0610
Serial number: 003GPD0NAVB3
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479D64EEFE74B17A2F-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100004MVA
Serial number: 6334MSME607209052
Serial number: 6344MSME6071394DH
Serial number: 6352QSME010D0F4AK
Serial number: 6362QSME240C377AN
Serial number: 63732SME1F5B134C8
Serial number: 63832SME534F1650$
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KFM001X7
Coding: 000017
VCID: 3D710606A4A8EBAA85-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 G HW: 8R0 920 981 G
Component: KOMBIINSTR. H41 0639
Revision: 00100000 Serial number: JUZ768L6C
Coding: 831722000300D705020000
VCID: 3E73010AA9AEF0B29C-806A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E115310322
Coding: 00C303
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790656003
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0075
Revision: AA000000 Serial number: 00000006231729
Coding: 00581B00000000000000
VCID: 428B75FADD569452F8-8016
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000117677243
Coding: 011D13205E00440004
VCID: 4A9B5DDAE5664C1230-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0151324427
Coding: 0126023A20FA749584B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000406288
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
03123 - Terminal 30 - 2
Fault Status: 00101011
Reset counter: 12
Mileage: 79138 km
Date: 2015.04.11
Time: 18:16:53
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804007353502
VCID: 7AFBCD1AF5061C92E0-802E
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000117513176
VCID: 499962D6E060470A39-801C
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000815276
VCID: 3467232297E22AE27A-8060
Part No: 8K0 907 357 D
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3663192A419E38F244-8062
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H51 0076
Revision: AB001007 Serial number: 156FX0B7519132
Coding: 020007010000000001
VCID: 1F4DDC8E0E6499BAB7-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
Component: H-BN-NA H52 0165
Revision: -------- Serial number: 490F+0B7625367
Coding: 010200060005A1EF41000B0E000000030000
VCID: 39791216B080D78AA9-806C
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466F/0B0609890
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000861831
Component: CD-Database 2712
Reset counter: 245
Mileage: 108403 km
Date: 2016.09.19
Time: 08:08:34
Voltage: 14.60 V
Bin. Bits: 00000000 00010000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000006418957
Coding: 010C13204000240004
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J1XA3JO
Coding: 1020010
VCID: 3467232257E22AE27A-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H51 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B75081EBABCE59ABB-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H51 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000006418976
End-------------------------(Elapsed Time: 04:08)--------------------------
