Results 1 to 5 of 5
Thread: Who turned on 18017/P1609 and/or activated crash shutdown 2000km after crash?
    Sep 2016
    Riga, Latvia
    Yesterday I had Touran in for diagnostics - engine was jerking and even sometimes stalls.
    I don't know complete history of this vehicle, facts I know:
    - car had a little crash some weeks ago (small crash, no airbags deployed);
    - car was repaired and engine works fine, some approx 2000km were driven;
    - car was repaired in another workshop after crash, I don't know, someone was looking at electronics, fault codes, cleared them or not. Probably noone did it;
    - car came to our workshop with engine performance problem, fuel filter was replaced first, it didn't change anything.
    First scan of this car:
    Thursday,22,September,2016,15:15:44:32442
    VCDS Version: 16.8.1.1
    Data version: 20160902 DS256
    VIN: WVGZZZ1TZ4W050528   License Plate:
    Chassis Type: 1T (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
    VIN: WVGZZZ1TZ4W050528   Mileage: 282660km-175636miles
    42-Door Elect, Driver -- Status: Malfunction 1010
    56-Radio -- Status: Sporadic communication error 1000
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 03G-906-016-BKC.lbl
       Part No SW: 03G 906 016 BT    HW: 028 101 073 1
       Component: R4 1,9L EDC G200SG  5644
       Revision: 12345678    Serial number: VWZ7Z0C8192905
       Coding: 0000072
       Shop #: WSC 46264 133 55764
       VCID: 76E38CE701B987F282-8022
    8 Faults Found:
    18359 - Radiator Fan 2 (V177)
                P1951 - 000 - Movement Restricted / Jammed - Intermittent
                        RPM: 1722 /min
                        Torque: 48.0 Nm
                        Speed: 76.0 km/h
                        Load: 16.9 %
                        Voltage: 14.21 V
                        Bin. Bits: 00101000
                        Temperature: 72.9C
                        Duty Cycle: 9.6 %
    18017 - Crash Shut-Down Activated
                P1609 - 000 -  - Intermittent
                        RPM: 1407 /min
                        Torque: 220.0 Nm
                        Speed: 30.0 km/h
                        Load: 100.0 %
                        Voltage: 12.77 V
                        Bin. Bits: 00101000
                        Torque: 210.0 Nm
                        Torque: 338.0 Nm
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
                P0671 - 000 - Electrical Fault - Intermittent
                        RPM: 966 /min
                        Torque: 42.0 Nm
                        Speed: 4.0 km/h
                        Voltage: 12.01 V
                        Bin. Bits: 00001111
                        Temperature: 16.2C
                        Bin. Bits: 10110000
    17056 - Cylinder 2 Glow Plug Circuit (Q11)
                P0672 - 000 - Electrical Fault - Intermittent
                        RPM: 966 /min
                        Torque: 42.0 Nm
                        Speed: 4.0 km/h
                        Voltage: 12.01 V
                        Bin. Bits: 00001111
                        Temperature: 16.2C
                        Bin. Bits: 10110000
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
                P0673 - 000 - Electrical Fault - Intermittent
                        RPM: 966 /min
                        Torque: 42.0 Nm
                        Speed: 4.0 km/h
                        Voltage: 12.01 V
                        Bin. Bits: 00001111
                        Temperature: 16.2C
                        Bin. Bits: 10110000
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
                P0674 - 000 - Electrical Fault - Intermittent
                        RPM: 966 /min
                        Torque: 42.0 Nm
                        Speed: 4.0 km/h
                        Voltage: 12.01 V
                        Bin. Bits: 00001111
                        Temperature: 16.2C
                        Bin. Bits: 10110000
    17949 - Fuel Pump Relay (J17)
                P1541 - 000 - Open Circuit
                        Torque: 0.0 Nm
                        Voltage: 12.01 V
                        Bin. Bits: 11001100
                        Bin. Bits:        0
                        (no units): 1.0
    18104 - Powertrain Data Bus
                P1696 - 000 - Implausible Message from Steering Column Controller - Intermittent
                        Torque: 0.0 Nm
                        Voltage: 12.39 V
                        Bin. Bits: 11001100
                        Bin. Bits: 11000000
                        (no units): 1.0
       Part No: 1K0 907 379 D
       Coding: 0053958
       Shop #: WSC 01324 785 00200
       VCID: 336575F3524BD2DA65-8066
       Part No: 1K0 907 044 AG
       Component: ClimatronicPQ35 066 0505
       VCID: 6CD7AE8F4FF54D2264-8038
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
       Component: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000001244418
       Coding: 008B8F201104100000120C000000000000087B075C
       Shop #: WSC 46264 133 54146
       VCID: 397947DB7027288AAF-806C
       Subsystem 1 - Part No: 1T0 955 119 A  Labels: 1TX-955-119.CLB
       Component: Wischer WWS A-MPV   0101
       Coding: 16711700
       Shop #: WSC 46264
    00154 - Windshield Wiper Motor;  Passenger Side (V217)
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605     HW: 1T0 909 605
       Component: 04 AIRBAG VW62 0102 2112
       Coding: 0012340
       VCID: 72EBB0F76DD19BD2AE-8026
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksaulenmodul 009 0030
       Coding: 0000042
       VCID: 306F7AFFA35DE9C218-8064
       Part No: 1T0 920 860 C
       Component: KOMBIINSTRUMENT VDD 1714
       Coding: 0007101
       Shop #: WSC 80093 222 69422
       VCID: 31697FFBA857E0CA17-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 G
       Component: Zuheizer        020 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
       Shop #: WSC 46264 133 10754
       VCID: 2959979B8087980ADF-807C
    01406 - No Flame
                000 -  -  - Intermittent
                        Fault Frequency: 47
                        Reset counter: 47
                        Mileage: 244047 km
                        Time: 29:31:22
                            Start
                        Temperature: 73.0C
                        Temperature: 68.0C
    02251 - Heater Unit Locked
                        Fault Frequency: 47
                        Reset counter: 47
                        Mileage: 244047 km
                        Time: 29:31:22
    00664 - Fuel gauge
                        Fault Frequency: 157
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
    01444 - Under-Voltage Shut-Off (Automatic)
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 A    HW: 1K0 907 951
       Component: Gateway         H08 0020
       Revision: 08          Serial number: 0000103705F003
       Coding: 3D3F1340078002
       VCID: 25419BABEC9FBC6AFB-8070
                        Fault Frequency: 37
                        Reset counter: 44
                        Mileage: 280065 km
                        Time: 14:45:44
                        Fault Frequency: 38
                        Reset counter: 44
                        Reset counter: 43
                        Mileage: 280093 km
                        Time: 00:20:19
    01304 - Radio
                        Reset counter: 44
                        Mileage: 280212 km
                        Time: 10:04:58
       Component: IMMO                1714
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1T0 959 701
       Component: Tuersteuergeraet 09 0111
       Coding: 0000116
       VCID: 74E7B6EF17C595E2BC-8020
       Part No: 1K1 909 143 L
       Component: EPS_ZFLS Kl.0       0402
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0201
       Coding: 00E802087F2D8404084F0100
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1T0 959 702
       Coding: 0000116
       VCID: 75E18BEB1CBF8CEA8B-8020
       Part No: 1K0 035 186 D
       Component: Radio BNO           0216
       Coding: 0040400
       VCID: 275D91A39693AE7AC9-8072
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 05 0107
       Coding: 0000048
       VCID: 2F6D7983BE63F63A01-807A
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Coding: 0000048
    End-------------------------(Elapsed Time: 01:54)--------------------------
    I cleared all codes and customer made about 10km long testdrive.
    No one engine related fault code returned and engine works fine. I went through all ECU output tests and no fault codes displayed, too. I'm a bit confused how just clearing codes could solve problem. I asked customer to come back next week to rescan his car.
    Autoscan after testdrive:
    Thursday,22,September,2016,15:30:23:32442
       Coding: 0000072
    Readiness: 0 0 1 1 1
       Coding: 0053958
       Coding: 16711700
       Shop #: WSC 46264
       Coding: 0012340
       Coding: 0000042
       Coding: 0007101
       Coding: 0000011
    01406 - No Flame
                        Fault Frequency: 47
                        Reset counter: 47
                        Mileage: 244047 km
                        Time: 29:31:22
                            Start
                        Temperature: 73.0C
                        Temperature: 68.0C
                        Fault Frequency: 47
                        Reset counter: 47
                        Mileage: 244047 km
                        Time: 29:31:22
    00664 - Fuel gauge
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
                        Reset counter: 123
                        Mileage: 469128 km
                        Time: 24:31:31
       Coding: 0000116
       Component:    KSG              0201
       Coding: 0000116
       Coding: 0040400
       Coding: 0000048
       Coding: 0000048
    End-------------------------(Elapsed Time: 01:51)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Mar 2016
    This fault code is stored when the airbag control module recognizes a crash, it tells the engine control module to stop the engine. This fault code is only an information and has no influence on the rest of the car.
    Sep 2016
    Riga, Latvia
    I thought the same, but what happened to this exact car? Why all engine problems disappeared after just clearing fault codes??? It was hard even to drive around our workshop before and 10km clear run after
    Maybe it had nothing wrong and someone unplugged sensors or caused issues during collision.
    After a DTC reset the adaptions are cleared and relearned.........maybe a-ok and all is needed.
    Check DTC's later on ............
  6. Likes Uwe liked this post
    This should be a lesson to anyone reading this.
    JPPSG..........rule to be added!
    If car is outside warranty and you are doing a repair/diagnosis.
    Read codes via auto-scan and archive.
    Read block value adaptions to see where the thresholds are, during last DCY & reference last learned value...... log them/archive.
    Clear codes see what immediately comes back/address them if needed..... if clear....... do the reset of all adaptions ..........then commence readiness tests for two DCY's
  8. Likes Uwe liked this post
