"no response from controller" ???
TheOrangeOne
US
C?ID=282089
Howdy y'all. I'm new to Volkswagen and VCDS, not new to fixing cars so I'm hoping to get some advice. So, I'm working on my 2001 1.9l TDI Jetta. When I bought the car it had a check engine light on and I felt compelled to purchase VCDS for troubleshooting.
Here is the auto-scan from when I ran vcds the first time.
Tuesday,05,July,2016,20:17:32:07677
VCDS Version: 15.7.4.1
Data version: 20160216
Mileage: 249380km-154957mi   Repair Order:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
          75 76
   Mileage: 249380km-154957miles
Address 01: Engine        Labels: 038-906-012-AGR.lbl
   Part No: 038 906 012 BD
   Component: 1,9l R4 EDC G000SG  2507
   Coding: 00002
   Shop #: WSC 00066
   VCID: 53AB6D14A1E8B5A693-4B18
            P1570 - 35-00 -
Readiness: 0 0 1 0 1
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E7D2CA03A6A48CE4C-4B18
   Part No: 6Q0 909 605 A
   Component: 15 AIRBAG VW5  02   0004
   Coding: 12597
   Shop #: WSC 00066
   VCID: 356F338C0F5C8B969D-4B18
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 900 L
   Component: A4-KOMBIINSTR. VDO V63
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2B5B15F4D918CD66FB-5178
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2486788
   IMMO-IDENTNR: VWZ7Z0Y2486788
01176 - Key
            07-00 - Signal too Low
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E1C29830BEEEBE8E-515A
Address 35: Centr. Locks        Labels: 1C0-962-258-II.lbl
   Part No: 1C0 962 258 P
   Component: 0J Zentr.Verriegel. 0001
   Coding: 04096
   Shop #: WSC 00066
   VCID: 34690E880426929EAA-4B64
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 180 D
   Component:  RADIO 3CP         0002
   Coding: 02401
   Shop #: WSC 00066
   VCID: 2041F2D8A0DE1E3E5E-4B18
00856 - Radio Antenna
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 05:10)--------------------------
Address 25: DTCs cleared
Address 25:Bitte Adress  channel 0 adapted from --- to 000
Address 01: DTCs cleared
Control Module Part Number: 038 906 012 BD
  Component and/or Version: 1,9l R4 EDC G000SG  2507
           Software Coding: 00002
            Work Shop Code: WSC 00066
Fault Codes have been Erased
            P1570 - 35-00 -
Readiness: 0 0 1 1 1
            P1570 - 35-00 -
Okay so the car wouldn't start with the regular key but ran just fine with the valet key until now. I went to drive the car the other day and it started and died just like when the immobilizer was activated, however there was no key shaped light this time. The problem occurs with both keys now. So i tried to run the auto-scan and this time my results were a lot different.
Wednesday,03,August,2016,17:47:41:07677
Mileage: 155152   Repair Order:
          75 76
   Coding: 03504
   Shop #: WSC 00066
   Coding: 12597
   Shop #: WSC 00066
   Coding: 04096
   Shop #: WSC 00066
   Coding: 02401
   Shop #: WSC 00066
   VCID: 2041F2D8A0DE1E3E5E-4B32
00853 - Loudspeaker(s); Rear
End-------------------------(Elapsed Time: 05:21)--------------------------
Also, a window popped up and said "no response from controller"
So where do I need to start troubleshooting? Not sure if its immobilizer related or maybe a ground issue somewhere? It seems like my laptop isn't connecting to those controllers anymore no matter what I try. What would cause that? Any help would be appreciated an thank you for your time.
Kevin
MartinsX
Riga, Latvia
C?ID=268515
Check all power and ground wires to instrument cluster according WD first ;)
Check K-line wire from diagnostic socket pin 7 to instrument cluster connector T32/pin 25 (T32 is the blue connector, T32a is the green one)
In addition to the ECU, both the Instrument Cluster and the CAN Gateway (which is integral with the instrument cluster) are missing. Diagnostic comms to the ECU run *through* the instrument cluster, (and the immo is in there too) so I'd be looking at that. Does it light up as usual with the key on?
MartinsX
Riga, Latvia
C?ID=268515
For testing ECU a jumper wire can be used from T32/25 to T32a/5 @ instrument cluster. If ECU is powered up and alive, it will talk to diagnostics.
TheOrangeOne
US
C?ID=282089
Wow! That was the quickest response I've ever seen! Thank you for the advice. Ill update after some troubleshooting! Yall are awesome!
TheOrangeOne
US
C?ID=282089
Alright so I gained access to the T32 connector and tested for continuity from pin 25 to pin
7 on the diagnostic socket. This tested good. I then tested all the pins for power to
chassis ground and these are the results:
Battery Voltage - 12.56
KEY OFF
1. .006
2. 0
3. 11.85
4. x
5. .020
6. x
7. .020
8. .075
9. .004
10. 013
11. 0
12. 0
13. x
14. x
15. x
16. 12.41
17. 0
18. 0
19. 0
20. 0
21. .135
22. .219
23. 12.68
24. .004
25. 6.69
26. 0
27. 0
28. 0
29. .010
30. .017
31. .004
32. x
Key On
1. 12.42
2. 0
3. 11.56
4. x
5. .060
6. x
7. .059
8. .059
9. .028
10. .030
11. .006
12. .001
13. x
14. x
15. x
16. 12.00
17. 0
18. 0
19. 0
20. 0
21. .179
22. .213
23. 12.44
24. .028
25. 11.44
26. 0
27. 0
28. .091
29. .003
30. 12.35
31. .026
32. x
After testing all of this I reinstalled the instrument cluster and tried to start the car.
Voila it started! however there are a few lights on. (air bag, battery, check engine) So I
decided to run another auto-scan to see whats going on this time. Here are the results of
that scan.
Tuesday,20,September,2016,17:51:36:07677
VCDS Version: 16.8.1.3
Data version: 20160902 DS256
VIN: 3VWRP29M51M042812   License Plate:
Mileage: 155152mi   Repair Order:
          75 76
   Mileage: 249690km-155150miles
   Coding: 00002
   Shop #: WSC 00066
   VCID: 53AB6D14A1E8B5DA43-4B32
            P1570 - 35-10 -  - Intermittent
16764 - Glow Plug/Heater (Q6) Circuit
            P0380 - 35-10 - Malfunction - Intermittent
Readiness: 1 1 0 0 0
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E7D2CA03A6A48B29C-4B18
   Coding: 12597
   Shop #: WSC 00066
   VCID: 356F338C0F5C8BEA4D-4B18
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2B5B15F4D918CD1A2B-5178
01176 - Key
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E1C29830BEEEC25E-5178
   Coding: 04096
   Shop #: WSC 00066
   VCID: 34690E88042692E27A-4B64
   Coding: 02401
   Shop #: WSC 00066
   VCID: 2041F2D8A0DE1E428E-4B18
End-------------------------(Elapsed Time: 05:12)--------------------------
          75 76
   Coding: 00002
   Shop #: WSC 00066
   VCID: 53AB6D14A1E8B5DA43-4B18
   Coding: 03504
   Shop #: WSC 00066
   Coding: 12597
   Shop #: WSC 00066
   Coding: 07242
   Shop #: WSC 00066
01176 - Key
   Coding: 00006
   Shop #: WSC 00066
   Coding: 04096
   Shop #: WSC 00066
   Coding: 02401
   Shop #: WSC 00066
End-------------------------(Elapsed Time: 05:00)--------------------------
I'm not sure what to make of this info. What should I try next? I don't want to drive it with
airbag light on. It seems pretty obvious that its a communication problem at the instrument
cluster I just don't know how to go about fixing that.
MartinsX
Riga, Latvia
C?ID=268515
Airbag is on, because You had ignition on with IPC disconnected. Now clear all codes @ all modules, restart car and make a new autoscan and post it here.
TheOrangeOne
US
C?ID=282089
So i ran the auto-scan then cleared the DTCs and auto-scan again. Here are the results of that.
Wednesday,21,September,2016,14:19:36:07677
Mileage: 249690km-155150mi   Repair Order:
          75 76
   Coding: 00002
   Shop #: WSC 00066
18058 - Powertrain Data Bus
            P1650 - 35-00 - Missing Message from Instrument Cluster
   Coding: 03504
   Shop #: WSC 00066
   Coding: 12597
   Shop #: WSC 00066
   Coding: 07242
   Shop #: WSC 00066
01176 - Key
   Coding: 00006
   Shop #: WSC 00066
   Coding: 04096
   Shop #: WSC 00066
   Coding: 02401
   Shop #: WSC 00066
End-------------------------(Elapsed Time: 05:05)--------------------------
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 35: DTCs cleared
Address 56: DTCs cleared
          75 76
   Coding: 00002
   Shop #: WSC 00066
   Coding: 03504
   Shop #: WSC 00066
   Coding: 12597
   Shop #: WSC 00066
   Coding: 07242
   Shop #: WSC 00066
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70E1C29830BEEEC25E-515A
   Coding: 04096
   Shop #: WSC 00066
   VCID: 34690E88042692E27A-4B4A
   Coding: 02401
   Shop #: WSC 00066
End-------------------------(Elapsed Time: 05:14)--------------------------
Looks like its good to go for now. Thank you so much for your help I'm gonna go take it on a test drive and report back. I couldn't have done it with out help!
Kevin
