Results 1 to 8 of 8
Thread: "no response from controller" ???
    Sep 2016
    US
    Howdy y'all. I'm new to Volkswagen and VCDS, not new to fixing cars so I'm hoping to get some advice. So, I'm working on my 2001 1.9l TDI Jetta. When I bought the car it had a check engine light on and I felt compelled to purchase VCDS for troubleshooting.
    Here is the auto-scan from when I ran vcds the first time.
    Tuesday,05,July,2016,20:17:32:07677
    VCDS Version: 15.7.4.1
    Data version: 20160216
    Mileage: 249380km-154957mi   Repair Order:
    Chassis Type: 9M - VW Jetta IV (1998 > 2014)
              75 76
       Mileage: 249380km-154957miles
    Address 01: Engine        Labels: 038-906-012-AGR.lbl
       Part No: 038 906 012 BD
       Component: 1,9l R4 EDC G000SG  2507
       Coding: 00002
       Shop #: WSC 00066
       VCID: 53AB6D14A1E8B5A693-4B18
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-00 -
    Readiness: 0 0 1 0 1
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 P
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       Shop #: WSC 00066
       VCID: 3E7D2CA03A6A48CE4C-4B18
       Part No: 6Q0 909 605 A
       Component: 15 AIRBAG VW5  02   0004
       Coding: 12597
       Shop #: WSC 00066
       VCID: 356F338C0F5C8B969D-4B18
    Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
       Part No: 1J0 920 900 L
       Component: A4-KOMBIINSTR. VDO V63
       Coding: 07242
       Shop #: WSC 00066
       VCID: 2B5B15F4D918CD66FB-5178
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2486788
       IMMO-IDENTNR: VWZ7Z0Y2486788
    01176 - Key
                07-00 - Signal too Low
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70E1C29830BEEEBE8E-515A
    Address 35: Centr. Locks        Labels: 1C0-962-258-II.lbl
       Part No: 1C0 962 258 P
       Component: 0J Zentr.Verriegel. 0001
       Coding: 04096
       Shop #: WSC 00066
       VCID: 34690E880426929EAA-4B64
       Part No: 1J0 035 180 D
       Component:  RADIO 3CP         0002
       Coding: 02401
       Shop #: WSC 00066
       VCID: 2041F2D8A0DE1E3E5E-4B18
    00856 - Radio Antenna
                36-00 - Open Circuit
    End-------------------------(Elapsed Time: 05:10)--------------------------
    Address 25: DTCs cleared
    Address 25:Bitte Adress  channel 0 adapted from --- to 000
    Address 01: DTCs cleared
    Control Module Part Number: 038 906 012 BD
      Component and/or Version: 1,9l R4 EDC G000SG  2507
               Software Coding: 00002
                Work Shop Code: WSC 00066
    Fault Codes have been Erased
                P1570 - 35-00 -
    Readiness: 0 0 1 1 1
                P1570 - 35-00 -
    Okay so the car wouldn't start with the regular key but ran just fine with the valet key until now. I went to drive the car the other day and it started and died just like when the immobilizer was activated, however there was no key shaped light this time. The problem occurs with both keys now. So i tried to run the auto-scan and this time my results were a lot different.
    Wednesday,03,August,2016,17:47:41:07677
    Mileage: 155152   Repair Order:
              75 76
       Coding: 03504
       Shop #: WSC 00066
       Coding: 12597
       Shop #: WSC 00066
       Coding: 04096
       Shop #: WSC 00066
       Coding: 02401
       Shop #: WSC 00066
       VCID: 2041F2D8A0DE1E3E5E-4B32
    00853 - Loudspeaker(s); Rear
    End-------------------------(Elapsed Time: 05:21)--------------------------
    Also, a window popped up and said "no response from controller"
    So where do I need to start troubleshooting? Not sure if its immobilizer related or maybe a ground issue somewhere? It seems like my laptop isn't connecting to those controllers anymore no matter what I try. What would cause that? Any help would be appreciated an thank you for your time.
    Kevin
    Sep 2016
    Riga, Latvia
    Check all power and ground wires to instrument cluster according WD first
    Check K-line wire from diagnostic socket pin 7 to instrument cluster connector T32/pin 25 (T32 is the blue connector, T32a is the green one)
    In addition to the ECU, both the Instrument Cluster and the CAN Gateway (which is integral with the instrument cluster) are missing. Diagnostic comms to the ECU run *through* the instrument cluster, (and the immo is in there too) so I'd be looking at that. Does it light up as usual with the key on?
    Sep 2016
    Riga, Latvia
    For testing ECU a jumper wire can be used from T32/25 to T32a/5 @ instrument cluster. If ECU is powered up and alive, it will talk to diagnostics.
  5. Likes Uwe, sazimam liked this post
    Sep 2016
    US
    Wow! That was the quickest response I've ever seen! Thank you for the advice. Ill update after some troubleshooting! Yall are awesome!
    Sep 2016
    US
    Alright so I gained access to the T32 connector and tested for continuity from pin 25 to pin
    7 on the diagnostic socket. This tested good. I then tested all the pins for power to
    chassis ground and these are the results:
    Battery Voltage - 12.56
    KEY OFF
    1. .006
    2. 0
    3. 11.85
    4. x
    5. .020
    6. x
    7. .020
    8. .075
    9. .004
    10. 013
    11. 0
    12. 0
    13. x
    14. x
    15. x
    16. 12.41
    17. 0
    18. 0
    19. 0
    20. 0
    21. .135
    22. .219
    23. 12.68
    24. .004
    25. 6.69
    26. 0
    27. 0
    28. 0
    29. .010
    30. .017
    31. .004
    32. x
    Key On
    1. 12.42
    2. 0
    3. 11.56
    4. x
    5. .060
    6. x
    7. .059
    8. .059
    9. .028
    10. .030
    11. .006
    12. .001
    13. x
    14. x
    15. x
    16. 12.00
    17. 0
    18. 0
    19. 0
    20. 0
    21. .179
    22. .213
    23. 12.44
    24. .028
    25. 11.44
    26. 0
    27. 0
    28. .091
    29. .003
    30. 12.35
    31. .026
    32. x
    After testing all of this I reinstalled the instrument cluster and tried to start the car.
    Voila it started! however there are a few lights on. (air bag, battery, check engine) So I
    decided to run another auto-scan to see whats going on this time. Here are the results of
    that scan.
    Tuesday,20,September,2016,17:51:36:07677
    VCDS Version: 16.8.1.3
    Data version: 20160902 DS256
    VIN: 3VWRP29M51M042812   License Plate:
    Mileage: 155152mi   Repair Order:
              75 76
       Mileage: 249690km-155150miles
       Coding: 00002
       Shop #: WSC 00066
       VCID: 53AB6D14A1E8B5DA43-4B32
                P1570 - 35-10 -  - Intermittent
    16764 - Glow Plug/Heater (Q6) Circuit
                P0380 - 35-10 - Malfunction - Intermittent
    Readiness: 1 1 0 0 0
       Coding: 03504
       Shop #: WSC 00066
       VCID: 3E7D2CA03A6A48B29C-4B18
       Coding: 12597
       Shop #: WSC 00066
       VCID: 356F338C0F5C8BEA4D-4B18
       Coding: 07242
       Shop #: WSC 00066
       VCID: 2B5B15F4D918CD1A2B-5178
    01176 - Key
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70E1C29830BEEEC25E-5178
       Coding: 04096
       Shop #: WSC 00066
       VCID: 34690E88042692E27A-4B64
       Coding: 02401
       Shop #: WSC 00066
       VCID: 2041F2D8A0DE1E428E-4B18
                36-10 - Open Circuit - Intermittent
    End-------------------------(Elapsed Time: 05:12)--------------------------
              75 76
       Coding: 00002
       Shop #: WSC 00066
       VCID: 53AB6D14A1E8B5DA43-4B18
       Coding: 03504
       Shop #: WSC 00066
       Coding: 12597
       Shop #: WSC 00066
       Coding: 07242
       Shop #: WSC 00066
    01176 - Key
       Coding: 00006
       Shop #: WSC 00066
       Coding: 04096
       Shop #: WSC 00066
       Coding: 02401
       Shop #: WSC 00066
    End-------------------------(Elapsed Time: 05:00)--------------------------
    I'm not sure what to make of this info. What should I try next? I don't want to drive it with
    airbag light on. It seems pretty obvious that its a communication problem at the instrument
    cluster I just don't know how to go about fixing that.
    Sep 2016
    Riga, Latvia
    Airbag is on, because You had ignition on with IPC disconnected. Now clear all codes @ all modules, restart car and make a new autoscan and post it here.
  9. Likes Uwe liked this post
  10. #8
    Sep 2016
    US
    So i ran the auto-scan then cleared the DTCs and auto-scan again. Here are the results of that.
    Wednesday,21,September,2016,14:19:36:07677
    Mileage: 249690km-155150mi   Repair Order:
              75 76
       Coding: 00002
       Shop #: WSC 00066
    18058 - Powertrain Data Bus
                P1650 - 35-00 - Missing Message from Instrument Cluster
       Coding: 03504
       Shop #: WSC 00066
       Coding: 12597
       Shop #: WSC 00066
       Coding: 07242
       Shop #: WSC 00066
    01176 - Key
       Coding: 00006
       Shop #: WSC 00066
       Coding: 04096
       Shop #: WSC 00066
       Coding: 02401
       Shop #: WSC 00066
    End-------------------------(Elapsed Time: 05:05)--------------------------
    Address 03: DTCs cleared
    Address 15: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 35: DTCs cleared
    Address 56: DTCs cleared
              75 76
       Coding: 00002
       Shop #: WSC 00066
       Coding: 03504
       Shop #: WSC 00066
       Coding: 12597
       Shop #: WSC 00066
       Coding: 07242
       Shop #: WSC 00066
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70E1C29830BEEEC25E-515A
       Coding: 04096
       Shop #: WSC 00066
       VCID: 34690E88042692E27A-4B4A
       Coding: 02401
       Shop #: WSC 00066
    End-------------------------(Elapsed Time: 05:14)--------------------------
    Looks like its good to go for now. Thank you so much for your help I'm gonna go take it on a test drive and report back. I couldn't have done it with out help!
    Kevin
  11. Likes Uwe liked this post
