Results 1 to 10 of 13
Thread: Mk7 GSW disabling DRL
    Verified VCDS User nacg8or's Avatar
    Feb 2016
    The Windy City
    I am trying to disable the DRLs but unlike my Mk5 Rabbit where there was a bit you could uncheck in the 09-Cent. Elect. controller, I don't see that here. Is there any way of doing it on the new Mk7s?
    I also noticed, when looking through the 17-Instruments controller that Byte 4, Bit 7 is checked (AWD installed) and this is not a awd car. Is there a reason that would be checked?
    Quote Originally Posted by nacg8or View Post
    nacg8or: Hello. Yes, as you have already observed, the lighting stuff on a mk7 is managed very differently to your mk5!. In your mk7, these facilities are still controlled by the 09-Cent. Elect. module (this forum tends to use the term BCM for this controller), but instead of using the Byte/Bits in the coding string, the swiches have been embedded into the module's adaptation channels. In fact, if you look at the admaps for the control modules on your mk7, you will be impressed by the total number of adaption channels that the car has - it's about 3,500 in my modestly equipped mk7!
    So, back to your question. If you just want to disable the DLRs (incidentally, you should check that doing this is legal in your local area before making the alteration), then try the following:
    1. Select 09 - Central Elect control module
    2. Select Security Access - 16 from the "Open Controller" screen
    3. Enter the magic number 31347 and return to the "Open Controller" screen
    4. Select Adaptation - 10 from the "Open Controller" screen
    5. Enter ENG115833 into the search box and from the pull-down button select IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag
    6. Change setting to not active (see picture below),
    PS: The tweak instructions above will permanently remove DRLs. Another, perhaps more elegant method of doing something similar is to enable a DRL switch on the MENU screen that allows the driver to choose which mode to use (i.e. DRL-on, of DRL-off). If you prefer this alternative, then see the instructions HERE
  3. Likes nacg8or, Uwe liked this post
    Feb 2016
    The Windy City
    Thanks for the info Don. I also looked at the multi function display and noticed you couldn't control DRLs from there either but if there is a way of adding it to the menu, that is great. I did look briefly at the adaptation channels and you need several hours to go through all that. Lol. I will take a look at your suggestions tomorrow and see how that goes.
    As far as my post regarding the fog light installation from the other thread, my car is definitely not equipped with a BCM that supports front fog lights. I saw that indicated in the Central Electrics controller, and that is unfortunate. It is odd that you can enable the rear fog light if you have tail lights that have it but you need an upgraded BCM to run front fog lights.
  5. Likes Uwe liked this post
  6. #4
    nacg8or: hm............. how did you deduce that the BCM can't accommodate front fog lights? Can you post-up an autoscan please?
  7. Likes Uwe liked this post
  8. #5
    Feb 2016
    The Windy City
    I was trying to post a snapshot image of the module for the front fogs not being supported but can't seem to get it to work. At any rate, Byte 7 in the 09 module has no bit 3 check box and the text reads "Front fog lights are NOT supported by this Contol Module".
    That said, here is the auto scan.
    Sunday,18,September,2016,10:10:12:27338
    VCDS Version: 16.8.1.3 (x64)
    Data version: 20160902 DS256
    Workshop Code: 444 12345 054321
    VIN: 3VWA17AU0HM505098   License Plate:
    Mileage: 471km-292mi   Repair Order:
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75
    VIN: 3VWA17AU0HM505098   Mileage: 471km-292miles
    Address 01: Engine (J623-CXBA)       Labels: None
       Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091100122424002F0000
       Shop #: WSC 00066 790 00202
       ASAM Dataset: EV_ECM18TFS0208V0906264K 001003
       ROD: N/A
       VCID: 44A99EAACFF11562CA-8010
    No ASAM data for: "EV_ECM18TFS0208V0906264K" (VW37)
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 51656000000540
       Coding: 04FA6AA1242009714077020981CB2920562490024081943400430050C00203
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
       VCID: 75CF336ED4ABFCEA8D-8020
    Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
       Part No SW: 5GM 907 426 B    HW: 5GM 907 426 B
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 02020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X.rod
       VCID: 47B389A6FEC73E7A2F-8012
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 087 T    HW: 5Q0 937 087 T
       Revision: --------    Serial number: 8658190716012T
       Coding: 000008424041804169E44000000407001000000000000000000000000000
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 4CB9B68AE7A1DD2202-8018
       Component: WWS    160804  043 0581
       Serial number:         160807202350
       Serial number: 003GCR056C61
       Occupant Detection:
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH000000000005H1GFE
       Coding: 303133
       Subsystem 2 - Part No SW: -----------    HW: 480 001 606 16
       Serial number: 357000000000B6A44C1K
       Subsystem 3 - Part No SW: -----------    HW: 480 001 606 16
       Serial number: 3580000000019B19FB1V
       Subsystem 4 - Part No SW: -----------    HW: 480 401 106 16
       Serial number: 3510002C320FC4C3015.
       Subsystem 5 - Part No SW: -----------    HW: 480 401 806 16
       Serial number: 3520002AD21160C1309R
       Subsystem 6 - Part No SW: -----------    HW: 480 401 706 16
       Serial number: 3550002AD20EDB6500BE
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 706 16
       Serial number: 3560002AD209E9E1B07K
       Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160713400290
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3A55E052BD355392A0-806E
       Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
       Component: KOMBI         244 8311
       Coding: 0BB41102A180CF0502086A001000000000000000
       VCID: 266D2422598DC772F4-8072
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2265
       Revision: --------    Serial number: 18061610800990
       Coding: 0101000830085900FB000008080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07025
       ROD: EV_GatewConti.rod
       VCID: 7BDB2556F28FAA9AFB-802E
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
       Component: E221__MFL-DC1  H17 0103
       Serial number: 29160000950270106196
       Coding: 30FFFF
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 150716060501QX
       Coding: 003003200000020000000000
       VCID: 41A797BED0E3004AE1-8014
       Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
       Serial number: 00000000000013355359
       Coding: 011000
       Component: EPS_MQB_ZFLS  129 1072
       Coding: 0102
       VCID: 45AF83AEC4CB2C6ADD-8010
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 120716060506KM
       VCID: 40A192BADBE90942EE-8014
       Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
       Serial number: 00000000000013085791
       Coding: 091000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 02730200FF00000051220001001808009F0100D40120010002
       ROD: EV_MUStd4CDELP_VW26.rod
       VCID: 2D7FDB0E7C7BF42A35-8078
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW00TZA
    Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
       Component: OCULowMQBUS   007 0568
       Coding: 02730202C2821A017F1E06000000
       ROD: EV_OCULowMQB.rod
       VCID: 43AB9DB6CAFF125AF3-8016
    End-------------------------(Elapsed Time: 02:26)--------------------------
    In addition, I'm getting a "No ROD file found" message for
    EV_ECM18TFS0208V0906264K 001003 (VW 37). I just updated VCDS to the latest version this morning.
    Nic
    VAG Cars owned
    '90 Audi Coupe Q - '06 VW Rabbit - '17 VW GSW
  9. Likes DV52 liked this post
  10. #6
    Brand new 2017 model car.....
  11. #7
    Magdeburg, Germany
    We will likely publish an update shortly and I've made some additions so that most modules will be covered with that new data version. Thanks for reporting this, your feedback is much appreciated.
  12. Likes nacg8or liked this post
  13. #8
    Feb 2016
    The Windy City
    You're welcome. I appreciate all the help you guys provide.
    VAG Cars owned
  14. #9
    Sebatian: guten Morgen. A question please - why does the second setting descriptor in my picture (post #2) incorrectly identify "daytime running lights" when this setting applies low-beams as DRLs?
  15. #10
    Magdeburg, Germany
    Please double check that with VCDS 16.8.2 or newer once it's out and let us know...
  16. Likes DV52 liked this post
