Hello
I have replaced my clutch master cylinder and it has now given me 2 fault codes one in the EPB and the other in the engine, everything works as it should i can start the car and the cruise control all works ok however i have got the EPB fault light on the dash could someone help with what my issue is please
here is my scan results thanks in advance
Saturday,17,September,2016,21:07:27:19936
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
Dealer/Shop Name: kieran burley
VIN: WVWZZZ3CZ6E154176 License Plate: K13TOK
Mileage: 244970km-152217mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 62 72 7D
VIN: WVWZZZ3CZ6E154176 Mileage: 244970km-152217miles
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 DP HW: 028 101 274 2
Component: R4 1,9L EDC G000SG 7870
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 70E85D3163EEF3C25E-8024
050199 - Implausible Data Received from Parking Brake Control Module
U0417 - 000 -
Mileage: 244300 km
Time: 22:49:47
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658581996
Coding: 0013569
Shop #: WSC 05311 000 00000
VCID: 2F6A9E4DBE50AC3A07-807A
Part No: 1K0 820 047 DP
Component: Climatic PQ35 090 0505
VCID: 75E66C251C8CD6EA8D-8020
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 L HW: 3C0 937 049 L
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000005962058
Coding: A5080E4701041A28000000000000000000095D43640000
Shop #: WSC 05311 123 12345
VCID: 326C9739AD6281D268-8066
Subsystem 1 - Part No: 3C2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 05311
00061 - Footwell Lights
Reset counter: 239
Mileage: 244979 km
Voltage: 12.15 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
Component: 05 AIRBAG VW8 029 2521
Revision: 09029000 Serial number: 003A2PRDUV4G
Coding: 0012341
VCID: 2D568445B45CDE2A35-8078
Subsystem 1 - Serial number: 6332MSME110A7E7E
Subsystem 2 - Serial number: 6342MSME0E566C0E
Subsystem 3 - Serial number: 6351HTS61IKEC9P2
Subsystem 4 - Serial number: 6361HTS61IK2LKV2
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 005 0010
Revision: 00005000 Serial number: 3C9953507C
Coding: 0000014
Shop #: WSC 05311 000 08193
VCID: 2A5C8F5985B2C912D0-807E
Part No SW: 3C0 920 960 H HW: 3C0 920 960 H
Revision: X0014000 Serial number: 00000000000000
Coding: 0005405
Shop #: WSC 54064 067 57207
VCID: 285875519BBEFB02C6-807C
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C16053B
Coding: 3DFD2C04C02003
Shop #: WSC 05311 123 08193
VCID: 214E6875F8840A4A81-8074
Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
Component: IMMO 038 0367
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 55916 001 1048576
Subsystem 1 - Part No: 3C0 905 861 D
Component: ELV 024 0370
3C0905861D ELV 024 0370
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2802
Coding: 0000695
Shop #: WSC 00028 028 00001
VCID: 3664AB29410A9DF244-8062
00105 - Signal Central Locking SAVE/LOCK Drivers Side
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3460912157768FE27A-8060
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0455
Coding: 1991020851030E760004941570081FCE103C80
Subsystem 2 - Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Subsystem 3 - Part No: 3C0 951 171 A
Component: Innenraumueberw.002 0508
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000694
VCID: 377AA62D460064FA5F-8062
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000011
00650 - Clutch Pedal Switch (F36)
Fault Status: 11101000
Reset counter: 171
Mileage: 243104 km
Time: 22:29:48
Voltage: 11.70 V
Count: 72
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 3C9 959 703
Component: Tuer-SG 021 2505
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 3C9 959 704
Coding: 0000144
VCID: 71EE583568E4FACA51-8024
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
014 - Defective
End-------------------------(Elapsed Time: 01:54)--------------------------
Saturday,17,September,2016,21:17:03:19936
Coding: 0000071
U0417 - 000 -
Mileage: 244979 km
Time: 21:19:31
Coding: 0013569
Coding: 00063445
Shop #: WSC 05311
Coding: 0012341
Coding: 0000014
Coding: 0005405
Coding: 0000687
Coding: 0000686
Revision: 013
Coding: 0000011
Reset counter: 171
Mileage: 243104 km
Time: 22:29:48
Voltage: 11.70 V
Count: 72
Coding: 0000144
Coding: 0000144
014 - Defective
End-------------------------(Elapsed Time: 01:44)--------------------------
