Results 1 to 10 of 13
Thread: CCM swap and now no start...
    United States
    here is the scan below
    Here is the deal
    well some PO changed my CCM to a non roadster model
    Henceforth the top and deflector would not work.
    So I found a CCM from the EU (Much cheaper!) and that worked fine
    Top powers up and the deflector works now.
    Even got a key fob from England and it synced fine.
    Problem is now the car wont start.
    Im thinking its the 01559 01560 codes.
    Thanks for all the help and your great product!
    George
    Friday,20,June,2014,15:27:27:41598
    VCDS Version: 14.6.0.0 (x64)
    Data version: 20140601
    VIN: TRUUT28N221019270   License Plate: 02AUDITT
    Mileage: 125046   Repair Order: myride
    Chassis Type: 8N (8N - Audi TT (1999 > 2007))
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    Address 01: Engine        Labels: 06A-906-032-AMU.lbl
       Part No: 8N0 906 018 AN
       Component: 1.8L R4/5VT     G   0004
       Coding: 06710
       Shop #: WSC 01236
       VCID: 7DB238BD755310D260-5184
       TRUUT28N221019270     AUZ5Z0AN120023
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
       Part No: 8N0 907 379 H
       Component: ESP ALLR
       Coding: 0022544
       Shop #: WSC 01236 785 00200
       VCID: 41CA844D192BB43244-5184
                014 - Defective
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00140
       Shop #: WSC 01236
       VCID: 281C39E9CA51657A63-2596
                41-00 - Blocked or No Voltage
    Address 15: Airbags        Labels: 8N0-959-655.lbl
       Part No: 8N0 959 655 A
       Component: Airbag Front+Seite 5000
       Coding: 01103
       Shop #: WSC 01236
       VCID: 3E30FFB138D5CBCA39-5184
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N1 920 980
       Component: KOMBI+WEGFAHRS. M73 D02
       Coding: 07244
       VCID: 73A61E85431756A206-4B3C
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F0E22359F1FA2C212-4B3C
    Address 35: Centr. Locks        Labels: 8Nx-962-267.lbl
       Part No: 8N7 962 267
       Component: Zentralverrieg.,DWA D04
       Coding: 04698
       Shop #: WSC 01236
       VCID: 7DB238BD755310D260-4F50
    01559 - Drivers Door
                61-00 - Won't De-Safe
    01560 - Passenger Door
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00010
       Shop #: WSC 01236
       VCID: 658270DDFDC3B81298-51CE
       Part No: 4B0 035 186 H
       Component: concert II  NP2    0006
       Coding: 04202
       VCID: 250230DDBD43781258-4EC8
    No Faults Found
    End-------------------------(Elapsed Time: 03:40)--------------------------
    Last edited by Uwe; 06-20-2014 at 07:08 PM. Reason: Wrapped CODE tags around Auto-Scan
    Well, if we look at your Central Locking Module's Coding, it has the following options set:
    +00001 = Rear Lid Opening via Rear Lid Lock Button
    +00002 = Anti-Theft Locking Confirmation (Turn Signals)
    +00004 = Selective Locking active
    +00008 = Anti-Theft-System installed
    +00016 = Half-Automatic Convertible Top (Roadster only)
    +00032 = Auto-Lock/Unlock (Locking at 15 km/h)
    +00064 = Comfort Operation (Windows/Sunroof) via Remote Control
    +00128 = Right-Hand-Drive (RHD)
    +00256 = Rear Lid Logic (Anti-Theft-System)
    +00512 = Remote Control "Close" Confirmation (1x Turn Signals)
    +01024 = Anti-Theft Locking Confirmation (Siren/Horn)
    +02048 = Door/Window Logic (USA / Terminal 87)
    +04096 = Remote Control "Open" Confirmation (2x Turn Signals)
    +08192 = Remote Control active
    You might try subtracting 8 from the existing coding to turn off the Anti-Theft system to see if that helps.
    However, I'm scratching my head wondering why there's no option to turn off the "Safe" stuff (that's an anti carjacking "dealbolt" type feature that isn't allowed in the US). That's the source of your 01559 and 01560 faults, but I don't think that's why the car won't start.
    Tartu, Estonia
    Describe the no start situation. There are no fault codes for failure of start.
    The world is my oyster...
    On those older cars, basically Mk.4 technology, the signal to the starter goes through the CCM (or in this case CLM) which can block it if it thinks that's appropriate. This will typically not produce any fault code.
    United States
    Yes there is no engine fault codes and no failure to start codes.
    Its like the starter was inhibited. No starter spin at all.
    Uwe I will try it out tomorrow. I Just wish I had the long code helper like the newer cars have. Worked on a friends 09 GTI and it was nice!
    There are 10 kinds of people in the world, those who understand binary and those who don't.
  7. Likes jakematic, TDI28, dafrazi liked this post
    United States
    This is a euro CCM so I think that might be why....
    George
  9. #8
    United States
    So I tried adding +8 and no go on the euro ccm. swapped back to the coupe american ccm and it starts. Copied the soft coding from the NA ccm and loaded in the euro ccm and swapped back. No start again.... perhaps the Euro ccm is bad or Im buggering it up.
    George
  10. #9
    Adding and subtracting are not the same thing.
    Tartu, Estonia
    You forgot the +2, turn signals for anti theft confirmation.
    Basicly the coding should be 04690, if I'm getting it correct.
