- Feb 27, 2015
- 68
- 64
- Central FL
- C?ID=148074
Can anyone help with the proper coding of the BOSE amp in 47 Sound System or will this vehicle have to go to the dealer? The amp got wet and I sent it out for repair. I did not have a log of this car prior to the amp getting wet. When it came in there was no communication with 47 SOUND SYSTEM. Its now communicating but the sound is not coming from all the speakers and there are faults for coding/basic settings.
Software coding 0000000 Should be 00000?6
workshop code 00000
importer number 000
equipment number 00000
The coding helper says:
Sound system bose coding j525
00000?X Microphone
1=1 microphone for vol. control
2=2 mic for vol control
4=1 mic for vol control and analog input (AUX)
5=2 mic for vol control and analog input (AUX)
00000X? Equipment
1 not applicable
2 not applicable
3 not applicable
4 not applicable
5 not applicable
6 Left-hand drive with leather trim and petrol engine
7 not applicable
8 not applicable
workshop code 00000
importer number 000
00000?X Microphone
00000X? Equipment
1 not applicable
2 not applicable
3 not applicable
4 not applicable
5 not applicable
7 not applicable
8 not applicable
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 3C 42 46 47
4F 52 55 56 61 62 65 69 6C 6D 6F 72 76 77
VIN: WA1BY74L97D076408 Mileage: 192980km-119912miles
0E-Media Player 1 -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 1010
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1634
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 68D5A0E95B026E0208-803C
P0300 - 008 - - Intermittent
Mileage: 191782 km
Date: 2016.09.05
Time: 13:00:42
RPM: 1737 /min
Load: 41.9 %
Speed: 20.0 km/h
Temperature: 60.0°C
Temperature: 36.0°C
Absolute Pres.: 1030.0 mbar
Voltage: 13.716 V
000774 - Cylinder 6
P0306 - 008 - Misfire Detected - Intermittent
Mileage: 191782 km
Date: 2016.09.05
Time: 13:01:04
RPM: 1270 /min
Load: 38.0 %
Speed: 22.0 km/h
Temperature: 59.0°C
Temperature: 36.0°C
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 008 - Misfire Detected - Intermittent
Mileage: 191782 km
Date: 2016.09.05
Time: 13:01:04
RPM: 1270 /min
Load: 38.0 %
Speed: 22.0 km/h
Temperature: 59.0°C
Temperature: 36.0°C
Voltage: 14.097 V
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4013838
VCID: 2953E5ED8088970AD7-807C
Address 03: ABS Brakes Labels: 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 2855E0E99B82AE02C8-807C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100640432
Coding: 0000131
Shop #: WSC 64034 000 1048576
VCID: 63CFB7C5A2240D5ADD-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0053
Fault Frequency: 6
Reset counter: 169
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354AN077516363
Coding: 0002003
VCID: 356B399D5C30C3EA43-8060
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000624055
Subsystem 3 - Serial number: 0103.01.070000000100010723ÿ
Subsystem 4 - Serial number: 010723ÿ
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 161
Time Indication: 15
00384 - Optical Databus
Fault Status: 00101011
Fault Frequency: 128
Reset counter: 40
Mileage: 188484 km
Date: 2016.07.17
Time: 13:25:16
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:06
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030022429
Coding: 0786470
VCID: 61C3BDCDB8381F4ACF-8034
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:06
Voltage: 8.60 V
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0014123
VCID: 31630D8DA858EFCA1F-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBG1028448
VCID: 1D3BC13DC4C07BAAAB-8048
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:25
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0032050
VCID: 2C5D1CF98F7A82222C-8078
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:35
Voltage: 8.30 V
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH41 0230
Revision: 05H41000 Serial number: 0038QD050AR6
Coding: 0014131
VCID: 2B5F1FE58A74851A25-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME1C5A2763L
Subsystem 3 - Serial number: 6342QSME1C5C4153J
Subsystem 4 - Serial number: 6352QSME1C54233DK
Subsystem 5 - Serial number: 6362QSME1C58395F-
Subsystem 6 - Serial number: 63734SME1C463509+
Subsystem 7 - Serial number: 63834SME1C493161$
00532 - Supply Voltage B+
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055063630090
Coding: 0002022
VCID: 66C9AED1511678723A-8032
Component: Lenkradmodul H07 0090
Fault Frequency: 14
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:18
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4L0 920 950 B
Component: KOMBIINSTR. M73 H11 0170
Revision: 00400000 Serial number: 4ZS139817
Coding: 0595263
Shop #: WSC 42863 001 1048576
VCID: 2045F8C9F3B2564280-8074
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.16
Time: 00:27:51
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06C088063
Coding: F7F7FE77741A02
Shop #: WSC 20211 444 84457
VCID: 6CDDDCF94FFA42226C-8038
00463 - Control Module for Digital Sound Package (J525)
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 04:16:59
Reset counter: 190
Mileage: 192981 km
Date: 2016.09.14
Time: 10:09:32
Reset counter: 150
Mileage: 192981 km
Date: 2016.09.14
Time: 18:22:07
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 2757E3D5569CA17AC1-8072
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000092349
Coding: 0000006
00003 - Control Module
Fault Status: 00100011
Fault Frequency: 8
Mileage: 172917 km
Date: 2016.02.03
Time: 14:31:27
02599 - Rear Left Temperature Flap Motor (V313)
Fault Frequency: 63
Reset counter: 160
Mileage: 188514 km
Date: 2016.07.17
Time: 18:13:48
Voltage: 13.30 V
Temperature: -100.0°C
(no units): 229.0
(no units): 61.0
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:06
Voltage: 8.50 V
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 129
Mileage: 191712 km
Date: 2016.08.16
Time: 00:06:10
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0010001
VCID: 2D5B11FDB4608B2A3B-8078
Subsystem 1 - Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F07.12.0600H0600000010196ÿ
Subsystem 4 - Serial number: 010196ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
014 - Defective
Fault Status: 01101110
Reset counter: 129
Mileage: 191712 km
Date: 2016.08.15
Time: 04:17:42
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Reset counter: 120
Mileage: 190632 km
Date: 2016.08.05
Time: 12:39:53
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:10
02857 - Supply Voltage for Lane Change Assistance Control Module 2
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:10
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: 5W1
Coding: 0035531
VCID: 2F670BF5BE6CF93A09-807A
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01029550070000
Coding: 7632925
02956 - Lamp in Trunk/Hatch Lid; Left
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 150
Mileage: 166463 km
Date: 2015.11.17
Time: 17:16:11
Bin. Bits: 001 010
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000012369
Coding: 0000000
Fault Frequency: 17
Reset counter: 150
02084 - Component Protection
Fault Status: 01100101
Mileage: 190036 km
Date: 2016.08.04
Time: 16:42:53
Fault Frequency: 17
Reset counter: 150
Mileage: 192981 km
Date: 2016.09.14
Time: 18:21:35
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000068511
Coding: 0012001
VCID: 5EB98631894620B2F2-800A
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 23:14:00
Voltage: 9.500 V
Temperature: 31.0°C
Fault Status: 00110010
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:00
Voltage: 7.700 V
Temperature: 31.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: I”5
Coding: 0035531
Reset counter: 169
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000021
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388L8067580598
VCID: 2E5916F1B966F03202-807A
Reset counter: 190
Mileage: 182401 km
Date: 2016.05.12
Time: 16:17:47
Fault Frequency: 81
Reset counter: 190
Mileage: 182401 km
Date: 2016.05.12
Time: 16:08:02
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000072976
VCID: 64CDB4D9A72A0A6224-8030
Component: von VA0 330423NOJD
Coding: 34463039313531303544205641303333303432334E4F4A44
Fault Frequency: 79
Mileage: 171444 km
Date: 2016.01.12
Time: 11:59:28
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 73
Reset counter: 168
Mileage: 189991 km
Date: 2016.08.04
Time: 01:05:41
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 23:14:28
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0035338
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700040242
Coding: 0062424
VCID: 2241F2C1FDBE445296-8076
002 - Lower Limit Exceeded - Intermittent - MIL ON
Fault Status: 10100010
Reset counter: 169
Mileage: 191712 km
Date: 2000.01.01
Time: 12:00:00
(no units): 255.0
Voltage: 6.50 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Fault Frequency: 29
Reset counter: 151
Mileage: 189663 km
Date: 2016.07.23
Time: 07:54:34
(no units): 54.0
Temperature: 26.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
VCID: 244DF4D9E7AA4A62E4-8070
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6Z41FK
Coding: 1001101
Fault Frequency: 6
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 03:01:13
Term 15 Off
Reverse OFF
Count: 3
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD05.01.07--H21001001B0222ÿ
Subsystem 4 - Serial number: 1B0222ÿ
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002306545-----
Coding: 0003595
VCID: 2649EED19196B872FA-8072
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
Fault Status: 00101010
Fault Frequency: 6
Reset counter: 190
Mileage: 191712 km
Date: 2016.08.15
Time: 03:14:57
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Fault Frequency: 6
Reset counter: 190
Mileage: 191712 km
Date: 2016.08.15
Time: 03:14:57
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230634806562
Coding: 0031246
VCID: 2757E3D5969CA17AC1-8072
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:15
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007560035
Coding: 0010900
End-------------------------(Elapsed Time: 04:01)--------------------------
Address 07: DTCs cleared
Address 01: DTCs cleared
Address 05: DTCs cleared
Address 0F: DTCs cleared
Address 46: DTCs cleared
Address 4F: DTCs cleared
Address 15: DTCs cleared
Address 19: DTCs cleared
Address 47: DTCs cleared
Address 28: DTCs cleared
Address 61: DTCs cleared
Coding: 0001175
Readiness: 0110 0101
Revision: 00H22001
Coding: 0033809
Coding: 0000131
Coding: 0002003
Coding: 0786470
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:06
Voltage: 8.60 V
Coding: 0014123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:25
Coding: 0014131
Coding: 0002022
Fault Frequency: 14
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:18
Coding: 0595263
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.16
Time: 00:27:51
Reset counter: 151
Mileage: 192981 km
Date: 2016.09.15
Time: 13:48:57
Revision: 00000000
Coding: 0000006
Reset counter: 151
Mileage: 192981 km
Date: 2016.09.15
Time: 13:47:33
Coding: 0082946
Coding: 0010001
014 - Defective
Reset counter: 129
Mileage: 191712 km
Date: 2016.08.15
Time: 04:17:42
014 - Defective
Reset counter: 120
Mileage: 190632 km
Date: 2016.08.05
Time: 12:39:53
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:10
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:10
Coding: 0035531
Coding: 7632925
Reset counter: 151
Mileage: 166463 km
Date: 2015.11.17
Time: 17:16:11
Bin. Bits: 001 010
Coding: 0000000
Reset counter: 151
Mileage: 192981 km
Date: 2016.09.15
Time: 13:46:40
Mileage: 190036 km
Date: 2016.08.04
Time: 16:42:53
Reset counter: 151
Mileage: 192981 km
Date: 2016.09.15
Time: 13:46:42
Coding: 0012001
Coding: 0035531
Reset counter: 169
Coding: 0000021
Reset counter: 191
Mileage: 182401 km
Date: 2016.05.12
Time: 16:17:47
Fault Frequency: 80
Reset counter: 191
Mileage: 182401 km
Date: 2016.05.12
Time: 16:08:02
Coding: 0035338
Coding: 0062424
Reset counter: 169
Mileage: 191712 km
Date: 2000.01.01
Time: 12:00:00
(no units): 255.0
Voltage: 6.50 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Fault Frequency: 29
Reset counter: 151
Mileage: 189663 km
Date: 2016.07.23
Time: 07:54:34
(no units): 54.0
Temperature: 26.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1001101
Fault Frequency: 6
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 03:01:13
Term 15 Off
Reverse OFF
Count: 3
Coding: 0003595
Fault Frequency: 6
Reset counter: 190
Mileage: 191712 km
Date: 2016.08.15
Time: 03:14:57
Fault Frequency: 6
Reset counter: 190
Mileage: 191712 km
Date: 2016.08.15
Time: 03:14:57
Coding: 0035338
Coding: 0031246
Reset counter: 169
Mileage: 191712 km
Date: 2016.08.15
Time: 09:29:15
Coding: 0010900
End-------------------------(Elapsed Time: 03:55)--------------------------
