Hey all.
Just wonder if these tweaks are available fora 2014 7P Touareg.
1. Off road suspension height (max height) speed limit and area view camera speed adjusted to approx. 35kph? Currently both turn off @ 20km/hr..
2. Radio turns off after approx 10 mins once ignition is off - can this be extended at all?
Full autoscan below.
Kind regards!
Sunday,11,September,2016,10:27:31:51599
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN:    License Plate:
Mileage: 68886km-42803mi   Repair Order: airbag suspension
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 32 34 42 46 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WVGZZZ7PZED040847   Mileage: 68886km-42803miles
Address 01: Engine (J623-CRCA)       Labels: 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0007
   Revision: 53H41---
   Coding: 296A4012233E01020000
   Shop #: WSC 30612 001 1048576
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 326B6E4B65E6EED266-8066
17262 - Terminal 30
          U140A 00 [032] - Open Circuit
5618 - Engine Off Timer Performance
          P150A 00 [032] - -
                    Mileage: 64590 km
                    Date: 2016.08.11
                    Time: 14:10:39
                    Engine speed: 706.00 /min
                    Normed load value: 12.2 %
                    Coolant temperature: 75 °C
                    Intake air temperature: 50 °C
                    Voltage terminal 30: 12.060 V
                    Unlearning counter according OBD: 10
                    Shut-off timer: last engine shut-off time: 2 s
                    Shut-off timer: last ECM after-run time: 37 s
                    Time since ignition off: 2 s
                    Shut-off timer: instrum panel counter: open circuit in term 30-Bit 0: 0
                    Terminal 15 status-Bit 0: 1
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 11113 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 7CF78073F722E8A2FC-8028
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 406140010EC818
   Coding: 4B6B13C34B282553D2FCC897D2D9A450F700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4A9B16ABED7686123E-801E
   Part No SW: 4H0 907 064 EM    HW: 4H0 907 064 EM
   Component: BCM2 2.0      H36 0521
   Coding: 01B60010000000000000
   VCID: 78FF9C63CB1AC48298-802C
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 0814000000518003
   Serial number: 0214000041954008
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: 3626200890
   VCID: 0501E59784E8A96A93-8050
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001530523
   Coding: 26001010D1345D010021000300005D0C431D670807010241000000020000
   VCID: 6CD7B0338F4278226C-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140308  033 0021
   Serial number: 90243401140312134122
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20281010
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002003140105
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261406800606
   Coding: 518501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43853B8FCA5C575AFD-8016
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag05K H06 0026
   Revision: --------    Serial number: 003L5004WVCM
   Coding: 00000000000000000000000000000000354B
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: 428B3E8BD5465E52F6-8016
   Serial number: 3575LRB405B2BDFS7GM+
   Serial number: 3585LRB405B2BDFS5GR2
   Serial number: 3515RRB401G50V9KPPKK
   Serial number: 3525RRB400250V9KFPI.
   Serial number: 3555NRB400Q50U88E28C
   Serial number: 3565NRB400Q50U88E29E
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
   Revision: --------    Serial number: 01335NCP000CR
   Coding: 000015
   VCID: 3663525B818EF2F24A-8062
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0001962 TRW 20140307
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658210314592058
   Coding: 33273300BA00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526_VW52.rod
   VCID: 479D2F9FFE647B7A21-8012
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001317734
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3F8D377FA6B433BA99-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41072H03115701898730
   Voltage stabilizer:
12290 - Quiescent Current
          U1406 00 [009] - Too High
                    Reset counter: 217
                    Mileage: 42595 km
                    Date: 2015.12.31
                    Time: 20:34:28
                    Voltage terminal 30: 12.8 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 29 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] -  -
                    Reset counter: 57
                    Mileage: 25868 km
                    Date: 2015.08.07
                    Time: 10:33:03
                    Voltage terminal 30: 14.6 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 42 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0218
   VCID: 4C9710B32F0298220C-8018
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H04         Serial number: 411317250504
   VCID: 0109F18758C0854AAF-8054
Address 34: Level Control (J197)       Labels: 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000140730125
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 76E3925BC90EB2F28A-8022
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000096133703
   Coding: 011D0620D001451005080002
   VCID: 7AFB866BF516D692EE-802E
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0330261665
   Coding: 019A162028B9108083200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
01506 - Bulb for Rear Fog; Right (L47)
            012 - Electrical Fault in Circuit - MIL ON
                    Fault Status: 11101100
                    Reset counter: 253
                    Mileage: 25754 km
                    Date: 2015.08.06
                    Time: 09:29:17
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000095566033
   Coding: 011D0620D001451005080000
   VCID: 489F2CA3FB7A740228-801C
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1431100240
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3663525B898EF2F24A-8062
   Slave 3:
0052 - Parking Brake Motor; Right
          C10BD 07 [008] - Mechanical Failure
                    Reset counter: 24
                    Mileage: 63874 km
                    Date: 2016.08.08
                    Time: 08:35:48
                    Voltage: 12.4 V
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AE00000F000A00
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227C+0E7894072
   Coding: 040005020100000003
   VCID: 2643821B512E8272FA-8072
   Part No SW: 7P6 035 764 E    HW: 7P6 035 764 A
   Component: H-BNT-RW      H40 0816
   Revision: --------    Serial number: 445CR0E7500531
   Coding: 010A01050040C1EF01002B0E00000003F00001020000000000
   VCID: 3B75436FBAAC2F9AB5-806E
   Subsystem 1 - Part No: 8R0 060 884 BN
   Component: ROW 2014  0605
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9PA2010GZ
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  5571
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000096520247
   Coding: 011804200001251005080000
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H11 0110
   Revision: 5A001001    Serial number: 00000323690787
   Coding: 030D000000000000
Address 6C: Back-up Cam. (J928)       Labels: 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
   Component: TopView       H05 0100
   Revision: 11001001    Serial number: 82330JF0141312
   Coding: 0100000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3B75436FB2AC2F9AB5-806E
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 060400980
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
0068 - Warning Buzzer for Rear Lid
          B11DF 13 [008] - Open Circuit
                    Reset counter: 46
                    Mileage: 61374 km
                    Date: 2016.07.25
                    Time: 10:29:54
                    14.31 V
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000096236020
End-------------------------(Elapsed Time: 04:49)--------------------------
