Friday,20,June,2014,14:53:31:25857
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: 3VWAL71KX9M057480 License Plate:
Mileage: 155190km-96430mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 56 62 65 72
VIN: 3VWAL71KX9M057480 Mileage: 155190km/96430miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0H824E14E
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3F8D57AD6E18BDE6A2D-806A
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - Intermittent
Mileage: 155001 km
Time: 13:01:20
RPM: 828 /min
Load: 0.0 %
Voltage: 13.68 V
Torque: 0.0 Nm
Hex Value: 0xFF00
Bin. Bits: 00101110
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Mileage: 155189 km
Time: 21:14:50
Voltage: 11.55 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 1100.0 mg/str
Mass Air / Rev.: 0.0 mg/str
001674 - ECM Power Relay Load Circuit: (J271)
P068A - 000 - De-Energized Performance Too Early - Intermittent
Load: 0.0 %
Voltage: 0.00 V
Hex Value: 0xFF00
Bin. Bits: 00000000
Temperature: -90.0°C
001025 - EGR System
P0401 - 000 - Insufficient Flow - Intermittent
Mileage: 155189 km
Time: 00:39:09
RPM: 1311 /min
Speed: 18.0 km/h
Voltage: 13.76 V
Load: 60.8 %
Load: 100.0 %
Mass Air / Rev.: 210.0 mg/str
Mass Air / Rev.: 345.0 mg/str
001162 - Exhaust Pressure Control Valve 1
P048A - 000 - Stuck Closed - Intermittent
Mileage: 155189 km
Time: 00:39:10
RPM: 1311 /min
Speed: 18.0 km/h
Load: 17.6 %
Load: 9.8 %
Lambda: 86.0 %
Temperature: 60.0°C
Temperature: 53.1°C
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1814
Revision: 04843012 Serial number: 00000806300812
Shop #: WSC 02069 000 90108
VCID: D0AFE4114386B29ECB7-8085
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 113B400D49270001880F02EC92190042B100
VCID: 75E1F585DCA437B6B81-8020
01487 - System Function Test
Reset counter: 222
Mileage: 155190 km
Count: 16384
Count: 4608
Count: 321
Count: 49958
Reset counter: 221
Mileage: 155190 km
Count: 16384
Count: 14
Count: 12800
Count: 320
Count: 49664
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78FFFCB10BB64ADEA37-802D
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001067477
Coding: 14018E234004150007140000001400000008730B5C000120000000000000
VCID: 326B0E99AD4A608E5D3-8067
Component: Wischer 290908 021 0501
Coding: 00038805
Shop #: WSC 00066
Revision: 00000000 Serial number: AUZ4Z7H0427318
Coding: 0000100
VCID: 33650B9D52506986565-8066
Reset counter: 221
Mileage: 155190 km
Time: 22:39:21
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06ZZZO
Coding: 0013889
VCID: 6CD7D0E14FEEF67E57F-8039
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME3E3153336
Subsystem 3 - Serial number: 6342MSME3F45060BG
Subsystem 4 - Serial number: 6351HSME18186E016
Subsystem 5 - Serial number: 6361HSME18191A211
Subsystem 6 - Serial number: 63727SME1746012F$
Subsystem 7 - Serial number: 63827SME16380775+
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 051 0101
Coding: 0012021
VCID: 84071841C77E9E3E3FF-80D1
Component: E0221 002 0010
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0H824E14E
Coding: 0023203
VCID: 397939B5703C93D69C9-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 130808F2000123
Coding: ED807F070013021002
VCID: 356135855C2477B6781-8060
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T3BYP04
Coding: 0000003
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000809388908
Coding: 0001205
VCID: 6FEDC7ED7EF80D6672D-803A
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A5B16F9859A284EE53-807F
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Coding: 13900F880186281B0904058FB0880F0488DC00
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08072303145601
Coding: 0001204
VCID: 70EFC49163C6129E6B7-8025
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2232853
Coding: 0010400
VCID: 2959E9F5809C2356EC9-807C
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003424293
Coding: 0001168
VCID: 76E3F28901A23CAEB1B-8023
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003439929
Coding: 0001168
VCID: 77FDFF8D06A845A6AAD-8022
