Results 1 to 9 of 9
Thread: Basic settings for DCC
    Jun 2015
    Hey guys,
    I am just finishing the retrofit of the dynamic chassis control on my vw golf mk6, and am having some trouble with doing the basic settings. I have managed to successfully code the module and wire everything. The only fault code i have left is "basic settings not performed". When i try to perform the basic settings, it says error/requirement not met. So i was wondering what's wrong? And what the min and max values are for the sensors?
    Mar 2014
    jack the car up in the air and let all 4 wheels hang at their lowest point. Then retry the basic settings.
  3. Likes Uwe liked this post
    Jun 2015
    Hey, i tried doing the basic settings with the wheels of the ground and also while it was on the ground, but it kept saying error. I'm not sure what's wrong, because there is no other fault code stored in the module except it hasn't had basic settings performed. Is there anything specific i need to check before doing the basic settings?
    Jan 2015
    Bosnia and Herzegovina
    For basic setting you need to lift your car so that wheel are hung and sensors are reading values,
    Address 14: Susp. Elect. (J250) Login: 31564, Basic Settings: channell: 1 Go ON/OFF.
    Jun 2015
    I done as you have said exactly, my mechanic lifted my car on his ramp and we tried the same procedure. I'm not sure why it's not working?
    Jun 2015
    Sorry I forgot to post the autoscan of my car, as I wasn't on my computer yesterday.
    Friday,09,September,2016,11:41:09:06975
    VCDS Version: 16.8.1.3 (x64)
    Data version: 20160902 DS256
    VIN: WVWZZZ1KZ9W511078   License Plate: G7 DLO
    Mileage: 106740km-66325mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 52 55 56 62 72
    VIN: WVWZZZ1KZ9W511078   Mileage: 106740km-66325miles
    Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
       Part No SW: 03C 906 016     HW: 03C 906 016
       Component: MED17.5.5       G   3546
       Revision: L3H04---    Serial number:
       Coding: 0000072
       VCID: 5CB7CE219F30B8A292-8008
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 163B400D092300FB680B02EB90210080300150
       VCID: 7AFBA8B9F5C46692E0-802E
    03075 - Parallel Parking Assistance Control Module (J791)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 28
                        Mileage: 106742 km
                        Date: 2016.09.09
                        Time: 11:37:46
                        Count: 2
                        Count: 12288
                        Count: 8258
                        Count: 41984
                        Count: 64256
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 3C8 907 336     HW: 3C8 907 336
       Component: Climatic      120 0102
       Revision: 00004001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ADB98F98D64D61210-803E
       Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
       Component: BCM PQ35  H+  103 0575
       Revision: 00103 AG
       Coding: 46180A3AF821F1C044080080340008EC45550488536D8960E48408040000
       Shop #: WSC 00152 210 91233
       VCID: 3365459D922E57DA63-8066
       Component: Wischer 13020  21  0501
       Coding: 009795
       Component: RLS 230209 05  54  0402
       Coding: 0730AD
       Subsystem 4 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HO  H08 9001
    Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56231203401265
       Coding: 149001
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000_VW36.rod
       VCID: 44871641CF80E062CA-8010
    Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
       Part No SW: 3C0 907 376 A    HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0071
       Revision: 00000000    Serial number: 30101500300001
       Coding: 000180
       Shop #: WSC 12345 123 12345
       VCID: 275DA1CD56F62B7ACF-8072
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Reset counter: 28
                        Mileage: 106741 km
                        Date: 2016.09.09
                        Time: 10:55:32
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    033 0604
       Serial number: 003C2D0960CE
       Coding: 00003136
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77FDB18DCED67BFA9F-8022
       Component: S.Sens.Fahr.V  U01 ----
       Serial number: 33304044ZZZZZZZZZZZZ
       Component: S.Sens.Beif.V  U01 ----
       Serial number: 22254145ZZZZZZZZZZZZ
       Serial number: 18471A3FZZZZZZZZZZZZ
       Serial number: 163E1827ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 0305D55D420E275AB3-8056
       Part No SW: 5K0 920 972     HW: 5K0 920 972
       Coding: 170B00
       ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
       VCID: 6DD193E5BC8AC12A75-8038
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533  Gateway   H07 0071
       Revision:   H07 01    Serial number: 110209F2001148
       Coding: E9A97F06000202000003
       VCID: 377D718D4656BBFA5F-8062
       Component: IMMO          H03 0607
       Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
       Component: Tuer-SG         008 2042
       Coding: 0000756
       VCID: 79F9B7B530C26D8AE9-802C
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 69     2501
       Revision: 00H15000
       VCID: 2C575EE18F10082222-8078
       Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
       Coding: 0000758
       VCID: 7AFBA8B935C46692E0-802E
       Coding: 1446940
       VCID: 34674681572050E27A-8060
       Coding: 00000022
       Coding: 00000022
    Address 56: Radio
       Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
       Component: Tuer-SG         007 2009
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
       Coding: 0000144
       VCID: 7BF5ADBD3AFE5F9AFB-802E
    End-------------------------(Elapsed Time: 02:16)--------------------------
    Jun 2015
    This pictures show the values for my front level sensors, and if I am correct they are within specification to run the basic settings.
    This is the screen I am showed after loging in with the security code '31564'
    This is the screen I get after pressing the 'on/off/next' button to do the basic settings.
    I was wondering if anything is wrong here, for basic settings not to be allowed to complete?
  9. #8
    Tartu, Estonia
    I've heard that VCDS can't perform basic setting for whatever reason and ODIS must be used.
    I haven't tried myself so i can't comment.
    JimmyCBX tried, but ended up using ODIS or was it VAS-PC
    The world is my oyster...
  10. #9
    Jan 2015
    i have performed basic settings for dcc via vcds no problems, updated software for dcc module http://forums.ross-tech.com/showthre...-el-suspension
    are all sensors correctly installed/pointing?
    http://www.swankmonkey.com/vw/jetta/...on_adjustment/
  11. Likes Uwe liked this post
