Results 1 to 9 of 9
Thread: Computer compatibility
    Jun 2014
    I know you don't support Apple and since my old job took back the computer I was using for my VCDS Hex-Net I need to invest in one myself. Can I use a ChromeBook? What are the minimum specs needed?
    Chromebook should work with VCDS-Mobile, but it will not work with VCDS "classic".
    If you're buying a "computer" anyway, I would get a 10" Windows machine of some sort, either a book, or a tablet. They are dirt cheap because MS has made Windows free for machines that size and smaller. $100-$150....
  3. Likes Boki Ar, D-Dub liked this post
    Oct 2014
    Arandjelovac, Serbia
    Illustration, HP mini, 10"
  5. Likes Uwe, Eric liked this post
  6. #4
    Jun 2014
    Exactly what I was looking for! Thanks!
    US 2014 GTI Drivers Edition/DSG
    just make sure your laptop/tablet has a usable USB port so you don't have to rely only on wifi
    Feb 2016
    VCDS works great on my Winbook Tablet with Win10.
    By the way, I recommend the Winbook tablets (7, 8 or 10 in.) available at MicroCenter for less than $100. They have a full size USB port for the Ross Tech adapter.
    Although I used the free upgrade to Win10 from Win8, it used up quite a bit of space on the 32 GB SS drive.
    After a year I did a clean reset/install (removes all files) to Win10, reloaded the applications and tablet works great, also with VCDS.
    Quote Originally Posted by elkm36a View Post
    What model Winbook do you have - 700, 801, 802 , 101, something else?
  10. #8
    Feb 2016
    I used the TW700, and while it worked, I'd was irritating to use VCDS with a touch screen and on-screen keyboard as the TW700 was never all that responsive. A small laptop is much easier to use in my experience.
  11. #9
    Quote Originally Posted by SHODAN View Post
    I've recently got a TW101 and it's proved to be much more usable than the Acer netbook I used to use - to make it easier to use I have a Bluetooth keyboard and mouse, but for scanning and code clearing the touch screen seems fine to me.
  12. Likes Uwe liked this post
