Results 1 to 3 of 3
Thread: 2013 Audi S4 DSG transmission problems
    Jun 2014
    I'm having what I think is a transmission problem with this car. It has the DL501 (0B5) DSG transmission, and it is driving very poorly. It shudders (vibrates) very noticeably when starting or shifting in D, and it surges in both D or M.
    The car is not throwing any transmission codes to help narrow the problem down. I'm hoping somebody might be able to suggest some values to log?
    Steps taken so far:
    1. Drained old ATF. (BTW, when draining the fluid look an odd light tan or very light green color. Can provide pictures if it helps.)
    2. Re-filled with 6.25L of RAVENOL J1D2111 following the procedure for correct fluid level.
    3. Did a test drive and everything seemed better, but on the next (longer) drive the problems slowly returned.
    4. Followed the Basic Setting steps here http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0B5). All 3 Basic Setting steps completed successfully, but didn't make any noticeable difference.
    5. Checked for any new codes between all of these steps but it hasn't thrown any auto trans codes during the entire time.
    Auto-Scan:
    Saturday,03,September,2016,13:35:56:62027
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WAUBGAFL9DA113356   License Plate:
    Mileage: 31970km-19865mi   Repair Order:
    Chassis Type: FL (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56 5F
              62 6C 72 A9
    VIN: WAUBGAFL9DA113356   Mileage: 31970km-19865miles
    Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0002
       Revision: --H07---
       Coding: 0A250034052600060000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 3875C55783A1C08258-806C
    Readiness: 0010 0100
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0004
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021_AU48.rod
       VCID: 4085ADB7DB718842E0-8014
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 040D61A787E9546284-8050
       Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H11 0621
       Coding: 0D814000000000000000
       VCID: 010368B398FB414AAF-8054
       Serial number: 2312000161098009
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01310720120951
       Coding: 6600228000
       VCID: 3973C053B0ABD98AA7-806C
       Revision: 08016001    Serial number: 00000454639701
       Coding: 26000011863CAFE0210040C300003D0D4F9CD308A2090221000008004000030100000030000000
       Shop #: WSC 06325 123 12345
       VCID: 78F50557CB21008298-802C
       Component: WWS 260712  H07 0080
       Serial number: SWF12070265290
       Coding: 00FD11
       Serial number: 20458214
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001207120515
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R2D5Q02
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: C408CD36000000000001
                        Reset counter: 47
                        Mileage: 31929 km
                        Date: 2016.08.10
                        Time: 23:37:29
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD90H8TW
       Coding: 303842354730303030304A55304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 4A918F9FED4D42123E-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1200009NB5
       Serial number: 6334MSME70124B3EF
       Serial number: 6344MSME6F652835O
       Serial number: 6352QSME721F5448N
       Serial number: 6362QSME7E1A0968X
       Serial number: 63732SME111B4774Z
       Serial number: 63832SME0A092D00Y
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20120801000928
       Coding: 000036
       VCID: 51A398F3081B71CA7F-8004
       Component: E221 - MFL  H03 0003
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 982 L    HW: 8K0 920 982 L
       Component: KOMBIINSTR.   H35 0553
       Revision: 00000000    Serial number: RBN337V7D
       Coding: 83BF09008301D705020000
       Shop #: WSC 54321 321 11111
       VCID: 3D7BD443A483E5AA8B-8068
       Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0051
       Revision: 1Y050025    Serial number: 2541Y1271881D6
       Coding: 80C303FF00
       VCID: 448DA1A7C7699462C4-8010
       Serial number: 6083707801
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H13 0100
       Serial number: 002007120001007
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F67FE0B76EF073A09-807A
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000034264172
       Coding: 00581B00000000000000
       VCID: 3B7FDA5BBA97EB9AB5-806E
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C13204E00410001
       VCID: 56A96BEF21F516F2AA-8002
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Revision: 00001000    Serial number: 0003459682
       Coding: 100000010001
       Shop #: WSC 55474 001 1048576
       ROD: EV_RCEPSAU48X.rod
       VCID: 346DF1679FC924E274-8060
       Revision: 00002001    Serial number: 0180938853
       Coding: 01060E3A00FA400580B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000550813
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
    Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
       Revision: 00005001    Serial number: 94813004952302
       VCID: 2D5BE40374E3752A3B-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55AB6CE33CF31DEAA3-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000077285
       ROD: EV_ParkiBrake_VW51.rod
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156G00C7619481
       Coding: 020007010000000001
       VCID: 21430833383BA14A8F-8074
       Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
       Component: H-BNT-NA      H43 0552
       Revision: --------    Serial number: 204GX0C7514384
       Coding: 110200000206E1EF45028F4E00000403140000000000000000
       VCID: 3669CB6F81B536F24A-8062
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Component: DU7 High  H41 0104
       Serial number: A130G-0C2508877
       Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
       Component: E0380 Bedient  H02 0020
       Serial number: 00000001122586
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0304
       Coding: 010C13204000210001
       VCID: 59B360D350EB398A87-800C
       Revision: --H07---    Serial number: 525PA8-J2690SQ
       Coding: 1000006
       VCID: 3875C5574BA1C08258-806C
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 0304
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120623201651
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       VCID: 72E1377FA55D6AD2A6-8026
    End-------------------------(Elapsed Time: 04:00)--------------------------
    Advanced Transmission ID:
    Saturday,20,August,2016,11:54:28:62027
    Mileage: TransAdvId   Repair Order:
    Control Module Part Number: 8K2 927 156 M
      Component and/or Version: 0B5 30TFSINAR H01 0004
               Software Coding: 000001
                Work Shop Code: WSC 06325
    Advanced Identification/FAZIT
         Identification: TFK-030
         Revision: --H01---
         Date: 05.07.12
         Manufacturer number: 0901
         Test stand number: 1321
    Flash Status
         Programming Attempts(application): 1/1
         Successful Attempts(application): 1/1
         Programming Status: 00000000
         Flash Date: 05.12.08
         Flash Date: 0000.00.00
         Flash Tool Code: 00000 000 00000
    Software
         UDS: 02.00.03
         ISO15765: 02.00.01
         CAN: 02.14.02
         HiSpd Net: 01.06.00
    Misc.
         Hardware number: 0B5 927 156 J
         Workshop System Name: J217
         ASAM Dataset Revision: 001010
    Car Info
         Chassis Number: WAUBGAFL9DA113356
    VCDS Info:
    I also tried logging some things that looked like they might be helpful, but I could really use some guidance here:
    Monday,05,September,2016,14:49:13:62027-VCID:4085ADB7DB718842E0-8014,VCDS Version: Release 16.8.0 (x64),Data version: 20160803 DS255
    8K2 927 156 M,ADVMB,0B5 30TFSINAR H01 0004,
    ,,G016,F0,G036,F0,G037,F0,G038,F0,G053,F0,G055,F0,G069,F0,G070,F0,G071,F0,G072,F0,G073,F0,G000,F0,
    Marker,TIME,Loc. IDE00085,TIME,Loc. IDE00098,TIME,Loc. IDE00100-ENG98502,TIME,Loc. IDE00101-ENG98502,TIME,Loc. IDE00854-ENG98502,TIME,Loc. IDE00856-ENG98502,TIME,Loc. IDE00876-ENG98502,TIME,Loc. IDE00877-ENG98502,TIME,Loc. IDE00878-ENG98502,TIME,Loc. IDE02720-ENG98502,TIME,Loc. IDE02721-ENG98502,,,
    ,STAMP,Normed load value,STAMP,Transmission position,STAMP,Engine torque-Data,STAMP,Engine specified torque during transmission intervention-Data,STAMP,Clutch 1 upper adaptation point-Data,STAMP,Clutch 2 upper adaptation point-Data,STAMP,Clutch pressure: clutch 1-Data,STAMP,Clutch pressure: clutch 2-Data,STAMP,Clutch status-Data,STAMP,Transmission input speed (RPM) shaft 1-Data,STAMP,Transmission input speed (RPM) shaft 2-Data,,,
    ,, %,, ,, Nm,, Nm,, bar,, bar,, bar,, bar,, ,, /min,, /min,,,
    ,1.63,24.3,1.83,d,2.03,58,0.01,37,0.21,6.311,0.40,5.830,0.60,2.80,0.80,0.01,1.01,Creeping,1.23,0,1.45,0,,,
    ,3.85,37.3,4.05,d,4.26,123,2.25,115,2.46,6.311,2.64,5.830,2.83,4.22,3.04,0.00,3.24,Start up,3.46,1090,3.65,724,,,
    ,6.26,49.0,6.51,d,6.76,186,4.51,156,4.77,6.311,5.00,5.830,5.21,2.14,5.40,4.29,5.60,Driving,5.80,1625,6.01,1547,,,
    ,8.65,59.2,8.85,d,9.05,216,6.97,215,7.20,6.311,7.38,5.830,7.58,5.64,7.78,0.01,8.00,Driving,8.24,1502,8.46,2341,,,
    ,10.89,71.8,11.08,d,11.28,304,9.26,248,9.50,6.311,9.71,5.830,9.90,6.22,10.10,0.00,10.30,Driving,10.50,2028,10.71,3198,,,
    ,13.30,12.9,13.51,d,13.76,3261,11.51,333,11.78,6.311,12.02,5.830,12.27,2.72,12.50,7.54,12.71,Driving,12.89,2178,13.10,1930,,,
    This car was partially rebuilt before I got it. I set the ATF level to the correct level when I finished the repairs, but I'm now kicking myself for not draining everything out. I can't verify if it had the right fluid when I topped it off. It feels like the clutches might be slipping even though this car has less than 20K miles. I don't mind getting into the transmission, but I don't know if I should be looking at the mechatronic or clutch disks or something else entirely. Does anyone have any suggestions to narrow down the problem?
    Buy a new trans at dealer...........or get them to good will if possible.
    Jun 2014
    Any other ideas?
    Can anybody recomend values to log that can tell me if the clutches are working correctly?
