Results 1 to 10 of 20
Thread: "Too many communiction errors to continue!"
    Jun 2014
    Hi everyone, just received my lead, and tried a few scans, but getting [too many communication errors to continue!] on instrument cluster and immobiliser, other elements communicating fine.
    Here's the autoscan
    Wednesday,18,June,2014,20:50:04:24290
    VCDS Version: 12.12.2.0
    Data version: 20140212
    VIN: WAUZZZ8Dxxxxxxxxx
    Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
       Part No: 038 906 018 S
       Component:  1,9l R4 EDC   00SG  1630
       Coding: 00002
       Shop #: WSC 00355
       VCID: 2643E2BFC2B9EF2EC1B-4B00
                P1570 - 35-00 -
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 8E0-614-111-ABS.lbl
       Part No: 8E0 614 111 AB
       Component: ABS 5.3 FRONT       D00
       Shop #: BB 24548
       VCID: 5EB38A5FDA6977EEC9B-5140
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                30-00 - Open or Short to Plus
    Address 08: Auto HVAC        Labels: 8L0-820-043-2D.lbl
       Part No: 8L0 820 043 D
       Component: A4 KLIMAVOLLAUTOMAT_D75
       Coding: 04144
       Shop #: WSC 06325
       VCID: 2959E983D3A7C056EC9-25A0
    00603 - Footwell/defroster Flap Positioning Motor (V85)
    01273 - Fresh Air Blower (V2)
                17-10 - Control Difference - Intermittent
    01582 - Signal for Coolant Temperature
    Address 15: Airbags        Labels: 8D0-959-655-AI7.lbl
       Part No: 8D0 959 655 L
       Component: Airbag 7 Audi      0503
       Coding: 00106
       Shop #: WSC 06325
       VCID: 3F8D57DB3D235EE6A2D-5140
                32-10 - Resistance Too High - Intermittent
    01217 - Side Airbag Igniter; Driver Side (N199)
    Address 17: Instruments        Labels:
       VCID: 55A19573AC5FB4B6981-5140
       Note: Excessive Comm Errors
    Address 25: Immobilizer        Labels:
    Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
       Part No: 8L0 862 257 G
       Component: ZV-Pumpe, DWA, Funk D08
       Coding: 13130
       Shop #: WSC 06325
       VCID: 397939C3230770D69C9-4ECE
    01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
                35-00 - -
    Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
       Part No: 4B0 951 173
       Component: Innenraumueberw.    D03
       Coding: 00102
       Shop #: WSC 06325
       VCID: E0CF34A7601DC11E7B7-4B4C
    Any ideas of how to get them clearly communicating with each other?
    Most often that's due to something else running on your PC preventing VCDS from answering modules in the real-time manner that they insist upon. What kind of PC are you running this on (CPU, RAM, version of Windows)? What else is running on it (particularly nannyware like virus scanners and such)? Have you looked at our FAQ Entry 2.5?
    Of course it could also be a dodgy instrument cluster (the Immo being a virtual controller that's part of the cluster).
    Jun 2014
    Hi Uwe,
    yes, I have done most of what's on faq2.5, running MSCONFIG shows only the cornucopia of microsoft services running.
    In answer to your question [Dell, intel P9400@2.4GHz, 2gRam, 32bitWin7] + no virus scanner running. Fresh windows install less than a year ago, and all os updates applied since.
    If you like to recommend which microsoft services i should turn off.
    Cluster key symbol behaves normally (disappears after approx 1second) and can be made to flash if reader coil is disconnected and rest of cluster behaves normally otherwise.
    When selecting 'instruments' can hear small relay methodically clicking in cluster. (selecting 'immobiliser' identical behaviour)
    Start
    (short pause)
    energised (approx 2second pause) relaxed (longer pause)
    End
    is there a way to debug? still saying "too many communication errors to continue!"
    OK, there's nothing obvious wrong with your computer or how it's configured. That doesn't mean it's not the source of the problem, so if you can beg, borrow, or steal another one to try temporarily, that would help trouble-shoot by process of elimination. I don't recall any instance where any MS service had to be turned off to allow VCDS to function properly.
    This being an 8D car, it's in its teens in terms of age. Have you pulled the cluster and inspected the connectors for corrosion? It sure couldn't hurt to do that, and it would doing so would also reboot the cluster, which normally always has some unswitched power going to it.
    Jun 2014
    Uwe, thanks for suggestions, and thanks for persisting with this one.
    I have tried another pc, but unfortunately the same problem.
    Then i pulled the cluster.
    The cluster connections look okay, a little oxidation evident on very close inspection, but nothing excessive. Even so, i spent a good while cleaning both the male and female sides. Alas, after all that same problem.
    Then I think by process of elimination, the cluster being flaky is now the most likely explanation.
    Jun 2014
    sorry to drag this up again, but having difficulty letting this car go.
    too many communication errors implies some communication, but not enough.
    i have been very persistent trying at different environment conditions multiple times.
    can i try changing the 'Port and Protocol Options' on the about screen to up the chances?
    is the security shutting down effective communication?
    Is flaky a euphemism ?
  8. #8
    Quote Originally Posted by gottacar View Post
    Just for laughs, have you tried a different PC?
    Assuming those settings are all at their default values, I can't think of anything there that's likely to help.
    I don't think so.
    Since you're from the UK, "flaky" is American for "dodgy". Since it's an 8D chassis, this car is at least 13-14 years old. Stuff sometimes goes bad.
    United States
    The Instrument cluster could be faulty but .... the factory 56-Radio isn't communicating. If this is a 1997/1998 (or newer) I believe you should have a diagnostic capable radio in that vehicle on the same K-line. Please let us know what year this is (the 10th digit of the VIN is edited so I can't tell) and if it has a factory or aftermarket radio installed.
  10. Likes Uwe liked this post
  11. #10
    Jun 2014
    Hi Dana, 10th digit is 'X', arrived in UK near the end of January 1999.
    'Concert' radio factory fitted.
    Autoscan will prompt radio to display 'diag' at the appropriate stage of scanning. CD changer in the trunk/boot area has previously physically been removed and coding reflects this absence, module is reporting no fault codes. I have no idea why 56-radio is not in the autoscan, but have been reading about unpredictability of all installed module appearing in the 'final report'
