Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Can a faulty MAF sensor cause all these problems?
    Sep 2016
    Sweden
    I've spent the whole day fault tracing my Audi A5 2.0TFSI. After finally disconnecting the MAF sensor the car runs fine, except some lack of power and some DTC's of course.
    The different problems I've had:
    1) Fails to start (crank) sometimes
    2) Sudden shutdowns during driving, a DTC readout showing 12-14DTC's at ECM, but none of them where pointing at the MAF sensor, more to a faulty ECU.
    3) Fails to start completely (After being at the workshop for some paint job the car did not start and had to be towed back home since the workshop did not find the fault)
    4) No connection to ECM in VCDS
    5) Impossible to do a full DTC scan in VCDS since it was just shutting down when trying to read ECM DTC's (this happend after I fault traced CAN links, supply and relays)
    But again, after disconnecting the MAF all connection and starting problems are gone. Still got a few codes after a test drive but I assume they are related (my readout are not in english so I will have to install the english version of VCDS and post tomorrow).
    Of course I'm goind to buy a new MAF, but I have to ask:
    So, can you really believe this is a MAF issue? is the fault monitoring and DTC inhibit handling this crappy in the ECM?
    No, I would not think that all of those symptoms are due to a bad MAF. The whole list seems more indicative of some other sort of electrical problem.
    Do you have a scan showing the list of 12-14 DTCs that you were getting?
    Sep 2016
    Sweden
    Mounted a new MAF tonight, believe it or not but no codes returned after a 10miles test trip and the car runs perfectly again!
    Log from when I had the random shutdown issues (unfortunately in Swedish):
    15,Aug,2016,15:24:45:54514
    Mätarställning: 100190km   Rep.order:
    Chassityp: 8T (8T0)
    Skanna: 01 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 55 56 62 69
              72 77
    VIN: WAUZZZ8T5AA069565   Mätarställning: 100190km
    01-Motor -- Status: Felfunktion 0010
    03-Bromselektronik -- Status: Felfunktion 0010
    04-Styrposition -- Status: OK 0000
    05-Behör.kontroll -- Status: OK 0000
    08-Klimatanläggning -- Status: OK 0000
    09-Elektron. elcentral -- Status: OK 0000
    10-park/styr-hjälp -- Status: OK 0000
    15-Krockkuddar -- Status: OK 0000
    16-Rattelektronik -- Status: OK 0000
    17-Instrument -- Status: OK 0000
    2E-Mediaspelare 3 -- Status: OK 0000
    42-Dörrel. förare -- Status: OK 0000
    46-Komfortcentral -- Status: OK 0000
    47-Ljudsystem -- Status: OK 0000
    52-Dörrelektr. pass. -- Status: OK 0000
    53-Parkeringsbroms -- Status: Felfunktion 0010
    55-Helljusområde -- Status: OK 0000
    56-Radio -- Status: Felfunktion 0010
    62-Dörr vä. bak -- Status: OK 0000
    69-Släpvagnsfunktion -- Status: OK 0000
    72-Dörr hö bak -- Status: OK 0000
    77-Telefon -- Status: OK 0000
    Adress 01: Motor (Ma----CDNB)       Labels: saknas
       Artikelnr HW: 8K2 907 115 L
       Komponent: 2.0l R4/4V TF H05 0004
       Revision: ECH05---
       Kodning: 0114000C18470960
       Verkstad #: WSC 06325 123 12345
       ASAM Dataset: EV_ECM20TFS8K2907115S A01006
       ROD: EV_ECM20TFS8K2907115L.rod
       VCID: 5599B95A34D5A4967D-8000
    14 Funna fel:
    4698 - Nedsatt funktion genom mottaget felmeddelande
              U1113 00 [047] - -
              Bekräftad - Testad efter att minnet rensats
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 6
                        Felfrekvens: 5
                        Mätarställning: 100140 km
                        Datum: 2016.08.13
                        Tid: 16:32:50
    4699 - Nedsatt funktion genom mottaget felmeddelande
              U1113 00 [039] - -
              Ej bekräftad - Testad efter att minnet rensats
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 6
                        Felfrekvens: 4
                        Datum: 2016.08.13
                        Tid: 16:32:50
    4628 - Inter kontrollmodul
              P0606 00 [036] - CPU-fel
              Intermittent fel - Ej bekräftad - Testad efter att minnet rensats
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 11
                        Mätarställning: 100187 km
                        Datum: 2016.08.15
                        Tid: 14:27:22
    4608 - Regleringsventil för bränsletryck (N276)
              P2294 00 [168] - avbrott
              Fellampa(MIL) tänd - Intermittent fel - Bekräftad - Testad efter att minnet rensats
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 10
    11913 - Start/stopp omstart
              P167E 00 [096] - Max. starttid överskriden
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 6
                        Felfrekvens: 1
                        Mätarställning: 100165 km
                        Datum: 2016.08.13
                        Tid: 20:08:58
    4629 - Huvudrelä
              P068A 00 [101] - Öppnas för tidigt
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
    2736 - Gasspjällstyrenhet (J338)
              P2106 00 [096] - begränsad effekt på grund av systemfel
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 3
                        Datum: 2016.08.15
                        Tid: 14:27:22
    2748 - Gasspjällstyrning
              P1545 00 [096] - Felfunktion
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 3
                        Datum: 2016.08.15
                        Tid: 14:27:22
    2754 - Gasspjällstyrning
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.08.15
                        Tid: 14:27:55
    2795 - Rad1
              P0011 00 [096] - sen kamaxelinställning Börvärde uppnåddes ej
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 2
                        Datum: 2016.08.13
                        Tid: 16:35:16
    2865 - Rad 1; lambdasond före kat.; värmeströmkrets
              P3255 00 [096] - reglering vid det övre anslaget
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 3
                        Mätarställning: 100141 km
                        Datum: 2016.08.13
                        Tid: 16:36:19
    4025 - Rad 1 -sond 2
              P0140 00 [101] - inte aktiv
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Mätarställning: 100167 km
                        Datum: 2016.08.13
                        Tid: 20:13:43
    7670 - Rad 1 -sond 1 elektriskt fel i strömkretsen
              P0130 00 [096] - -
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 2
                        Datum: 2016.08.13
                        Tid: 16:36:19
    4632 - Inter kontrollmodul
              P0606 00 [168] - CPU-fel
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 11
                        Datum: 2016.08.15
                        Tid: 14:27:18
    Adress 03: Bromselektronik (J104)       Labels: AER\8K0-907-379.clb
       Artikelnr SW: 8K0 907 379 BD    HW: 8K0 907 379 BD
       Komponent: ESP8 front    H04 0030
       Revision: --------    Serienummer: --------------
       Kodning: 248D0C
       VCID: 7CCFCCFEFF3F95DE22-8028
    3 Funna fel:
    01314 - Motorstyrdon
                008 - Orimlig signal
                 frysta data:
                        Felstatus: 01101000
                        Felprioritet: 2
                        Felfrekvens: 5
                        Reset-räknare: 125
                        Tidsindikering: 0
                        Datum: 2016.08.13
                        Tid: 16:32:48
                 frysta data:
                        Hex-värde: 0x0800
                        Hex-värde: 0x0002
                        Hex-värde: 0x0226
                        Hex-värde: 0x80A7
                        Hex-värde: 0x00FF
    00473 - Styrdon för elektrisk parkerings-/handbroms (J540)
                013 - Kontrollera  DTC-minne
                 frysta data:
                        Felstatus: 01101101
                        Felprioritet: 6
                        Felfrekvens: 4
                        Reset-räknare: 125
                        Tidsindikering: 0
                        Datum: 2016.08.13
                        Tid: 16:32:48
                 frysta data:
                        Hex-värde: 0x0800
                        Hex-värde: 0x2202
                        Hex-värde: 0x0232
                        Hex-värde: 0x02A8
                        Hex-värde: 0x00FF
                013 - Kontrollera  DTC-minne - Intermittent fel
                 frysta data:
                        Felstatus: 01101000
                        Felprioritet: 2
                        Felfrekvens: 5
                        Reset-räknare: 125
                        Tidsindikering: 0
                        Datum: 2016.08.13
                        Tid: 16:32:48
                 frysta data:
                        Hex-värde: 0x0800
                        Hex-värde: 0x0002
                        Hex-värde: 0x0226
                        Hex-värde: 0x80A7
                        Hex-värde: 0x00FF
    Adress 05: Behör.kontroll (J393)       Labels: AER\8K0-907-064-05.clb
       Artikelnr SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Komponent: BCM2 1.1      H02 0328
       Kodning: 032400
       Verkstad #: WSC 06325 000 00000
       VCID: 0131BD0A98DDF83671-8054
       Subsystem 1 - Artikelnr SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Komponent: FBSAUDIB8 IDG  H37 0060
       Subsystem 2 - Artikelnr SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Komponent: J764 ELV MLB  H37 0042
    Ingen felkod funnen.
    Adress 08: Klimatanläggning (J255)       Labels: AER\8Tx-820-043-1Z.clb
       Artikelnr SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
       Komponent: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serienummer: 01180320101504
       Kodning: 64200000
       VCID: 77C5D3D2C619B6864F-8022
    Adress 09: Elektron. elcentral (J519)       Labels: AER\8K0-907-063.clb
       Artikelnr SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Komponent: BCM1 1.0      H25 0380
       Revision: 10025001    Serienummer: 00000000495660
       Kodning: 2600D0914034BF010009000300005D5D0F1C230806010101000000
       VCID: 3C4F0CFEBFBF55DE62-8068
       Subsystem 1 - Artikelnr SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: AER\1KX-955-119.CLB
       Komponent: WWS 250210  H14 0070
       Kodning: 00FD11
       Subsystem 2 - Artikelnr SW: 8K0 955 559     HW: 8K0 955 559   Labels: AER\8K0-955-559.CLB
       Komponent: RLS  H04 0003
       Kodning: 02532C
       Subsystem 3 - Artikelnr SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Komponent: E1 - LDS  H08 0090
    Adress 10: park/styr-hjälp (J446)       Labels: AER\8K0-919-475.clb
       Artikelnr SW: 8K0 919 475 R    HW: 8K0 919 475 A
       Komponent: PARKHILFE 8K  H06 0070
       Revision: 11001001    Serienummer: 50941007207675
       Kodning: 110007
       VCID: 48A7602EFB67097EF6-801C
    Adress 15: Krockkuddar (J234)       Labels: AER\8K0-959-655.clb
       Artikelnr SW: 8K0 959 655 J    HW: 8K0 959 655 J
       Komponent: AirbagVW-AU10 H41 0610
       Serienummer: 003GKD0DLM8U
       Kodning: 30343438363030303030554A304C38543053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 44BF741ECF4F2D1E1A-8010
       krocksensor för sidoairbag på förarsidan:
       Serienummer: 6334MSME5153642CB
       krocksensor för sidoairbag på passagerarsidan:
       Serienummer: 6344MSME51552C127
       krocksensor för sidoairbag bak på förarsidan:
       Serienummer: 6352QSME19570F1CR
       Krocksensor för sidoairbag bak; passagerarsidan:
       Serienummer: 6362QSME1C53241CI
       krocksensor för airbag fram på förarsidan:
       Serienummer: 63732SME3771322F$
       krocksensor för airbag fram på passagerarsidan:
       Serienummer: 63832SME35140965X
    Adress 16: Rattelektronik (J527)       Labels: AER\8K0-953-568.clb
       Artikelnr SW: 8K0 953 568 F    HW: 8K0 953 568 F
       Komponent: Lenks.Modul   H16 0014
       Revision: --------    Serienummer: 90315JCJ000P2
       Kodning: 000016
       VCID: 3D4901FAA4A55CD655-8068
       Komponent: E221 - MFL  H02 0010
    Adress 17: Instrument (J285)       Labels: AER\8T0-920-xxx-17.clb
       Artikelnr SW: 8T0 920 900 N    HW: 8T0 920 900 N
       Komponent: KOMBIINSTR.   H33 0255
       Revision: 00100000    Serienummer: CGZ24HH3A
       Kodning: 0F1D300003000008010000
       VCID: 3E4B06F6A9A347CE4C-806A
    Adress 19: CAN Gateway (J533)       Labels: AER\8T0-907-468.clb
       Artikelnr SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Komponent: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serienummer: 5300G1030583FA
       Kodning: 00CF07
       Subsystem 1 - Artikelnr SW: 8X0 915 181     HW: 8X0 915 181
       Komponent: J367-BDM  H07 0125
       Subsystem 2 - Artikelnr SW: 8K0 959 663     HW: 8K0 959 663
       Komponent: J532_DCDCStab  H16 0038
    Adress 2E: Mediaspelare 3 (R199)       Labels: AER\8T0-035-785.clb
       Artikelnr SW: 8T0 035 785 A    HW: 8T0 035 785
       Komponent: SG ext.Player H08 0280
       Revision: 00000000
       Kodning: 020202
       VCID: 394115EAB08D60F679-806C
    Adress 42: Dörrel. förare (J386)       Labels: AER\8K0-959-793.clb
       Artikelnr SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Komponent: TSG FA        H07 1301
       Kodning: 011C02624000450005
       VCID: 5097484E0337C1BEAE-8004
    Adress 46: Komfortcentral (J393)       Labels: AER\8K0-907-064-46.clb
       Revision: 00002001    Serienummer: 0128047385
       Kodning: 013A0620203904400030043680000000
       Subsystem 1 - Artikelnr: 8K0 951 177
       Komponent: DWA-Sensor  H02 0040
       Subsystem 2 - Artikelnr: 1K0 951 605 C
       Komponent: LIN BACKUP HO  H05 1501
    Adress 47: Ljudsystem (J525)       Labels: AER\8T0-035-223-ASC.clb
       Artikelnr SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Komponent: DSP STD       H11 0440
       Revision: 00000000    Serienummer: 00000000000001
       Kodning: 0203010102
       VCID: 2F552BB27EC9BE46D7-807A
    Adress 52: Dörrelektr. pass. (J387)       Labels: AER\8K0-959-792.clb
       Artikelnr SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Komponent: TSG BF        H07 1301
       Kodning: 011C02224000450005
       VCID: 4F954B321E09DE46B7-801A
    Adress 53: Parkeringsbroms (J540)       Labels: AER\8K0-907-801-V1.clb
       Artikelnr SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Komponent: EPB Audi B8   H09 0100
       Revision: 00000003    Serienummer: 00000000594314
       Verkstad #: WSC 00000 000 00000
       VCID: 345F24DE97EF9D9EAA-8060
    2 Funna fel:
                 frysta data:
                        Felstatus: 00101101
                        Felprioritet: 4
                        Felfrekvens: 6
                        Reset-räknare: 165
                        Tidsindikering: 0
                        Datum: 2016.08.13
                        Tid: 16:32:56
                 frysta data:
                        Spänning: 12.30 V
                        Räkna/re: 58
                        Hastighet: 0.0 km/h
                        Hex-värde: 0x02F0
                        Hex-värde: 0x0001
                        Hex-värde: 0x0101
                008 - Orimlig signal - Fellampa(MIL) tänd
                 frysta data:
                        Felstatus: 11101000
                        Felprioritet: 3
                        Felfrekvens: 6
                        Reset-räknare: 125
                        Tidsindikering: 0
                        Datum: 2016.08.13
                        Tid: 16:32:48
                 frysta data:
                        Spänning: 13.40 V
                        Räkna/re: 56
                        Hastighet: 8.0 km/h
                        Hex-värde: 0x0260
                        Hex-värde: 0x0004
                        Hex-värde: 0x0101
    Adress 55: Helljusområde        Labels: AER\8K0-907-357.clb
       Artikelnr: 8K5 907 357 A
       Komponent: Dynamische LWR  H01 0010
       Revision: 00000001    Serienummer:
       Kodning: 0000001
       Verkstad #: WSC 06324 000 00000
       VCID: 384710EE4B8779FE86-806C
    Adress 56: Radio (J503)       Labels: AER\8Tx-035-1xx-56.clb
       Artikelnr SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Komponent: Concert3      H07 0350
       Revision: 00000010    Serienummer: AUZ5Z6J1370643
       Kodning: 0402008201048500415B070800
       VCID: 44BF741EC74F2D1E1A-8010
       Subsystem 1 - Artikelnr SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Komponent: Display
    1 fel funnet:
    03157 - Nedsatt funktion p.g.a. kommunikationsstörning
                000 - - - Intermittent fel
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 6
                        Felfrekvens: 9
                        Reset-räknare: 165
                        Mätarställning: 97177 km
                        Tidsindikering: 0
                        Datum: 2016.05.01
                        Tid: 12:17:42
                 frysta data:
                        Binära Bitar: 00000000
                        Binära Bitar: 10000000
    Adress 62: Dörr vä. bak (J388)       Labels: AER\8K0-959-795.clb
       Artikelnr SW: 8T0 959 795 J    HW: 8T0 959 795 B
       Komponent: TSG HL        H05 1301
       Kodning: 010C02224000450005
       VCID: 529342460D3BB3AE98-8006
    Adress 69: Släpvagnsfunktion (J345)       Labels: AER\8K0-907-383.clb
       Artikelnr SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Komponent: Anhaenger     H09 0100
       Revision: 1A001001    Serienummer: 00000194989758
       Kodning: 0100000000000000
       VCID: 365B1ED681938F8E94-8062
    Adress 72: Dörr hö bak (J389)       Labels: AER\8K0-959-794.clb
       Komponent: TSG HR        H05 1301
    Adress 77: Telefon        Labels: AER\8P0-862-335.lbl
       Artikelnr SW: 8T0 862 335 D    HW: 8T0 862 335 D
       Komponent: FSE_256x BT     H39 0600
       Revision: 00000000    Serienummer: 00000005173069
       Kodning: 0010390
       VCID: 3B4D0FE27AB152E66B-806E
    Slut------------------------(Förfluten tid: 02:26)-------------------------
    When I got the car back from the workshop it could not be started and VAG com could not reach the engine - therefore no logs from this.
    The following log is after a clear and disconnection of MAF and ~10miles of driving:
    Monday,05,September,2016,21:25:24:54514
    VCDS Version: 16.8.1.1 (x64)
    Data version: 20160902 DS256
    VIN: WAUZZZ8T5AA069565   License Plate:
    Mileage: 100220km-62273mi   Repair Order: Efter att nya MAF monterad
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 55 56 62 69
              72 77
    VIN: WAUZZZ8T5AA069565   Mileage: 100220km-62273miles
    Address 01: Engine (Ma----CDNB)       Labels: 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 S    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H05 0004
       Revision: ECH05---
       Coding: 0114000C18470960
       Shop #: WSC 06325 123 12345
       VCID: 3FB57BF2A6A94EBA91-806A
    6 Faults Found:
              U1113 00 [044] - -
                        Fault Frequency: 16
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:21:52
                        Engine speed: 1198.00 /min
                        Normed load value: 14.1 %
                        Coolant temperature: 20 °C
                        Intake air temperature: 20 °C
                        Voltage terminal 30: 11.921 V
              U1113 00 [036] - -
                        Mileage: 100228 km
                        Date: 2016.09.05
                        Time: 19:29:14
                        Engine speed: 795.00 /min
                        Normed load value: 11.0 %
                        Coolant temperature: 92 °C
                        Intake air temperature: 56 °C
                        Voltage terminal 30: 11.756 V
    2795 - Bank 1: Camshaft A (Intake)
              P0011 00 [096] - Retard Setpoint not Reached (Over-Advanced)
                        Mileage: 100211 km
                        Date: 2016.09.03
                        Time: 21:53:39
                        Engine speed: 1921.00 /min
                        Normed load value: 27.8 %
                        Vehicle speed: 34 km/h
                        Coolant temperature: 78 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 13.711 V
    5664 - Mass Air Flow Sensor (G70)
              P0100 00 [232] - Supply Voltage
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:21:51
                        Engine speed: 1224.50 /min
                        Normed load value: 15.7 %
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 11.638 V
    2865 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
              P3255 00 [096] - Regulation at Upper Limit
                        Mileage: 100211 km
                        Date: 2016.09.03
                        Time: 21:53:22
                        Engine speed: 1172.00 /min
                        Normed load value: 36.5 %
                        Vehicle speed: 20 km/h
                        Coolant temperature: 75 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 13.523 V
    7670 - Oxygen (Lambda) Sensor B1 S1
              P0130 00 [096] - Malfunction in Circuit
                        Mileage: 100211 km
                        Date: 2016.09.03
                        Time: 21:53:22
                        Unlearning counter according OBD: 38
    Readiness: 0110 0101
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 BD    HW: 8K0 907 379 BD
       Component: ESP8 front    H04 0030
       Coding: 248D0C
       VCID: 7CCFCCFEFF3F95A2F4-8028
                        Fault Status: 00101101
                        Fault Frequency: 9
                        Reset counter: 171
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:21:52
                        Hex Value: 0x00C0
                        Hex Value: 0x40A2
                        Hex Value: 0x0026
                        Hex Value: 0x4694
                        Hex Value: 0x00FF
                        Reset counter: 171
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:21:53
                        Hex Value: 0x00C0
                        Hex Value: 0x62A2
                        Hex Value: 0x0032
                        Hex Value: 0x0297
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0328
       Coding: 032400
       Shop #: WSC 06325 000 00000
       VCID: 0131BD0A98DDF84AA7-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0510000016039009
       Serial number: 0210000028293002
       Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01180320101504
       Coding: 64200000
       VCID: 77C5D3D2C619B6FA99-8022
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000495660
       Coding: 2600D0914034BF010009000300005D5D0F1C230806010101000000
       VCID: 3C4F0CFEBFBF55A2B4-8068
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 250210  H14 0070
       Serial number: SWF10020251019
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10827746
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000603100875
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0070
       Revision: 11001001    Serial number: 50941007207675
       Coding: 110007
       VCID: 48A7602EFB67090220-801C
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GKD0DLM8U
       Coding: 30343438363030303030554A304C38543053
       VCID: 44BF741ECF4F2D62CC-8010
       Serial number: 6334MSME5153642CB
       Serial number: 6344MSME51552C127
       Serial number: 6352QSME19570F1CR
       Serial number: 6362QSME1C53241CI
       Serial number: 63732SME3771322F$
       Serial number: 63832SME35140965X
       Revision: --------    Serial number: 90315JCJ000P2
       Coding: 000016
       VCID: 3D4901FAA4A55CAA83-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 900 N    HW: 8T0 920 900 N
       Component: KOMBIINSTR.   H33 0255
       Revision: 00100000    Serial number: CGZ24HH3A
       Coding: 0F1D300003000008010000
       VCID: 3E4B06F6A9A347B29A-806A
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G1030583FA
       Coding: 00CF07
       Component: J367-BDM  H07 0125
       Serial number: 00000000002791078952
       Component: J532_DCDCStab  H16 0038
       Serial number: 10078000190011200180
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020202
       VCID: 394115EAB08D608AAF-806C
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1301
       Coding: 011C02624000450005
       VCID: 5097484E0337C1C278-8004
       Revision: 00002001    Serial number: 0128047385
       Coding: 013A0620203904400030043680000000
    Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F552BB27EC9BE3A01-807A
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1301
       Coding: 011C02224000450005
       VCID: 4F954B321E09DE3A61-801A
       Revision: 00000003    Serial number: 00000000594314
       VCID: 345F24DE97EF9DE27C-8060
                        Fault Frequency: 9
                        Reset counter: 171
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:21:53
                        Voltage: 12.10 V
                        Count: 58
                        Hex Value: 0x02E3
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No: 8K5 907 357 A
       Shop #: WSC 06324 000 00000
       VCID: 384710EE4B87798250-806C
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H07 0350
       Revision: 00000010    Serial number: AUZ5Z6J1370643
       Coding: 0402008201048500415B070800
       VCID: 44BF741EC74F2D62CC-8010
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 167
                        Mileage: 100209 km
                        Date: 2016.09.03
                        Time: 20:17:17
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8T0 959 795 J    HW: 8T0 959 795 B
       Component: TSG HL        H05 1301
       Coding: 010C02224000450005
       VCID: 529342460D3BB3D24E-8006
    Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00000194989758
       Coding: 0100000000000000
       VCID: 365B1ED681938FF242-8062
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H05 1301
       Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
       Component: FSE_256x BT     H39 0600
       Revision: 00000000    Serial number: 00000005173069
       Coding: 0010390
       VCID: 3B4D0FE27AB1529ABD-806E
    End-------------------------(Elapsed Time: 02:29)--------------------------
    With the old sensor the P-Brake and Brake lamp together with a beep was presented at key on (before even starting the engine) so it seems this sensor really messed the ECM up.
    Sep 2016
    Sweden
    Too fast
    After a couple of more starts many of the original DTC's appeared again
    What is promising is that not I have a good timestamp at most DTC's and most of them are pointing at the lambda sensors:
    #1: P3255, P3266, P0130
    #2: P1114, P0140
    Right?
    These are also the ones to be set first (in the morning) together with P0011 Camshaft A (Intake): Retard Setpoint not Reached.
    In the afternoon (17:31:40) the P0606 codes appeared again
    I would really appreciate some ideas because I'm lost here!
    Log, unfortunately in swedish again since I'm using my old laptop with WinXP and it failed to install interface drivers with the Eng version (newer version than the swedish one)
    Adress 01: Motor (Ma----CDNB)       Labels: AER\06H-907-115-CAB.clb
       Artikelnr SW: 8K2 907 115 S    HW: 8K2 907 115 L
       Revision: ECH05---
       VCID: 3FB57BF2A6A94EC647-806A
    13 Funna fel:
              U1113 00 [032] - -
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 6
                        Felfrekvens: 1
                        Mätarställning: 100253 km
                        Datum: 2016.09.06
                        Tid: 17:31:40
              U1113 00 [032] - -
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 6
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:40
              P0606 00 [032] - CPU-fel
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:40
              P2294 00 [032] - avbrott
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:42
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:40
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:40
    2795 - Rad1
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Mätarställning: 100245 km
                        Datum: 2016.09.06
                        Tid: 08:37:03
    2856 - Rad 1 sond 2
              P1114 00 [096] - inre motståndet för stort
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Mätarställning: 100248 km
                        Datum: 2016.09.06
                        Tid: 08:40:59
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 08:36:45
    2868 - Rad 1; sond 1
              P3266 00 [096] - inre motståndet orimligt
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Mätarställning: 100244 km
                        Datum: 2016.09.06
                        Tid: 08:35:39
              P0140 00 [096] - inte aktiv
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 08:41:05
              P0130 00 [096] - -
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 08:35:39
                 frysta data:
                        Felstatus: 00000001
                        Felprioritet: 2
                        Felfrekvens: 1
                        Datum: 2016.09.06
                        Tid: 17:31:40
    Readiness: 0010 0001
       Kodning: 248D0C
    2 Funna fel:
                008 - Orimlig signal - Intermittent fel
                 frysta data:
                        Felstatus: 00101000
                        Felprioritet: 2
                        Felfrekvens: 1
                        Reset-räknare: 174
                        Tidsindikering: 0
                        Datum: 2016.09.06
                        Tid: 17:31:40
                 frysta data:
                        Hex-värde: 0x0000
                        Hex-värde: 0x00A2
                        Hex-värde: 0x0026
                        Hex-värde: 0x809E
                        Hex-värde: 0x00FF
                 frysta data:
                        Felstatus: 00101101
                        Felprioritet: 6
                        Felfrekvens: 1
                        Reset-räknare: 174
                        Tidsindikering: 0
                        Datum: 2016.09.06
                        Tid: 17:31:40
                 frysta data:
                        Hex-värde: 0x0000
                        Hex-värde: 0x22A2
                        Hex-värde: 0x0032
                        Hex-värde: 0x029E
                        Hex-värde: 0x00FF
       Kodning: 032400
    Adress 08: Klimatanläggning        Labels: AER\8Tx-820-043-1Z.clb
       Komponent: KLIMA 1 ZONE  H08 KLIMA 1 ZONE  H08 01710171
       Kodning: 64200000
    Inga fel funna
      eller felkoder stöds ej av styrenhet
      eller ett kommunikationsfel uppkom
    Adress 09: Elektron. elcentral        Labels: AER\8K0-907-063.clb
       Komponent: BCM1 1.0      H25 BCM1 1.0      H25 03800380
       Kodning: 00FD11
       Subsystem 2 - Artikelnr: 8K0 955 559   Labels: AER\8K0-955-559.CLB
       Komponent: RLS
       Kodning: 02532C
       Subsystem 3 - Artikelnr: 8K0 941 531 AL
       Komponent: E1 - LDS
    Inga fel funna
       Kodning: 110007
       Kodning: 000016
       Kodning: 00CF07
       Revision: 00000000
       Kodning: 020202
    Adress 46: Komfortcentral        Labels: AER\8K0-907-064-46.clb
       Komponent: BCM2 1.1      H02 BCM2 1.1      H02 03280328
    Inga fel funna
       Kodning: 0203010102
    2 Funna fel:
                 frysta data:
                        Felstatus: 00101101
                        Felprioritet: 4
                        Felfrekvens: 1
                        Reset-räknare: 174
                        Tidsindikering: 0
                        Datum: 2016.09.06
                        Tid: 17:31:42
                 frysta data:
                        Spänning: 12.50 V
                        Räkna/re: 58
                        Hastighet: 0.0 km/h
                        Hex-värde: 0x0273
                        Hex-värde: 0x0001
                        Hex-värde: 0x1010
                 frysta data:
                        Felstatus: 00101000
                        Felprioritet: 3
                        Felfrekvens: 1
                        Reset-räknare: 174
                        Tidsindikering: 0
                        Datum: 2016.09.06
                        Tid: 17:31:40
                 frysta data:
                        Spänning: 12.70 V
                        Räkna/re: 56
                        Hastighet: 0.0 km/h
                        Hex-värde: 0x0263
                        Hex-värde: 0x0001
                        Hex-värde: 0x1010
       Kodning: 0000001
       Komponent: Display
    1 fel funnet:
                 frysta data:
                        Felstatus: 00100000
                        Felprioritet: 6
                        Felfrekvens: 1
                        Reset-räknare: 174
                        Mätarställning: 100256 km
                        Tidsindikering: 0
                        Datum: 2016.09.06
                        Tid: 17:46:28
                 frysta data:
    Adress 62: Dörr vä. bak        Labels: AER\8K0-959-795.clb
    Inga fel funna
    Adress 77: Telefon        Labels: saknas
       VCID: 5599B95ABCD5A4967D-8000
    Inga fel funna
    Slut------------------------(Förfluten tid: 03:24)-------------------------
    Mar 2016
    Check the positive and negative terminals of the ECM, if they turn out ok. Preform a software update. If P0606 returns replace the ECM
    Sep 2016
    Riga, Latvia
    There are less freeze frame data in Swedish version than in English one. Can You do one more autoscan using English version? Supply voltage at the moment of each fault is my point of interest right now.
    Try to measure voltage between car body and engine block. With engine running and at moment of starting engine. Try to add additional ground wire for test/compare.
  7. #7
    Quote Originally Posted by MartinsX View Post
    That's not a question of Swedish vs. English, but rather the version of VCDS being used. 16.8 deciphers and presents considerably more freeze-frame data than from UDS modules than 15.7 did. However, there is no Swedish 16.8 yet.
  8. Likes Jack@European_Parts liked this post
  9. #8
    Please submit a later VCDS English scan ........thank you.
  10. #9
    Sep 2016
    Sweden
    Thank you soo much for your support with my problem!
    Here is a fresh english log with all freeze frame data
    Wednesday,07,September,2016,17:36:01:54514
    Mileage: 100250km-62292mi   Repair Order: efter ytterligare problem, eng
              72 77
     Mileage: 100250km-62292miles
       Revision: ECH05---
    13 Faults Found:
              U1113 00 [032] - -
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Coolant temperature: 84 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 12.722 V
              U1113 00 [032] - -
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
    4628 - Internal Control Module
              P0606 00 [032] - Processor Fault
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
    4608 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [032] - Open Circuit
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:42
                        Intake air temperature: 34 °C
                        Voltage terminal 30: 12.557 V
    2736 - Throttle Valve Actuator Module (J338)
              P2106 00 [096] - Power Limited due to Malfunction
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
    2748 - Throttle Valve Controller
              P1545 00 [096] - Malfunction
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Mileage: 100245 km
                        Date: 2016.09.06
                        Time: 08:37:03
                        Engine speed: 1515.00 /min
                        Normed load value: 9.4 %
                        Vehicle speed: 41 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 14.442 V
    2856 - Oxygen (Lambda) Sensor; B1 S2
              P1114 00 [096] - Internal Resistance too High
                        Mileage: 100248 km
                        Date: 2016.09.06
                        Time: 08:40:59
                        Engine speed: 1503.50 /min
                        Normed load value: 54.1 %
                        Vehicle speed: 79 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 14.583 V
                        Mileage: 100245 km
                        Date: 2016.09.06
                        Time: 08:36:45
                        Engine speed: 784.00 /min
                        Normed load value: 12.9 %
                        Vehicle speed: 15 km/h
                        Voltage terminal 30: 14.324 V
    2868 - Oxygen (Lambda) Sensor B1 S1
              P3266 00 [096] - Internal Resistance Implausible
                        Mileage: 100244 km
                        Date: 2016.09.06
                        Time: 08:35:39
                        Engine speed: 1087.50 /min
                        Normed load value: 18.8 %
                        Vehicle speed: 18 km/h
                        Coolant temperature: 83 °C
                        Voltage terminal 30: 13.994 V
    4025 - Oxygen (Lambda) Sensor B1 S2
              P0140 00 [096] - No Activity
                        Mileage: 100248 km
                        Date: 2016.09.06
                        Time: 08:41:05
                        Engine speed: 1506.00 /min
                        Normed load value: 33.3 %
                        Mileage: 100244 km
                        Date: 2016.09.06
                        Time: 08:35:39
    4632 - Internal Control Module
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Voltage terminal 30: 12.745 V
       Coding: 248D0C
                        Reset counter: 174
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x0026
                        Hex Value: 0x809E
                        Hex Value: 0x00FF
                        Reset counter: 174
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Hex Value: 0x0000
                        Hex Value: 0x22A2
                        Hex Value: 0x0032
                        Hex Value: 0x029E
                        Hex Value: 0x00FF
       Coding: 032400
       Coding: 64200000
       Coding: 00FD11
       Coding: 02532C
       Coding: 110007
       Coding: 000016
       Coding: 00CF07
       Revision: 00000000
       Coding: 020202
       Coding: 0203010102
                        Reset counter: 174
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:42
                        Voltage: 12.50 V
                        Count: 58
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                        Reset counter: 174
                        Mileage: 100253 km
                        Date: 2016.09.06
                        Time: 17:31:40
                        Voltage: 12.70 V
                        Count: 56
                        Hex Value: 0x0263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Component: Display
                        Reset counter: 174
                        Mileage: 100256 km
                        Date: 2016.09.06
                        Time: 17:46:28
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Coding: 0010390
  11. #10
    Sep 2016
    Riga, Latvia
    More like ECU itself goes crazy. Not sure, software update will help.
