Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 16486 - Mass Air Flow Sensor (G70)
    Mar 2016
    Philadelphia PA USA
    RE : Address #1
    I'm looking for suggestions on my best approach to this issue.
    Firstly I have removed/ unscrewed the sensor and cleaned it as good as I could . Is there anything that I can do using the hex net to determine whether the sensor is the issue before replacing parts. Also Im reading that there are quite a few sensors that will fit but not necessarily be correct. I looked at the identifiers on the sensor but I cant be sure that its the correct one since the manufacturing date was in 2005 even though the car is a vw cabrio 2002.
    Thanks for your time
    EDIT . I did this but not sure if i followed the procedure correctly. I'm looking for the log from the procedure but I cant find it anywhere. Maybe I didn't do it right. Finally what is 3e gear , is that 3rd gear?
    " You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)"
    Friday,02,September,2016,11:12:47:42100
    VCDS Version: 16.8.0.3 (x64)  HEX-NET CB: 0.4321.4
    Data version: 20160803 DS255
    VIN: XXXXXXXXXXXXXXXXX   License Plate:
    Chassis Type: XX (1V - VW Golf Cabriolet (1997 > 2002))
    Scan: 01 02 03 08 15 25 35 56
    Address 01: Engine        Labels: 037-906-018-ABA.lbl
       Part No: 037 906 018 H
       Component: 2.0l R4/2V  MOTR AT V04
       Coding: 00003
       Shop #: WSC 00066
       VCID: 9A78996F043B4D92CE-4B3C
                P0102 - 35-00 - Signal too Low
    Readiness: 0010 1101
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 LA
       Component: AG4 Getriebe 01M    4899
       Coding: 00000
       VCID: FAB8B9EFE47BAD926E-0964
    Address 03: ABS Brakes        Labels: 3A0-907-379.lbl
       Part No: 3A0 907 379 D
       Component: ABS     ITTAE 20 GI V00
       Coding: 03704
       VCID: AB164CAB5BA1C41AA5-4AC2
                16-00 - Signal Outside Specifications
                35-10 -  -  - Intermittent
                16-10 - Signal Outside Specifications - Intermittent
    Address 25: Immobilizer        Labels: 6X0-953-257.lbl
       Part No: 6X0 953 257
       Component: IMMO                0008
       Coding: 00001
       Shop #: WSC 40629
       VCID: FDB2B2F3F5559AAA4B-4B3C
       XXXXXXXXXXXXXXXXX     VWZ1Z0A1666169
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1JM 035 157 A
       Component:  Radio DE2         0005
       Coding: 07403
       Shop #: WSC 09144
       VCID: BE3075FFB8D341B212-51F2
    00856 - Radio Antenna
                36-00 - Open Circuit
    End----------(Elapsed Time: 02:13, VBatt start/end: 12.3V/12.1V)-----------
    Mar 2016
    Please check the MAF data and the EGR at the same time, if the EGR is stuck open, on older cars, you get a MAF error, wilst the EGR is the cause
  3. Likes ivagp liked this post
    I would indeed take a look at what the ECU is seeing in [01-Engine] [MVB 003.2]. Start with just checking it at idle. I would expect to see 2-4 g/s at idle. If that's OK, then log it throughout the RPM range at full throttle in the highest gear you can. If you're in the city, that may be 2nd rather than 3rd gear.
  5. Likes Jetta ,97 liked this post
  6. #4
    What MAF part # is installed?
    Please post pictures ..........
    Coding: 00003
    Based on the part # above for engine controller, you have the later production, and require MAF part # 06A-906-461C or CX
    Another example how an auto-scan helps us help you............
  7. Likes Uwe, ivagp liked this post
  8. #5
    Dallas (McKinney) ,TX ,USA
    This is common problem on ABA engines.The problem is that breather hose is design very bad , above air boot and what happens , oil from breather hose goes down to air flow meter.
    Is you car idling up/down?
    When you Remove air boot did you see lot of oil at air flow meter?
    In most cases cleaning whole air boot and air flow meter will fix problem.
    I suggest to use Air Flow mater cleaner form retail store like Napa , o'reilly and Etc, if you use Carb cleaner, or similar stuff you will kill sensor.
    I know JACK will not agree with me on this one for cleaning with Air flow meter cleaner, .
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  9. Likes Uwe, COBHONIAN liked this post
  10. #6
    Mar 2016
    Philadelphia PA USA
    Quote Originally Posted by Jetta ,97 View Post
    Thanks for the response. The air boot was cleaned and every other part of that system prior to this problem.
  11. #7
    Mar 2016
    Philadelphia PA USA
    Hi Jack, i cant find the paper clip symbol to attach pictures .The manufacturing date for the part (just the sensor ,not the box unit) was july of 2005 even though its a 2002 car. So who knows if this is actually the correct sensor. The numbers on the MAF sensor are BOSCH F00C-262034 Also 587-21-3c ( another marking on there) and an encircled 3 digit number 816.
    VIN 3VWDC21VX2M803667
    This car does not have an EGR but rather a Secondary air control valve.
    PS How am I to attach a picture?
  12. #8
    Mar 2016
    Philadelphia PA USA
    Thanks Dutchie, will do , just so you know this model is a 2002 non californian car . The Californians have an EGR and from what I understand , the rest have a secondary air control valve /pump system.Group number 077
  13. #9
    Mar 2016
    Philadelphia PA USA
    Thanks Uwe. I just completed doing that. However I'm not sure if I followed your instruction to a T . "then log it throughout the RPM range" I started at idle , hit the log button (not the add to log ,,not sure sure what the difference or purpose is yet of that) Took it out on Stenton Ave to 309 , came back and hit STOP.
    Then attached the data to a LOG SUBMISSION FORM and sent it in.
    So did i do that much correctly. ? Did I leave anything out?
    BTW could you tell me how to attach a csv or and jpeg to this forum , I cant find the paper clip symbol. Thanks again
  14. #10
    Mar 2016
    There is a trick for some MAF to check them if they are good. It must be from Bosch, and it has to be a 5 pin (4 pin works to some times :P ). Leave the connector on the MAF, decouple the MAF from the hoses and duct tape both side shut, so there is no movement of the air. Then use a digital volt meterv or a scoop, and check the voltage from the MAF, it has to be 1V (+/- 0.01V), any thing else, then its not trust worthy and needs to be replaced.
  15. Likes COBHONIAN liked this post
