Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 82
Thread: Acronyms
  1. #61
    Jun 2017
    i'll do some brainstorming...
    eBKV = elektronischer Bremskraftverstärker (wtf is the english translation...idk lol)
    MO_StSt = Motor Start-Stop??
    AGA = Abgasanlage (exhaust)
    Freilauf = ...sailing fr automatic transmission
    MO = Motor
    GE = Getriebe (Transmission)
    AEB = Automatic emergency Brake
    MXB = Matrix Beam
    I think there should be some VAG acronym rap song. Can RT recruit Eminem?
  2. Likes Uwe, jyoung8607, Dana, Fredrick Awuor liked this post
  3. #62
    Aug 2014
    Australia
    Does anyone know what OCU is in central electrics, it refers to indicator flashing and something to do with a signal from the key fob
  4. #63
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Online Communication Unit (OCU)
    -Wolfgang
    Drive more talk less
  5. Likes jyoung8607, Uwe, Dana, Fredrick Awuor liked this post
  6. #64
    United States
    I'm looking for: ASW
    Crash repaired NAR 2018 Q5 with ASW_HMI_defekt:
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 80A 907 566     HW: 80A 907 566
       Component: MRR1Rear      H18 0420
       Revision: --------
       Coding: 0EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       ROD: EV_RearRadarS1BoschAU736.rod
    1192187 - Databus
              [databus error value received - ASW_HMI_defekt]
                        Reset counter: 104
                        Mileage: 23715 km
                        Date: 2019.03.19
                        Time: 10:45:05
                        Control Module temperature: 27 °C
                        Voltage terminal 30: 12.10 V
                        Vehicle speed: 0.00 km/h
                        Terminal 15 status: On
                        Voltage terminal 15: Measured value not available
    ASW is used in Exp coding charts for modules such as Address A5 and it makes numerous FF appearances in Andy's A3 e-tron after a flat 12V battery. The only other DTC in this car is:
       Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
       Component: TSG HBFS006 0737
       Coding: 000D0B000000148040000020
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    196887 - Function Lighting for Exit Warning LED
              B1791 01 [009] - Electrical Failure
                        Reset counter: 104
                        Mileage: 23715 km
                        Date: 2019.03.19
                        Time: 10:44:58
    We will advise them to fix the known rear door problem but I don't think that's gonna help. HMI = History Memory Information so ASW might clear things up if anyone can help.
  7. Likes DrPeter, Uwe liked this post
  8. #65
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Automatic Lane Change maybe? You're in 3C after all...
    SWA = Spurwechselassistent
    So ASW = auto Spur Wechsel?
    I think Audi knows how to safely steer to change lanes instead of just warn of traffic in your blind spot, using fusion of data from the forward camera, rear radar, and maybe side ultrasonic sensors.
    HMI may also mean Human Machine Interface, think infotainment user interface. See references like SportHMI referring to the infotainment performance monitor on GTI and R.
    I'd guess that error to mean a config mismatch between 5F, A5, 3C and maybe 10.
    Edit: front ACC radar might be involved in the fusion as well, so check 13.
    Silence gives consent.
  9. Likes Dana, DrPeter, Eric liked this post
  10. #66
    Cincinnati, OH
    I'm going to revise my answer:
    Actually I bet it will!
    1192187 - Databus
    That's Audi Vehicle Exit Assist. Warns you if you're trying to open your door into traffic or bicycles or whatnot. One of your customer's door exit warning LEDs is busted. Those being the human-machine interface for Exit Assist feature, 3C is warning you the feature functionality is impaired.
  11. #67
    Cincinnati, OH
    Looking for: TSK
    It comes up in some CAN messaging. I believe it'll have something to do with drivetrain coordination, possibly with Haldex engagement.
  12. Likes Dana liked this post
  13. #68
    Jun 2017
    Looking for: TSK
    Treibstrang-Koordinator.
    So you gave yourself the answer: drivetrain coordination
  14. Likes NEtech, jyoung8607, Uwe, Dana liked this post
  15. #69
    Cincinnati, OH
    So you gave yourself the answert: drivetrain coordination
    Damn I'm good.
    Thanks!
  16. Likes Uwe liked this post
  17. #70
    Should the term " FeC " be included into the forum lexicon-perhaps?
  18. Likes Uwe liked this post
