Audi TT (8S) TPMS enabling
fzanicotti
Brazil
C?ID=201619
Hello! My Audi TT MY16 didn't come with TPMS. It's not even a factory option to purchase it in Brazil (we have only two 'packages' to choose from: Attraction and Ambition), although I consider it a top safety pick. Anyway, tinkering around and previously having activated TPMS on an Audi A3 (8V) successfully, I'm struggling to find a way to do it on my TT. First, factory sticker (attached) doesn't show 1AS or 1AT, so I'm not even sure if I can have it software enabled. Second, all the instructions I could find relate to 1AS or 1AT. Any ideas would be much appreciated. As a note, I'm only interested in software approaches, no hardware retrofits (parts are very expensive in Brazil and labor usually doesn't have the know-how to do it anyway).
Friday,19,August,2016,11:03:08:39651
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 16.8.0.3 (x64)
Data version: 20160803 DS255
Dealer/Shop Name: Fernando Godoy Zanicotti
VIN: TRUAFBFV6G1002041   License Plate: AZZ-7906
Mileage: 2727   Repair Order:
Chassis Type: FV (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 42 44 52 55 5F A9
Address 01: Engine (J623-CHHC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A1D00324424050B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259 001005
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AFE67AFFD45BA92EE-802F
Readiness: 0000 0001
   Part No SW: 0D9 300 042 E    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4901
   Revision: 05853104    Serial number: TFK01504242831
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1B30422B123F239A55-804F
          P1734 00 [002] - -
   Part No SW: 8S0 907 379 C    HW: 8S0 907 379 C
   Component: ESC           H31 0511
   Revision: 00000000    Serial number: 61335000000133
   Coding: 32AA208D0A9915AB409100680292930EA24C0450A8020040C97045
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 418CD043D013294AEF-8015
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0368562483
   Coding: 000F0F1720
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB_VW37.rod
   VCID: 397CB8A3B8C3718AA7-806D
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0030
   Revision: 20009000    Serial number: 15110000009000
   Coding: 400040140011141000
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6CD251F7871114226C-8039
   Serial number: 0D8887A7000000000001
   Operating and display unit 2 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0020
   Serial number: 00000000000000006887
   Operating and display unit 3 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0020
   Part No SW: 5Q0 937 084 BS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0174
   Serial number: 01061513502246
   Coding: 04055D42C20106FD03044004B30807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 0A1E376FADA5AA12FE-805F
   Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 150223  032 0371
   Serial number: 00000001502200601641
   Coding: 1BC7F7
   Serial number: 23965774
   Coding: 07005D
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 10 03 2015  00000442
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY150982K93
   Serial number: 00000000000062354044
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39231513801658
   Coding: 0000040011
   Shop #: WSC 10570 002 1048576
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3C72A1B7B7F144A2BC-8069
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R00L374
   Coding: 88CCC000008000005C000000004800000065
   VCID: 4D94FC731C4BFD2A1B-8019
   Subsystem 1 - Part No SW: -----------    HW: 480 001 905 15
   Serial number: 3570000000088C29A41Q
   Subsystem 2 - Part No SW: -----------    HW: 480 001 905 15
   Serial number: 3580000000048C29A41N
   Subsystem 3 - Part No SW: -----------    HW: 480 011 205 15
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A0533A42321FF/
   Subsystem 4 - Part No SW: -----------    HW: 480 400 902 15
   Serial number: 3550002B7198E154F33A
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 902 15
   Serial number: 3560002B1198E153E175
   Part No SW: 8S0 907 129 AG    HW: 8S0 907 129 AG
   Component: Lenks. Modul  H07 0140
   Revision: --------    Serial number: 91335OEM00923
   Coding: 201C
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 7F0896BBE6679FBAD9-802B
Address 17: Instruments (J285)       Labels: Redir Fail!
   Part No SW: 8S0 920 790 A    HW: 8S0 920 790 A
   Component: FBenRDW       H35 0265
   Coding: 04250140288000081A20E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 3778BE9B8ED767FA51-8063
   Part No SW: 8S0 907 468 B    HW: 8S0 907 468
   Component: GW MQB TT3    012 0223
   Revision: --------    Serial number: 08051510800496
   Coding: 030100042F025A004B0002681C0000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011003
   ROD: EV_GatewContiAU33X.rod
   VCID: 3F88D6BBA6E75FBA99-806B
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0001
   Serial number: 20150506124801 RD053
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 3759906103
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Part No SW: 8S0 857 511 C    HW: 8S0 857 511 C
   Component: FLA           H09 0003
   Revision: AA001001
   Coding: 0404000400000000000001
   ASAM Dataset: EV_HighBeamAssisAU33X 001017
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 010415BCM19799
   Coding: 001E46224100040100001402
   VCID: 428EDF4FD5153252F6-8017
   Coding: 8103
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 270415BDR04484
Address 55: Headlight Range (J745)       Labels: 4H4-907-357-V2.clb
   Coding: 03DA00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
   ROD: EV_HeadlRegulAUDIMXBAU64X_AU37.rod
   VCID: 346289979FA18CE274-8061
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 045 B    HW: 8S0 035 045
   Component: MU-H-N-RW     042 0229
   Serial number: A583E0F7500038
   Coding: 01330403FF08000011220001001800002F0000E000700000DE
   VCID: 2E569BFF718DA63202-807B
   Subsystem 1 - Part No SW: V03 959 801 FP    HW: -----------
   Component: ROW 2016/2017  --- 0058
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Component: ControlUnit_H  H22 0129
   Serial number: C1000011041500010125
   Component: Gracenote2  --- 4007
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 150517200651
End-------------------------(Elapsed Time: 05:37)--------------------------
Gateway Installation List:  8S0 907 468 B
fzanicotti
Brazil
C?ID=201619
So I just came across this (http://forums.ross-tech.com/showthr...ion-reset-and-disable-coding-with-VCDS-mk6-VW) regarding indirect TPMS, which is exactly what I have as standard factory config (7K0). Does anyone here have a TT MY16 without TPMS like mine?
Uwe and other experienced members: is it valid to give it a go in the 03 ABS > Coding > Long Coding Helper > Byte 16, bit 2 [ON] or should I avoid the temptation since it is the ABS unit and thus wait for more contribution from the community? I'm not a noob but also far from an expert.
What you have there is not an MK60EC1, and I would not expect any of the coding info for an MK60EC1 to apply to your MK100IPB. Hence I would not recommend changing bits willy-nilly.
